黄金会员
回帖0
积分7830
阅读权限40
注册时间2013-4-23
两天前不知道啥是OPENWRT,想无线挂摄像头,开始了刷机经历,直接TTL刷机。
刚开始买的TTL,超级终端一直显示无法连接,百思不得其解,用USB测试TTL软件,(连接RX-TX),发现无法连通,检查线路也没问题,直接换了PL2303芯片,仍通不过检测,这都三个小时了,郁闷无奈手工焊接了一块USB-PL2303,通过检测收发正常,超级终端也收发正常。
开始刷机:
1.按照TTL刷机标准刷机教程HG255D-UM 第1~8步(刷U-BOOT),注意备份EERPOM,背完完OK,不要看剩下的教程了,(什么打开TFTP2,TFTP1.6固件更新器之类的软件, 什么按2,Y,三个回车,CTRL+C ,全都扔掉,因为这些,闹腾了半天也没刷进去固件。
之前刷不进去固件的过程如下:按了那么多2,刷了N次也没见TFTP把BIn给我刷进去,纠结。
U-Boot 1.1.3 (Jan 18 2013 - 13:45:38)
SoC:Ralink RT3052
DRAM: Memory Testing.......32768K OK. is 32 MB
relocate_code Pointer at: 81fa8000
config usb..
Software System Reset Occurred
Flash JEDEC Info:
Manufacturer ID:0x00000001
Device ID:0x0000227E
Mode ID:0x00002221
Part ID:0x00002201
FLASH:S29GL128P/N, SIZE:16 MBytes SECTOR:128
S29GLXXX:set sect_size =0x20000
*** Warning - bad CRC, using default environment
__________________________________________
| ____ ____ |
| | _ \ _ __ ___ __ _ _ __ ___ | __ ) _____ __ |
| | | | | '__/ _ \/ _` | '_ ` _ \| _ \ / _ \ \/ / |
| | |_| | | | __/ (_| | | | | | | |_) | (_) > < |
| |____/|_| \___|\__,_|_| |_| |_|____/ \___/_/\_\ |
| DreamBox Team |
| http://www.openwrt.org.cn |
| Board:HuaWei HG255D |
| lintel<lintel.huang@gmail.com> |
|____________________________________________________|
===============System Info==================
ASIC 3052_MP2 (Port5<->None)
DRAM component: 256 Mbits SDR
DRAM bus: 32 bit
Flash component: NOR Flash
CPU Speed: 384 MHZ
RAM Size:32 Mbytes
Build Date:Jan 18 2013 Time:13:45:38
GPIO Init:
UARTF_SHARE_MODE:GPIO
SPI_GPIO_MODE:GPIO
I2C_GPIO
GPIO_MODE_REG status:0x29f
ReadyLED Bit:0x100
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
7: Load Boot Loader code then write to Flash via Serial.
9: Load Boot Loader code then write to Flash via TFTP.
You choosed 2
0
2: System Load Linux Kernel then write to Flash via TFTP.
Warning!! Erase Linux in Flash then burn new one. Are you sure?(Y/N
Please Input new ones /or Ctrl-C to discard
Input device IP (192.168.1.1) ==:192.168.1.1
Input server IP (192.168.1.100) ==:192.168.1.100
Input Linux Kernel filename () ==:E.bin
netboot_common, argc= 3
NetTxPacket = 0x81FE4D80
KSEG1ADDR(NetTxPacket) = 0xA1FE4D80
NetLoop,call eth_halt !
NetLoop,call eth_init !
Trying Eth0 (10/100-M)
Waitting for RX_DMA_BUSY status Start... done
ETH_STATE_ACTIVE!!
Using Eth0 (10/100-M) device
TFTP from server 192.168.1.100; our IP address is 192.1
Filename 'E.bin'.
TIMEOUT_COUNT=10,Load address: 0x80100000
Loading: *
ArpTimeoutCheck
T Got ARP REQUEST, return our IP
T Got ARP REPLY, set server/gtwy eth addr (00:0f:b0:81:f5:ff)
Got it
(按照教程我该喝咖啡去了,为何蛋疼的还一直LOADING)
checksum bad
checksum bad
T T T T T T Got ARP REQUEST, return our IP
T T
Retry count exceeded; starting again
ETH_STATE_ACTIVE!!
TFTP from server 192.168.1.100; our IP address is 192.168.1.1
Filename 'E.bin'.
Loading: Got ARP REPLY, set server/gtwy eth addr (00:0f:b0:81:f5:ff)
Got it
