这种网络摄像头算是带云台中的最廉价的了,某宝活动价88元时买的。
先拆解看看,内部构造很简单:一块主板+摄像头+两个云台电机+麦克+喇叭。
无线网卡和电源芯片:
主板上空闲的接口有三个,左下、右下、下面中间,左下那个是4针debug串口(波特率115200),另外两个不知道是啥,右下猜测是刷机用的。
我不懂刷机,所以研究了下debug串口,发现所有的客户端操作都能通过这个串口输出,这下就好玩了!可以通过单片机解析串口数据扩展其他功能,比如把摄像头放到小车上,可以实现远程控制,哈哈。。。
抓了启动debug,懂的朋友帮忙研究下都是啥意思?
@ ?Nconsole init done
U-Boot 2012.10 (Feb 24 2016 - 22:33:54) for GK7102 rb sc1045 v2.00 (GOKE)
HAL: 20151223
DRAM: 64 MiB
Flash: 16 MiB
16 MiB
NAND: SPINAND MID = 0xff, DID = 0xffff, Data = 0x1ffffff !spinand_board_init[1581]: No support this SPI nand!
SF: Detected W25Q128FV with page size 256 B, sector size 64 KiB, total size 16 MiB
In: serial
Out: serial
Err: serial
Net: ARM_freq(600MHz)..............0x112032
use int MII..............
gk7101
Hit any key to stop autoboot: 2 1 0
[PROCESS_SEPARATORS] run sfboot
[PROCESS_SEPARATORS] setenv bootargs console=${consoLEDev},${baudrate} noinitrd mem=${mem} rw ${rootfstype} init=linuxrc ;sf probe 0 0;sf read ${loadaddr} ${sfkernel} ${filesize}; bootm
put param to memory
mem size (41)
bsb size (2)
the kernel image is zImage or Image
entry = 0xc1000000
## Transferring control to Linux (at address c1000000)...
Starting kernel ...
machid = 3988 r2 = 0xc0000100
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.43-gk (bruce@ubuntu) (gcc version 4.6.1 (crosstool-NG 1.18.0) ) #33 PREEMPT Thu May 19 20:55:21 PDT 2016
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: VIPT aliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Goke GK7102 RB_SC1045 board V2.00
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AHB: 0x90000000 0xf2000000 -- 0x1000000
[ 0.000000] APB: 0xa0000000 0xf3000000 -- 0x1000000
[ 0.000000] PPM: 0xc0000000 0xc0000000 -- 0x200000
[ 0.000000] BSB: 0xc2b00000 0xf5000000 -- 0x200000
[ 0.000000] DSP: 0xc2d00000 0xf6000000 -- 0x1300000
[ 0.000000] hal version = 20151223
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10414
[ 0.000000] Kernel command line: console=ttySGK0,115200 noinitrd mem=41M rw rootfstype=jffs2 root=/dev/mtdblock3 init=linuxrc
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 41MB = 41MB total
[ 0.000000] Memory: 36636k/36636k available, 5348k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB)
[ 0.000000] vmalloc : 0x83000000 - 0xff000000 (1984 MB)
[ 0.000000] lowmem : 0x80000000 - 0x82900000 ( 41 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x8044d000 (4372 kB)
[ 0.000000] .init : 0x8044d000 - 0x8046e000 ( 132 kB)
[ 0.000000] .data : 0x8046e000 - 0x80497260 ( 165 kB)
[ 0.000000] .bss : 0x80497284 - 0x804c9888 ( 202 kB)
[ 0.000000] NR_IRQS:128
[ 0.000000] >> gk7101 init irq vic1...
[ 0.000000] >> gk7101 init irq vic2...
[ 0.000000] gk7101 init vic...
[ 0.000000] mach gk7101 init timer...
[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttySGK0] enabled
[ 0.010000] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.070000] pid_max: default: 32768 minimum: 301
[ 0.070000] Mount-cache hash table entries: 512
[ 0.080000] CPU: Testing write buffer coherency: ok
[ 0.090000] Setting up static identity map for 0xc0571630 - 0xc0571668
[ 0.100000] NET: Registered protocol family 16
[ 0.110000] gk7101 init timer...
[ 0.110000] Init HW timer for DSP communication
[ 0.120000] gk7101 init gpio...
[ 0.120000] gpiochip_add: registered GPIOs 0 to 63 on device: gk7101-gpio0
[ 0.130000] gpio map init...
[ 0.130000] create proc dir
[ 0.130000] gk7101 register devices 9
[ 0.140000] gk7101 register I2C
[ 0.290000] bio: create slab <bio-0> at 0
[ 0.290000] spi spi.0: gk7101 SPI Controller 0 created
[ 0.300000] spi spi.0: master is unqueued, this is deprecated
[ 0.300000] usbcore: registered new interface driver usbfs
[ 0.310000] usbcore: registered new interface driver hub
[ 0.320000] usbcore: registered new device driver usb
[ 0.320000] i2c regbase: 0xf3003000
[ 0.330000] i2c i2c.0: i2c irq:registers 9
[ 0.330000] i2c i2c.0: GK7101 I2C[0] adapter[i2c-0] probed!
[ 0.340000] i2c regbase: 0xf3004000
[ 0.340000] i2c i2c.1: i2c irq:registers 58
[ 0.350000] i2c i2c.1: GK7101 I2C[1] adapter[i2c-1] probed!
[ 0.360000] FS-Cache: Loaded
[ 0.360000] CacheFiles: Loaded
[ 0.370000] cfg80211: Calling CRDA to update world regulatory domain
[ 0.380000] gk7101-sd gk7101-sd.0: Slot0 req_size=0x00010000, segs=16, seg_size=0x00010000
[ 0.410000] gk7101-sd gk7101-sd.0: GK7101 SD/MMC[0] has 1 slots @ 46000000Hz, [0x09e130b0:0x00000000]
[ 0.420000] NET: Registered protocol family 2
[ 0.420000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.430000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.440000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.450000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.460000] TCP: reno registered
[ 0.460000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.470000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.470000] NET: Registered protocol family 1
[ 0.480000] RPC: Registered named UNIX socket transport module.
[ 0.490000] RPC: Registered udp transport module.
[ 0.490000] RPC: Registered tcp transport module.
[ 0.500000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.500000] mdma init...
[ 0.510000] mdma request irq: 54
[ 0.520000] NFS: Registering the id_resolver key type
[ 0.520000] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.530000] fuse init (API version 7.18)
[ 0.540000] msgmni has been set to 71
[ 0.550000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 0.560000] io scheduler noop registered
[ 0.560000] io scheduler deadline registered
[ 0.570000] io scheduler cfq registered (default)
[ 0.570000] uart.0: ttySGK0 at MMIO 0xa0005000 (irq = 31) is a gk7101uart
[ 0.580000] uart.1: ttySGK1 at MMIO 0xa001f000 (irq = 15) is a gk7101uart
[ 0.590000] uart.2: ttySGK2 at MMIO 0xa001e000 (irq = 27) is a gk7101uart
[ 0.600000] brd: module loaded
[ 0.610000] loop: module loaded
[ 0.620000] adc initialized (10:11)
[ 0.620000] slram: not enough parameters.
[ 0.630000] speed_mod is 0
[ 0.630000] gk7101_flash gk7101_flash.0: W25Q128FV (16384 Kbytes)
[ 0.640000] Creating 5 MTD partitions on "gk7101_flash":
[ 0.640000] 0x000000000000-0x000000040000 : "uboot"
[ 0.650000] 0x000000040000-0x000000050000 : "ubootenv"
[ 0.660000] 0x000000050000-0x000000200000 : "kernel"
[ 0.660000] 0x000000200000-0x000001000000 : "rootfs"
[ 0.670000] 0x000000000000-0x000001000000 : "all"
[ 0.680000] GKETH_init
[ 0.680000] [GKETH_drv_probe] eth_base = 0xf200e000
[ 0.690000] mii id = 0
[ 0.690000] ###### PHY Reset.1.0.2
[ 0.810000] mdiobus_register: PHY[0] whose id 0x00000000
[ 0.810000] goke MII Bus: probed
[ 0.820000] gk7101-eth gk7101-eth.0: MAC Address[02:11:22:a3:a0:00].
[ 0.830000] usbcore: registered new interface driver cdc_wdm
[ 0.830000] usbcore: registered new interface driver libusual
[ 0.840000] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.850000] musb phy Begin initial sequence ...
[ 1.090000] gk7101 musb init end...
[ 1.100000] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 1.100000] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 1
[ 1.110000] vm : ffde0000, phy : c25a0000
[ 1.120000] dma_buf alloc ok!
[ 1.120000] hub 1-0:1.0: USB hub found
[ 1.120000] hub 1-0:1.0: 1 port detected
[ 1.130000] musb-hdrc musb-hdrc: USB Host mode controller at f0006000 using PIO, IRQ 26
[ 1.140000] platform add gk7101 musb...
[ 1.140000] mousedev: PS/2 mouse device common for all mice
[ 1.150000] input: GKInput as /devices/virtual/input/input0
[ 1.160000] Protocol NEC[0]
[ 1.160000] ir request irq: 62
[ 1.160000] IR Host Controller probed!
[ 1.170000] i2c /dev entries driver
[ 1.170000] gk7101_wdt: GK7101 Watchdog Timer, (c) 2014 Goke Microelectronics
[ 1.180000] [gk7101_wdt_init]: init
[ 1.180000] [gk7101_wdt_probe]: probe
[ 1.190000] [gk7101_wdt_probe]: probe mapped wdt_base=f3006000
[ 1.190000] watchdog inactive, reset disabled, irq disabled
[ 1.200000] IPv4 over IPv4 tunneling driver
[ 1.210000] gre: GRE over IPv4 demultiplexor driver
[ 1.210000] ip_gre: GRE over IPv4 tunneling driver
[ 1.220000] TCP: cubic registered
[ 1.220000] Initializing XFRM netlink socket
[ 1.230000] NET: Registered protocol family 10
[ 1.240000] IPv6 over IPv4 tunneling driver
[ 1.240000] NET: Registered protocol family 17
[ 1.250000] NET: Registered protocol family 15
[ 1.250000] lib80211: common routines for IEEE802.11 drivers
[ 1.260000] Registering the dns_resolver key type
[ 1.270000] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 1.580000] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 10.120000] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 10.130000] Freeing init memory: 132K
Starting mdev...
[ 12.770000] net eth0: ###### GKETH_start_hw
[ 12.780000] net eth0: ###### GKETH_phy_start_aneg...
[ 12.780000] ADDRCONF(NETDEV_UP): eth0: link is not ready
Archive: /mnt/mtd/ipc/ipc_server
inflating: ipc_server
Welcome to HiLinux
后面还有很长很长。。。
下面几个控制指令分别是:
云台-左、云台-右、云台-上、云台-下、拉近、拉远、聚焦减、聚焦加、光圈放大(仅PC)、光圈缩小(仅PC)
ptz ctrl req: u32Ctrl=1, u32Mode=1, u16TurnTime=50
ptz ctrl req: u32Ctrl=2, u32Mode=1, u16TurnTime=50
ptz ctrl req: u32Ctrl=3, u32Mode=1, u16TurnTime=50
ptz ctrl req: u32Ctrl=4, u32Mode=1, u16TurnTime=50
ptz ctrl req: u32Ctrl=9, u32Mode=0, u16TurnTime=10
ptz ctrl req: u32Ctrl=10, u32Mode=0, u16TurnTime=10
ptz ctrl req: u32Ctrl=11, u32Mode=0, u16TurnTime=10
ptz ctrl req: u32Ctrl=12, u32Mode=0, u16TurnTime=10
ptz ctrl req: u32Ctrl=13, u32Mode=0, u16TurnTime=10
ptz ctrl req: u32Ctrl=14, u32Mode=0, u16TurnTime=10
