楼主: lili_11
关于国庆抢购的1602!!
发表于 2011-10-13 09:44 | 显示全部楼层
这样直接接5V肯定不行的,这个1602应该是3V的,可以参考http://www.everbouquet.com.tw/products3.htm 未命名.jpg
同样使用NT7607,电压是3V,NT7607的资料没找到,找到了NT7606的pdf,可供参考 DSA-597008.pdf (579.31 KB, 下载次数: 483)
发表于 2011-10-13 09:48 | 显示全部楼层
弱弱的问一句3V的液晶咋驱动?
发表于 2011-10-13 21:19 | 显示全部楼层
这个。。。我还收了10个等高手呢。。。还好便宜。。。悲剧不大。更好的。只能购十个。不然就更大悲剧了。
发表于 2011-10-13 22:17 | 显示全部楼层
网上淘的NT7607
Features
? Single-chip LCD controller / driver
- 26 common outputs
- 80 segment outputs
? Applicable display panel
- 2-line x 16 characters + 80 icons (1/17 duty)
- 3-line x 16 characters + 80 icons (1/25 duty)
? 5 x 7 character format plus cursor; 5 x 8 for user defined symbols
? Character Generator ROM (CGROM)
- 10,240 bits (256 characters x 5 x 8 dots)
- Custom CGROM is also available
? Character Generator RAM (CGRAM): 320 bits (8 characters x 5 x 8 dots)
? Display Data RAM (DDRAM): 512 bits (16 characters x 4 lines x 8)
? Segment Icon Ram (ICONRAM): 80 bits (80 icons)
? Versatile functions provided on chip: Return home, Display control, Power save, Power control, etc.
? COM / SEG bi-directional (4-type LCD application available)
? On-chip oscillator requires no external components (external clock also possible)
? 2X / 3X DC-DC converter generation of LCD supply voltage
? Voltage regulator with electronic volume for contrast control (32 steps)
? Voltage follower & bias circuit
? Very low current consumption (VDD, VDD2 = 3.0 V):
- Sleep mode: < 5 &#181;A
- Normal mode: < 80 &#181;A
? Power supply voltage: VDD=1.8~3.6V, VDD2 = 2.4~3.6V
? Display supply voltage range (VLCD = V0 - VSS): VLCD = 4.0 to 7.0 V
? 80 / 67 Hz frequency selection of frame rate
? No busy check or no execution waiting time
? 4-bit or 8-bit parallel bus: 6800 and 8080
? Serial interface: 3-wire / 4-wire SPI
? CMOS process
? Available in COG form
General Description
The NT7607 is a low power CMOS LCD controller and driver designed to drive a dot matrix LCD display
of 2-line or 3-line by 16 characters with 5  ??8-dot format. All necessary functions for the display are
provided in a single chip, including on-chip generation of LCD bias voltages, resulting in a minimum of
external components and lower system current consumption. The NT7607 interfaces to most
micro-controllers via a 4-bit / 8-bit parallel bus or via the 3SPI / 4SPI serial interface. The chip contains a
character generator and displays alphanumeric character.
发表于 2011-10-14 19:14 | 显示全部楼层
楼主,液晶焊接最好用防静电的烙铁。
发表于 2011-10-17 01:46 | 显示全部楼层
没有研究了吗?。。
发表于 2011-10-20 03:14 | 显示全部楼层
老大们研究啊。。。这个东西尺寸很不错的。很小。。
发表于 2011-10-20 20:32 | 显示全部楼层
等待最新研究成果
发表于 2011-10-21 13:09 | 显示全部楼层
{:3_479:}等待最新研究成果
发表于 2011-10-21 15:00 | 显示全部楼层
给厂家发询问邮件了 等结果
GMT+8, 2025-12-13 20:42 , Processed in 0.037024 second(s), 28 queries , Gzip On.
