查看: 2579|回复: 0
[其他综合] 初学者发个矩阵键盘的例子,借鉴了线反转法并有所改进
发表于 2011-10-10 19:59 | 显示全部楼层 |阅读模式
///*2011/10/10*///
///*WOSS1001*///
#include<reg52.h>
#define un8 unsigned char
#define un16 unsigned int
sbit e= P0^2;
sbit rs=P0^3;
un8 code TAB[]={"0123456789abcdef"};
void lcdinit();    //1602初始化
void lcdcom(un8 com); //1602写指令
void lcddata(un8 dat); //1602写数据
void Delay(un8 xms);
void Delay1(un16 xus);
un8 COUTER=0;
main()
  EA=1;
  ET0=1;
  TMOD|=0X01;
  TH0=(65536-65000)/256;
  TL0=(65536-65000)%256;
  TR0=1;
  lcdinit();
  while(1)
   lcdcom(0X80);//第1行第1位
   if(255==COUTER)
    COUTER=99;
   if(100==COUTER)
    COUTER=0;
   //lcddata('n');
   lcddata(TAB[COUTER/10]);
   lcddata(TAB[COUTER%10]);
  //其他代码
////*********每65MS扫描一次键盘*******************////
void Timer0_interrupt() interrupt 1 using 2
     un8 row,col,value,temp,n;
     P3=0x0f;
  row=P3&0x0f;
  row=row&0x0f;
     if((row!=0x0f)&&(temp=0x0f))
   n++;                 //有按钮按下后N+1,65MS后再次检测按钮是否按着相当于按下消抖
  else
          n=0;
       temp=row;
  if(2==n)           //稳定后
   P3=0xf0;
      col=P3&0xf0;
      col=col&0xf0;
   if(col!=0xf0)
       value=row|col; //键值
    switch (value)
            case 0x77:COUTER++; //只作示范,按自己需要修改
              break;
            case 0x7b:COUTER++;
              break;
            case 0x7d:COUTER++;
              break;
         case 0x7e:COUTER++;
              break;
          case 0xb7:COUTER++;
              break;
            case 0xbb:COUTER++;
              break;
         case 0xbd:COUTER++;
              break;
         case 0xbe:COUTER++;
              break;
            case 0xd7:COUTER--;
              break;
          case 0xdb:COUTER--;
              break;
          case 0xdd:COUTER--;
              break;
          case 0xde:COUTER--;
              break;
          case 0xe7:COUTER--;
              break;
          case 0xeb:COUTER--;
              break;
          case 0xed:COUTER--;
              break;
          case 0xee:COUTER--;
              break;
     default:   break;
   temp=row;
////***************Lcd初始化****************************////
void lcdinit()
  Delay(15);
   lcdcom(0x33);
    Delay(5) ;
     lcdcom(0x32);
      Delay(2);
    lcdcom(0x2); //4线模式
        Delay(1);
   lcdcom(0x06); //地址增量1,字符不动
          lcdcom(0x0C); //显示开,光标关,光标不闪
              lcdcom(0x28);
      lcdcom(0x01); //清屏
       Delay(5);
        lcdcom(0x02); //光标复位
////*********LCD写指令***********/////
//un8 temp;
// temp=com;
   P0=com|0x0f; //不需要前面两条,因为COM的值未变
    rs=0;
      Delay1(2);
       e=1;
        Delay1(2);
         e=0;
//com=temp;
  P0=(com<<4)|0x0f;
   rs=0;
     Delay1(2);
      e=1;
       Delay1(2);
        e=0;
////*****************LCD写数据**************////
// un8 temp1;
// temp1=dat;
P0=dat|0x0f;
    rs=1;
Delay1(2);
e=1;
Delay1(2);
e=0;
// dat=temp1;
P0=(dat<<4)|0x0f;
    rs=1;
Delay1(2);
e=1;
Delay1(2);
e=0;
void Delay(un8 xms)
un8 i,j;
for(i=xms;i>0;i--)
    for(j=120;j>0;j--);
un16 i,j;
for(i=xus;i>0;i--)
    for(j=25;j>0;j--);
矩阵键盘.rar (81.71 KB, 下载次数: 318)
GMT+8, 2025-11-4 20:16 , Processed in 0.034768 second(s), 21 queries , Gzip On.
