查看: 2194|回复: 6
求能显示英文字母的程序
发表于 2013-2-26 16:07 | 显示全部楼层 |阅读模式
点阵是16*64,2片138+595,可以显示中文出来,但是想显示出英文字母却不行。怎样修改?程序如下
#include <reg52.h>
sbit STR=P2^2;  //锁存
sbit CLK=P2^3;        //时钟
sbit RData= P2^1;        //红 数据
//sbit GData= P3^5;        //绿 数据
sbit E=  P1^4;        //使能
unsigned char code hanzi[][32]={
0xFF,0xBF,0x81,0xBF,0xBF,0xBF,0xBB,0x83,0x9B,0x7B,0xAB,0x77,0xB6,0xDF,0xB7,0xDF,
0xAB,0xDF,0xAB,0xAF,0x9B,0xAF,0xBF,0xAF,0xBF,0x77,0x81,0x77,0xFE,0xFB,0xFD,0xFD,/*"欧",0*/
0xFF,0xFF,0x83,0xFF,0xBA,0x03,0xB6,0xFB,0xB6,0xFB,0xAE,0xFB,0xB6,0xFB,0xB6,0xFB,
0xBA,0x03,0xBA,0xFB,0xBA,0xFB,0x96,0xFB,0xAE,0xFB,0xBE,0xFB,0xBE,0x03,0xBE,0xFB,/*"阳",1*/
0xFB,0xFF,0xFB,0xFF,0xFB,0xFF,0xFB,0xFF,0x80,0x1F,0xFB,0xDF,0xFB,0xDF,0xFB,0xDF,
0xF7,0xDF,0xF7,0xDF,0xF7,0xDF,0xEF,0xDD,0xEF,0xDD,0xDF,0xDD,0xBF,0xE1,0x7F,0xFF,/*"九",2*/
0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xC3,0xF8,0x3F,0x05,0xFF,
0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFB,0xFD,0xFB,0xFD,0xFB,0xFE,0x03,0xFF,0xFF,/*"七",3*/
void delay(unsigned char n)
     while(n--);
void sendbyteRG(unsigned char bbyte1)
unsigned char i;
for(i=0;i<8;i++)
     RData=bbyte1&0x80;   //取高位
     CLK=0;  CLK=1;
     bbyte1<<=1;
void main(void)
        unsigned char i;
         while(1)
     for(i=0;i<16;i++)
               E=1;//禁止行输出
                sendbyteRG(hanzi[0][i*2]);
                sendbyteRG(hanzi[0][i*2+1]);
                sendbyteRG(hanzi[1][i*2]);
                sendbyteRG(hanzi[1][i*2+1]);
                sendbyteRG(hanzi[2][i*2]);
                sendbyteRG(hanzi[2][i*2+1]);
                sendbyteRG(hanzi[3][i*2]);
                sendbyteRG(hanzi[3][i*2+1]);
            P1=i;
            delay(10);
           E=0;//打开行输出
发表于 2013-2-26 16:35 | 显示全部楼层
重新取字模。
 楼主| 发表于 2013-2-26 16:58 | 显示全部楼层
重新取模也不行。字母是半码,中文是全码,全码显示正常,现在想显示出半码。
发表于 2013-2-26 17:14 | 显示全部楼层
取字模,改程序
发表于 2013-2-26 21:32 | 显示全部楼层
另一半,填充0
发表于 2013-2-26 22:43 | 显示全部楼层
英文字母 也可以像汉字那样,取模时设定一下
 楼主| 发表于 2013-2-27 09:08 | 显示全部楼层
取模时要怎样的设定?
GMT+8, 2026-1-12 15:47 , Processed in 0.033097 second(s), 24 queries , Gzip On.
