查看: 5578|回复: 4
[51单片机] 请教,如何将数据存入stc12c5612ad单片机内部
发表于 2012-7-27 08:18 | 显示全部楼层 |阅读模式
本人单片机菜鸟一个,用89s52照抄郭天祥老师的程序可以,单为缩小体积,改用stc12c5612ad,就不知如何弄了,宏晶的那段测试程序看不懂,还望那位师傅依照郭天祥老师的风格给段stc12c5612ad的内部eeprom读写程序看看,先谢谢了
发表于 2012-7-27 08:23 | 显示全部楼层
菜鸟的 菜鸟,硬是没看明白这只菜鸟说的什么意思,
发表于 2012-7-27 09:00 | 显示全部楼层
晕,难道不一样么?
发表于 2012-7-27 12:34 | 显示全部楼层
stc片内eeprom
/* --- STC MCU Limited ---------------------------------------------*/
/* --- STC12C56xx Series MCU ISP/IAP/EEPROM Demo -------------------*/
/* --- Mobile: (86)13922805190 -------------------------------------*/
/* --- Fax: 86-755-82905966 ----------------------------------------*/
/* --- Tel: 86-755-82948412 ----------------------------------------*/
/* --- Web: www.STCMCU.com -----------------------------------------*/
/* If you want to use the program or the program referenced in the  */
/* article, please specify in which data and procedures from STC    */
#include "reg51.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
/*Declare SFR associated with the IAP */
sfr IAP_DATA    =   0xE2;           //Flash data register
sfr IAP_ADDRH   =   0xE3;           //Flash address HIGH
sfr IAP_ADDRL   =   0xE4;           //Flash address LOW
sfr IAP_CMD     =   0xE5;           //Flash command register
sfr IAP_TRIG    =   0xE6;           //Flash command trigger
sfr IAP_CONTR   =   0xE7;           //Flash control register
/*Define ISP/IAP/EEPROM command*/
#define CMD_IDLE    0               //Stand-By
#define CMD_READ    1               //Byte-Read
#define CMD_PROGRAM 2               //Byte-Program
#define CMD_ERASE   3               //Sector-Erase
/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
//#define ENABLE_IAP 0x80           //if SYSCLK<30MHz
//#define ENABLE_IAP 0x81           //if SYSCLK<24MHz
#define ENABLE_IAP  0x82            //if SYSCLK<20MHz
//#define ENABLE_IAP 0x83           //if SYSCLK<12MHz
//#define ENABLE_IAP 0x84           //if SYSCLK<6MHz
//#define ENABLE_IAP 0x85           //if SYSCLK<3MHz
//#define ENABLE_IAP 0x86           //if SYSCLK<2MHz
//#define ENABLE_IAP 0x87           //if SYSCLK<1MHz
//Start address for STC12C56xx EEPROM
#define IAP_ADDRESS 0x0400
void Delay(BYTE n);
void IapIdle();
BYTE IapReadByte(WORD addr);
void IapProgramByte(WORD addr, BYTE dat);
void IapEraseSector(WORD addr);
void main()
    WORD i;
    P1 = 0xfe;                      //1111,1110 System Reset OK
    Delay(10);                      //Delay
    IapEraseSector(IAP_ADDRESS);    //Erase current sector
    for (i=0; i<512; i++)           //Check whether all sector data is FF
        if (IapReadByte(IAP_ADDRESS+i) != 0xff)
            goto Error;             //If error, break
    P1 = 0xfc;                      //1111,1100 Erase successful
    Delay(10);                      //Delay
    for (i=0; i<512; i++)           //Program 512 bytes data into data flash
        IapProgramByte(IAP_ADDRESS+i, (BYTE)i);
    P1 = 0xf8;                      //1111,1000 Program successful
    Delay(10);                      //Delay
    for (i=0; i<512; i++)           //Verify 512 bytes data
        if (IapReadByte(IAP_ADDRESS+i) != (BYTE)i)
    P1 = 0xf0;                      //1111,0000 Verify successful
    while (1);
Error:
    P1 &= 0x7f;                     //0xxx,xxxx IAP operation fail
    while (1);
Software delay function
void Delay(BYTE n)
    WORD x;
    while (n--)
        x = 0;
        while (++x);
Disable ISP/IAP/EEPROM function
Make MCU in a safe state
void IapIdle()
    IAP_CONTR = 0;                  //Close IAP function
    IAP_CMD = 0;                    //Clear command to standby
    IAP_TRIG = 0;                   //Clear trigger register
    IAP_ADDRH = 0x80;               //Data ptr point to non-EEPROM area
    IAP_ADDRL = 0;                  //Clear IAP address to prevent misuse
Read one byte from ISP/IAP/EEPROM area
Input: addr (ISP/IAP/EEPROM address)
Output:Flash data
    BYTE dat;                       //Data buffer
    IAP_CONTR = ENABLE_IAP;         //Open IAP function, and set wait time
    IAP_CMD = CMD_READ;             //Set ISP/IAP/EEPROM READ command
    IAP_ADDRL = addr;               //Set ISP/IAP/EEPROM address low
    IAP_ADDRH = addr >> 8;          //Set ISP/IAP/EEPROM address high
    IAP_TRIG = 0x46;                //Send trigger command1 (0x46)
    IAP_TRIG = 0xb9;                //Send trigger command2 (0xb9)
    _nop_();                        //MCU will hold here until ISP/IAP/EEPROM operation complete
    dat = IAP_DATA;                 //Read ISP/IAP/EEPROM data
    IapIdle();                      //Close ISP/IAP/EEPROM function
    return dat;                     //Return Flash data
Program one byte to ISP/IAP/EEPROM area
       dat (ISP/IAP/EEPROM data)
Output:-
    IAP_CMD = CMD_PROGRAM;          //Set ISP/IAP/EEPROM PROGRAM command
    IAP_DATA = dat;                 //Write ISP/IAP/EEPROM data
    IapIdle();
Erase one sector area
Output:-
    IAP_CMD = CMD_ERASE;            //Set ISP/IAP/EEPROM ERASE command
    IapIdle();
下个stc-isp-15xx-v6.15.exe在范例程序页的东西可能对你有帮助
建议查看数据手册后在实验
郭天祥例子里好像那块主要讲的不是读写"eeprom", 而是I2C的驱动
 楼主| 发表于 2012-7-27 22:25 | 显示全部楼层
回复 4# goodcode
    先谢了,慢慢消化
GMT+8, 2026-6-23 09:26 , Processed in 0.033401 second(s), 22 queries , Gzip On.
