查看: 4389|回复: 14
[其他综合] 发现开源个叫“CEE provides ”的USB东东~应该很玩头~
发表于 2012-10-18 23:39 | 显示全部楼层 |阅读模式
作者:http://www.nonolithlabs.com/cee/
http://www.nonolithlabs.com/cee/home-hero.jpeg
http://www.nonolithlabs.com/blog/2012/images/sine-drag.gif
http://www.nonolithlabs.com/cee/wiring.jpeg
CEE provides an extremely flexible analog interface, allowing you to connect your computer to the real world.
  • 2 source-measure channels
  • 0–5V range
  • Source or sink 200mA per channel
  • 80,000 samples per second
  • USB-powered — one cable
Assembled in the USA.
Electronics
发表于 2012-10-18 23:44 | 显示全部楼层
虚拟示波器吧
上位机做得很炫,不知啥语言做的
估计是win7平台
 楼主| 发表于 2012-10-18 23:53 | 显示全部楼层
XP能也用~还有个小视频了~
http://www.kickstarter.com/projects/itdaniher/cee-the-usb-analog-electronics-multi-tool?ref=card
发表于 2012-10-18 23:55 | 显示全部楼层
看那窗口控制栏都在左上角 估计不是windows啊
发表于 2012-10-18 23:57 | 显示全部楼层
看窗口控制按钮貌似是苹果的mac系统
 楼主| 发表于 2012-10-19 00:03 | 显示全部楼层
常见问题;http://wiki.nonolithlabs.com/cee/faq/
文中好像有说到~,但英语太差看到有什么作用,不是虚拟示波器
What sort of computer will I need to use the CEE?
Pixelpulse runs in Google Chrome on operating systems including Windows XP, Windows 7, Ubuntu, and OSX. We recommend having a 1.6GHz-or-better processor and at least 1GB of RAM.
发表于 2012-10-19 00:05 | 显示全部楼层
像gnome啊
发表于 2012-10-19 03:50 | 显示全部楼层
Windows, Mac, and Linux,三个平台都可以用。
发表于 2012-10-19 08:29 | 显示全部楼层
他软件是网页架构,基于Chrome浏览器的
http://apps.nonolithlabs.com/pixelpulse
发表于 2012-10-19 08:35 | 显示全部楼层
基于网页,这也可以
GMT+8, 2026-1-30 16:29 , Processed in 0.033798 second(s), 27 queries , Gzip On.
