查看: 3353|回复: 3
[其他综合] 自己觉得比较好的按钮扫描程序,有仿真
发表于 2011-10-8 20:15 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define un8 unsigned char
#define un16 unsigned int
sbit Press_key = P2^0;//按键的I/O
sbit Press_key1 = P3^4;
un8 bdata Control_Port;     // 声明一个可位寻址的字节变量
sbit     new_value = Control_Port^1;   // 引用该字节变量的某一位
sbit     old_value = Control_Port^2;
sbit     new_value1 = Control_Port^3;   // 引用该字节变量的某一位
sbit     old_value1 = Control_Port^4;
sbit led=P1^0;
sbit e= P0^2;
sbit rs=P0^3;
un8 code TAB[]={"0123456789"};
void lcdinit();    //1602初始化
void lcdcom(un8 com); //1602写指令
void lcddata(un8 dat); //1602写数据
void Delay(un8 xms);
void Delay1(un16 xus);
un8 COUTER=0;
main()
  EA=1;
  ET0=1;
  TMOD|=0X01;
  TH0=(65536-60536)/256;
  TL0=(65536-60536)%256;
  TR0=1;
  //old_value=1;
// old_value1=1;
  lcdinit();
      //lcdcom(0X82);//第1行第3位
  while(1)
   lcdcom(0X80);//第1行第3位
   lcddata('n');
   lcddata(TAB[COUTER/10]);
   lcddata(TAB[COUTER%10]);
  //其他代码
/*void P_key() //按下后松开有效
     new_value =Press_key;
     if(new_value && !old_value)//识别按键。
         led=~led;
     old_value = new_value;
void Timer0_interrupt() interrupt 1 using 2
     un8    ban,can;
  TH0=(65536-65500)/256;
  TL0=(65536-65500)%256;
     if(!new_value && old_value)//识别按键。(按下即有效)
         COUTER++;
   if(100==COUTER)
    COUTER=0;
//短按减1,长按按下后先减1,按下超过25X65.5MS后每4x65.5MS减1//
     new_value1 =Press_key1;
     if(!new_value1 && old_value1)//短按立即有效.
         COUTER--;
   can=0;
   if(255==COUTER)
       COUTER=99;
  if(!new_value1&&!old_value1)  //按下未松开则每65,5MS can+1
   can++;
   if(can>25)
    ban++;
    if(4==ban)
       ban=0;
    COUTER--;
    if(255==COUTER)
         COUTER=99;
old_value1 = new_value1;
////***************Lcd初始化****************************////
void lcdinit()
  Delay(15);
   lcdcom(0x33);
    Delay(5) ;
     lcdcom(0x32);
      Delay(2);
    lcdcom(0x2); //4线模式
        Delay(1);
   lcdcom(0x06); //地址增量1,字符不动
          lcdcom(0x0C); //显示开,光标关,光标不闪
              lcdcom(0x28);
      lcdcom(0x01); //清屏
       Delay(5);
        lcdcom(0x02); //光标复位
////*********LCD写指令***********/////
//un8 temp;
// temp=com;
   P0=com|0x0f; //不需要前面两条,因为COM的值未变
    rs=0;
      Delay1(2);
       e=1;
        Delay1(2);
         e=0;
//com=temp;
  P0=(com<<4)|0x0f;
   rs=0;
     Delay1(2);
      e=1;
       Delay1(2);
        e=0;
////*****************LCD写数据**************////
// un8 temp1;
// temp1=dat;
P0=dat|0x0f;
    rs=1;
Delay1(2);
e=1;
Delay1(2);
e=0;
// dat=temp1;
P0=(dat<<4)|0x0f;
    rs=1;
Delay1(2);
e=1;
Delay1(2);
e=0;
void Delay(un8 xms)
un8 i,j;
for(i=xms;i>0;i--)
    for(j=120;j>0;j--);
un16 i,j;
for(i=xus;i>0;i--)
    for(j=25;j>0;j--);
key1好.rar (53.53 KB, 下载次数: 492)
发表于 2011-10-10 19:56 | 显示全部楼层
这要顶,谢谢分享
发表于 2011-10-10 20:25 | 显示全部楼层
谢谢分享~
发表于 2011-10-13 22:48 | 显示全部楼层
个人觉得上软件流程图比上代码好,或者代码可以作为附件,呵,让人明白设计思路很重要。
GMT+8, 2026-1-30 03:07 , Processed in 0.031057 second(s), 24 queries , Gzip On.
