高级会员
帖子
积分2022
阅读权限30
注册时间2011-5-25
我的机器是pogoplug v4 mobile,昨天折腾一下午,上网也查不到怎么中断
按esc和回车没反应,按ctrl+pause可以中断,但出现ce>>之后不管键盘怎么输入光标那连字都不出来
然后重复试了几次,基本ctrl+pause都能中断,说明ttl小板有成功送过去键盘操作
所以我觉得应该还是方法不对,应该还有其他中断的方法
不知道现在还有没有高手还在玩这个?能不能告诉我怎么正确中断呢?
因为不想用ssh然后网线登陆所以才想用ttl的,我不是用来修砖只是喜欢用ttl(感觉上权限比ssh要高)
谢谢
我中断就是在显示
USB 0: host mode
PEX 0: interface detected no Link.
Net: egiga0 [PRIME]
Hit any key to stop autoboot: 0
这个读秒的时候按下ctrl+pause
软件试过crt,xshell,putty结果都是一样的,我觉得应该是中断的按键不对
=========以下是启动信息====================
U-Boot 1.1.4 (Oct 1 2011 - 12:21:35) Cloud Engines 1.1.2 (3.4.27) PHYADDR=0
U-Boot code: 00600000 -> 0067FFF0 BSS: -> 006918B4
Soc: 88F6192 A1 (DDR2)
CPU running @ 800Mhz L2 running @ 400Mhz
SysClock = 200Mhz , TClock = 166Mhz
DRAM CAS Latency = 3 tRP = 3 tRAS = 8 tRCD=3
DRAM CS[0] base 0x00000000 size 128MB
DRAM Total size 128MB 16bit width
Addresses 8M - 0M are saved for the U-Boot usage.
Mem malloc Initialization (8M - 7M): Done
NAND:128 MB
Flash: 0 kB
CPU : Marvell Feroceon (Rev 1)
CLOUD ENGINES BOARD: PPV4A1
Streaming disabLED
Write allocate disabled
USB 0: host mode
Net: egiga0 [PRIME]
Loading from NAND 128MB 3,3V 8-bit, offset 0x200000
Image Name: Linux-2.6.31.8
Created: 2011-08-23 20:00:55 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2080956 Bytes = 2 MB
Load Address: 00008000
Entry Point: 00008000
## Booting image at 00800000 ...
Verifying Checksum ... OK
OK
Starting kernel ...
Uncompressing Linux..................................................................................................................................... done, booting the kernel.
[ 0.000000] Linux version 2.6.31.8 (afenn@kt) (gcc version 4.3.2 (sdk3.3-ct-ng-1.4.1) ) #4 Tue Aug 23 13:00:50 PDT 2011
[ 0.000000] CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: Feroceon-KW
[ 0.000000] Using UBoot passing parameters structure
[ 0.000000] Ignoring unrecognised tag 0x41004345
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200 root=ubi0:rootfs ubi.mtd=4,2048 rootfstype=ubifs
[ 0.000000] PID hash table entries: 512 (order: 9, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 118356KB available (3852K code, 261K data, 124K init, 0K highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:128
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 799.53 BogoMIPS (lpj=3997696)
[ 0.230000] Mount-cache hash table entries: 512
[ 0.230000] CPU: Testing write buffer coherency: ok
[ 0.230000] NET: Registered protocol family 16
[ 0.230000] Feroceon L2: Enabling L2
[ 0.230000] Feroceon L2: Cache support initialised.
[ 0.230000]
[ 0.230000] CPU Interface
[ 0.230000] -------------
[ 0.230000] SDRAM_CS0 ....base 00000000, size 128MB
[ 0.230000] SDRAM_CS1 ....disable
[ 0.230000] SDRAM_CS2 ....disable
[ 0.230000] SDRAM_CS3 ....disable
[ 0.230000] PEX0_MEM ....base e0000000, size 128MB
[ 0.230000] PEX0_IO ....base f2000000, size 1MB
[ 0.230000] PEX1_MEM ....no such
[ 0.230000] PEX1_IO ....no such
[ 0.230000] INTER_REGS ....base f1000000, size 1MB
[ 0.230000] NFLASH_CS ....base fa000000, size 2MB
[ 0.230000] SPI_CS ....base f4000000, size 16MB
[ 0.230000] BOOT_ROM_CS ....no such
[ 0.230000] DEV_BOOTCS ....no such
[ 0.230000] CRYPT_ENG ....base f0000000, size 2MB
[ 0.230000]
[ 0.230000] Marvell Development Board (LSP Version KW_LSP_5.1.3_patch18)-- RD-88F6192A-NAS Soc: 88F6192 A1 LE
[ 0.230000]
[ 0.230000] Detected Tclk 166666667 and SysClk 200000000
[ 0.230000] Marvell USB EHCI Host controller #0: c403e740
[ 0.730000] PEX0 interface detected no Link.
[ 0.730000] PCI: bus0: Fast back to back transfers enabled
[ 0.730000] mvPexLocalBusNumSet: ERR. Invalid PEX interface 1
[ 0.750000] bio: create slab <bio-0> at 0
[ 0.750000] SCSI subsystem initialized
[ 0.750000] usbcore: registered new interface driver usbfs
[ 0.750000] usbcore: registered new interface driver hub
[ 0.750000] usbcore: registered new device driver usb
[ 0.750000] NET: Registered protocol family 2
[ 0.750000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.750000] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.750000] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.750000] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.750000] TCP reno registered
[ 0.750000] NET: Registered protocol family 1
[ 0.750000] cpufreq: Init kirkwood cpufreq driver
[ 0.760000] XOR registered 4 channels
[ 0.760000] XOR 2nd invalidate WA enabled
[ 0.760000] cesadev_init(c000d7fc)
[ 0.760000] mvCesaInit: sessions=640, queue=64, pSram=f0000000
[ 0.760000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.770000] msgmni has been set to 231
[ 0.770000] alg: No test for cipher_null (cipher_null-generic)
[ 0.770000] alg: No test for ecb(cipher_null) (ecb-cipher_null)
[ 0.770000] alg: No test for digest_null (digest_null-generic)
[ 0.770000] alg: No test for compress_null (compress_null-generic)
[ 0.780000] alg: No test for stdrng (krng)
[ 0.780000] alg: No test for hmac(digest_null) (hmac(digest_null-generic))
[ 0.790000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.790000] io scheduler noop registered
[ 0.790000] io scheduler anticipatory registered (default)
[ 0.790000] Initializing ths8200_init
[ 0.790000] Initializing dove_adi9889_init
[ 0.810000] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.810000] serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
[ 0.810000] console [ttyS0] enabled
[ 0.820000] Integrated Sata device found
[ 0.830000] IRQ 21/mvSata: IRQF_DISABLED is not guaranteed on shared IRQs
[ 0.850000] scsi0 : Marvell SCSI to SATA adapter
[ 0.860000] scsi1 : Marvell SCSI to SATA adapter
[ 0.870000] Loading Marvell Ethernet Driver:
[ 0.870000] o Cached descriptors in DRAM
[ 0.880000] o DRAM SW cache-coherency
[ 0.880000] o 1 Giga ports supported
[ 0.880000] o Single RX Queue support - ETH_DEF_RXQ=0
[ 0.890000] o Single TX Queue support - ETH_DEF_TXQ=0
[ 0.890000] o TCP segmentation offload (TSO) supported
[ 0.900000] o Large Receive offload (LRO) supported
[ 0.900000] o Receive checksum offload supported
[ 0.910000] o Transmit checksum offload supported
[ 0.910000] o Network Fast Processing (Routing) supported - (Disabled)
[ 0.920000] o Driver ERROR statistics enabled
[ 0.930000] o Proc tool API enabled
[ 0.930000] o SKB Reuse supported - (Disabled)
[ 0.930000] o SKB Recycle supported - (Disabled)
[ 0.940000] o Rx descripors: q0=128
[ 0.940000] o Tx descripors: q0=532
[ 0.950000] o Loading network interface(s):
[ 0.950000] o register under mv88fx_eth platform
[ 0.960000] o eth0, ifindex = 2, GbE port = 0
[ 0.960000]
[ 0.960000] mvFpRuleDb (c45b2000): 1024 entries, 4096 bytes
[ 0.970000] Counter=0, opIdx=6, overhead=16
[ 0.970000] Counter=1, opIdx=2, overhead=0
[ 0.980000] Counter=2, opIdx=1, overhead=18
[ 0.980000] Counter=3, opIdx=2, overhead=0
[ 0.990000] tun: Universal TUN/TAP device driver, 1.6
[ 0.990000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.000000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3,3V 8-bit)
[ 1.010000] Scanning device for bad blocks
[ 1.030000] Bad eraseblock 331 at 0x000002960000
[ 1.060000] Using static partition definition
[ 1.070000] Creating 5 MTD partitions on "nand_mtd":
[ 1.070000] 0x000000000000-0x000000200000 : "u-boot"
[ 1.080000] 0x000000200000-0x000000500000 : "uImage"
[ 1.080000] 0x000000500000-0x000000800000 : "uImage2"
[ 1.090000] 0x000000800000-0x000001000000 : "failsafe"
[ 1.090000] 0x000001000000-0x000008000000 : "root"
[ 1.100000] UBI: attaching mtd4 to ubi0
[ 1.100000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.110000] UBI: logical eraseblock size: 126976 bytes
[ 1.120000] UBI: smallest flash I/O unit: 2048
[ 1.120000] UBI: sub-page size: 512
[ 1.120000] UBI: VID header offset: 2048 (aligned 2048)
[ 1.130000] UBI: data offset: 4096
[ 1.360000] UBI: attached mtd4 to ubi0
[ 1.360000] UBI: MTD device name: "root"
[ 1.360000] UBI: MTD device size: 112 MiB
[ 1.370000] UBI: number of good PEBs: 895
[ 1.370000] UBI: number of bad PEBs: 1
[ 1.380000] UBI: max. allowed volumes: 128
[ 1.380000] UBI: wear-leveling threshold: 4096
[ 1.390000] UBI: number of internal volumes: 1
[ 1.390000] UBI: number of user volumes: 1
[ 1.400000] UBI: available PEBs: 0
[ 1.400000] UBI: total number of reserved PEBs: 895
[ 1.410000] UBI: number of PEBs reserved for bad PEB handling: 8
[ 1.410000] UBI: max/mean erase counter: 1/0
[ 1.420000] UBI: image sequence number: 0
[ 1.420000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.430000] ehci_marvell ehci_marvell.70059: Marvell Orion EHCI
[ 1.430000] ehci_marvell ehci_marvell.70059: new USB bus registered, assigned bus number 1
[ 1.440000] UBI: background thread "ubi_bgt0d" started, PID 451
[ 1.470000] ehci_marvell ehci_marvell.70059: irq 19, io base 0xf1050100
[ 1.490000] ehci_marvell ehci_marvell.70059: USB 2.0 started, EHCI 1.00
[ 1.490000] usb usb1: configuration #1 chosen from 1 choice
[ 1.500000] hub 1-0:1.0: USB hub found
[ 1.500000] hub 1-0:1.0: 1 port detected
[ 1.510000] Initializing USB Mass Storage driver...
[ 1.510000] usbcore: registered new interface driver usb-storage
[ 1.520000] USB Mass Storage support registered.
[ 1.520000] usbcore: registered new interface driver ums-datafab
[ 1.530000] usbcore: registered new interface driver ums-freecom
[ 1.530000] usbcore: registered new interface driver ums-jumpshot
[ 1.540000] usbcore: registered new interface driver ums-sddr09
[ 1.550000] usbcore: registered new interface driver ums-sddr55
[ 1.550000] usbcore: registered new interface driver ums-usbat
[ 1.560000] mice: PS/2 mouse device common for all mice
[ 1.560000] i2c /dev entries driver
[ 1.580000] sdhci: Secure Digital Host Controller Interface driver
[ 1.580000] sdhci: Copyright(c) Pierre Ossman
[ 1.590000] mmc0: mvsdio driver initialized, using GPIO 27 for card detection
[ 1.600000] usbcore: registered new interface driver usbhid
[ 1.600000] usbhid: v2.6:USB HID core driver
[ 1.610000] TCP cubic registered
[ 1.610000] NET: Registered protocol family 17
[ 1.620000] RPC: Registered udp transport module.
[ 1.620000] RPC: Registered tcp transport module.
[ 1.630000] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 1.760000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 1.760000] UBIFS: file system size: 110723072 bytes (108128 KiB, 105 MiB, 872 LEBs)
[ 1.770000] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 1.780000] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 1.780000] UBIFS: default compressor: lzo
[ 1.790000] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 1.790000] VFS: Mounted root (ubifs filesystem) on device 0:11.
[ 1.800000] Freeing init memory: 124K
[ 1.860000] mmc0: new SD card at address 0001
[ 1.890000] mmcblk0: mmc0:0001 256MB 241 MiB
[ 1.890000] mmcblk0: p1
[ 4.200000] eth0: started
udhcpc (v1.16.1) started
HWADDR 00 0x25 0x31 0x03 0xe7 0xa7
PIP0 231
PIP1 167
cat: can't open '/etc/resolv.conf': No such file or directory
route: SIOCDELRT: No such process
grep: /etc/resolv.conf: No such file or directory
Sending discover...
Sending discover...
Sending discover...
PIP0 231
PIP1 167
No lease, forking to background
modprobe: module 'vfat' not found
[ 13.830000] ufsd: module license 'Commercial product' taints kernel.
[ 13.840000] Disabling lock debugging due to kernel taint
[ 13.870000] ufsd: driver 8.5 (NTFS4LINUX_U85_017_S[2011-08-17-16:51:48]) LBD=ON with delayalloc with ioctl loaded at bf000000
[ 13.870000] NTFS support included
[ 13.870000] Hfs+/HfsX support included
[ 13.870000] For 'CloudEngines_PogoPlug_2011-08-03'
Loading rt3070sta.ko: [ 14.210000] rtusb init rt2870 --->
[ 14.220000] usbcore: registered new interface driver rt2870
Success
Loading xce.ko: [ 14.240000] Cloud Engines XCE Init [Version: 3.1.99.12]
[ 14.250000] XCE: CPU MEMORY MAP:
[ 14.250000] XCE: -- 0x00001000 - 0xbeffffff (3055 MB) User Space Mappings
[ 14.260000] XCE: -- 0xbf000000 - 0xbfffffff ( 16 MB) Kernel module space
[ 14.270000] XCE: -- 0xc0000000 - 0xc7ffffff ( 128 MB) Kernel direct-mapped ram
[ 14.270000] XCE: -- 0xc8800000 - 0xe7ffffff ( 504 MB) Kernel vmalloc space
[ 14.280000] XCE: -- 0xe8000000 - 0xfeffffff ( 367 MB) Kernel platform space
[ 14.290000] XCE: CPU FEATURES:
[ 14.290000] XCE: -- I Cache: enabled
[ 14.290000] XCE: -- D Cache: enabled
[ 14.300000] XCE: -- Branch Predict: disabled
[ 14.300000] XCE: -- MMU: enabled
[ 14.310000] XCE: -- Alignment Abort: enabled
[ 14.320000] XCE: BLPARAMS: -- Loading properties [c4cdfefc].
[ 14.320000] XCE: BLPARAMS: -- MTD @ [c45c0c00].
[ 14.330000] XCE: BLPARAMS: Locating parameter block...
[ 14.330000] XCE: BLPARAMS: reading 2048 bytes @ a0000
[ 14.340000] XCE: Loaded Property Size: 2048
[ 14.340000] XCE: - 'cesvcid' -> 'FQGAJJKHKXFSQQTN5KFH78Q7JJ'
[ 14.350000] XCE: - 'ceboardver' -> 'PPV4A1'
[ 14.350000] XCE: -- ICache Prefetch: enabled
[ 14.360000] XCE: -- DCache Prefetch: enabled
[ 14.360000] XCE: -- L2 Cache: enabled
[ 14.370000] XCE: -- L2 Prefetch: disabled
[ 14.370000] XCE: -- L2 Writethrough: disabled
[ 14.380000] XCE: -- Write Allocate: disabled
[ 14.380000] XCE: -- Streaming: disabled
[ 14.390000] XCE: Current GPIO State:
[ 14.390000] XCE: GPIO L OUT: 0x01e18400
[ 14.390000] XCE: GPIO L OE: 0xfe004800
[ 14.400000] XCE: GPIO L BLINK: 0x00000000
[ 14.400000] XCE: GPIO L POL: 0x00000000
[ 14.410000] XCE: GPIO L IN: 0x21e00000
[ 14.410000] XCE: GPIO H OUT: 0x00000008
[ 14.410000] XCE: GPIO H OE: 0x00000005
[ 14.420000] XCE: GPIO H BLINK: 0x00000000
[ 14.420000] XCE: GPIO H POL: 0x00000000
[ 14.430000] XCE: GPIO H IN: 0x00000008
Success
Starting hbplug: Success
/ # [ 14.520000] XCE: BLPARAMS: -- Loading properties [c4cdfecc].
[ 14.520000] XCE: BLPARAMS: -- MTD @ [c45c0c00].
[ 14.530000] XCE: BLPARAMS: Locating parameter block...
[ 14.530000] XCE: BLPARAMS: reading 2048 bytes @ a0000
[ 14.540000] XCE: BLPARAMS: reading 2048 bytes @ a0800
[ 14.550000] XCE: BLPARAMS: reading 2048 bytes @ a1000
[ 14.550000] XCE: BLPARAMS: reading 2048 bytes @ a1800
[ 19.820000] XCE: XCE: LED -> DISCONNECTED
[ 19.840000] kjournald starting. Commit interval 5 seconds
[ 19.850000] EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
[ 19.960000] EXT3 FS on mmcblk0p1, internal journal
[ 19.970000] EXT3-fs: recovery complete.
[ 19.970000] EXT3-fs: mounted filesystem with writeback data mode. |
