初级会员
帖子
积分70
阅读权限10
注册时间2012-4-29
不知道为什么,我用的是Keil uVision4,代码超过几百行就出现这种现象,求大神指点,真的很菜我
Build target '目标 1'
compiling LED_Scan.C...
compiling LED_Shift.C...
LED_SHIFT.C(273): warning C291: not every exit path returns a value
compiling HDW_Init.C...
compiling DownLoad.C...
linking...
BL51 BANKED LINKER/LOCATER V6.22 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2009
"Main.obj",
"LED_Scan.obj",
"LED_Shift.obj",
"HDW_Init.obj",
"DownLoad.obj"
TO "LED"
RAMSIZE(256)
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 1429H BYTE (252%) *
Program Size: data=31.1 xdata=236 code=5258
LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
MODULE: D:\KEIL\C51\LIB\C51S.LIB (-----)
LIMIT: 0800H BYTES
Target not created |
