淘宝购买链接https://item.taobao.com/item.htm?spm=0.0.0.0.9Pj8xd&id=557066536943 HB SERIES SPST, SPDT ROCKER SWITCHES UP TO 20A 125VAC, IP42 RATING, T125 classical outlook, crystal lighting, 6A "L", splash protected - 20A 125VAC / 16A 250VAC (UL,CUL)
- 6A 125VL, 3/4HP 250VAC(UL,CUL)
- 16(4) A 250VAC~T125 (VDE, ENEC)
- 16A 250VAC (CQC)
- Initial contact resistance : 20m ohm max.
- Insulation resistance : 100M ohm min, at 500VDC
- Dielectric strength : 1,000VAC for 1 minute
- Electrical life : 10,000 cycles
- Temperature range : -20 to +125 degrees in Celsius
- Two-Color actuator available
- Classical outlook, full or soft lighting
- Switch for Class II appliances
- Base : Nylon 66, UL rated 94V-2 min
- Actuator : Nylon 66 or PC, UL rated 94V-2 min
- Spring : Piano wire
- Contacts : Silver alloy
- Terminals : Silver plated copper
- Lamp : Neon
Quoted from Wekipedia:
~Inrush current, input surge current or switch-on surge is the maximum, instantaneous input current drawn by an electrical device when first turned on. For example, incandescent light bulbs have high inrush currents until their filaments wARM up and their resistance increases. Alternating current electric motors and transformers may draw several times...... ~
Choosing a switch that can have a good capacity for your device is thus very important for your device's safety. Our HB series can offer an option up to 6A'L' up to 92A inrush that can be the appropriate switch to ensure your device's life and stability. |
