一乐交易区摊主
帖子
积分60399
阅读权限30
注册时间2009-11-15
APC P6GC-CA 6路定时插座,6开6关,全新剪线[size=12.727272033691406px]2 B: [: I; r/ l4 t2 {! U
" p% o% ]+ |; C$ L
]% o; T& T1 t
/ A5 v. u! d' r- s8 ^[size=12.727272033691406px]都是全新剪线的,然后装进袋子,都有划痕,成色还不错
9 G1 i6 J: x6 ][size=12.727272033691406px]有100多条,38元一条包邮(偏远另外计算). V! m, M- z9 D; G
送改装配件(2个电阻,一个电容)压敏直接拆了,还没买呢,货到后一起发货!
9 y9 a8 p0 P* P2 U" h2 y官方网址:http://www.apc.com/products/reso ... cr=2&tab=models8 c! K' P0 S% }" [) a
6 U8 B5 c# R, b! h; EOutput
; h' `8 c; t! Q" H% u7 X" ?4 Q1 K1 x L1 r
Number of Outlets
& A1 B5 H0 r9 ` u+ u. U61 B6 W9 n$ G1 a4 t# T
$ b/ |5 v4 x- ?& y$ ~) c/ Q' B
0 I* G: \* I/ C- x% KReceptacle Style
$ ?; W5 D' @6 r8 MNEMA 5-15R1 x& s6 u7 q4 T# L" Q# z
' b6 [/ Y G/ o$ c3 ^8 j
. L9 N! u' T7 Y, f1 u. P# C8 W* ^( l0 w. X, ~' x% x) u9 a& M
1 p3 L# n, u5 M1 l: xInput
; c1 h/ y& q& o! Y2 z- \
$ d$ w) |7 @! k8 r4 ZNominal Input Voltage
: n6 ~5 r4 G/ M120V
4 T, }+ @6 w+ g \7 n
; X8 D+ w( }7 x, {% _. W' h0 I6 A7 T5 L
Input Frequency0 b4 W- _" {; ~ {" W" U7 h$ p
50/60 Hz
" u7 | E! i1 Z' E$ s. S0 T2 i6 K
* x) k' V% ^6 R9 Q* h' @# ?: `
Input Connections
1 d8 u9 d9 a# g {# q* W$ @( F* D2 V) L: e' I. [$ M
. d# V4 m6 ~, Z* R& E' X, _
, p. O7 Y0 a! }, ^% O$ j0 `& u. sCord Length
: `. {6 M# f$ [' [" c0.91 meters) E% r1 g4 l* Z& r- N
2 P; X$ d$ Y; h4 Y2 x, i h* z
6 r$ K1 t) S, ?4 K) X6 ^3 gMaximum Input Current+ N3 y% h3 C6 Y9 {( D( T6 x
15A$ ^# `/ e7 d( B. D4 l# d9 Z4 M. {
7 C9 J# j O% u p" h
& _' |- q' |7 U
4 n) ^ K G( } X$ T, ^# k* V
4 S4 b; }: j2 m# E: Y7 J* J/ O
Surge Protection and Filtering
! l+ i4 C$ Q9 \8 F- U2 {! f: L+ \; Y- n* h; p1 p8 a
Surge energy rating
! X& _2 d7 b# a3 p/ i$ k2 }1080 Joules2 }+ |. {; h+ D, s5 B6 K* k
7 |7 f5 B7 {, ~* j4 f2 m( d3 q
$ p5 Z6 v1 D( wEMI/RFI Noise rejection (100 kHz to 10 MHz)
4 o0 F- _4 k# P* w& _40 dB
& a2 y& {& X; p/ P" K
; ~7 e4 R+ W& P+ V
% A2 @; q+ J- A% u* u. p& KPeak Current Common Mode$ A/ a3 P& r' i% Y9 a6 m/ ?- ~
72 kAmps
! }% Z% m- Z( m& |
( s/ r, ^1 z3 I6 E2 }7 H: F
! q+ ^8 }+ L2 L; t! d/ D( [NM Surge Response Time (ns)8 {" U# L/ n! p& Z8 A
1 ns- E) A2 @! s& Q
2 K/ n f2 q! @! [! _" f
" h! h$ Q# T$ @0 q2 M
# H7 j! _ v+ z3 F
/ m" i+ a+ [+ x9 _7 h- J% MPhysical
% l x/ _5 O( ~2 r& J$ ^/ Q
( b+ M7 k- C3 y+ dNet Weight
" ]* e4 l- }0 L( z0.59 KG! A( d) T0 R1 s9 d* N5 @( {. L
% m4 p) A. @5 b2 ?3 g* p. R9 ?
: `% s0 \% m+ AMaximum Height9 n# Y+ B' |) [4 T
362.00 mm
^6 E. M. r& A2 ]# @
3 U) I! T0 W/ F+ d2 y
3 l0 l7 E- x. ~2 ]; }6 s, OMaximum Width& M+ ?" Z: _( U# {/ f& L/ Y Q
57.00 mm4 T' O5 F X! W1 v
) }* @: k/ S0 @$ Z( |/ \
C! g3 h- }$ ^# m7 Q5 j9 H
Maximum Depth
7 E. J! z# z1 i9 a) b+ X- x+ U3 T46.00 mm: _$ Q) S0 ]! B; `' X; c9 v
, X) e6 o# C8 _* f; H- I9 u; ~8 O0 h% y9 k+ B% D! B
Shipping Weight
% l1 Y5 P) d* r7 A1 t. {- N0.72 KG
( W \. C6 i; K6 j% H3 J7 E9 O. Q& W& L' L/ Q
~( T4 l1 t5 ?6 EShipping Height) g( s3 n$ s" Z' x7 C) F
476.00 mm
3 W( I3 R7 ?; l( V& V; \1 {7 D; ^5 s1 |
2 V, E# P' Q* L/ l) F, \" J
Shipping Width, R1 W& f" A; }4 X* l
171.00 mm3 k; z8 R" a9 v9 `+ \% v
7 a8 Q0 T( ]( _
& u3 m g' q" F' W. j9 l2 r- k" S: Y
Shipping Depth
7 B& {: y3 y2 @5 o8 {51.00 mm
& I9 A! _' o9 p k1 C' L7 h. Z
2 }# ~& o! W- C) D5 |3 n {: K+ b3 y. }7 J3 l9 W8 Y# X0 ?# M3 C
Master Carton Units
1 c R* }& u* n6.00
5 B. m8 ?# z$ C9 p7 O( L4 K' V+ {/ r! O0 T6 u. {
1 k1 K/ c2 o6 l, c4 X- @; O
Master Carton Dimensions (Length x Width x Height)! i& F# {; t/ ]7 K) q
401 x 254 x 528 mm$ c7 ]' y8 R6 ]+ X/ ?( S% }7 V
% P" q6 ?( p6 r- u$ M: d7 l7 W2 L# ^* V3 u0 Q( t# A
Master Carton Weight
8 S/ e1 y- E. i: C6 \5.80 KG
/ V3 ~% F8 S" b1 l1 E) X" b0 b7 y) a9 Q
0 l# s9 Y$ \( c# X
SCC Codes
# R/ H E8 v+ @2 t6 o& q* o1073130426925 7
: C7 i/ ]( R" G0 S7 |8 A" E5 O p
2 d' F) F- x5 V' Q$ i
2 n1 P1 b2 r# z5 @9 IColor9 W4 u0 c6 f0 s( N; J# O& q
White
7 t. w& c9 r6 Y! G# _5 U% N& H0 e6 I* U! U
% s9 p% A4 w# ?" h6 A, H9 H: [
Units per Pallet, x& ?% g7 y, V$ _, [) R2 N- O
216.00
$ ~* ?+ C s& ^ f. {
. h6 Q3 I: J( a: {1 g! r" M! y. _9 F- M* t( l( ?/ P; P
9 Z! p+ i9 p$ N* j& T2 i
1 A! Y- Z0 ^" A' V$ KEnvironmental
" F$ O! q6 H; @: ?
7 x2 M2 ?4 O A1 i1 GOperating Environment
+ s3 j2 k# H: [* X; v0 - 45 °C
( ~- M, k8 ]- s" n# h/ W
. X: }6 n# ~0 {6 W: X1 O: u q! ~ h: H' J& @* x% y, ]4 `. ^2 t
Operating Relative Humidity5 v6 K; w* Q* r5 @" [* m
0 - 95%5 h* ~" ^& J3 Y- y( j5 I" u( I
{; f) Q7 e- q1 t1 a2 p
, [: O. d+ \5 ]- t
Operating Elevation" p' H9 W/ R+ [9 Y
0-3000 meters
) d2 h$ \% l2 R" s* v
! f5 s0 o& r6 g) D1 {8 {! U2 t8 G! \$ Q2 M/ ]+ c
Storage Temperature
7 J# d1 f W' r( J9 Z1 _-5 - 45 °C
, [2 |( r) p2 _6 ~0 s2 Z. W x. }; K/ f9 Q
2 j: w4 U; y7 e: j5 ?Storage Relative Humidity0 _) u) \2 r2 ~4 D, w
0 - 95%8 ?" f, o9 ` }8 V- g& u
6 @3 }% X. C6 [$ T. r" e( E9 Q, S6 k+ ^, Q
Storage Elevation- n: L( ~/ u2 V8 w- d6 F
0-15000 meters) ]8 G$ I2 T A
7 K% Z# O' o5 s4 N! a$ @; i" [
! }4 k" t: n' c$ _( a
, Q9 j+ e, Y% ]+ N5 z. ]1 t
# O; j9 ~, G' JConformance* I. _. Y ~+ I8 d$ x$ c
- R3 E% n+ z: [1 C
Regulatory Approvals# e# m' L7 E0 p4 H
ETL, UL 1449
6 K& `' A' C4 S% T; }7 F1 K; ]" v
; {5 L4 p* J/ y* e! W0 B4 ^. @/ Q6 Q* U: u) d5 o
Standard Warranty* b z3 U3 c0 ^8 ] e B- Z
Lifetime, W6 |- y/ W* l6 A
) t/ @ b8 X: r+ e% J; S& f2 j
. l2 a( |* I% E2 S) _UL 1449 TVSS Rating
& o) l }7 f2 r9 L6 D: }* N<400V$ _, L8 \7 N3 A+ P8 q
1 s) Q3 Z: W. h5 B/ J
) H3 Y, k+ l- t# x: t0 X. M1 c' |- s, s3 ~
# j" C" \: ]. H# k$ `( F6 m% L' P
Sustainable Offer Status
, ~$ ]0 a1 x6 f' S- O) `5 S
: [- T# X M s2 v7 w% IRoHS0 H9 d! R; e) O8 a! A9 ~: i
Compliant
& Q& i# N9 `$ {" O- T. c
7 n; |( c/ [ e" M9 X% @/ @# j0 h7 h8 S8 n! o
REACH, U2 r- {" p I6 _* p
REACH: Contains No SVHCs' {: m4 N" R+ J8 |( m8 o
5 ^* Z# c' k" F! C2 J+ P) C
) C! H& N/ R( |5 M
4 m5 J1 E; C! F# ]* v
6 Q, p. N7 [5 Z9 H8 a/ W8 J N$ n7 Z; h+ V6 [
P6GC Features0 Z1 v4 Q, b1 ~% Y S* e
" N/ x+ ~' X2 ?Lightning and Surge Protection
. Y" \( j6 G2 E0 kTo prevent damage to your equipment from electric power surges and spikes.
) N( ~* ], J. j4 G% u% L: l" }! w, ^6 x8 t# Q
9 r- L. k/ ]) z$ n& z/ M4 [% x7 S( cLCD Timer
4 v# D2 x( q9 cSaves power by automatically turning equipment ON and OFF based on six preset time programs. Select the exact time and day of the week that your equipment receives power from the "ControlLED by Timer" outlets and prevent unnecessary electricity waste.
3 X5 P) a, |2 u6 `
O* i7 f2 R0 l% H' `7 @; z
- D: F! ]& e- Y& m5 {0 cEMI and RFI noise filtering $ p8 d; B$ O H* _! y3 Z
Reduces line noise that can cause data loss and keyboard errors.
- L# u4 L. e9 u9 A' L; y
$ _% J- X1 U' ^; u- R4 J8 O
7 \' | r" T4 V7 x: S/ @# ~6 q3 Modes of protection (L-N : L-G : N-G)
" Y% O$ f! b; b9 ?+ SThe remaining modes continue to provide protection in the event a mode of protection is compromised as a result of a surge.
! ]2 h. S, g* X1 X8 c, F" E& Q V7 M( N0 r
- H) C4 K3 |: lCatastrophic Event Protection
+ _1 H$ n9 j4 p; USurgeArrest components such as MOVs and Thermal fuse ensure instantaneous reaction to lightning strikes and wiring faults. If the surge components are damaged due to power spike or over voltage, excess power cannot reach your equipment. Unlike the APC SurgeArrest products, most surge suppressors continue to let power through even after circuits have been damaged, leaving your equipment exposed to other damaging surges., c' { g' t# C' {
1 Y5 s" @0 n9 l3 s( N, n ?) @ |& H/ b% P) Q+ p- B1 o5 E
Noise Filtering 7 K& w N$ q0 E( B+ |
Attenuates EMI/RFI line noise that can cause data errors and keyboard lockups, ensuring better performance of protected equipment.( g4 j1 u( L2 P; s) A; i' K3 b3 c: C7 ?6 @
6 {, D# [8 \( F6 w: Q6 G- o
) j$ A0 j3 d% \( z( KFail Safe Mode 0 i: f5 x; x9 {1 b1 \, u, N
Most other surge suppressors continue to let power through even after their circuits have been damaged, leaving your equipment exposed to future surges. APC's SurgeArrest fail safe, which means that once the circuit of an APC SurgeArrest has been compromised the unit disconnects equipment from the power supply ensuring that no damaging surges reach your equipment.
6 l$ O# A8 W* I, y
+ j& q# f% g2 y3 T- q
/ F2 r! y# r7 ~% g) c- h( JBuilding Wiring Fault Indicator
* B$ e/ D ~+ c7 }1 }+ d% d+ ^This LED informs users of potentially dangerous wiring problems in the wall circuit.
+ J* r( \9 }) Z/ }
( I9 k9 B8 P! c
/ w, {, J8 N. S' H$ e+ j2 o" d' Q+ R$ p* ]4 B3 }8 Q
! Z1 S6 U+ _1 H7 s4 J1 V
# s8 a8 [6 G: H! e8 O) v+ O
+ ^7 v. G, l% k2 i# |
SurgeArrest Essential Features & Benefits! u. z9 U' ]& t: ?
Protection
: q! l: J4 \6 Y0 W0 J; [3 x0 P3 b; S8 I" k0 Z
# w- J1 |1 f8 A1 ~; B# h+ _
2 d: e9 @5 C: N! ALightning and Surge Protection
* b2 j" x ]7 f$ [8 ?- @To prevent damage to your equipment from electric power surges and spikes.
: m( Y: W8 ^5 Z1 t% r$ R4 `* ~0 S
. O5 p2 V4 s4 \- f( H" }2 T+ A% ~IEEE let-through ratings and regulatory agency compliance
- b3 n7 y2 E6 w6 aAPC surge protectors undergo stringent testing by IEEE, and are awarded "let-through ratings", which indicate the maximum voltage level that can possibly reach your equipment after a surge or voltage spike has passed through an electric surge protector. Lower IEEE let-through ratings indicate better protection and performance. The APC Essential SurgeArrest series offers optimal performance with a let-through rating of less than 330V for North American products, and a rating of less than 15% for products sold worldwide. All APC products comply with local agency safety requirements, including UL in North America and CE/Kema/Gost/C-tick/A-Tick/Telepermit in their respective regions.
& n' d: g) {3 _3 e+ v; \3 e+ x7 X
: B* i( t7 V" g7 h
Noise Filtering
. g# E( k& c3 c9 t7 yAttenuates EMI/RFI line noise that can cause data errors and keyboard lockups, ensuring better performance of protected equipment.
8 ]3 l4 N+ ~7 B1 l. y
: E6 R: f; i( K
+ y/ i0 S6 D/ V9 Q- B* n9 T/ |& B! \* a5 a \) x
4 e9 e" X% v% [0 V4 q4 b' w/ gSafety9 R0 j3 {) Z, t5 Y( x/ w
l$ O% t$ \. Q- j
8 e w [( [1 b5 |4 E3 K3 g1 `1 {: e
Catastrophic Event Protection8 ]0 N1 x7 I; q8 k* `4 N
- \9 U% G# F7 M! ^% G" V5 }! }4 ]: w, p% e7 h
5 ^ I3 m5 e6 }" _9 N$ E
Fail Safe Mode
N! D& t) P5 a9 @3 D" W) QMost other surge suppressors continue to let power through even after their circuits have been damaged, leaving your equipment exposed to future surges. APC's SurgeArrest fail safe, which means that once the circuit of an APC SurgeArrest has been compromised the unit disconnects equipment from the power supply ensuring that no damaging surges reach your equipment.+ s/ g7 V: L( f! v9 W
& U a0 l, o/ ?! F2 @6 H$ `, m. s' w* Z$ s J/ D7 t
Protection Working Indicator
% M) y& L: X/ e- V; DSurgeArrest will warn you if its circuitry has been damaged by heavy strike or power line surge and it is unable to provide 100% protection. If still under warranty, APC will then replace your damaged SurgeArrest free of charge.
% c9 M- x" K' N7 ]* ^5 b. y0 ]3 `- U! W% d1 e3 h- `$ `
) ~/ d) M N, w {1 r3 QBuilding Wiring Fault Indicator( p Z/ f5 h, @0 T @4 d
0 ~- @0 g- X* f) l, X
# Z" [! r) w2 J) j
5 Z8 N: Y* L% b; ]8 BThis LED informs users of potentially dangerous wiring problems in the wall circuit./ g V, e- Z# f
" T* J2 a; m' |3 J; z
6 j; z2 A, C8 Y [' k& D q. c2 }( D: h% ]4 j0 e" p$ M
1 i, J/ V% F+ y' \& f( Q! w
( Y1 }9 o+ z6 K. A4 q
) T/ v: a; j! i2 s& c Y0 g% c* l
& u& O3 Y" D) e7 Q0 ~" V& p |
