查看: 5782|回复: 8
[其他综合] PIC16f914的编译问题
发表于 2012-2-17 21:09 | 显示全部楼层 |阅读模式
平时用MPLAB_IDE_8_53。这二天写了一个PIC16F914测试程序。结果发现编译不了
经查是版本问题。重新按装了MPLAB_IDE_8_83,一切OK!
        由于文件太大,上传不了,玩PIC16F914的朋友可上网下载更新版本!
发表于 2012-2-17 21:53 | 显示全部楼层
我用 MPLAB IDE v8.76 玩过913
报警器没抢到啊
发表于 2012-2-17 22:08 | 显示全部楼层
{:3_479:}坐地收购3-6个
 楼主| 发表于 2012-2-18 11:48 | 显示全部楼层
坐地收购3-6个
pfg20999 发表于 2012-2-17 22:08 https://www.yleee.com.cn/images/common/back.gif
报警器没抢到啊
pfg20999 发表于 2012-2-17 21:53 https://www.yleee.com.cn/images/common/back.gif
            出手晚了!
发表于 2012-2-21 21:17 | 显示全部楼层
pic的,好像很复杂的样子,我前年还买了一套烧录器,结果一直没用过,(因为不会用.学也没人教.慢慢的放弃了.)
发表于 2012-2-29 18:25 | 显示全部楼层
倪工,我在用MAPLAB8.80编译你写的那个914的测试文件的时候出现了不少的错误提示,能否看看是什么原因?以前没用过这个。
Clean: Deleting intermediary and output files.
Clean: Deleted file "E:\liwei\picc\PIC16F914test\914test.mcs".
Clean: Done.
Executing: "E:\HI-TECH Software\PICC\9.50\bin\picc.exe" -C -E"MyProject.cce" "MyProject.c" -O"MyProject.obj" -Zg9 -O -ASMLIST -Q -MPLAB -16F917
Advisory[1209]   : An old MPLAB tool suite plug-in was detected. Some options may not work correctly
Advisory[1210]   : Visit www.htsoft.com or contact support@htsoft.com for an update
Warning[176] E:\liwei\picc\PIC16F914test\MyProject.c 46 : missing newline
Warning[374] E:\liwei\picc\PIC16F914test\MyProject.c 3 : missing basic type; int assumed
Error[372] E:\liwei\picc\PIC16F914test\MyProject.c 3 : "," expected
Warning[374] E:\liwei\picc\PIC16F914test\MyProject.c 4 : missing basic type; int assumed
Error[372] E:\liwei\picc\PIC16F914test\MyProject.c 4 : "," expected
Warning[374] E:\liwei\picc\PIC16F914test\MyProject.c 5 : missing basic type; int assumed
Error[372] E:\liwei\picc\PIC16F914test\MyProject.c 5 : "," expected
Warning[374] E:\liwei\picc\PIC16F914test\MyProject.c 6 : missing basic type; int assumed
Error[372] E:\liwei\picc\PIC16F914test\MyProject.c 6 : "," expected
Warning[374] E:\liwei\picc\PIC16F914test\MyProject.c 7 : missing basic type; int assumed
Error[372] E:\liwei\picc\PIC16F914test\MyProject.c 7 : "," expected
Warning[374] E:\liwei\picc\PIC16F914test\MyProject.c 8 : missing basic type; int assumed
Error[372] E:\liwei\picc\PIC16F914test\MyProject.c 8 : "," expected
Warning[374] E:\liwei\picc\PIC16F914test\MyProject.c 9 : missing basic type; int assumed
Error[372] E:\liwei\picc\PIC16F914test\MyProject.c 9 : "," expected
Advisory[1] E:\liwei\picc\PIC16F914test\MyProject.c 9 : too many errors (21)
Halting build on first failure as requested.
BUILD FAILED: Wed Feb 29 18:24:19 2012
发表于 2012-2-29 18:53 | 显示全部楼层
那个文件是用VB编写的?
 楼主| 发表于 2012-2-29 19:46 | 显示全部楼层
倪工,我在用MAPLAB8.80编译你写的那个914的测试文件的时候出现了不少的错误提示,能否看看是什么原因?以前 ...
gmliwei 发表于 2012-2-29 18:25 https://www.yleee.com.cn/images/common/back.gif
         以前用的是MPLAB_IDE_8_53,无法编译PIC16F914。
        所以改用的是其它编译器。当然MAPLAB8.83编译时会出错。不兼用。
发表于 2012-2-29 19:52 | 显示全部楼层
        所以改用的是其它编译器 ...
倪大德 发表于 2012-2-29 19:46 https://www.yleee.com.cn/images/common/back.gif
哦,我说呢,呵呵
GMT+8, 2026-6-23 06:13 , Processed in 0.034718 second(s), 26 queries , Gzip On.
