白钻会员
帖子
积分54909
阅读权限50
注册时间2010-5-23
原贴:【用M8制作电感、电容、电解电容测量仪表】:
http://www.amobbs.com/forum.php?mod=viewthread&tid=3279392
由于使用的1602是非标准的,LCD需要略加修改驱动程显示行地址,第一行0x80,0x90才能正常显示,可是找不到哪里修改
下面是程序- '****************************************************
- '* 电感电容电解电容测量仪 *
- '* 电容:1P-2.5uF *
- '* 电感:1uH-2.0H *
- '* 电解电容:0.1uF-20000uF *
- '* 吕军省 天津大港 *
- '* junsheng427@126.com *
- '* 20081217 *
- $regfile = "m8def.dat"
- $crystal = 8000000
- Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = Portb.5 , E = Portb.1 , Rs = Portb.0
- Config Lcd = 16 * 2
- Config Timer1 = Counter , Edge = Falling '配置T/C1为计数
- Config Timer2 = Timer , Prescale = 64 '配置T/C2定时
- Config Int0 = Falling
- Config Timer0 = Timer , Prescale = 8
- On Ovf0 Tim0_isr
- On Int0 T1_isr
- On Ovf2 Tim2_isr
- Enable Ovf2
- On Ovf1 Tim1_isr
- Enable Ovf1
- Enable Interrupts
- Tcnt2 = &H83
- Start Timer2
- Counter1 = 0
- Start Counter1
- Dim F1 As Long
- Dim F2 As Long
- Dim C1 As Single
- Dim Ca1 As Single
- Dim Ca2 As Single
- Dim Cx As Single
- Dim L1 As Single
- Dim Lx As Single
- Dim F11 As Single
- Dim V1 As String * 11
- Dim V2 As String * 11
- Dim Vf As String * 6
- Dim Vs As String * 8
- Dim Z1 As String * 2
- Dim J As Bit
- Dim I As Byte
- Dim K As Bit
- Dim M As Bit
- Dim Vl As Byte
- Dim Tc As Byte
- Dim Tc1 As Long
- Dim Te As Long
- Ddrd.7 = 0 '键初始
- Portd.7 = 1
- Ddrd.4 = 1 '继电器初始化
- Ddrd.3 = 1
- Portd.4 = 1
- Portd.3 = 1
- Ddrd.6 = 1
- Portd.6 = 1
- J = 1
- K = 1
- M = 1
- I = 1
- Tc1 = 0
- Cls
- Cursor Off
- '/////主程序/////
- Do
- '/////按键处理/////
- If Pind.7 = 0 Then 'S1
- Waitms 40
- Incr I
- Bitwait Pind.7 , Set
- End If
- End If
- '/////电感L1,电容C1计算/////
- If I = 1 Then
- If J = 1 Then
- Lcd " L_C_CE meter"
- Lowerline
- Lcd " 20081217"
- Waitms 1500 '等待F1计数
- Portd.3 = 0 '接入标准电容C2
- Waitms 1500 '等待f2计数
- Ca1 = F1 * F1
- Ca2 = F2 * F2
- C1 = Ca1 - Ca2
- C1 = Ca2 / C1
- C1 = C1 * 1800 '1800是标准电容C2 ;单位pF
- L1 = 3.1416 * 3.1416
- L1 = L1 * 4
- L1 = L1 * Ca1
- L1 = L1 * C1
- L1 = 1 / L1
- L1 = L1 * 1000000000000000000 '单位uH
- Portd.3 = 1 '断开标准电容C2
- End If
- J = 0
- Vf = Str(f1) '显示f1
- Vf = Format(vf , " ")
- Locate 1 , 7
- Lcd "F=" ; Vf ; "Hz"
- Locate 1 , 1
- Lcd "SetOK "
- V1 = Fusing(c1 , "#.#")
- V2 = Fusing(l1 , "#.#")
- Locate 2 , 1
- Lcd V1 ; "pF " ; V2 ; "uH"
- End If
- '/////电容Cx计算/////
- If I = 2 Then
- Vf = Str(f1)
- Locate 1 , 7
- F11 = F1 * F1
- Cx = Ca1 / F11
- Cx = Cx - 1
- Cx = Cx * C1
- V1 = Fusing(cx , "#.#")
- Vl = Len(v1)
- Z1 = "pF"
- If Vl = 6 Then
- V1 = Mid(v1 , 1 , 4)
- Z1 = "pF"
- End If
- If Vl = 7 Then
- V1 = Format(v1 , "00.00")
- Z1 = "nF"
- End If
- If Vl = 8 Then
- V1 = Format(v1 , "000.0")
- Z1 = "nF"
- End If
- If Vl = 9 Then
- V1 = Format(v1 , "0.000")
- Z1 = "uF"
- End If
- Vs = Space(8)
- Locate 2 , 1
- Lcd " Cx=" ; V1 ; Z1 ; Vs
- Locate 1 , 1
- Lcd "TestC "
- End If
- '/////电感Lx计算/////
- If I = 3 Then
- Vf = Str(f1)
- If F1 < 50 Then
- Vf = " 0"
- End If
- Locate 1 , 7
- Portd.4 = 0 '输入端切换到测电感
- If F1 > 1000 Then
- F11 = F1 * F1
- Lx = Ca1 / F11
- Lx = Lx - 1
- Lx = Lx * L1
- Else
- Lx = 0
- End If
- V1 = Fusing(lx , "#.##")
- Vl = Len(v1)
- Z1 = "uH"
- If Vl = 6 Then
- V1 = Mid(v1 , 1 , 5)
- Z1 = "uH"
- End If
- If Vl = 7 Then
- Z1 = "mH"
- End If
- If Vl = 8 Then
- Z1 = "mH"
- End If
- If Vl = 9 Then
- Z1 = "mH"
- End If
- If Vl = 10 Then
- Z1 = "H "
- End If
- Vs = Space(8)
- Locate 2 , 1
- Lcd " Lx=" ; V1 ; Z1 ; Vs
- Locate 1 , 1
- Lcd "TestL "
- End If
- '/////电解电容器测量(<500uF) /////
- If I = 4 Then
- Portd.4 = 1
- If K = 1 Then
- Disable Ovf1
- Disable Ovf2
- Enable Int0
- Enable Ovf0
- Locate 1 , 1
- Lcd "TestCE [<500uF]"
- Locate 2 , 1
- Lcd " CEx= "
- End If
- K = 0
- Portd.6 = 0 '开始充电
- Start Timer0 '开始计时
- End If
- '/////电解电容测量(2) /////
- If I = 5 Then
- If M = 1 Then
- Portd.3 = 0
- Locate 1 , 1
- Lcd "TestCE [>500uF]"
- Locate 2 , 1
- Lcd " CEx= "
- End If
- M = 0
- Portd.6 = 0 '开始充电
- End If
- '/////返回到电容测量//////
- If I = 6 Then
- I = 2 '返回到电容测量
- Enable Ovf1
- Enable Ovf2
- Disable Int0
- Disable Ovf0
- Portd.3 = 1
- K = 1
- M = 1
- End If
- Loop
- End
- '/////计数中断/////
- Tim1_isr:
- Incr Tc1 '这么作可使计数分辩率最高到1Hz
- Return
- '/////定时中断/////
- Tim2_isr:
- Tcnt2 = &H83 '定时器T2初值
- Incr Tc
- If Tc = 250 Then '定时250mS
- Stop Counter1
- Tc1 = Tc1 * 65535
- If Portd.3 = 1 Then
- F1 = Counter1
- F1 = F1 + Tc1
- F1 = F1 * 4
- End If
- If Portd.3 = 0 Then
- F2 = Counter1
- F2 = F2 + Tc1
- F2 = F2 * 4
- End If
- Counter1 = 0
- Start Counter1
- Tc = 0
- Tc1 = 0
- End If
- Return
- '/////定时中断,测电解电容/////
- Tim0_isr:
- Incr Te '定时器0中断次数
- Return
- '/////外部中断,测电解电容/////
- T1_isr:
- Stop Timer0
- Te = Te * 256
- Te = Te + Tcnt0
- Te = Te / 2 '时间/充电电阻=被测电容
- V1 = Str(te)
- Vl = Len(v1)
- If Portd.3 = 1 Then '充电电阻R9接入,<500uF
- If Vl = 2 Then
- V1 = "NO"
- End If
- If Vl = 3 Then
- V1 = Mid(v1 , 1 , 3)
- End If
- If Vl = 4 Then
- V1 = Format(v1 , "0.00")
- End If
- If Vl = 5 Then
- V1 = Format(v1 , "0.0")
- End If
- If Vl = 6 Then
- End If
- If Vl = 7 Then
- V1 = " OL "
- End If
- End If
- If Vl = 2 Then
- V1 = Mid(v1 , 1 , 2)
- End If
- If Vl = 3 Then
- End If
- If Vl = 4 Then
- End If
- If Vl = 5 Then
- End If
- If Vl = 6 Then
- End If
- If Vl = 7 Then
- End If
- End If
- Vs = Space(7)
- If Te > 1 And Te < 10 Then
- Locate 2 , 1
- Lcd " CEx=" ; "0" ; "uF" ; Vs
- End If
- If Te > 10 Then
- Locate 2 , 1
- Lcd " CEx=" ; V1 ; "uF" ; Vs
- End If
- Portd.6 = 1 '开始放电
- If Portd.3 = 1 And Te > 10 Then
- Waitms 100
- End If
- If Portd.3 = 0 And Te > 10 Then
- Waitms 500
- End If
- Tcnt0 = 0 '定时计数器清零
- Te = 0 '定时中断次数清零
- Return
复制代码 |
