查看: 5628|回复: 29
【已解决】32*64的屏,要多大电流能带动?
发表于 2012-11-20 16:40 | 显示全部楼层 |阅读模式
各位大神,你们屏的电源都是接的哪里啊?我没有恒流源,用自己的板子 貌似提供不了那么大的电流,接通一会就只有2行的灯会亮一下下,也就能坚持1秒左右就灭了!
最新情况:换了个电源,烧入程序,就只有16和32行常亮!程序如下(程序系转载)
#include <REG52.H>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit HC138_A   = P1^4;
sbit HC138_C   = P1^3;
sbit HC595_STB = P1^2;
sbit HC595_GD  = P1^1;
sbit HC138_OE  = P1^0;
sbit HC138_B   = P1^5;
sbit HC138_D   = P1^6;
sbit HC595_CLK = P1^7;
sbit HC595_RD  = P3^2;
unsigned char r_data[16], g_data[16];
unsigned char k, t;
unsigned char code hanzi[][8]={                 //二维数据
0x00,0x18,0x24,0x24,0x24,0x24,0x24,0x18,        //0
0x00,0x08,0x18,0x08,0x08,0x08,0x08,0x08,        //1
0x00,0x18,0x24,0x24,0x08,0x10,0x20,0x3C,        //2
0x00,0x18,0x24,0x04,0x18,0x04,0x24,0x18,        //3
0x00,0x04,0x0C,0x14,0x24,0x3E,0x04,0x04,        //4
0x00,0x3C,0x20,0x38,0x24,0x04,0x24,0x18,        //5
0x00,0x18,0x24,0x20,0x38,0x24,0x24,0x18,        //6
0x00,0x3C,0x04,0x08,0x10,0x10,0x10,0x10,        //7
0x00,0x18,0x24,0x24,0x18,0x24,0x24,0x18,        //8
0x00,0x18,0x24,0x24,0x1C,0x04,0x24,0x18,        //9
0x00,0x26,0x69,0x29,0x29,0x29,0x29,0x26,        //10
0x00,0x22,0x66,0x22,0x22,0x22,0x22,0x22,        //11
0x00,0x26,0x69,0x29,0x22,0x24,0x28,0x2F,        //12
0x00,0x26,0x69,0x21,0x26,0x21,0x29,0x26,        //13
0x00,0x22,0x66,0x2A,0x32,0x3F,0x22,0x22,        //14
0x00,0x2F,0x68,0x2E,0x29,0x21,0x29,0x26,        //15
//delay us
void Delay(uchar us)
        while(--us);
void Write_HC595(unsigned char rdd, gdd)
        unsigned char i;
        for (i=0;i<8;i++)
                HC595_RD=~rdd&0x80;    //只显示红色字
                rdd=rdd<<1;
                HC595_CLK=1;
                HC595_CLK=0;
void main (void)
        while(1)
                for(t=0;t<16;t++)   //16 行
            HC138_OE = 1;
                                r_data[0] = hanzi[0][t];
                                r_data[1] = hanzi[2][t];
                                r_data[2] = hanzi[4][t];
                                r_data[3] = hanzi[6][t];
                                r_data[4] = hanzi[8][t];
                                r_data[5] = hanzi[10][t];
                                r_data[6] = hanzi[12][t];
                                r_data[7] = hanzi[14][t];
                        for (k=0;k<8;k++)
                                Write_HC595(r_data[k], g_data[k]);
                        HC138_OE  = 0;
                        HC595_STB = 1;
                        HC595_STB = 0;
                        HC138_A = t&0x01;
                        HC138_B = t&0x02;
                        HC138_C = t&0x04;
                        HC138_D = t&0x08;
                        Delay(1000);
        }        //end while
经过几个小时的试验,终于用上面的程序,成功的显示出了字!这里说明一下:
       1、电源用的是独立的开关电源,电压是5V,电流由于没有表,没有测。
       2、之前一直没有显示,应该是我的单片机板子没有和电源共地!(可能是我板子的原因,USB和电脑相连,即使关掉板子上的开关,指示灯还是会亮,只不过亮度要暗一些)不和电源共地的话,就会出现某两行高亮,其余行不显示!
在此,特别感谢给过我建议的朋友!感谢你们的帮助!没有你们的帮助,估计我现在还是一头雾水!再次谢过!!!
发表于 2012-11-20 16:46 | 显示全部楼层
你做毕设学校不提供实验室,不提供合适的电源吗?
 楼主| 发表于 2012-11-20 16:49 | 显示全部楼层
回复 2# 80x86
   我们学校实验室不提供东西,说是实验室,其实感觉更像办公室!我做这个是带我的毕业设计老师让我帮忙做的,他那有台比较精密的电源舍不得给我用,so...
发表于 2012-11-20 17:00 | 显示全部楼层
用5A的电源去带,电脑电源就行
注意那组就12V 那组是5V
 楼主| 发表于 2012-11-20 17:01 | 显示全部楼层
回复 4# enhsh
   好像不行,我板子上的就是5V的电源,就出现了说的情况!
发表于 2012-11-20 17:02 | 显示全部楼层
解决还得靠自己  去你们附近的收废品哪里找个电源   或者  做室外照明led广告屏的 商家   买个旧的  他们哪里有   价格很低的  碰到好心人 送你个也很正常
 楼主| 发表于 2012-11-20 17:04 | 显示全部楼层
回复 6# donglele2005
   感谢提醒~
发表于 2012-11-20 17:12 | 显示全部楼层
电脑的5V都带不动??
发表于 2012-11-20 17:18 | 显示全部楼层
不能用恒流源吧
你先搞清楚是要什么电源再说,没搞清楚之前就上电?
 楼主| 发表于 2012-11-20 17:23 | 显示全部楼层
回复 8# 80x86
   我用的是 USB接的板子,板子上的5V接的屏。
GMT+8, 2026-3-13 18:16 , Processed in 0.037214 second(s), 27 queries , Gzip On.
