返回列表 发新帖
楼主: Yim
M8 R2R电源,老外网站,硬/固件有更新
发表于 2010-7-2 12:07 | 显示全部楼层
那位英文好找找电路图来.........和现在的完全不一样了
fujiachun 发表于 2010-7-2 08:44 https://www.yleee.com.cn/images/common/back.gif
没找到图,我把找到的觉得有用的资料发到这里吧,大家参考的话方便些:
A microcontroller based bench DC power supply unit
hardware version 3.0
This is a kit to build a small but very advanced bench top power supply with current and voltage regulation. For more details see the article "A digital DC power supply, hardware version 3.0"
This kit includes:
·    Documentation: pinout description of the components, circuit diagram, assembly instructions
·    Two professionally printed circuit boards (epoxy board): the main board (61x75.5 mm, 2.4x2.97 inch) and one pcb for the key-pad (27x46 mm, 1.06x1.81 inch). The boards are gold plated.
·    Mechanical parts: 2 x M3x16 mounting screw and 2 x Insulation-pad for transistors
·    Capacitors: 1 x 470μF, 3 x 0.1μF, 1 x 10nF, 2x 10uF
·    1 x 5 pin ISP connector
·    Diodes: 1 x 1N5400, 1 x 1N4004
·    Transistors: 1 x BD245B, 1 x BD137, 1 x BC547, 1 x BC557
·    Resistors: 6 x 4K9, 11 x 10K, 1 x 5K6, 2 x 1.5 Ohm 3W, 1 x 820 Ohm, 1 x 100 Ohm, 1 x 470 Ohm, 6 x 1K, 1 x 68K
图(能看得清PCB的排版吗?):
介绍资料:
bench-power-supply-v3.pdf (1.71 MB, 下载次数: 680)
最新程序(0.6.1):
digitaldcpower-0.6.1.tar.gz (16.61 KB, 下载次数: 439)
发表于 2010-7-2 12:33 | 显示全部楼层
PS了一下,是不是能看得更清楚些了:
发表于 2010-7-2 14:39 | 显示全部楼层
没有找到新版的原理图,看了一下介绍,下面两段应当是重点:
Combining R2R-ladder and PWM
Oversampling
DAC从旧版的10 bit提升到12bit,ADC通过Oversampling来提升精度,电路图变了,v3新版的程序不能用在之前的版本上,值得期待!
发表于 2010-7-19 13:28 | 显示全部楼层
Oversampling ...
gumpcn 发表于 2010-7-2 14:39 https://www.yleee.com.cn/images/common/back.gif
Oversampling=过采样
发表于 2010-7-20 18:14 | 显示全部楼层
呵呵,e文不好,只能等到出中文的
呵呵,e文不好,只能等到出中文的
发表于 2010-7-30 04:01 | 显示全部楼层
手里没有DIP28的,用mega8L做了一个。用2004显示,8M显示有些乱,4M没有问题。README里说芯片用mega8或者mega8a。
发表于 2010-7-31 02:14 | 显示全部楼层
LS 的兄弟有 SCH 原理图吗????能否上传到论坛。。。。。。。。。
GMT+8, 2025-4-28 19:10 , Processed in 0.048963 second(s), 30 queries , Gzip On.
