查看: 3269|回复: 4
网上收集恒压恒流代码大家看看是否完整
发表于 2011-4-15 21:42 | 显示全部楼层 |阅读模式
//// CVCC Control Program
//// Constant Current Constant Voltage Controller
//// Analog Input Data
////   CH0 : 晧壸揹棳(Curr_Now)
////   CH1 : 嵟戝晧壸揹棳愝掕抣(Curr_Set)
////   CH2 : 揹棳惂屼揹埑抣(Volt_Cont)
////   CH3 : 弌椡揹埑抣(Volt_Now)
#include    <16f876.h>
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
#device ADC=10         //A/D曄姺侾侽價僢僩儌乕僪
#use delay(CLOCK = 20000000)     //僋儘僢僋20MHz
#use fast_io(B)         //擖弌椡儌乕僪屌掕
#use fast_io(C)
////// 塼徎昞帵婍儔僀僽儔儕梡愝掕
#define mode  0       //嬻偒僺儞偺擖弌椡儌乕僪
#define input_x   input_B      //愙懕億乕僩巜掕
#define output_x output_B
#define set_tris_x set_tris_B
#define stb   PIN_B3      //惂屼怣崋愝掕
#define rs   PIN_B2
#include  <lcd_lib.c>       //儔僀僽儔儕僀儞僋儖乕僪
///// 儊僀儞娭悢
void main()
float Curr_Now, Curr_Set;     //寁應僨乕僞丂float巜掕
float Volt_Cont, Volt_Now;
float Max_Pwr, Temp;      //嵟戝揹椡愝掕抣
int   Set_Pwr, flag;
setup_adc_ports(A_ANALOG);     //RA0-RA5僺儞偑傾僫儘僌擖椡
setup_adc(ADC_CLOCK_DIV_32);    //Fosc/32 嵟崅懍搙
set_tris_b(0);        //慡僺儞弌椡儌乕僪
output_B(0);        //0僋儕傾
set_tris_c(0);
output_C(0);
//// 塼徎昞帵弶婜昞帵
lcd_init();         //塼徎昞帵婍弶婜壔
lcd_clear();        //慡徚嫀
printf(lcd_data,"Start!!");     //僗僞乕僩儊僢僙乕僕弌椡
delay_ms(1000);        //侾昩懸偪
lcd_clear();
//丂寁應昞帵孞傝曉偟儖乕僾
while(1)
  /// 弌椡揹埑寁應
  set_adc_channel(3);      //僠儍僱儖3慖戰
  delay_us(50);       //傾僋僀僕僔儑儞懸偪
  Volt_Now = read_adc();     //A/D曄姺僨乕僞侾侽價僢僩撉傒崬傒
  Volt_Now = (Volt_Now * 15.0) / 1024; //揹埑15VMax傊僗働乕儖曄姺
  /// 晧壸揹棳抣
  set_adc_channel(1);      //僠儍僱儖1慖戰
  delay_us(50);       //傾僋僀僕僔儑儞僞僀儉懸偪
  Curr_Now = read_adc();     //10價僢僩偱撉傒崬傒
  Curr_Now = (5.3 * Curr_Now)/1024 - 0.12; //5.0A僼儖僗働乕儖偱曄姺
  /// 嵟戝揹棳抣
  set_adc_channel(2);      //僠儍僱儖2慖戰
  Curr_Set = read_adc();     //10價僢僩偱撉傒崬傒
  Curr_Set = (4.6 * Curr_Set)/1024 - 1.26; //僼儖僗働乕儖曄姺
  /// 揹棳惂屼揹埑抣
  set_adc_channel(0);      //僠儍僱儖0慖戰
  Volt_Cont = read_adc();     //A/D曄姺僨乕僞侾侽價僢僩撉傒崬傒
  Volt_Cont = (Volt_Cont * 5.0) / 1024; //揹埑乮13VMax)傊僗働乕儖曄姺
  /// 壏搙寁應
  set_adc_channel(4);      //僠儍僱儖係慖戰
  delay_us(50);
  Temp = read_adc();
  Temp = Temp * 100;
  //// 奺抣昞帵
  lcd_clear();       //1峴栚偺愭摢傊堏摦
  printf(lcd_data, "V=%2.2f LMT%1.2f", Volt_Now, Volt_Cont);
  lcd_cmd(0xC0);       //2峴栚偺摢偵堏摦
  printf(lcd_data, "A=%1.2f Max%1.2f", Curr_Now, Curr_Set);
  /////丂嵟戝晧壸揹棳惂尷愝掕弌椡
  /////  嵟戝侾侽倂傑偱偲偡傞
  Max_Pwr = 10.0/(15.0 - Volt_Now);  //擖椡侾俆倁
  if (Max_Pwr > 2.0)      //嵟戝俀俙
   Set_Pwr = 0x0F;
  else
   Set_Pwr = (Max_Pwr * 0x0F) / 2;
  //// 俢乛俙弌椡
  output_c(Set_Pwr);      //壓埵係價僢僩弌椡
  ////  LED Controle
  if (flag)
   output_bit(PIN_C7, 1);    //俴俤俢徚摂
   flag = 0;
  else
   output_bit(PIN_C7, 0);    //俴俤俢揰摂
   flag = 1;
  delay_ms(500);       //0.5昩懸偪
发表于 2011-4-15 21:55 | 显示全部楼层
哪国文字?看不懂
 楼主| 发表于 2011-4-15 21:58 | 显示全部楼层
日本语,我也看不懂
发表于 2011-4-17 18:01 | 显示全部楼层
有中文的源码,可以在一乐找到
发表于 2011-4-17 19:10 | 显示全部楼层
回复 3# 农村人
    这个不是日语好不好,是乱码了!
日语是像这样的“[北河トウタ] あれふぇち ”
GMT+8, 2026-6-13 10:35 , Processed in 0.031160 second(s), 22 queries , Gzip On.
