查看: 9120|回复: 6
[其他综合] bascom编写的天马四段数码1602显示DS1302时钟
发表于 2012-9-17 19:19 | 显示全部楼层 |阅读模式
中元节过去很久了,小鬼还是不少。刚才的问题已经解决了,把1302读写信号线像双绞线那样搅在一起就好了。。。我汗。。。。
版主大人:看您觉得如果有必要的话,可以移到单片机区去了。。。
更新分隔,原标题:
DS1302插上VCC2(5V)读出的数就乱了,拔下来好了。。。求教
RT,同时给出显示结果和代码。bascom 2.0
http://ww2.sinaimg.cn/large/9d382e6bjw1dwxkf37s7hj.jpg
  1. $regfile = "m128def.dat"
  2. $crystal = 8000000
  3. $hwstack = 32                                               ' 设置堆栈大小
  4. $swstack = 10
  5. $framesize = 40
  6. Config Lcdpin = Pin , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7 , E = Portc.7 , Rs = Portc.6
  7. Config Lcd = 16 * 2
  8. Cursor Off Noblink
  9. Cls
  10. Dim Secs As Byte
  11. Dim Mins As Byte
  12. Dim Hour As Byte
  13. Dim Dates As Byte
  14. Dim Month As Byte
  15. Dim Day As Byte
  16. Dim Year As Byte
  17. Dim Tri As Byte
  18. '----------------------- Define RTC I/O Port       --------------------------
  19. Config Portb.5 = Output
  20. Config Portb.4 = Output
  21. Ds_rst Alias Portb.5                                        'reset pin.
  22. Ds_dat Alias Portb.3                                        'IO(data pin).
  23. Ds_dati Alias Pinb.3                                        'IO(data pin). Used for reading
  24. Ds_clk Alias Portb.4                                        'Clock pin.
  25. '----------------------- Write Commands For DS1302 --------------------------
  26. Const Writesec = &H80                                       ' Write Seconds
  27. Const Writemin = &H82                                       ' Write Minutes
  28. Const Writehour = &H84                                      ' Write Hour
  29. Const Writedates = &H86                                     ' Write Date
  30. Const Writemonth = &H88                                     ' Write Month
  31. Const Writeday = &H8A                                       ' Write Day
  32. Const Writeyear = &H8C                                      ' Write Year
  33. Const Writectrl = &H8E                                      ' Write Protect
  34. 'Const Writectrl = &H90
  35. Const Protect = &H80
  36. Const Unprotect = &H00
  37. '------------------------- Read Commands For DS1302 -------------------------
  38. Const Readsec = &H81                                        ' Read seconds from DS1302
  39. Const Readmin = &H83                                        ' Read minutes from DS1302
  40. Const Readhour = &H85                                       ' Read hours from DS1302
  41. Const Readdates = &H87                                      ' Read date from DS1302
  42. Const Readmonth = &H89                                      ' Read month from DS1302
  43. Const Readday = &H8B                                        ' Read day from DS1302
  44. Const Readyear = &H8D                                       ' Read year from DS1302
  45. Const Readprotect = &H8F                                    ' Read Protect
  46. Const Readctrl = &H91
  47. Declare Sub Ds1302_w_byte(byval Wdata As Byte)
  48. Declare Sub Ds1302_r_byte(wdata As Byte )
  49. Declare Sub Write_ds1302(byval Cmd As Byte , Byval Wdata As Byte)
  50. Declare Function Read_ds1302(byval Cmd As Byte) As Byte
  51. Declare Sub Gettime
  52. Declare Sub Settime
  53. Declare Sub Ds1302_init
  54.    Call Ds1302_init
  55. Do
  56.    Call Gettime
  57.    Locate 1 , 1
  58.    Lcd "  " ; Hex(year) ; "/" ; Hex(month) ; "/" ; Hex(dates) ; " Week " ; Hex(day)
  59.    Locate 2 , 1
  60.    Lcd "  " ; Hex(hour) ; ":" ; Hex(mins) ; ":" ; Hex(secs)
  61.    Waitms 500
  62. Loop
  63. End
  64. Sub Ds1302_init
  65.   Tri = Read_ds1302(&Hc1)
  66.   If Tri <> &HF0 Then                                       'Clock is stopped
  67.   Call Write_ds1302(writectrl , Unprotect)
  68.   Call Write_ds1302(writesec , &H01)                        'Let it run
  69.   Call Write_ds1302(writemin , &H28)
  70.   Call Write_ds1302(writehour , &H18)
  71.   Call Write_ds1302(writedates , &H17)
  72.   Call Write_ds1302(writemonth , &H09)
  73.   Call Write_ds1302(writeyear , &H12)
  74.   Call Write_ds1302(writeday , &H01)
  75.   Call Write_ds1302(&H90 , &HAA)
  76.   Call Write_ds1302(&Hc0 , &HF0)
  77.   Call Write_ds1302(writectrl , Protect)
  78.   End If
  79. End Sub
  80. Sub Settime
  81.   Call Write_ds1302(writectrl , Unprotect)
  82.   Call Write_ds1302(writesec , Secs)
  83.   Call Write_ds1302(writemin , Mins)
  84.   Call Write_ds1302(writehour , Hour)
  85.   Call Write_ds1302(writeday , Day)
  86.   Call Write_ds1302(writedates , Dates)
  87.   Call Write_ds1302(writemonth , Month)
  88.   Call Write_ds1302(writeyear , Year)
  89.   Call Write_ds1302(writectrl , Protect)
  90. End Sub
  91. Sub Gettime
  92.    Secs = Read_ds1302(readsec)
  93.    Mins = Read_ds1302(readmin)
  94.    Hour = Read_ds1302(readhour)
  95.    Dates = Read_ds1302(readdates)
  96.    Month = Read_ds1302(readmonth)
  97.    Day = Read_ds1302(readday)
  98.    Year = Read_ds1302(readyear)
  99. End Sub
  100. Sub Ds1302_w_byte(wdata As Byte)
  101. Config Portb.3 = Output
  102.   Local I As Byte
  103.    Reset Ds_clk
  104.    Waitus 2
  105.    For I = 0 To 7
  106.       If Wdata.i = 1 Then
  107.         Set Ds_dat
  108.         Else
  109.         Reset Ds_dat
  110.       End If
  111.       Waitus 2
  112.       Set Ds_clk
  113.       Waitus 2
  114.       Reset Ds_clk
  115.    Next I
  116. End Sub
  117. Sub Ds1302_r_byte(wdata As Byte )
  118. Config Pinb.3 = Input
  119. Pinb.3 = 1
  120.   Local I As Byte
  121.   Waitus 2
  122.   For I = 0 To 7
  123.     Wdata.i = Ds_dati
  124.     Waitus 2
  125.     Set Ds_clk
  126.     Waitus 2
  127.     Reset Ds_clk
  128.   Next I
  129. End Sub
  130. Sub Write_ds1302(cmd As Byte , Wdata As Byte)
  131.    Reset Ds_rst
  132.    Reset Ds_clk
  133.    Set Ds_rst
  134.    Call Ds1302_w_byte(cmd)
  135.    Call Ds1302_w_byte(wdata)
  136.    Set Ds_clk
  137.    Reset Ds_rst
  138. End Sub
  139. Function Read_ds1302(cmd As Byte)
  140.    Local I As Byte
  141.    Local X As Byte
  142.    Reset Ds_rst
  143.    Reset Ds_clk
  144.    Set Ds_rst
  145.    Call Ds1302_w_byte(cmd)
  146.    Call Ds1302_r_byte(x)
  147.    Set Ds_clk
  148.    Reset Ds_rst
  149.    Read_ds1302 = X
  150. End Function
复制代码
发表于 2012-9-17 19:31 | 显示全部楼层
2002?漂亮
 楼主| 发表于 2012-9-17 19:33 | 显示全部楼层
回复 1# keanu131
再上张有问题时候的图。上面单个插针就是vcc2,直接接到5v。拔下来后时间就正常了
   http://ww3.sinaimg.cn/large/9d382e6bjw1dwzquenf6gj.jpg
 楼主| 发表于 2012-9-17 19:34 | 显示全部楼层
2002?漂亮
灰太狼8888 发表于 2012-9-17 19:31 https://www.yleee.com.cn/images/common/back.gif
   天马那个带四个数码管的1602
发表于 2012-9-17 19:58 | 显示全部楼层
vcc2应该要低一点儿吧?3.7V锂电池或者3V纽扣电池试试……
 楼主| 发表于 2012-9-17 20:16 | 显示全部楼层
sdf15937 发表于 2012-9-17 19:58 https://www.yleee.com.cn/images/common/back.gif
我以前也是这么认为的,所以法拉电容接的位置不对,一直充不上电。后来看了pdf改好了,如图: 未命名.bmp
发表于 2012-9-28 22:11 | 显示全部楼层
不错不错  bascom还是通俗易懂
GMT+8, 2026-6-23 10:50 , Processed in 0.042087 second(s), 33 queries , Gzip On.
