楼主: 无锡风
[其他综合] 【pic18f6520】demo版
发表于 2010-6-16 12:04 | 显示全部楼层
不知您用的什么软件!
          我用几个电阻做了个简易低压编程器,用的软件是IC-Prog。 ...
倪大德 发表于 2010-6-16 08:14 https://www.yleee.com.cn/images/common/back.gif
我以前也用IC-prog,现在用PICPGM,这软件能自动识别IC型号,支持的编程器很多,而且基本支持全系列PIC芯片。
http://members.aon.at/electronics/pic/picpgm/index.html
支持的型号列表:
PIC10F:
PIC10F200, PIC10F202, PIC10F204, PIC10F206, PIC10F220, PIC10F222
PIC12F:
PIC12F508, PIC12F509, PIC12F510, PIC12F609, PIC12F615, PIC12F617, PIC12F629, PIC12F635, PIC12F675, PIC12F683, PIC12HV609, PIC12HV615
PIC16F:
PIC16F610, PIC16F616, PIC16F627, PIC16F627A, PIC16F628, PIC16F628A, PIC16F630, PIC16F631, PIC16F636, PIC16F639, PIC16F648A, PIC16F676, PIC16F677, PIC16F684, PIC16F685, PIC16F687, PIC16F688, PIC16F689, PIC16F690, PIC16F716, PIC16F73, PIC16F737, PIC16F74, PIC16F747, PIC16F76, PIC16F767, PIC16F77, PIC16F777, PIC16F818, PIC16F819, PIC16F84A, PIC16F87, PIC16F870, PIC16F871, PIC16F872, PIC16F873, PIC16F873A, PIC16F874, PIC16F874A, PIC16F876, PIC16F876A, PIC16F877, PIC16F877A, PIC16F88, PIC16F882, PIC16F883, PIC16F884, PIC16F886, PIC16F887, PIC16F913, PIC16F914, PIC16F916, PIC16F917, PIC16F946, PIC16HV610, PIC16HV616
PIC18F:
PIC18F1220, PIC18F1320, PIC18F2220, PIC18F2221, PIC18F2320, PIC18F2321, PIC18F2331, PIC18F2410, PIC18F242, PIC18F2420, PIC18F2423, PIC18F2431, PIC18F2450, PIC18F2455, PIC18F2458, PIC18F248, PIC18F2480, PIC18F2510, PIC18F2515, PIC18F252, PIC18F2520, PIC18F2523, PIC18F2525, PIC18F2550, PIC18F2553, PIC18F258, PIC18F2580, PIC18F2585, PIC18F2610, PIC18F2620, PIC18F2680, PIC18F2682, PIC18F2685, PIC18F4220, PIC18F4221, PIC18F4320, PIC18F4321, PIC18F4331, PIC18F4410, PIC18F442, PIC18F4420, PIC18F4423, PIC18F4431, PIC18F4450, PIC18F4455, PIC18F4458, PIC18F448, PIC18F4480, PIC18F4510, PIC18F4515, PIC18F452, PIC18F4520, PIC18F4523, PIC18F4525, PIC18F4550, PIC18F4553, PIC18F458, PIC18F4580, PIC18F4585, PIC18F4610, PIC18F4620, PIC18F4680, PIC18F4682, PIC18F4685, PIC18F6520, PIC18F6527, PIC18F6585, PIC18F6680, PIC18F8585, PIC18F8680, PIC18F6620, PIC18F6622, PIC18F6627, PIC18F6628, PIC18F6720, PIC18F6722, PIC18F6723, PIC18F8520, PIC18F8527, PIC18F8620, PIC18F8622, PIC18F8627, PIC18F8628, PIC18F8720, PIC18F8722, PIC18F8723
dsPIC30F:
dsPIC30F2010, dsPIC30F2011, dsPIC30F2012, dsPIC30F3010, dsPIC30F3011, dsPIC30F3012, dsPIC30F3013, dsPIC30F3014, dsPIC30F4011, dsPIC30F4012, dsPIC30F4013, dsPIC30F5011, dsPIC30F5013, dsPIC30F5015, dsPIC30F5016, dsPIC30F6010, dsPIC30F6010A, dsPIC30F6011, dsPIC30F6011A, dsPIC30F6012, dsPIC30F6012A, dsPIC30F6013, dsPIC30F6013A, dsPIC30F6014, dsPIC30F6014A, dsPIC30F6015
发表于 2010-6-16 13:09 | 显示全部楼层
等着听讲
 楼主| 发表于 2010-6-16 14:27 | 显示全部楼层
6520字符附近是否有短路的地方,看到一个尖 55-C8之间
fujiachun 发表于 2010-5-27 15:25 https://www.yleee.com.cn/images/common/back.gif
现在才回答 傅老师:
不是您所说的“6520字符附近是否有短路的地方”。
故障原因,仍然不清楚。
给 倪工的这块
是已经使用K149编程器、下载成功了的。
发表于 2010-6-16 16:23 | 显示全部楼层
您用得是K149?,等等看FAT师兄用的啥编程器,先解决这个编程器,那位老师推荐个最简单得能写6520的
发表于 2010-6-16 21:25 | 显示全部楼层
我以前也用IC-prog,现在用PICPGM,这软件能自动识别IC型号,支持的编程器很多,而且基本支持全系列PI ...
fat 发表于 2010-6-16 12:04 https://www.yleee.com.cn/images/common/back.gif
fat师兄帮忙看看这个能写6520不?
http://www.olimex.com/dev/pic-pg2.html
发表于 2010-6-17 06:23 | 显示全部楼层
给 倪工的这块
无锡风 发表于 2010-6-16 14:27 https://www.yleee.com.cn/images/common/back.gif
          谢谢老冯!
         照顾我这个二差生,一是眼力差(350度)。最重要的是焊工差(贴片焊不了)。https://www.yleee.com.cn/images/smilies/default/55.gif
发表于 2010-6-17 06:24 | 显示全部楼层
             谢谢fat提供的资料!
发表于 2010-6-17 11:41 | 显示全部楼层
fat师兄帮忙看看这个能写6520不?
fujiachun 发表于 2010-6-16 21:25 https://www.yleee.com.cn/images/common/back.gif
这个PIC-PG2可以写啊,这个实际上就是JDM的变形电路,需要有“标准”串口。
发表于 2010-6-17 11:49 | 显示全部楼层
fat 发表于 2010-6-17 11:41 https://www.yleee.com.cn/images/common/back.gif
谢谢,您提供的链接就看这个简单,英文不好,看原文太吃力,回头按这个电路做一个,您说的“标准串口”是不是就是PC本身的串口?
发表于 2010-6-17 14:39 | 显示全部楼层
回复 19# fujiachun
是的,我说的“标准串口”就是指普通台式PC上的串口,本本上的或是USB转出来的串口不能保证能用。
GMT+8, 2026-3-25 16:55 , Processed in 0.037403 second(s), 26 queries , Gzip On.
