白钻会员
帖子
积分98801
阅读权限50
注册时间2008-12-10
楼主 |
发表于 2013-4-3 20:30
显示全部楼层
# RT1602C BTPlug GPIO接脚
DB0 ~ DB7 => GPIO00 ~ GPIO07
RS => GPIO10
RW => GPIO11
E => GPIO13
Vdd/背光电压+ => 接串口的Vcc输出
GND => GPIO GND
makefile- DRIVER_VERSION := 1.0.0.000
- KDIR := /lib/modules/$$$$(shell uname -r)/build
- PWD := $$$$(shell pwd)
- OBJ := gpio1602
- obj-m := $$$$(OBJ).o
- EXTRA_CFLAGS := -DDRIVER_VERSION="v$$$$(DRIVER_VERSION)"
- all: clean compile
- compile:
- $$$$(MAKE) -C $$$$(KDIR) M=$$$$(PWD) modules
- load:
- su -c "insmod ./usbdpfp.ko"
- load_debug:
- @echo "try "tail -f /var/log/message" in another window as root...";
- su -c "insmod ./$$$$(OBJ).ko debug=1"
- unload:
- -su -c "rmmod -s $$$$(OBJ)"
- clean:
- make -C /lib/modules/$$$$(shell uname -r)/build M=$$$$(PWD) clean
- debug: unload clean compile load_debug
复制代码 gpio1602.c- /*
- 2011-04-18. version 0.1
- TTY DRIVER TO CONNECT LCM 1602 VIA BTPLUG GPIO
- 本源码以MIT-LICENSE授权发布
- Copyright (c) 2011 Jia Huang, jia.huang@geneegroup.com
- Permission is hereby granted, free of charge, to any person obtaining
- a copy of this software and associated documentation files (the
- "Software"), to deal in the Software without restriction, including
- without limitation the rights to use, copy, modify, merge, publish,
- distribute, sublicense, and/or sell copies of the Software, and to
- permit persons to whom the Software is furnished to do so, subject to
- the following conditions:
- The above copyright notice and this permission notice shall be
- included in all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
- EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
- MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
- NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE
- LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
- OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
- WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
- #define DRV_NAME "gpio1602"
- #define DEV_NAME "ttyG"
- #include <linux/console.h>
- #include <linux/delay.h>
- #include <linux/err.h>
- #include <linux/kernel.h>
- #include <linux/module.h>
- #include <linux/mutex.h>
- #include <linux/tty.h>
- #include <linux/tty_driver.h>
- #include <linux/tty_flip.h>
- #include <linux/io.h>
- #define BYTE unsigned char
- #define UINT unsigned int
- #define BOOL unsigned char
- #define TRUE 1
- #define FALSE 0
- #define FLAG_RS 0x01
- #define FLAG_RW 0x02
- #define FLAG_E 0x04
- #define DATA_BUSY 0x80
- #define DATA_CTL 0x98
- #define DATA 0x78
- #define FLAG_CTL 0x99
- #define FLAG 0x79
- #define CMD_SET_OPT 0x20
- #define CMD_OPT_8BITS 0x10
- #define CMD_OPT_2LINES 0x08
- #define CMD_OPT_F5x10 0x04
- #define CMD_SET_DISP 0x08
- #define CMD_DISP_ON 0x04
- #define CMD_DISP_CURSOR_ON 0x02
- #define CMD_DISP_CURSOR_BLINK 0x01
- #define CMD_CLEAR 0x01
- #define CMD_RESET_CURSOR 0x02
- #define CMD_SET_MODE 0x04
- #define CMD_MODE_SHIFT_RIGHT 0x02
- #define CMD_MODE_SHIFT_SCREEN 0x01
- #define CMD_SET_MOVE 0x10
- #define CMD_MOVE_CURSOR 0x00
- #define CMD_MOVE_SCREEN 0x08
- #define CMD_MOVE_RIGHT 0x04
- #define CMD_MOVE_LEFT 0x00
- //#define FLAG_LINE1 0x00 //第一行显示位置0~15 0x00~0x0F
- //#define FLAG_LINE1 0x40 //第二行显示位置0~15 0x41~0x4F
- #define CMD_LOCATE 0x80
- #define CMD_LOCATE_LINE2 0x40
- #define MAX_X 16
- #define MAX_Y 2
- #define OUT(x,y) outb(y, x)
- #define IN(x) inb(x)
- #define DELAY(x) udelay(x)
- GPIO与1602连接:
- DB0 = GPIO 00
- DB7 = GPIO 07
- RS = GPIO 10;
- RW = GPIO 11;
- E = GPIO 12;
- static char g1602_buffer[MAX_Y][MAX_X];
- static BYTE g1602_busy(void)
- BYTE is_busy;
- // rs = 0; rw = 1; e = 1; 检测忙标志
- OUT(FLAG, FLAG_RW|FLAG_E);
- OUT(DATA_CTL, 0); // set all pins to input mode
- DELAY(5);
- is_busy = (IN(DATA) & DATA_BUSY);
- // e = 0;
- OUT(FLAG, FLAG_RW);
- OUT(DATA_CTL, 0xff); // set all pins to OUTPut mode
- return is_busy;
- static void g1602_command(BYTE cmd, int usec)
- while (g1602_busy()) DELAY(5);
- // rs = 0; rw = 0; e = 0;
- OUT(FLAG, 0);
- OUT(DATA, cmd);
- // e = 1;
- OUT(FLAG, FLAG_E);
- DELAY(5);
- // e = 0;
- OUT(FLAG, 0);
- DELAY(usec);
- static int g1602_cur_x = 0, g1602_cur_y = 0;
- static void g1602_locate(int x, int y)
- BYTE flag = 0;
- if (y > 0) flag |= CMD_LOCATE_LINE2;
- flag |= (x >= MAX_X ? MAX_X - 1 : x);
- g1602_command(CMD_LOCATE|flag, 50);
- static void g1602_clear(void) {
- g1602_cur_x = 0;
- g1602_cur_y = 0;
- g1602_command(CMD_CLEAR, 2000);
- static void g1602_reset_cursor(void) {
- g1602_cur_x = 0;
- g1602_cur_y = 0;
- g1602_command(CMD_RESET_CURSOR, 2000);
- static void g1602_putc(BYTE ch)
- while(g1602_busy()) DELAY(5);
- // rs = 1; rw = 0; e = 0;
- OUT(FLAG, FLAG_RS);
- DELAY(5);
- OUT(DATA, ch);
- // rs = 1; rw = 0; e = 1;
- OUT(FLAG, FLAG_RS|FLAG_E);
- DELAY(5);
- static void g1602_raw_write(const char *s, int slen)
- g1602_command(CMD_SET_MODE|CMD_MODE_SHIFT_RIGHT, 50);
- while (slen--) {
- g1602_putc(*s);
- ++s;
- static void g1602_scrollup(void) {
- BYTE y=0;
- for (y=1; y<MAX_Y; y++) {
- memcpy(g1602_buffer[y-1], g1602_buffer[y], MAX_X);
- memset(&g1602_buffer[MAX_Y-1], ' ', MAX_X);
- // 更新整个屏幕
- g1602_clear();
- for (y=0; y<MAX_Y-1; y++) {
- g1602_locate(0,0);
- g1602_raw_write(g1602_buffer[y], MAX_X);
- static void g1602_relocate(BOOL force) {
- BOOL altered = FALSE;
- if (g1602_cur_x == MAX_X) {
- g1602_cur_x = 0;
- g1602_cur_y ++;
- altered = TRUE;
- if (g1602_cur_y == MAX_Y) {
- g1602_scrollup();
- g1602_cur_x = 0;
- g1602_cur_y = MAX_Y - 1;
- altered = TRUE;
- if (altered || force) {
- g1602_locate(g1602_cur_x, g1602_cur_y);
- static void g1602_show_cursor(BOOL show) {
- if (show) {
- g1602_command(CMD_SET_DISP|CMD_DISP_ON|CMD_DISP_CURSOR_ON|CMD_DISP_CURSOR_BLINK, 50);
- else {
- g1602_command(CMD_SET_DISP|CMD_DISP_ON, 50);
- typedef enum {PARSE_NORMAL, PARSE_ESC, PARSE_CSI, PARSE_SPEC} PARSE_STATUS;
- static void g1602_write(const char *s, int slen)
- char ch;
- int i;
- static PARSE_STATUS status = PARSE_NORMAL;
- static int codes[2] = {0, 0};
- static int code_i = 0;
- for (i=0; i < slen; i++) {
- ch = s[i];
- switch (status) {
- case PARSE_SPEC:
- if (ch >= '0' && ch <= '9') {
- codes[code_i] = codes[code_i] * 10 + (ch - '0');
- else switch (ch) {
- case ';':
- code_i++;
- codes[code_i] = 0;
- break;
- case 'l':
- if (codes[0] == 25) {
- g1602_show_cursor(TRUE);
- status = PARSE_NORMAL;
- break;
- case 'h':
- g1602_show_cursor(FALSE);
- break;
- default:
- break;
- case PARSE_CSI:
- case ';': // sep
- code_i++;
- break;
- case '?': //cursor ?
- code_i = 0;
- codes[0] = 0;
- status = PARSE_SPEC;
- break;
- case 'J': //clear screen
- g1602_clear();
- break;
- case 'K': //clean to end
- g1602_relocate(FALSE);
- int n = MAX_X - g1602_cur_x;
- while (n--) g1602_putc(' ');
- g1602_relocate(TRUE);
- break;
- case 'H': //locate to x:y *[x:yH
- g1602_cur_x=codes[0];
- g1602_cur_y=codes[1];
- break;
- default:
- break;
- case PARSE_ESC:
- switch (ch) {
- case '[':
- status = PARSE_CSI;
- code_i = 0;
- codes[0] = 0;
- break;
- case 27:
- break;
- default:
- i--; // 更新状态重新处理该字符
- break;
- default:
- if (ch >= ' ') { // 空格
- g1602_buffer[g1602_cur_y][g1602_cur_x] = ch;
- g1602_putc(ch);
- g1602_cur_x++;
- else switch(ch) {
- case '\e': // ESC
- status = PARSE_ESC;
- break;
- case '\n':
- g1602_cur_x = 0;
- g1602_cur_y ++;
- break;
- /* default: skip */
- static void g1602_puts(const char *s) {
- g1602_write(s, strlen(s));
- static void g1602_init(void)
- memset(g1602_buffer, ' ', MAX_Y * MAX_X);
- /* set GPIO port0[7-0] as OUTPut mode */
- /* set GPIO port1[2-0] as OUTPut mode */
- OUT(FLAG_CTL, FLAG_RS|FLAG_RW|FLAG_E);
- g1602_command(CMD_SET_OPT|CMD_OPT_8BITS|CMD_OPT_2LINES, 50);
- g1602_clear();
- #define pr_init(fmt, args...) ({ static const __initconst char __fmt[] = fmt; printk(__fmt, ## args); })
- static struct tty_driver *gpio_driver;
- static struct tty_struct * volatile gpio_tty;
- static unsigned long gpio_count;
- static DEFINE_MUTEX(gpio_tty_mutex);
- static int
- gpio_open(struct tty_struct *tty, struct file *filp)
- mutex_lock(&gpio_tty_mutex);
- pr_debug("open %lu\n", gpio_count);
- ++gpio_count;
- gpio_tty = tty;
- mutex_unlock(&gpio_tty_mutex);
- return 0;
- static void
- gpio_close(struct tty_struct *tty, struct file *filp)
- pr_debug("close %lu\n", gpio_count);
- if (--gpio_count == 0)
- gpio_tty = NULL;
- #ifndef CONFIG_BFIN_JTAG_COMM_CONSOLE
- # define acquire_console_sem()
- # define release_console_sem()
- #endif
- static int gpio_write(struct tty_struct *tty, const unsigned char *buf, int count)
- acquire_console_sem();
- g1602_write(buf, count);
- release_console_sem();
- return count;
- static void gpio_flush_chars(struct tty_struct *tty)
- static int gpio_write_room(struct tty_struct *tty)
- if (tty->stopped)
- return 0;
- return 32768;
- static int gpio_chars_in_buffer(struct tty_struct *tty)
- return 0;
- static struct tty_operations gpio_ops = {
- .open = gpio_open,
- .close = gpio_close,
- .write = gpio_write,
- /*.put_char = gpio_put_char,*/
- .flush_chars = gpio_flush_chars,
- .write_room = gpio_write_room,
- .chars_in_buffer = gpio_chars_in_buffer,
- /*.wait_until_sent = gpio_wait_until_sent,*/
- static int __init gpio_init(void)
- int ret;
- ret = -ENOMEM;
- gpio_driver = alloc_tty_driver(1);
- if (!gpio_driver)
- goto err;
- gpio_driver->owner = THIS_MODULE;
- gpio_driver->driver_name = DRV_NAME;
- gpio_driver->name = DEV_NAME;
- gpio_driver->type = TTY_DRIVER_TYPE_SERIAL;
- gpio_driver->subtype = SERIAL_TYPE_NORMAL;
- gpio_driver->init_termios = tty_std_termios;
- tty_set_operations(gpio_driver, &gpio_ops);
- ret = tty_register_driver(gpio_driver);
- if (ret)
- goto err;
- g1602_init();
- pr_init(KERN_INFO DRV_NAME ": initialized\n");
- return 0;
- err:
- put_tty_driver(gpio_driver);
- return ret;
- static void __exit gpio_exit(void)
- tty_unregister_driver(gpio_driver);
- static void gpio_console_write(struct console *co, const char *buf, unsigned count)
- static struct tty_driver *gpio_console_device(struct console *co, int *index)
- *index = co->index;
- return gpio_driver;
- static struct console gpio_console = {
- .name = DEV_NAME,
- .write = gpio_console_write,
- .device = gpio_console_device,
- .flags = CON_ANYTIME | CON_PRINTBUFFER,
- .index = -1,
- static int __init gpio_console_init(void)
- register_console(&gpio_console);
- return 0;
- MODULE_AUTHOR("Jia Huang <jia.huang@geneegroup.com>");
- MODULE_DESCRIPTION("TTY over GPIO for LCM1602");
- MODULE_LICENSE("MIT");
- module_init(gpio_init);
- module_exit(gpio_exit);
- console_initcall(gpio_console_init);
复制代码 现成的代码,但是在debian6现有能用的内核上没编译通过。
