查看: 1790|回复: 6
AA121XJ01 AA084VE01 AA084XA03 AA084SA01 AA065VB03 AA065VB05 AA065VB01 三菱液晶屏
发表于 2014-5-20 12:02 | 显示全部楼层 |阅读模式
AA121XJ01 AA084VE01 AA084XA03 AA084SA01 AA065VB03 AA065VB05 AA065VB01 G065VN01 V.2 V.1 V.0   AA065VB01  NL6448BC20-18D
GEKODA ELECTRONIC ( HK ) CO.,LIMITED
TEL:86-755-29481291 13714589913
FAX: 86-755-83319773
E-MAIL:gdszwzh@vip.126.com
MSN: wenzihui1113@hotmail.com
QQ: 1835409144
SKYPE: wenzihui
http://www.gekoda.com/
http://www.gkd-lcd.com/
http://wenzihui.taobao.com/
*-*-NSN03-*-8510H11-0101
MADE  IN  JAPAN
R70HS0AC
MITSUBISHI ELECTRIC
AA121XJ01
E158720
121X04S
121X04S1D2
JAE
13PCS   3PCS A
ITEM                   SPECIFICATION
Display Area (mm)  245.76(H) u 184.32(V)   (12.106-inch diagonal)
Number of Dots 1024 u3 (H) u 768 (V)
Pixel Pitch (mm) 0.240 (H) u 0.240 (V)
Color Pixel Arrangement RGB vertical stripe
Display Mode Normally white TN
Number of Color 262 K(6 bit/color), 16.7 M(8 bit/color)
Brightness (cd/m2) 1000
Wide Viewing Angle Technology Optical Compensation Film
Viewing Angle (CR t10) -65~65° (H) -75~45° (V)
Surface Treatment :Antiglare and hard-coating 3H
Electrical Interface: LVDS(6 bit/8 bit)
Optimum Viewing Angle(Contrast ratio) 6 o’clock
Module Size (mm) 280.0 (W) u 219.0 (H) u 17.8 (D)
Module Mass (g) 1150
Backlight Unit CCFL, 4-tubes, edge-light, replaceable
1 VCC +3.3 V Power supply m
2 VCC +3.3 V Power supply m
3 GND GND m
4 GND GND m
5 Link 0- R0, R1, R2, R3, R4, R5, G0 R2, R3, R4, R5, R6, R7, G2 R0, R1, R2, R3, R4, R5, G0
6 Link 0+ R0, R1, R2, R3, R4, R5, G0 R2, R3, R4, R5, R6, R7, G2 R0, R1, R2, R3, R4, R5, G0
7 GND GND m
8 Link 1- G1, G2, G3, G4, G5, B0, B1 G3, G4, G5, G6, G7, B2, B3 G1, G2, G3, G4, G5, B0, B1
9 Link 1+ G1, G2, G3, G4, G5, B0, B1 G3, G4, G5, G6, G7, B2, B3 G1, G2, G3, G4, G5, B0, B1
10 GND GND m
11 Link 2- B2, B3, B4, B5, DENA B4, B5, B6, B7, DENA B2, B3, B4, B5, DENA
12 Link 2+ B2, B3, B4, B5, DENA B4, B5, B6, B7, DENA B2, B3, B4, B5, DENA
13 GND GND m
14 CLKIN- Clock - m
15 CLKIN+ Clock + m
16 GND GND m
17 Link3- See: *2) R0, R1, G0, G1, B0, B1 R6, R7, G6, G7, B6, B7
18 Link3+ See: *2) R0, R1, G0, G1, B0, B1 R6, R7, G6, G7, B6, B7
19 MODE Low=ISP 6 bit compatibility mode High=ISP
8 bit compatibility mode
20 SC Scan direction control. ( Low : Normal , High : Reverse ) m
Melco Display Technology Lnc.
8.4INCH VGA MAA084DVE01
A-D-CVE01-G0818St13 1
MADE  IN  JAPAN
QC03C0KA
QC03D0KD
MITSUBISHI ELECTRIC
AA084VE01
E158720
084V
084V03S2D3
16PCS   8PCS A
Screen Size
21cm (8.4 inch)
Model Name
AA084VE01
Number of Pixels
640 × 480
Pixel Pitch (H倶V/mm)
0.267 × 0.267
Brightness (cd/m2)
200
Contrast Ratio
200:1
CMOS
Power Supply Voltage (V)
3.3
Viewing Angle (°)
80/80 (R/L) 50/70 (U/D)*
Number of Colors
262k (6-bit)
Module Size (mm)
199.5 (W) × 149.0 (H) × 11.5 (D)
Module Mass (g)
360 (typ)
Backlight Unit
CCFT, 2 tubes (replaceable)
(Contrast Ratio)
6 o'clock*
8.4INCH VGA MAA084DXA03
*-D-AXA03-B9708St11 L
MADE  IN  JAPAN
Q20JQ03D
Q20DS08F
MITSUBISHI ELECTRIC
AA084XA03
E158720
084X02S
15PCS   2PCS NG
Screen Size
21cm (8.4 inch)
Model Name
AA084XA03
Number of Pixels
1024 × 768
0.167 × 0.167
Brightness (cd/m2)
300
Contrast Ratio
400:1
LVDS
3.3
Viewing Angle (°)
65/65 (R/L) 60/50 (U/D)*
Number of Colors
262k/16.77M (6-bit/8-bit)
Module Size (mm)
205.0 (W) × 152.4 (H) × 11.3 (D)
Module Mass (g)
380
Backlight Unit
(Contrast Ratio)
12 o'clock*
8.4INCH VGA MAA084DSA01
*-A-CSA01-G0311St13 L
MADE  IN  JAPAN
QE06N08D
MITSUBISHI ELECTRIC
AA084SA01
E158720
1PCS
Screen Size
21cm (8.4 inch)
Model Name
AA084SA01
Number of Pixels
800 × 600
0.213 × 0.213
Brightness (cd/m2)
400
Contrast Ratio
600:1
LVDS
3.3
Viewing Angle (°)
80/80 (R/L) 80/60 (U/D)*
Number of Colors
Module Size (mm)
Module Mass (g)
380
Backlight Unit
(Contrast Ratio)
6 o'clock*
6.5INCH VGA MAA065DVB03
A-C-NVB01-A7512St11-0439
MADE  IN  JAPAN
B40440BE
MITSUBISHI ELECTRIC
AA065VB03
E158720
065V01S1
065V01S1C1
3PCS
ITEM                 SPECIFICATION
Display Area (mm) 132.48(H) × 99.36(V)
               (6.5-inch diagonal)
Number of Dots 640 × 3 (H) × 480 (V)
Pixel Pitch (mm) 0.207 (H) × 0.207 (V)
Number of Color 262k
Luminance (cd/m2) 600
Wide Viewing Angle Technology Optical compensation film
Viewing Angle (CR ≥ 10) ?65?65° (H) ?60~50° (V)
Surface Treatment Anti-reflection and hard-coating 2H
Electrical Interface CMOS
Optimum Viewing Angle (Contrast ratio) 6 o’clock
Module Size (mm) 154.0 (W) × 121.0 (H) × 11.0 (D)
Module Mass (g) 205
Backlight Unit CCFL, 2-tubes, edge-light, replaceable
6.5INCH VGA MAA065DVB05
A-C-NVB01-A6824St11-0333
A-C-NVB01-A6914St11-0114
A-C-NVB01-A8515St11-0150
MADE  IN  JAPAN
B401R0JB
B40290LD
BC01202E
MITSUBISHI ELECTRIC
AA065VB05
E158720
065V01S1
065V01S1 C1
065V02S 2E6  TW10794V-0
15PCS   1PCS A
Screen Size
17cm (6.5 inch)
Model Name
AA065VB05
Number of Pixels
640 × 480
Pixel Pitch (HV/mm)
0.207 × 0.207
Brightness (cd/m2)
400
Contrast Ratio
600:1
CMOS
3.3
Viewing Angle (°)
Number of Colors
262k (6-bit)
Module Size (mm)
Module Mass (g)
205
Backlight Unit
(Contrast Ratio)
6 o'clock*
6.5INCH VGA MAA065DVB01
A-C-NVB01-A8903St11-0386
MADE  IN  JAPAN
B408809A
MITSUBISHI ELECTRIC
AA065VB01
E158720
065V01S1
065V01S1 C1
96PCS
ITEM           SPECIFICATION
Display Area (mm) 132.48(H) × 99.36(V)   (6.5-inch diagonal)
Display Mode normally white
Number of Color 260K
Brightness (cd/m2) 400
Module Mass (g) 220
Surface Treatment Anti-glare and hard-coating 3H
三菱液晶屏型号:AA043MA01 AA050MA01 AA050ME01 AA057VF02 AA065VB01 AA065VB02 AA065VB03 AA065VB05 AA084VC04 AA084VC05 AA084VE01 AA084SA01 AA084XA03 AA090MC01 AA104VC02 AA104VC08 AA104VC09 AA104VC10 AA104VC11 AA104VF01 AA104VF02 AA104SG01 AA104SG02 AA104XA02 AA121SL03 AA121SL08 AA121SL09 AA121SL10 AA121SL11 AA121SM01 AA121SM02 AA121SN01 AA121SN02 AA121SN03 AA121SN04 AA121XH03 AA121XH04 AA121XH05 AA121XJ01 AA121XJ02 AA121TA01 AA141TA01 AA150XN02 AA150XC01 AA150XN01 AA150XN02 AA150XN03 AA150XN04 AA150XN08 AA150XR01 AA175TB01
评分
参与人数 1一乐金币 -30 收起 理由
jigsaw -30 封ID吧
查看全部评分
发表于 2014-5-20 12:14 | 显示全部楼层
滚轮滑动了半天终于发现有汉语了。真不容易啊
发表于 2014-5-20 12:25 | 显示全部楼层
LZ欲传达怎样一种意思?
发表于 2014-5-20 12:28 | 显示全部楼层
屏太贵没有人会以要的。
 楼主| 发表于 2014-5-20 17:00 | 显示全部楼层
CHQING1361 发表于 2014-5-20 12:28
屏太贵没有人会以要的。
如果要货的话, 可以给我一个目标价格的,能做就做呗。
发表于 2014-5-20 20:54 | 显示全部楼层
如果搞维修的或许可以要,要是搞开发估计有点困难。。。。。量产供货困难。。。
发表于 2014-5-21 20:46 | 显示全部楼层
去38度卖啊。钱多的都在38度
GMT+8, 2025-8-19 09:36 , Processed in 0.040022 second(s), 24 queries , Gzip On.
