游客
回帖0
积分47
阅读权限1
注册时间2012-7-31
楼主 |
发表于 2012-8-1 19:57
显示全部楼层
回复 4# 2010sky
# include <STC90.H>
# define uint unsigned int
# define uchar unsigned char
sbit Data=P3^0;
sbit CLK=P3^1;
sbit G=P3^2;
sbit STB=P1^7;
uchar move;//列指针
uchar line;//行指针
uint word;//字模计数器
uchar speed=20;
uchar BUFF[12];//缓存
void load_data(void);// 调整数据
void send_data(void);//发送数据
void scan();//16段扫描
uchar code table[]=
0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0x80,0x03,0xFB,0xFF,0xF6,0xFF,0xEE,0xFF,0xDE,0xFF,
0xC0,0x07,0xFE,0xFF,0xF6,0xDF,0xEE,0xEF,0xDE,0xF7,0xBE,0xFB,0xFA,0xFF,0xFD,0xFF,
0xFB,0xBF,0xFB,0xBF,0xFB,0xBF,0xFB,0xBB,0xFB,0xB7,0x83,0xAF,0xFB,0x9F,0xFB,0xBF,
0xFB,0xBF,0xFB,0xBF,0xFB,0xBF,0xFB,0xBD,0xE3,0xBD,0x1B,0xBD,0xBB,0xC1,0xFB,0xFF,
0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0x00,0x01,0xFE,0xFF,0xFE,0xFF,
0xFD,0x7F,0xFD,0x7F,0xFB,0xBF,0xFB,0xBF,0xF7,0xDF,0xEF,0xEF,0xDF,0xF7,0x3F,0xF9,
0xDD,0xF7,0xEE,0xF7,0xEE,0xEF,0xFF,0xDF,0x80,0x01,0xBF,0xFD,0x7F,0xFB,0xE0,0x1F,
0xFF,0xBF,0xFE,0x7F,0x00,0x01,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFA,0xFF,0xFD,0xFF};
void main(void)
uchar i;
move=0;
word=0;
G=0;
while(1)
while(move<16)//数据移位
for(i=0;i<speed;i++)//移动速度
scan();
move++;//移动一步
move=0;
word=word+32;//后移一个字
if(word>=128) //到最后从头开始
word=0;
void scan()
for(line=0;line<16;line++)
load_data(); //调整数据
send_data(); //串口发送数据
P1=line;//行选
//P1=0x7f;//关闭显示
STB=1; //锁存为高
STB=0;
uchar s;
for(s=0;s<5;s++)
BUFF[s*2]=table[word+(32*s)+(2*line)];//左半屏,line是行数,word是字数
BUFF[s*2+1]=table[word+(32*s+1)+(2*line)];//右半屏
char s;
uchar inc,tempyd,temp;
if(move<8)
inc=0;
else
inc=1;
for(s=0+inc;s<=7+inc;s++)
if(move<8)
tempyd=move;
else
tempyd=move-8;
temp=(BUFF<<tempyd)|(BUFF[s+1]>>(8-tempyd));
SBUF=temp;
while(!TI);
TI=0;
16*16点阵左移显示的程序,哪位朋友研究过,帮忙修改一下并做个注释,谢谢。在屏上测试显示是乱码,感觉好像字在移动过程中是叠在一起的。 |
