钻石会员
回帖0
积分23364
阅读权限50
注册时间2011-3-24
楼主 |
发表于 2013-4-1 01:16
显示全部楼层
千辛万苦找了好多个网站,注册了好多次,下载到一个aygshell.dll 这个东西太有用了,但不同的系统所需要的 aygshell.dll 是不同的,必须一个个试试看!慢慢折腾!
aygshell.rar
(341.63 KB, 下载次数: 197)
you'll need the fourth aygshell (file size is 16.5 K) in most of the cases. however you might find applications that will need another version of aygshell (especially from the 13th or 14th folder).
so i suggest you always put aygshell.dll in the program's folder and NOT in Windows folder.
17th and 18th aygshell are special, read their included readme's.
the aygshells sometimes won't work on ce.net 4.2 without renaming aygshell and editing the app to call that.
old stuff:
update: the 9th aygshell is an updated version of the second/third ones, they're sometimes good if the 4th one fails.
10th and 11th are probably with the OS version ce 4.1, i'll check that, and they can be modified with execheck anyway. (also they may be specifically for sig3., especially for skype.)
update again: 12th and 13th aygshell look very good so far. updated versions of the 9th one :) (from HM again)
new update: use always the 4th (Dic's aygshell, size 16.5K), or if that fails, the 13th aygshell (HM's newest version, size 22K)! if these don't work, you can still try the others but not much hope then...
update 3: 14th is now hou ming's newest aygshell. so use 4th or 13/14th ones for the first time.
