查看: 2110|回复: 5
接上帖 无意搜索iphomecamera 发现好多人在用
发表于 2011-7-29 00:29 | 显示全部楼层 |阅读模式
http://camaraipsinpro.dyndns.org:8081/
http://roundgis-global.gicp.net/
剩下的都需要翻墙了 也可在google搜索iphomecamera
看来这个不安全 不适合在家里用
 楼主| 发表于 2011-7-29 00:36 | 显示全部楼层
 楼主| 发表于 2011-7-29 00:37 | 显示全部楼层
使用方法
1 Right click on a source and go to PCI / USB (WDM Driver)
2 Select IP Camera [JPEG/MJPEG]
3 Right click on the source again and go to 'source settings'.
4 Select 'Raw URL Mode'
5 Type http://192.168.0.139/image.jpg into the box (if that doesn't work try the other URL you posted)
6 Set up the username/password and FPS etc based on your camera's support
7 Make sure you select save before you click ok.
8 Restart webcamXP (mine didn't update until I restarted)
 楼主| 发表于 2011-7-29 01:06 | 显示全部楼层
发表于 2011-7-29 10:34 | 显示全部楼层
里面空荡荡,虾米都没有!
发表于 2011-7-29 18:29 | 显示全部楼层
评分
参与人数 2一乐金币 -28 收起 理由
benli -8 灌水
admin -20 恶意灌水
查看全部评分
GMT+8, 2025-4-29 18:23 , Processed in 0.049004 second(s), 31 queries , Gzip On.
