查看: 4758|回复: 15
前几天的320x240 RA8835 点亮了。。发帖庆贺一下。。。
发表于 2014-4-23 11:52 | 显示全部楼层 |阅读模式
如题:
稍后传上代码。
1:gnd
2:VCC
3:VHIN
4:WR
5:RD
6:CS
7:A0
8:RESET
9:D0
10:D1
11:D2
12:D3
13:D4
14:D5
15:D6
16:D7
17:VLED
18:VHOUT
void CmdWrite(unsigned int Data )
                 MCU_CSL;
                 //DelayUs(1);
                 MCU_A0H;
                 //DelayUs(1);
                 DrvGPIO_SetPortBits(E_GPA,Data);
                 //DelayUs(1);
                 MCU_WRL;
                 //DelayUs(1);
                 MCU_WRH;
                 //DelayUs(1);
     //MCU_CSH;
void DataWrite(unsigned int Data )
                 MCU_CSL;
                 //DelayUs(1);
                 MCU_A0L;
                 //DelayUs(1);
                 //DelayUs(1);
                 MCU_WRL;
                 //DelayUs(1);
                 MCU_WRH;
                 //DelayUs(1);
     MCU_CSH;
unsigned char DataRead(void )
                 unsigned char dat;
                 MCU_CSL;
                 //DelayUs(1);
                 MCU_A0L;
                 DrvGPIO_SetPortBits(E_GPA,0xffff);
                 //DelayUs(1);
                 dat= DrvGPIO_GetPortBits(E_GPA)&0x00ff;
                 //DelayUs(1);
                 MCU_WRL;
                 //DelayUs(1);
                 MCU_WRH;
                 //DelayUs(1);
     MCU_CSH;
     return         dat;
//oˉêy1|Äü: òo¾§ÆáÇå 32K RAM oˉêy,·′ó3μ½ÆáÄ»¼′ÎaÇåÆá
//      μ«ò»°ãÇåÆá2»DèòaÇåËùóD 32K RAM,Õa¸öìØêa
//èë¿ú2Îêy: ÎT
//3ö¿ú2Îêy: ÎT
void FullScreenFill(unsigned char low,unsigned char high,unsigned char fill_data)
  unsigned char i,j;
  CmdWrite(0x46);
  DataWrite(low);
  DataWrite(high);
  CmdWrite(0x42);
  for(i=0;i<240;i++)
    for(j=0;j<40;j++)
      DataWrite(fill_data);
void LcdInit(void)
    MCU_CSL;
    MCU_RSL;
    DelayMs(100);
    MCU_RSH;
    DelayMs(100);
    CmdWrite(SystemSet);
    DataWrite(0x32);
    DataWrite(0x87);
    DataWrite(0x07);
    DataWrite(0x27);
    DataWrite(0x42);
    DataWrite(0xf0);
    DataWrite(0x28);
    DataWrite(0x00);
    CmdWrite(Scroll );
    CmdWrite(Scroll );
    DataWrite(0x00);
    DataWrite(0x00);
    DataWrite(0xF0);    //?? f0
    DataWrite(0x00);
    DataWrite(0x40);
    DataWrite(0x00);
    DataWrite(0x80);  //??
    DataWrite(0x00);
    DataWrite(0x00);  //??
    CmdWrite( HdotScr ); //μ&#227;&#206;&#187;ò&#198;éè&#214;&#195;
    DataWrite( 0 );
    CmdWrite( Ovlay ); //&#207;&#212;ê&#190;o&#207;3ééè&#214;&#195;
    DataWrite( 0x04); //ò&#187;&#199;&#248;&#206;&#196;±&#190;·&#189;ê&#189;£&#172;&#198;&#228;&#203;&#251;í&#188;D&#206;£&#172;òì&#187;ò·&#189;ê&#189;
          CmdWrite( 0x4c ); //éè&#214;&#195;1a±êóòò&#198;
    CmdWrite( DispOn );
    DataWrite( 0x54 ); //&#207;&#212;ê&#190;&#187;-&#195;&#230;2&#187;éá&#203;&#184;£&#172;1&#216;1a±ê&#207;&#212;ê&#190;
void LcmLocateXY(unsigned char x,unsigned char y)
    unsigned int temp,locateH,locateL;
    temp = (unsigned int)y*paraP9+x;
    locateL = (unsigned char)(temp & 0xff);
    locateH = (unsigned char)(temp / 256 );
    if( LcmLayer == 2 ) { locateH = locateH + 0x40; }
    if( LcmLayer == 3 ) { locateH = locateH +0x80; }
    CmdWrite( CsrW );
    DataWrite( locateL );
    DataWrite( locateH );
void Locatexy(unsigned char x,unsigned char y, unsigned char attribs)
  unsigned int temp;
        if(attribs)temp += BasePart2*256;
        CmdWrite( CsrW );                                // ??Locate,??
        DataWrite( (unsigned char)(temp & 0xff) );        // ????CSRL?????????8?
        DataWrite( (unsigned char)(temp /256 ) );        // ????CSRH?????????8?
void Point(unsigned int Px, unsigned char Py, unsigned char attr )
  unsigned int tempPtr;
  unsigned char tempD,tempP;
        tempPtr = (unsigned int)Py * paraP9 + (Px & 0x7fff)/8;
        CmdWrite( CsrDirD );
        CmdWrite( CsrW );
        DataWrite( (unsigned char)(tempPtr & 0xff) );
        DataWrite( (unsigned char)(tempPtr /256) );
        CmdWrite( mRead );
        tempD = DataRead();
        tempP = 1<<(unsigned char)(7-Px & 0x0007);
        if( attr )tempD |= tempP;        // ??
        else tempD &= ~tempP;                                // ??
        CmdWrite( CsrW );
        DataWrite((unsigned char)(tempPtr & 0xff) );
        DataWrite((unsigned char)(tempPtr /256) );
        CmdWrite( mWrite );                                                // ??0x42,??????
        DataWrite( tempD );                                                        // ??????
void circle(unsigned int Ox,unsigned char Oy,unsigned char Rx,unsigned char attr)
        unsigned int xx,rr,xt,yt,rs,col,row;
        yt=Rx;
        rr=Rx*Rx+1;
        rs=(yt+(yt>>1))>>1;
        for (xt=0;xt<=rs;xt++)
                xx=xt*xt;
                while ((yt*yt)>(rr-xx))yt--;
                col=Ox+xt;                //????
                row=Oy-yt;
                Point(col,row,attr);
                col=Ox-xt;                //????
                row=Oy+yt;                //????
                col=Ox+xt;                //????
/***************45???????***************/
                col=Ox+yt;                //????
                row=Oy-xt;
                col=Ox-yt;                //????
                row=Oy+xt;                //????
                col=Ox+yt;                //????
void Linexy(unsigned int x0,unsigned char y0,unsigned int xt,unsigned char yt,unsigned char att)
        register unsigned char t;
        int        xerr=0,yerr=0,delta_x,delta_y,distance;
        int        incx,incy;
        unsigned int row,col;
        delta_x        = xt-x0;                                                        //??????
        delta_y        = yt-y0;
        col        = x0;
        row        = y0;
        if(delta_x>0) incx=1;                                                //??????
        else
            if( delta_x==0        ) incx=0;                                //???
                else {incx=-1;delta_x=-delta_x;}
        if(delta_y>0) incy=1;
        else
            if( delta_y==0        ) incy=0;
                else {incy=-1;delta_y=-delta_y;}
        if(        delta_x        > delta_y )        distance=delta_x;
        else distance=delta_y;
        for( t=0;t <= distance+1; t++ )
                Point((unsigned int)col,row,att);
                xerr +=        delta_x        ;
                yerr +=        delta_y        ;
                if(        xerr > distance        )
                        xerr-=distance;
                        col+=incx;
                if(        yerr > distance        )
                        yerr-=distance;
                        row+=incy;
void TextDisp( unsigned char Ox,unsigned char Oy, unsigned char  *ptr )
unsigned char TexLength=0,ii;
unsigned int  iTemp;
        while(ptr[TexLength]>0x1f) {TexLength++;};   // ??????
        iTemp = Oy*paraP9+Ox;
        CmdWrite( CsrForm );                // ??????,??0x5d
        DataWrite( 0x07 );                                // ????????CSX=8
        DataWrite( 0x07 );                                // ???????,????CSY=8
        CmdWrite( Ovlay );                        // ????????.??0x5b
        DataWrite( 0x01 );                                // ????:??3??????,??xor??
        CmdWrite( DispOn );                        // ????DISP ON/OFF??,????:
        DataWrite( 0x56 );                                // 01 01 01 10??1~4????,??????
        iTemp = (unsigned int)Oy * paraP9 + Ox;                            // ???????ram????
        CmdWrite( CsrDirR );                                        // ????????
        CmdWrite( CsrW );                                                // ??????
        DataWrite( (unsigned char)(iTemp &0xff) );                        // ??????CSR
        DataWrite( (unsigned char)(iTemp /256 + BasePart3) );        // ??????????SAD2H
        CmdWrite( mWrite );                                                // ??????????
        for(ii=0;ii < TexLength;ii++)
                   DataWrite( ptr[ii] );                                        // ????????
void PutCdotInGraph( unsigned int Ox, unsigned char Oy, unsigned char Cnumber, unsigned char DotWidth ) {
unsigned int tempPtr,Optr;
unsigned char tempCount1,tempCount2,nByte;
        Optr = (unsigned int)Oy * paraP9 + Ox;
        nByte = DotWidth/8;
        tempPtr = (unsigned int)Cnumber * DotWidth*nByte;
        for (tempCount1=0;tempCount1<nByte;tempCount1++) {
                CmdWrite( CsrW );
                DataWrite( (unsigned char)(Optr &0xff) );
                DataWrite( (unsigned char)(Optr /256 ) );
                CmdWrite( mWrite );
                switch(DotWidth)
                        case 16:        for(tempCount2=0;tempCount2<DotWidth;tempCount2++)
                                                         DataWrite( Cdotlib[tempCount2*2+tempCount1] );                // ????
                                                break;
                        case 24:        for(tempCount2=0;tempCount2<DotWidth;tempCount2++)
                                                         DataWrite( Cdot24lib[tempPtr] );                // ????
                                                         tempPtr += nByte;
                                                break;
                tempPtr = Cnumber * DotWidth*nByte + tempCount1 + 1;
                Optr++;
unsigned char dprintf(unsigned char x,unsigned char y, char  *ptr, unsigned char att)
        unsigned char  c1,c2;
        unsigned char i,j,uLen,uRow,uCol,temp;
        unsigned int  k;
        uRow = x;
        uCol = y;
        uLen=0;
        CmdWrite( CsrDirD );                                                 // ????????:????
        Locatexy(uRow,uCol,att);                                                //????
        while ( (unsigned char)ptr[uLen] >= 0x10 ){uLen++;};        //??????
        i=0;
        while(i<uLen)
                c1 = ptr[i];
                c2 = ptr[i+1];
//ascii????????????128???,?????????
                if(c1 <=128)        // ASCII
                        if (c1 >= 0x10)        {
                                CmdWrite( mWrite );                                // ???(??)
                                for(j=0;j<16;j++) DataWrite( ASC_MSK[(c1-0x20)*16 +j ]);
                        uRow++;        // ???1
                else        // ??
                        for(j=0;j < (sizeof(Cdotlib))/sizeof(Cdotlib[0]);j++)        // ????
                                  if((c1 == Cdotlib[temp*2 + k]) && (c2 == Cdotlib[temp + k]))        break;
                        for(k=0;k<2;k++)                                                // ?16???
                                Locatexy(uRow+k,uCol,att);
                                for(temp=0;temp<16;temp++) DataWrite( Cdotlib[temp*2 + k]);
                        uRow +=2;        // ???????
                        i++;
                if(uRow >= 40)        // ????
                        uCol += 16;        // Y??
                        uRow = 0;                                                            // X??
                        if( uCol >= 240 ) uCol = 0;
                i++;
        return uLen;        //??????,???2????
void PutCdotInAlpha( unsigned char Ox, unsigned char Oy, unsigned char Cnumber ) {
unsigned char tempCount;
        tempPtr = (unsigned int)Oy * paraP9 + Ox;
        CmdWrite( CsrDirD );                                        // CSRDIR ??(??)
        for(tempCount=0;tempCount<2;tempCount++) {
                CmdWrite( CsrW );                                        // CSRW ??,??????
                DataWrite( (unsigned char)(tempPtr &0xff) );        // ??????CSR
                DataWrite( tempPtr /256 + BasePart3 );
                DataWrite( Cnumber++ );                                        // ??????
                tempPtr++;        // ??????
void RollLaft( void )
        unsigned char tempI,jj=25;
        unsigned int  iTemp=0;
        while(jj--) {
                for(tempI=0;tempI<8;tempI++) {
                        CmdWrite( HdotScr );                // ??HDOT SET ??
                        DataWrite( tempI );                                // ????
                        DelayMs(20);                                                // ??????
                iTemp ++;
                CmdWrite( Scroll );                                // ??????????
                DataWrite( (unsigned char)(iTemp & 0xff) );                        // ????
                DataWrite( (unsigned char)(iTemp /256) );                        // ????
void Rollright( void ) {
        unsigned int  iTemp=24;
        while(jj--) {
                tempI = 8;
                CmdWrite( Scroll );                                // ????(??)??
                while( tempI-- ) {
                iTemp--;
void RollDown( void ) {
unsigned char         jj = 50;                                        // ??32?
unsigned int          iTemp=paraP9*50;
        while(jj--)
                   iTemp -= paraP9;
                   DelayMs(20);
        CmdWrite( Scroll );
        DataWrite( 0 );
        DataWrite( 0 );
void RollUp( void ) {
unsigned char         jj = 50;                                        // ??30?
        while(jj--) {
                iTemp += paraP9;
                DelayMs(30);                                // ??????
评分
参与人数 1一乐金币 +40 收起 理由
fujiachun + 40 很给力!
查看全部评分
发表于 2014-4-23 11:54 | 显示全部楼层
上图才是关键。又是黑白屏吧,我手里也有个老的黑白屏,还是高压背光。懒得摆弄了,除了耗电多使用麻烦,没有别的特色。
发表于 2014-4-23 12:04 | 显示全部楼层
用硬封装控制器的屏还是很容易玩起来的,驱动容易,也不怕找不到资料。
只是现在还有几个人喜欢单色屏呢?
发表于 2014-4-23 12:21 | 显示全部楼层
2楼真理,上图才是关键
发表于 2014-4-23 12:45 | 显示全部楼层
贴上来的注解都乱码,求上完整程序学习学习
发表于 2014-4-23 14:25 | 显示全部楼层
玩黑白屏就复古的感觉,,
发表于 2014-4-23 14:32 | 显示全部楼层
我还是比较喜欢黑白屏或者EL之类的屏,至少在某些专业领域我认为挺好的
发表于 2014-4-23 16:16 | 显示全部楼层
无论什么屏,点亮了就是高手
发表于 2014-4-23 17:21 | 显示全部楼层
上图,是什么样的屏都,不知道
 楼主| 发表于 2014-4-23 17:52 | 显示全部楼层
GMT+8, 2026-7-13 09:10 , Processed in 0.039334 second(s), 31 queries , Gzip On.
© 2001-2026 Discuz! Team.
