查看: 3637|回复: 4
找到两片LTC1605,16BIT ADC 100KSPS
发表于 2012-4-11 19:57 | 显示全部楼层 |阅读模式
从前面没出掉的板子上发现了两片LTC1605,凌特的16位ADC:
做什么用呢?
LTC1605 - 16-Bit, 100ksps, Sampling ADC特点
  • Sample Rate: 100ksps
  • Single 5V Supply
  • Bipolar Input Range: ±10V
  • Power Dissipation: 55mW Typ
  • Integral Nonlinearity: ±2.0LSB Max
  • Guaranteed No Missing Codes
  • Signal-to-Noise Ratio: 86dB Typ
  • Operates with Internal or External Reference
  • Internal Synchronized Clock
  • Improved 2nd Source to ADS7805 and AD976
  • 28-Pin 0.3” PDIP, SSOP and SW Packages
典型应用http://cds.linear.com/images/product/1547_app_1.jpg
http://cds.linear.com/images/product/1547_app_2.jpg
描述
The LTC®1605 is a 100ksps, sampling 16-bit A/D converter that draws only 55mW (typical) from a single 5V supply. This easy-to-use device includes sample-andhold, precision reference, switched capacitor successive approximation A/D and trimmed internal clock.
The LTC1605’s input range is an industry standard ±10V. Maximum DC specs include ±2.0LSB INL and 16-bits no missing codes over temperature. An external reference can be used if greater accuracy over temperature is needed.
The ADC has a microprocessor compatible, 16-bit or two byte parallel output port. A convert start input and a data ready signal (BUSY) ease connections to FIFOs, DSPs and microprocessors.
封装如需了解完整与最新的封装信息及图例,请查阅我们的封装网页
N-28, SSOP-28, SW-28http://cds.linear.com/images/product/1547_pack_1.jpg
订购信息
    以 PBF 结尾的器件型号表示这些是无铅型器件。如需了解有关含铅涂层器件的信息,请与凌力尔特公司联系。
    型号当中包含 TR 或 TRM 的器件分别采用卷带装500 片微型卷带装的形式进行装运。
  • 如需了解更多的细节,请查阅我们一般订购信息或产品数据手册。
各种封装型式和定价
器件型号封装引脚温度价格 (以 1 ~ 99 片为批量)价格 (以 1000 片为批量) *RoHS 数据
LTC1605-1CGSSOP28C$20.80$17.40视图
LTC1605-1CG#PBFSSOP28C$20.80$17.40视图
LTC1605-1CG#TRSSOP28C$17.50视图
LTC1605-1CG#TRPBFSSOP28C$17.50视图
LTC1605-1CNPDIP28C$20.05$17.00视图
LTC1605-1CN#PBFPDIP28C$20.05$17.00视图
LTC1605-1IGSSOP28I$22.25$18.40视图
LTC1605-1IG#PBFSSOP28I$22.25$18.40视图
LTC1605-1IG#TRSSOP28I$18.50视图
LTC1605-1IG#TRPBFSSOP28I$18.50视图
LTC1605-1INPDIP28I$21.25$18.00视图
LTC1605-1IN#PBFPDIP28I$21.25$18.00视图
LTC1605-2CGSSOP28C$20.80$17.40视图
LTC1605-2CG#PBFSSOP28C$20.80$17.40视图
LTC1605-2CG#TRSSOP28C$17.50视图
LTC1605-2CG#TRPBFSSOP28C$17.50视图
LTC1605-2CNPDIP28C$20.05$17.00视图
LTC1605-2CN#PBFPDIP28C$20.05$17.00视图
LTC1605-2IGSSOP28I$22.25$18.40视图
LTC1605-2IG#PBFSSOP28I$22.25$18.40视图
LTC1605-2IG#TRSSOP28I$18.50视图
LTC1605-2IG#TRPBFSSOP28I$18.50视图
LTC1605-2INPDIP28I$21.25$18.00视图
LTC1605-2IN#PBFPDIP28I$21.25$18.00视图
LTC1605ACGSSOP28C$28.35$23.40视图
LTC1605ACG#PBFSSOP28C$28.35$23.40视图
LTC1605ACG#TRSSOP28C$23.50视图
LTC1605ACG#TRPBFSSOP28C$23.50视图
LTC1605ACSWSO28C$27.90$23.00视图
LTC1605ACSW#PBFSO28C$27.90$23.00视图
LTC1605ACSW#TRSO28C$23.10视图
LTC1605ACSW#TRPBFSO28C$23.10视图
LTC1605AIGSSOP28I$29.15$24.00视图
LTC1605AIG#PBFSSOP28I$29.15$24.00视图
LTC1605AIG#TRSSOP28I$24.10视图
LTC1605AIG#TRPBFSSOP28I$24.10视图
LTC1605AISWSO28I$29.15$24.00视图
LTC1605AISW#PBFSO28I$29.15$24.00视图
LTC1605AISW#TRSO28I$24.10视图
LTC1605AISW#TRPBFSO28I$24.10视图
LTC1605CGSSOP28C$20.80$17.40视图
LTC1605CG#PBFSSOP28C$20.80$17.40视图
LTC1605CG#TRSSOP28C$17.50视图
LTC1605CG#TRPBFSSOP28C$17.50视图
LTC1605CNPDIP28C$20.65$17.00视图
LTC1605CN#PBFPDIP28C$20.65$17.00视图
LTC1605CSWSO28C$20.65$17.00视图
LTC1605CSW#PBFSO28C$20.65$17.00视图
LTC1605CSW#TRSO28C$17.10视图
LTC1605CSW#TRPBFSO28C$17.10视图
LTC1605IGSSOP28I$22.25$18.40视图
LTC1605IG#PBFSSOP28I$22.25$18.40视图
LTC1605IG#TRSSOP28I$18.50视图
LTC1605IG#TRPBFSSOP28I$18.50视图
LTC1605INPDIP28I$21.85$18.00视图
LTC1605IN#PBFPDIP28I$21.85$18.00视图
LTC1605ISWSO28I$21.85$18.00视图
LTC1605ISW#PBFSO28I$21.85$18.00视图
LTC1605ISW#TRSO28I$18.10视图
LTC1605ISW#TRPBFSO28I$18.10视图
 楼主| 发表于 2012-4-11 20:04 | 显示全部楼层
还有几片AD677AD(陶瓷封装的,更牛,analog官网 100-499片报价59.14美金)
AD677是一款多用途16位串行输出模数转换器 , 利用开关电容/电荷再分配架构 , 转换速率达100 kSPS(10 µs总转换时间) 。 通过片内自动校准功能对内部非线性进行数字校正 , 从而优化整体性能。
AD677电路分为两个单芯片:数字控制芯片采用ADI公司的DSP CMOS工艺制造 , 模拟ADC芯片采用BiMOS II工艺制造 。 两个芯片集成于单封装内。
AD677的信纳比、总谐波失真和交调失真等交流(或“动态”)参数,对于信号处理应用极为重要。此外,直流参数对测量应用也至关重要。
AD677采用+5 V和±12 V电源供电 , 使用10 V基准电压源时  展开
, 转换期间的功耗通常为450 mW(使用5 V基准电压源时为360 mW) 。 数字电源(VDD)与模拟电源(VCC、VEE) 分离 , 以减少数字串扰 。 提供模拟参考地 , 可远程检测信号源的地电位 。 如果信号必须传播一定距离才能到达A/D转换器 , 此器件会非常有用 。 此外还提供独立的模拟地和数字地。
AD677采用16引脚窄体塑封DIP封装、16引脚窄体侧面钎焊陶瓷封装或28引脚SOIC封装。AD676为并行输出版本,采用28引脚陶瓷或塑封DIP封装。所有型号的工作温度范围为0℃至+70℃商用温度范围或-40°C至+85°C工业温度范围。
发表于 2012-4-11 20:14 | 显示全部楼层
贵是贵,好像也没有多高端。
发表于 2012-4-11 20:45 | 显示全部楼层
不知道能做几个零的电压表头
发表于 2012-4-17 18:21 | 显示全部楼层
我也有2片1604 没有板子,焊不了啊……
GMT+8, 2025-5-1 00:29 , Processed in 0.103383 second(s), 29 queries , Gzip On.
