钻石会员
帖子
积分10948
阅读权限50
注册时间2012-3-28
Be aware that the company no longer supports this particular product (the original model). As far as I know, there is no longer a website to register or download scenes. Fortunately, I bought this when the website was still up and running. Another thing, customer support was awful. They would not replace a defective camera unit and kept saying my system did not meet the requirements. I ended up opening the camera case and finding loose wires on the inside. Finally got the camera working, no thanks to Yoostar.
If all you really want is a small portable green screen and a webcam, then go ahead and purchase this. But you can probably get those elsewhere, if you bother to look hard enough. Otherwise, look into buying the newer versions of this system, maybe they are better. I think you need an xbox for the new versions... (括号中是个人的补完,或者说言下之意。翻译水平有限,估计和机翻差不多,见谅)
请注意这一代产品(老版本或称为原始版本)已经不再提供支持,供应商网站上已经没有用于注册并下载“场景”的网页。好在我之前买的时候还能行。
另一件值得注意的事情是,客服实在是糟糕。他们以我的计算机不能满足(最低)系统要求为理由,拒绝更换有缺陷的摄像头。迫不得已,我自己拆开摄像头,连接上一根松掉的连线,修好了它。
如果你只是想要一个带有绿色小屏幕的摄像头,可以购买这个。不过你似乎可以看看其他产品,只要愿意找(你能找到更好的)。另外,可以尝试下新版的摄像头,那个可能会好一些。不过你需要有一台Xbox360才行……
