钻石会员
帖子
积分10261
阅读权限50
注册时间2012-5-17
楼主 |
发表于 2017-5-5 09:43
显示全部楼层
LM2904跟LM358 差不多啊! TP1272 数据手册! 36V Single Supply, Precision RRO Op-amps With 7MHz Bandwidth
Low Offset Voltage: 150μV Maximum
 Low Drift: ±0.9μV/°C
 Wide Supply Range: 2.7V to 36V
 Gain-bandwidth Product: 7MHz
 High Slew Rate: 20V/μs
 High EMIRR: 84dB at 900MHz
 High Common-Mode Rejection: 126dB
 High Power Supply Rejection: 130dB
 Low Input Bias Current: 3pA Typical
 Below-Ground (V-) Input Capability to -0.3V
 Rail-to-Rail Output Voltage Range
 Pb-Free Packages are Available
 –40°C to 125°C Operation Range
 Robust 3kV – HBM and 2kV – CDM ESD Rating |
