查看: 5651|回复: 6
AXI-STREAM 模式
发表于 2019-4-9 21:37 | 显示全部楼层 |阅读模式
5 E* n2 q" H4 q& E+ C3 @* R4 c1 \) Q) D
https://blog.csdn.net/xdczj/article/details/72058100
 楼主| 发表于 2019-4-11 21:09 | 显示全部楼层
 楼主| 发表于 2019-4-11 21:11 | 显示全部楼层
+ K' A2 a0 X' G7 ~; {
`timescale 1 ns / 1 ps$ A: D- ^+ h2 u' V2 p
: D8 w6 w* k* t" u: ]
        module AXI_STREAM_IP_v1_0_S00_AXIS #6 S% X8 u; W( i
        (7 k  T, b  ^% b1 V8 I
                // Users to add parameters here
8 h9 C0 p* x: \5 n( s
9 G0 d! _4 B& l% w; X( r# M2 {                // User parameters ends( e; T2 ~4 D0 p& S& r7 k
                // Do not modify the parameters beyond this line
. L: u1 \+ R7 C$ c! n: d# C+ w2 P  u
2 R3 |0 R9 |) q+ K, c                // AXI4Stream sink: Data Width
/ F* V# A3 r, U0 R                parameter integer C_S_AXIS_TDATA_WIDTH        = 32
+ O- z& X5 s0 o+ h        )3 O/ m, ?. ?  S7 Y' `+ S
& X/ x7 p! O7 K                // Users to add ports here, p/ v0 Z& g2 c& ?* m
4 ?+ Y# }  f, F+ I+ C/ `                // User ports ends+ F3 n. k/ T4 U6 m& s( K1 t) t
                // Do not modify the ports beyond this line( g0 W6 L& P7 X+ K6 f
7 j) T$ `/ `3 P
                // AXI4Stream sink: Clock
4 v, u5 S5 ~) Y) P: @: o                input wire  S_AXIS_ACLK,
& ~0 f' c, ]8 Q/ e: u6 r; C                // AXI4Stream sink: Reset
+ a3 W; K+ Q" u" L) i1 c8 [( a                input wire  S_AXIS_ARESETN,
* X, j) V) W' v+ a1 o/ J/ E* X$ z                // Ready to accept data in
( s( H# C- l# [4 Y% g2 c$ q                output wire  S_AXIS_TREADY,  v1 G3 x9 F3 H  c6 Z
                // Data in
7 L' g6 a- ^* O2 [; c( l& D9 g% }. J                input wire [C_S_AXIS_TDATA_WIDTH-1 : 0] S_AXIS_TDATA,5 |  ]/ U6 h: {) u( w
                // Byte qualifier
! o: h* F- _5 h1 w. Q( m  S. E                input wire [(C_S_AXIS_TDATA_WIDTH/8)-1 : 0] S_AXIS_TSTRB,
& @! h. f5 E* F( B) F) R# Y                // Indicates boundary of last packet
# a: d/ S: n  i8 B% T1 |- s* h                input wire  S_AXIS_TLAST,
% K5 L  _% F% Y                // Data is in valid
8 L% ^& G! p1 W$ X) u4 j5 F" r' M                input wire  S_AXIS_TVALID
. b+ a6 h* B# y* r        );
. e% t, ^7 g% M; H        // function called clogb2 that returns an integer which has the
9 v* \1 M8 ]4 J9 E# d( j) `7 q9 d9 N        // value of the ceiling of the log base 2.
7 L4 \) H% m, @        function integer clogb2 (input integer bit_depth);
( Q' `: \! R5 y: I) ^$ Z1 p          begin
! |* W( D6 ]! A0 k2 a1 U- X1 C            for(clogb2=0; bit_depth>0; clogb2=clogb2+1)
; U; b/ ^  W4 s: ~) H: M: |* c              bit_depth = bit_depth >> 1;1 B4 c. |8 D5 z4 P! K, O3 L
          end
* z# J: \, M$ {! P9 ]        endfunction, o& Z2 n( L% [
. l6 {+ N  E2 J0 q7 |5 z1 h& D) y
        // Total number of input data.: X: N4 U6 F9 d7 E1 X4 r
        localparam NUMBER_OF_INPUT_WORDS  = 8;9 Y6 O* v! G. ?
        // bit_num gives the minimum number of bits needed to address 'NUMBER_OF_INPUT_WORDS' size of FIFO.4 C; C% h. l5 j6 E- Z+ x
        localparam bit_num  = clogb2(NUMBER_OF_INPUT_WORDS-1);
& y/ h; S2 w0 x- q* K. J5 h        // Define the states of state machine
' s  _2 P2 M) q        // The control state machine oversees the writing of input streaming data to the FIFO,) ?% |7 z% v. t7 s% ?
        // and outputs the streaming data from the FIFO/ X+ x, h: [5 V3 \0 ~9 G' g- {, w4 u
        parameter [1:0] IDLE = 1'b0,        // This is the initial/idle state ! t% b, O4 s! ^0 w2 g  l$ c
+ C. r" @7 ^0 E  @
                        WRITE_FIFO  = 1'b1; // In this state FIFO is written with the
1 ~8 K! Q6 p3 S. ~( D                                            // input stream data S_AXIS_TDATA
' y6 \* ^/ ], w2 ]/ \: O        wire          axis_tready;
- d/ y1 g& h! [7 H  a- }3 S        // State variable$ ?0 [, a- O0 G: F$ c- R
        reg mst_exec_state;  ; d  a& B6 S9 F; b2 T& N- b
        // FIFO implementation signals
* L) s: e, X- P9 m2 J5 i, V3 `        genvar byte_index;     & s9 N* A1 \  Q' p+ K2 ]
        // FIFO write enable6 l6 O/ J  Y" [0 F  ^( A6 N
        wire fifo_wren;. D0 s* z* _* n( M% k2 `+ S* a
        // FIFO full flag- E6 ]8 s, D" J
        reg fifo_full_flag;
: u" a/ R, p0 T# ~7 M% T+ I        // FIFO write pointer
8 v8 {( B9 O9 b! A/ o        reg [bit_num-1:0] write_pointer;' M4 p! D& k3 o6 Z& e
        // sink has accepted all the streaming data and stored in FIFO: u" K: Q! Q: ~3 P
          reg writes_done;0 O  S$ M& Z  }2 r; a$ ^. |$ B5 [
        // I/O Connections assignments
, m: v! k' Y; D3 k0 j. B$ v" z0 O: d* a/ P4 f% A
        assign S_AXIS_TREADY        = axis_tready;
5 U( o2 k+ x4 n2 e; ?  K* J        // Control state machine implementation2 K4 H- c* F, j* T8 s
        always @(posedge S_AXIS_ACLK)
+ E; K( ~8 E! N& a0 o+ J        begin
1 N+ W" z: K- q( c$ r          if (!S_AXIS_ARESETN) ' t  x1 D8 F( X+ W4 U. D5 o
          // Synchronous reset (active low)
& R) M1 w5 k0 _4 o            begin9 t3 x1 y% u2 F" c2 z
              mst_exec_state <= IDLE;
. Q) M0 I3 \8 u! s7 u& t* x            end  : K" `4 `: m; ]" d' p7 W
          else
; \1 t# u* O) p3 ?/ `            case (mst_exec_state)5 C& x3 ]& y; O/ V" n: Z( d5 ]( r( Y
              IDLE: / l0 U2 D. c/ a+ z8 x
                // The sink starts accepting tdata when
) m* V# w# G$ j6 @                // there tvalid is asserted to mark the
$ I* @* }" J1 ]' E/ f                // presence of valid streaming data
2 ^8 J, }0 r6 ~% E! A                  if (S_AXIS_TVALID)
2 e' I0 f2 k) Y# H# Y                    begin
2 \# x1 G) {' F. A0 C/ O7 q$ c$ B                      mst_exec_state <= WRITE_FIFO;4 c9 G% J, F: }1 {0 A; y$ A& X
                    end
! p: f1 w. a4 [/ G% _                  else& X' ~5 {1 d; R" P' q
                    begin# R- D" y: x& K+ Y
                      mst_exec_state <= IDLE;) F1 f( P; v5 f5 k
                    end. F2 Z, l" O; y. H7 W0 l
              WRITE_FIFO: & J2 R6 g: N, N
                // When the sink has accepted all the streaming input data,6 w* m, H* V3 e4 R; X7 i
                // the interface swiches functionality to a streaming master* T# L1 z7 _9 b& Q
                if (writes_done)
4 ?- X1 y' y7 y                  begin
% v! A8 `5 V+ w5 V! Q                    mst_exec_state <= IDLE;
- i8 |7 [0 ]6 q: {4 @( B& ?                  end
! O9 e5 ^# K: ~7 P" K0 P: a9 j                else
/ L2 _% ?; d+ h6 P  T3 q& r                  begin
/ W) U+ P3 ~5 }1 X7 q8 F* D- E                    // The sink accepts and stores tdata
5 d1 L' c9 p4 _- [9 `- T                    // into FIFO
: p$ ?% [' i: R                    mst_exec_state <= WRITE_FIFO;
% K* p3 w) l6 x. U5 I1 M" h                  end
; L! `6 y  i+ f  Q" o7 a' G+ o1 Q" G$ t/ @. R; G! C
            endcase
* E, o0 x$ f7 z6 S* Z        end3 D3 m0 o% m+ f- {+ H
        // AXI Streaming Sink 3 Y. j$ `/ s  `* x
        // * U7 z' b. K' e
        // The example design sink is always ready to accept the S_AXIS_TDATA  until" R3 K4 {: z  c6 ~! L  J
        // the FIFO is not filled with NUMBER_OF_INPUT_WORDS number of input words.; V' ]7 {# ^- S+ X* @$ {5 H
        assign axis_tready = ((mst_exec_state == WRITE_FIFO) && (write_pointer <= NUMBER_OF_INPUT_WORDS-1));4 h. W7 Y: J6 E  }0 j  W  z: t4 n5 z2 I
. o! w  P: W7 x        always@(posedge S_AXIS_ACLK)
. W/ T4 J' t+ S. [7 B4 ~        begin# J' j* N2 j7 U# u" m& z& Y
          if(!S_AXIS_ARESETN)# h' f( B! _- {) A. t
            begin9 b$ X/ S' J' B$ `$ H8 l, Y4 T5 r2 D
              write_pointer <= 0;
% w6 \& c6 L3 T* S              writes_done <= 1'b0;9 q, B, I% M* F2 w, y, ^+ r: v' `
            end  : K! r1 Q4 Y, {5 J4 p- L
          else! q" a7 H5 p" e% X
            if (write_pointer <= NUMBER_OF_INPUT_WORDS-1)
& q; R! A2 |9 R. `- u$ x; R              begin- A4 q" F5 g. ~  B; I4 F3 f. J
                if (fifo_wren)6 o% ]- ~1 `/ ?9 Q7 `' [' z! H' `  g) d
                  begin
7 @9 e% Q7 Y  U% x8 {& H0 x                    // write pointer is incremented after every write to the FIFO! V/ l" K/ q1 i" Z+ E' ~& C+ V
                    // when FIFO write signal is enabled.
  o" ?5 }, n- ~. w                    write_pointer <= write_pointer + 1;
  N' \; T3 H" @& c, ^- k                    writes_done <= 1'b0;
- b0 Y' Y# R$ k8 E9 q& @& @8 ?1 y4 X                  end) A6 |# b5 n, |% i0 |
                  if ((write_pointer == NUMBER_OF_INPUT_WORDS-1)|| S_AXIS_TLAST)
- h6 e: n, ]* [' S7 g8 Z5 N/ }0 }                    begin7 E# r% W$ `5 c3 H* u* E  o% b% Y( N& {
                      // reads_done is asserted when NUMBER_OF_INPUT_WORDS numbers of streaming data
4 p; p9 Q# Z3 A! H  `                      // has been written to the FIFO which is also marked by S_AXIS_TLAST(kept for optional usage).
% }/ r7 R* Y% c7 v                      writes_done <= 1'b1;% i; b! ^  v5 j, h
                    end# B  Y8 e7 B* ?/ a
              end  & M& D$ Q* M" f- {* B: ~
        end8 m8 q" [: P% ^! ]
( }- [$ ~9 ]- t$ [" @        // FIFO write enable generation$ N- Z$ Q# w, C. c7 r* o, R
        assign fifo_wren = S_AXIS_TVALID && axis_tready;0 l" W. b% ?: s: _/ v
: c- M. d4 j- j1 r
        // FIFO Implementation
( m  W, h/ }# m" M0 ?* [        generate 8 O$ M* [9 C; d7 W5 a5 l7 c% S0 z, q! ?# x
          for(byte_index=0; byte_index<= (C_S_AXIS_TDATA_WIDTH/8-1); byte_index=byte_index+1)+ Y5 k' [4 w6 S8 l
          begin:FIFO_GEN
7 ]7 b$ W2 U8 s1 j  r/ y) z
4 b( Z6 B7 l' P1 k            reg  [(C_S_AXIS_TDATA_WIDTH/4)-1:0] stream_data_fifo [0 : NUMBER_OF_INPUT_WORDS-1];7 s/ f6 ?1 y) b
# E1 U  f" N/ Y9 Q3 z2 D' o* F
            // Streaming input data is stored in FIFO
: I2 p. V8 N# d5 g1 E
5 q, `. f, G* C- w0 T7 F) N1 S7 O            always @( posedge S_AXIS_ACLK )2 C$ \' z' ^; t* H# H2 q
            begin2 L* [/ r6 P+ J; M5 o, e
              if (fifo_wren)// && S_AXIS_TSTRB[byte_index])
$ B( A8 z1 b9 q* b4 y" j                begin" d9 J. m! w7 ]  t! @5 _
                  stream_data_fifo[write_pointer] <= S_AXIS_TDATA[(byte_index*8+7) -: 8];8 q1 u* }5 S0 a1 `8 M
                end
- j0 b, u* @2 v* m            end  : ~/ ]" g; Q; r" X; J: J
          end                " o4 o2 v8 A7 x; q- L
        endgenerate
: V1 F; g# I# t( u, b- c( ]9 A; S" M/ D) O) P
        // Add user logic here0 B# C. j$ [: r8 J
; ]- M6 O0 {5 Q  g        // User logic ends9 I0 L' H1 b5 V4 s" H" L0 @
1 g/ K. t' B$ s6 g$ c: Q3 x        endmodule
' r$ H% I% H* a( K4 _! d8 m- |8 o- h' }+ Y
  P- Y# @* m( W' Z+ O6 h; U: S4 K& @
 楼主| 发表于 2019-4-11 21:14 | 显示全部楼层
axis_timming.png " Z' V/ t' p8 k2 \, ~9 e
 楼主| 发表于 2019-4-11 21:19 | 显示全部楼层
Verilog的generate的用法" i, t) o% z7 e% u% K/ C
6 h+ v8 Q& {$ ]0 U( X生成语句可以动态的生成verilog代码,当对矢量中的多个位进行重复操作时,或者当进行多个模块的实例引用的重复操作时,或者根据参数的定义来确定程序中是否应该包含某段Verilog代码的时候,使用生成语句能大大简化程序的编写过程。, k4 i' C8 g& y6 X1 ~) A/ a
       生成语句生成的实例范围,关键字generate-endgenerate用来指定该范围。生成实例可以是以下的一个或多个类型:: C0 Y  |, I8 ~7 O! R
       (1)模块;(2)用户定义原语;(3)门级语句;(4)连续赋值语句;(5)initial和always块。4 V- J  m- g' b4 Y1 {+ b! z
       generate语句有generate-for,generate-if,generate-case三种语句。( Q* N# U  J0 f) A) E  V' g
generate-for语句$ m5 x: G' e2 D7 }9 u4 w/ b
(1) 必须有genvar关键字定义for语句的变量。8 q6 u4 r: ?+ ^0 d, f
(2)for语句的内容必须加begin和end(即使就一句)。$ h* e4 U% ]+ G$ E
(3)for语句必须有个名字。" i) f; b6 v. g1 U+ b
例1:assign语句实现7 E' B: B+ a. E2 c) l
module test(bin,gray);
+ r+ T' l) M8 d1 n2 I$ O: _5 {       parameter SIZE=8;
( q5 F6 o; i+ Z7 E3 O       output [SIZE-1:0] bin;% a% n( p9 |- D; ?; i  j
       input [SIZE-1:0] gray;
% P$ V# |" @2 f% v/ n% r       genvar i; //genvar i;也可以定义到generate语句里面: w, e9 G. a7 Q4 f1 C$ Y% @
       generate5 [' R# h: `7 V! e
              for(i=0;i<SIZE;i=i+1)
" k2 C6 w5 c. F! K' Z" I9 Z              begin:bit# d2 l& C" A. w
                     assign bin=^gray[SIZE-1:i];! \9 I# j! B4 |& S; h- _
              end( s4 S/ }6 x8 H, k9 B6 K
       endgenerate
7 s' T7 u3 D$ _9 ?7 X4 T  m* Z( |endmodule
7 y7 v5 `2 W. V等同于下面语句
, ~, c: c1 d/ V+ ~0 f, |+ Iassign bin[0]=^gray[SIZE-1:0];; `8 g- o1 Z5 P  L/ L/ L' X& N! y
assign bin[1]=^gray[SIZE-1:1];) \  q: m2 e; b9 q) t3 D
assign bin[2]=^gray[SIZE-1:2];. ]1 \$ Z! r5 D. C: {
assign bin[3]=^gray[SIZE-1:3];
/ _% s. O! D6 c6 s3 Q  q$ a1 ]assign bin[4]=^gray[SIZE-1:4];2 W# G( g9 r# m9 L8 q3 I' F4 H' @
assign bin[5]=^gray[SIZE-1:5];" {) O  g5 B: \2 h8 n2 s1 f
assign bin[6]=^gray[SIZE-1:6];6 }- H! P$ K+ [6 G. Q
assign bin[7]=^gray[SIZE-1:7];- {/ K6 c- V* z$ d5 q3 v4 X
例2:; C9 O% w1 s& F
generate
" V1 |. ]' h, q. C2 R) o. W+ Q       genvar i;
& ^& S9 N; B. z* f. ]       for(i=0;i<SIZE;i=i+1)
9 ~  y( _/ C. w, {& X6 I       begin:shifter0 @- ^5 P0 v8 L/ l( t
              always@(posedge clk)
. f. Y- t- R8 F+ u0 Q' o) D, w                     shifter<=(i==0)?din:shifter[i-1];$ F: [8 Y2 J5 j" a; e2 F/ V
       end, N! T9 ?8 J2 d7 S, T6 }
endgenerate
8 u5 v1 _. G5 P% i; W- e% d相当于& m3 [/ i& @( q7 O2 T
always@(posedge clk)7 l2 j' p7 U* S& t5 B" ^9 C
       shifter[0]<=din;6 p# n6 l, ^/ `0 b
always@(posedge clk). S6 ~5 f7 X1 R; z) [) I
       shifter[1]<=shifter[0];
$ ^! [; s/ o" e& calways@(posedge clk)
- _9 N0 a) L& [% D5 k9 h       shifter[2]<=shifter[1];
8 G- g" V( N- N* a- q" f- s.................3 `: t& _; d% K
       ......................0 q9 a; E) |2 Y" O! K, ^
always@(posedge clk)# `0 @5 b* W( h5 y8 w% a
       shifter[SIZE]<=shifter[SIZE-1];
5 Z0 S6 y/ D3 A' t8 Igenerate-if,generate-case和generate-for语句类似。' b5 U( \1 R4 {+ v
6 F1 R# v! ~1 G3 Y  ?, H转载自:http://lihaichuan.blog.51cto.com/498079/1118866- _* G5 s! l' {. n3 b8 n  o' [
5 K: w% b1 G3 a, z( z& A
3 O* c* e( _9 V7 o" T# V
$ o' s; A$ u3 V' o- m' \
 楼主| 发表于 2019-4-12 10:48 | 显示全部楼层
Verilog之function使用说明8 r- C; f! D$ m7 p  }4 _) c1 _3 V- E
1.function的定义6 i" v4 i/ u5 ]3 v8 }
; N6 l# g  ~8 E" U- I) W  {0 H- Qfunction [range] function_name;
3 c, b% h" i: b( h6 ?    input_declaration
2 g% t% s' e) b* Z* r    other_declarations / Y$ P0 n9 {& x' n+ g4 X
    procedural_statement " t0 n4 S4 m6 l- k
endfunction
2 V! W4 G+ d! n. Y
( P- S' i6 C6 {0 H: m/ p! B(1)函数通过关键词 function 和 endfunction 定义;$ S; R5 Q. ~4 l6 e- F0 p6 W6 \
(2)不允许输出端口声明(包括输出和双向端口) ;但可以有多个输入端口;' ^; X0 r% x+ o4 I6 l; b7 t
' p8 a7 i) d2 H/ U: B! U
(3)[range]参数指定函数返回值的类型或位宽,是一个可选项,若没有指定,默认缺省值为宽度 1 比特的寄存器数据8 {9 R2 ^. [* k6 N- B
+ h2 s4 p9 o9 L(4)function_name为所定义函数的名称,对函数的调用也是通过函数名完成的,并在函数结构体内部代表一个内部变量,函数调用的返回值就是通过函数名变量传递给调用语句。函数定义在函数内部会隐式定义一个寄存器变量,该寄存器变量和函数同名并且位宽也一致。函数通过在函数定义中对该寄存器的显式赋值来返回函数计算结果
$ ]4 h+ S7 m8 b  {7 f9 X
. E5 U" o& l$ \(5)input_declaration 为各个输入端口的位宽和类型进行说明,在函数定义中至少要有一个输入端口) i  h/ z  _: ^+ w- P
3 t. l2 F/ B0 }: M' p
: T" w- p. {0 {4 S2 @8 z" }; z$ T  P" \5 R
注意事项:; L& S. P+ V5 l3 _" Y0 A
/ D2 k9 B" }# [
(1)函数定义只能在模块中完成,不能出现在过程块中;( T& D) V) s# p8 A
2 d4 b0 P/ N, M% H$ b$ s(2)函数至少要有一个输入端口;不能包含输出端口和双向端口;! @3 o% s* p! `' H& ?
: A* R( A& L, `4 Q5 V(3) 在函数结构中, 不能使用任何形式的时间控制语句 (#、 wait 等) , 也不能使用 disable中止语句;) ]+ V2 P7 e! v  h; M
6 w* {4 a: a1 p6 i1 Z(4)函数定义结构体中不能出现过程块语句(always 语句);6 g# p8 ?8 [: m- P0 H( d$ J- [% H# e
8 w+ i7 G+ }+ {
(5)函数内部可以调用函数,但不能调用任务。" e5 o+ U# q) c; z& N- Q
0 U7 C. S5 Z6 }, T' ]2.函数的调用1 ~! p- y% ~" L* }$ I( }
8 J* h9 G, ~  e$ \3 K! d% v
    func_name(expr1, expr2, ........., exprN),
% B4 o) ^7 u5 T1 V! U0 ?9 b6 w4 S
    expr1, expr2, ......exprN是传递给函数的输入参数列表,该输入参数列表的顺序必须与函数定义时声明其输入的顺序相同.
5 z" j" \8 |/ u& J* d! z4 P; n/ D- \2 V! u& }/ i
! b- q4 ?# Q8 P; U# Z
, a+ w) u1 e! Z' l  在函数调用中,有下列几点需要注意: ) X! P& `! X/ P9 ~
  (1)函数调用可以在过程块中完成,也可以在 assign 这样的连续赋值语句中出现。 " }) n0 t2 K3 T/ u2 d) V) V  M) a
  (2)函数调用语句不能单独作为一条语句出现,只能作为赋值语句的右端操作数。& [. x' S# {# O2 l/ [. l9 h
& T4 o% Q0 {" n& ?" b8 `% D     如果task或者function在不同地方并发调用,则它们使用同一组变量个内存地址,存在冲突产生错误。为避免错误,声明时在task和function后面加上automatic 关键字。如:task automatic task_id ........ endtask3 ]" V/ r7 w/ a" ?$ \8 i& O3 k0 N/ @
7 Z; _, H9 b/ H9 H$ X2 l
调用例子:
# e! l4 e& v; I/ j
6 Z0 O0 E% U5 ^& r) C- [- Q, L. A在过程语句always模块内调用,
8 u  {, l$ N& f0 n- U! u. l$ ?0 l3 L$ H. u9 X0 I. E9 @% F/ I7 u
8 L2 X  T, r) E`timescale 1ns / 100ps5 Z9 Q$ ?* h- T1 ~8 J0 ^" E
* E$ d, u$ Q; y( l+ y9 \4 G) s
8 p" }# [6 W7 k2 F  P3 pmodule lfsr (clk, ena, nReset, rst, q);3 k# p+ D# f% B% A' N
" s% q# }3 y( k( N6 I5 c, o
        //7 v1 o2 [8 T( `: S0 z
        // parameters
. ?9 Z3 B& H; Q: }- Q6 u. ^9 z" \        //9 X$ G! @! R( P8 L* Y
        parameter [3:0] TAPS   = 8;                // number of flip-flops in LFSR
( Y- o5 U% n+ e; q' s9 e& M1 M
" h8 K( \/ l2 K3 r/ p' s- y! I        //6 e" O) u) J4 ^/ S+ V5 n. I' C
        // inputs & outputs" k8 u& K' _+ w: }
7 p  y( t) k! f( R. u3 V  G; ~        input clk;                                 // master clock
2 A6 l3 J! d# p* d' h        input ena;                                 // clock enable
; r" x0 h2 [6 y4 l1 B0 a. J- ?. z        input nReset;                              // asynchronous active low reset
5 f; F4 Q) E6 ~+ n( N# z        input rst;                                 // synchronous active high reset/ P/ @& s) V( d' b3 x1 p/ h
* i/ v# c- c2 z; Q# {8 e4 T6 o        output [TAPS:1] q;                         // LFSR output% T2 O1 O; c+ _7 m" s
        reg [TAPS:1] q;! w$ z9 z0 w8 e: k
2 l# p; z6 V/ X- j# c1 I        //9 K; R. k2 I' _6 I1 G* k7 E
        // Module body$ y4 t3 G/ t2 M" F
1 K8 N/ O/ H  D6 Z6 B        function lsb;
' M8 D, C9 N( S- a" q% I- n" b           input [TAPS-1:0] q;
7 l+ @' O& @/ Q* U8 W* O# Q$ ~3 E
% @3 v# O1 G( C& }           case (TAPS)
: j( X1 v) x! L               2: lsb = ~q[0];
$ V$ [! h. R% x7 a2 X' S               3: lsb = q[3] ^ q[2];
8 s9 K3 Q7 y# Q. {* C" j3 U               4: lsb = q[4] ^ q[3];, h6 [  s1 c; ~2 w# j6 }. ^
               5: lsb = q[5] ^ q[3];' x9 x/ ~; ~1 w# D6 `  T9 I
               6: lsb = q[6] ^ q[5];. D6 J9 s9 c" [% Q
               7: lsb = q[7] ^ q[6];
( Q3 J& L1 i$ ~* E; y2 K' Z               8: lsb = q[8] ^ q[6] ^ q[5] ^ q[4];
- M# h5 r  v$ ]* I. f2 `) o8 K               9: lsb = q[9] ^ q[5];) d) j; Z2 W. @* Y7 L9 Z" W
              10: lsb = q[10] ^ q[7];
. W& ~* M$ S1 s: A. z( d6 ]8 K              11: lsb = q[11] ^ q[9];, Z0 {% |0 O9 _) f6 u
              12: lsb = q[12] ^ q[6] ^ q[4] ^ q[1];' H# Y3 y6 C; T# O: W( z+ ~
              13: lsb = q[13] ^ q[4] ^ q[3] ^ q[1];
8 g# W. J8 C$ p              14: lsb = q[14] ^ q[5] ^ q[3] ^ q[1];
' `" F8 z+ t" F              15: lsb = q[15] ^ q[14];/ A) ^* G  |0 [+ I
              16: lsb = q[16] ^ q[15] ^ q[13] ^ q[4];, d  M# e0 S/ f' N2 G' \2 m
           endcase
- \7 y5 M# ]) d1 S1 w6 a        endfunction
) u, k: q* \/ C9 m- J) V8 s, a  f& h
        always @(posedge clk or negedge nReset)
3 g+ Y6 H* a- y          if (~nReset)        q <= #1 0;* L2 E2 t& l  \' B1 L$ B
          else if (rst)        q <= #1 0;
; v5 a7 I2 w9 _; L, t" v) J          else if (ena)        q <= #1 {q[TAPS-1:1], lsb(q)};/ y% @7 R  _5 b" C7 }
endmodule
7 ?' z. X5 V! e---------------------
0 s: c1 h& |, |% \作者:罗马教皇@ # P4 b- P4 L) u) y. G+ c. Q% Z
来源:CSDN
4 J. b$ a' I3 i7 {. J' e& Q原文:https://blog.csdn.net/HengZo/article/details/49688677 * u) Y1 Q. Y( }
版权声明:本文为博主原创文章,转载请附上博文链接!2 ^9 }! }2 j  O2 t* f  x( L) S
: G- b" L6 r3 r) x, d
8 P& s1 j* [5 c/ D+ ?$ J! [
 楼主| 发表于 2019-4-12 18:09 | 显示全部楼层
GMT+8, 2025-4-28 09:35 , Processed in 0.051599 second(s), 32 queries , Gzip On.
