管理员
帖子
积分34960
阅读权限200
注册时间2008-11-13
以下是脚本的源码,粗看了一下似乎没有什么问题
* This code is data acquisition code for www.linezing.com web traffic analysis platform.
* www.linezing.com is Taobao's website.
function lz_encode(str)
var e = "", i = 0;
for(i=0;i<str.length;i++) {
if(str.charCodeAt(i)>=0&&str.charCodeAt(i)<=255) {
e = e + escape(str.charAt(i));
else {
e = e + str.charAt(i);
return e;
function lz_get_screen()
var c = "";
if (self.screen) {
c = screen.width+"x"+screen.height;
return c;
function lz_get_color()
var c = "";
if (self.screen) {
c = screen.colorDepth+"-bit";
return c;
function lz_get_language()
var l = "";
var n = navigator;
if (n.language) {
l = n.language.toLowerCase();
else
if (n.browserLanguage) {
l = n.browserLanguage.toLowerCase();
return l;
function lz_get_agent()
var a = "";
var n = navigator;
if (n.userAgent) {
a = n.userAgent;
return a;
function lz_get_jvm_enabled()
var j = "";
var n = navigator;
j = n.javaEnabled() ? 1 : 0;
return j;
function lz_get_cookie_enabled()
var c = "";
var n = navigator;
c = n.cookieEnabled ? 1 : 0;
return c;
function lz_get_flash_ver()
var f="",n=navigator;
if (n.plugins && n.plugins.length) {
for (var ii=0;ii<n.plugins.length;ii++) {
if (n.plugins[ii].name.indexOf('Shockwave Flash')!=-1) {
f=n.plugins[ii].description.split('Shockwave Flash ')[1];
break;
else
if (window.ActiveXObject) {
for (var ii=10;ii>=2;ii--) {
try {
var fl=eval("new ActiveXObject('ShockwaveFlash.ShockwaveFlash."+ii+"');");
if (fl) {
f=ii + '.0';
break;
catch(e) {}
return f;
function lz_get_app()
var a = "";
var n = navigator;
if (n.appName) {
a = n.appName;
return a;
function lz_c_ctry_top_domain(str)
var pattern = "/^aero$|^cat$|^coop$|^int$|^museum$|^pro$|^travel$|^xxx$|^com$|^net$|^gov$|^org$|^mil$|^edu$|^biz$|^info$|^name$|^ac$|^mil$|^co$|^ed$|^gv$|^nt$|^bj$|^hz$|^sh$|^tj$|^cq$|^he$|^nm$|^ln$|^jl$|^hl$|^js$|^zj$|^ah$|^hb$|^hn$|^gd$|^gx$|^hi$|^sc$|^gz$|^yn$|^xz$|^sn$|^gs$|^qh$|^nx$|^xj$|^tw$|^hk$|^mo$|^fj$|^ha$|^jx$|^sd$|^sx$/i";
if(str.match(pattern)){ return 1; }
return 0;
function lz_c_ctry_domain(str)
var pattern = "/^ac$|^ad$|^ae$|^af$|^ag$|^ai$|^al$|^am$|^an$|^ao$|^aq$|^ar$|^as$|^at$|^au$|^aw$|^az$|^ba$|^bb$|^bd$|^be$|^bf$|^bg$|^bh$|^bi$|^bj$|^bm$|^bo$|^br$|^bs$|^bt$|^bv$|^bw$|^by$|^bz$|^ca$|^cc$|^cd$|^cf$|^cg$|^ch$|^ci$|^ck$|^cl$|^cm$|^cn$|^co$|^cr$|^cs$|^cu$|^cv$|^cx$|^cy$|^cz$|^de$|^dj$|^dk$|^dm$|^do$|^dz$|^ec$|^ee$|^eg$|^eh$|^er$|^es$|^et$|^eu$|^fi$|^fj$|^fk$|^fm$|^fo$|^fr$|^ly$|^hk$|^hm$|^hn$|^hr$|^ht$|^hu$|^id$|^ie$|^il$|^im$|^in$|^io$|^ir$|^is$|^it$|^je$|^jm$|^jo$|^jp$|^ke$|^kg$|^kh$|^ki$|^km$|^kn$|^kp$|^kr$|^kw$|^ky$|^kz$|^la$|^lb$|^lc$|^li$|^lk$|^lr$|^ls$|^lt$|^lu$|^lv$|^ly$|^ga$|^gb$|^gd$|^ge$|^gf$|^gg$|^gh$|^gi$|^gl$|^gm$|^gn$|^gp$|^gq$|^gr$|^gs$|^gt$|^gu$|^gw$|^gy$|^ma$|^mc$|^md$|^mg$|^mh$|^mk$|^ml$|^mm$|^mn$|^mo$|^mp$|^mq$|^mr$|^ms$|^mt$|^mu$|^mv$|^mw$|^mx$|^my$|^mz$|^na$|^nc$|^ne$|^nf$|^ng$|^ni$|^nl$|^no$|^np$|^nr$|^nu$|^nz$|^om$|^re$|^ro$|^ru$|^rw$|^pa$|^pe$|^pf$|^pg$|^ph$|^pk$|^pl$|^pm$|^pr$|^ps$|^pt$|^pw$|^py$|^qa$|^wf$|^ws$|^sa$|^sb$|^sc$|^sd$|^se$|^sg$|^sh$|^si$|^sj$|^sk$|^sl$|^sm$|^sn$|^so$|^sr$|^st$|^su$|^sv$|^sy$|^sz$|^tc$|^td$|^tf$|^th$|^tg$|^tj$|^tk$|^tm$|^tn$|^to$|^tp$|^tr$|^tt$|^tv$|^tw$|^tz$|^ua$|^ug$|^uk$|^um$|^us$|^uy$|^uz$|^va$|^vc$|^ve$|^vg$|^vi$|^vn$|^vu$|^ye$|^yt$|^yu$|^za$|^zm$|^zr$|^zw$/i";
return 0;
function lz_get_domain(host)
var d=host.replace(/^www\./, "");
var ss=d.split(".");
var l=ss.length;
if(l == 3){
if(lz_c_ctry_top_domain(ss[1]) && lz_c_ctry_domain(ss[2])){
else{
d = ss[1]+"."+ss[2];
else if(l >= 3){
var ip_pat = "^[0-9]*\.[0-9]*\.[0-9]*\.[0-9]*$";
if(host.match(ip_pat)){
return d;
if(lz_c_ctry_top_domain(ss[l-2]) && lz_c_ctry_domain(ss[l-1])) {
d = ss[l-3]+"."+ss[l-2]+"."+ss[l-1];
else{
d = ss[l-2]+"."+ss[l-1];
return d;
function lz_get_cookie(name)
var mn=name+"=";
var b,e;
var co=document.cookie;
if (mn=="=") {
return co;
b=co.indexOf(mn);
if (b < 0) {
return "";
e=co.indexOf(";", b+name.length);
if (e < 0) {
return co.substring(b+name.length + 1);
else {
return co.substring(b+name.length + 1, e);
function lz_set_cookie(name, val, cotp)
var date=new Date;
var year=date.getFullYear();
var hour=date.getHours();
var cookie="";
if (cotp == 0) {
cookie=name+"="+val+";";
else if (cotp == 1) {
year=year+10;
date.setYear(year);
cookie=name+"="+val+";expires="+date.toGMTString()+";";
else if (cotp == 2) {
hour=hour+1;
date.setHours(hour);
var d=lz_get_domain(document.domain);
if(d != ""){
cookie +="domain="+d+";";
cookie +="path="+"/;";
document.cookie=cookie;
function str_reverse(str) {
var ln = str.length;
var i=0;
var temp="";
for(i=ln-1; i>-1; i--) {
if(str.charAt(i)==".")
temp += "#";
else
temp += str.charAt(i);
return temp;
function lz_get_ss_id(str)
len=str.indexOf("_");
str=str.substring(len+1);
return str;
function lz_get_ss_no(str) {
str=str.substring(0,len);
return parseInt(str);
function lz_get_stm()
var date = new Date();
var yy=date.getFullYear();
var mm=date.getMonth();
var dd=date.getDate();
var hh=date.getHours();
var ii=date.getMinutes();
var ss=date.getSeconds();
var i;
var tm=0;
for(i = 1970; i < yy; i++) {
if ((i % 4 == 0 && i % 100 != 0) || (i % 100 == 0 && i % 400 == 0)) {
tm=tm+31622400;
else {
tm=tm+31536000;
mm=mm+1;
for(i = 1; i < mm; i++) {
if (i == 1 || i == 3 || i == 5 || i == 7 || i == 8 || i == 10 || i == 12) {
tm=tm+2678400;
else {
if (i == 2) {
if ((yy % 4 == 0 && yy % 100 != 0) || (yy % 100 == 0 && yy % 400 == 0)) {
tm=tm+2505600;
else {
tm=tm+2419200;
else {
tm=tm+2592000;
tm = tm + (dd-1) * 86400; tm = tm + hh * 3600;
tm = tm + ii * 60;
tm = tm + ss;
return tm;
function lz_get_ctm(str) {
return parseInt(str, 10);
/* main function */
function lz_main()
var unit_id = "951838";
var client_ip = "121.14.63.173";
var server_time = "1278171747";
var verify_code = "19fd7929";
var type = "2";
var dest_path = "http://dt.tongji.linezing.com/tongji.do?unit_id="+unit_id;
var expire_time = 1800;
var i;
var host=document.location.host;
var domain = lz_get_domain(host.toLocaleLowerCase());
var hashval = 0;
for (i=0; i< domain.length; i++){
hashval += domain.charCodeAt(i);
var uv_str = lz_get_cookie("lzstat_uv");
var uv_id = "";
var uv_new = 0;
if (uv_str == ""){
uv_new = 1;
var rand1 = parseInt( Math.random() * 4000000000 );
var rand2 = parseInt( Math.random() * 4000000000 );
uv_id = String(rand1) + String(rand2);
var value = uv_id+"|"+unit_id;
lz_set_cookie("lzstat_uv", value, 1);
else{
var arr = uv_str.split("|");
uv_id = arr[0];
var uids_str = arr[1];
var uids = uids_str.split("@");
var uid_num = uids.length;
var bingo = 0;
for(var pos=0,max=uids.length;pos<max;pos++) {
var uid = uids[pos];
if (uid == unit_id){
bingo = 1;
break;
if (bingo == 0){
uv_new = 1;
if (uid_num >= 100){
else{
var value = uv_str+"@"+unit_id;
var ss_str = lz_get_cookie("lzstat_ss");
var ss_id = "";
var ss_no = 0;
if (ss_str == ""){
ss_no = 0;
var rand = parseInt(Math.random() * 4000000000);
ss_id = String(rand);
value = ss_id+"_"+"0_"+lz_get_stm()+"_"+unit_id;
lz_set_cookie("lzstat_ss", value, 0);
else {
var arr = ss_str.split("|");
var ss_num = arr.length;
var bingo = 0;
for(var pos=0,max=arr.length;pos<max;pos++) {
var ss_info = arr[pos];
var items = ss_info.split("_");
var cookie_ss_id = items[0];
var cookie_ss_no = parseInt(items[1]);
var cookie_ss_stm = items[2];
var cookie_ss_uid = items[3];
if (cookie_ss_uid == unit_id){
bingo = 1;
if (lz_get_stm() - cookie_ss_stm > expire_time) {
ss_no = 0;
else{
ss_no = cookie_ss_no + 1;
ss_id = cookie_ss_id;
value = ss_id+"_"+ss_no+"_"+lz_get_stm()+"_"+unit_id;
arr[pos] = value;
ss_str = arr.join("|");
lz_set_cookie("lzstat_ss", ss_str, 0);
break;
if (bingo == 0)
ss_no = 0;
if (ss_num >= 20){
pos = parseInt(Math.random() * ss_num);
else{
pos = ss_num;
arr[pos] = value;
var ref = document.referrer;
ref = lz_encode(String(ref));
var url = document.URL;
url = lz_encode(String(url));
var title = document.title;
title = escape(String(title));
var charset = document.charset;
charset = lz_encode(String(charset));
var screen = lz_get_screen();
screen = lz_encode(String(screen));
var color =lz_get_color();
color =lz_encode(String(color));
var language = lz_get_language();
language = lz_encode(String(language));
var agent =lz_get_agent();
agent =lz_encode(String(agent));
var jvm_enabled =lz_get_jvm_enabled();
jvm_enabled =lz_encode(String(jvm_enabled));
var cookie_enabled =lz_get_cookie_enabled();
cookie_enabled =lz_encode(String(cookie_enabled));
var flash_ver = lz_get_flash_ver();
flash_ver = lz_encode(String(flash_ver));
var app = lz_get_app();
app = lz_encode(String(app));
var filtered = 0;
var domain_filters = new Array();
var ip_filters = new Array();
domain_filters[0] = "gro#tra763";
domain_filters[1] = "moc#olzd";
domain_filters[2] = "moc#tra763";
domain_filters[3] = "moc#df571";
domain_filters[4] = "ten#oog1";
domain_filters[5] = "nc#ppk1";
domain_filters[6] = "nc#osnaknak";
domain_filters[7] = "nc#emocwww";
domain_filters[8] = "nc#psalla";
domain_filters[9] = "moc#oesii";
domain_filters[10] = "moc#kh0083";
domain_filters[11] = "nc#kpwww";
domain_filters[12] = "nc#moc#zw001";
domain_filters[13] = "nc#kpemoc";
domain_filters[14] = "moc#eyiq063";
domain_filters[15] = "moc#qqa4";
domain_filters[16] = "ten#aboakoak";
domain_filters[17] = "moc#ecilliw";
domain_filters[18] = "nc#moc#ibeea";
domain_filters[19] = "moc#ibeea";
domain_filters[20] = "nc#tra763";
domain_filters[21] = "moc#025sns";
domain_filters[22] = "moc#og321oah";
domain_filters[23] = "moc#9zznc";
domain_filters[24] = "nc#9zznc";
domain_filters[25] = "moc#d135";
domain_filters[26] = "moc#ridzoog";
domain_filters[27] = "ten#rqrq";
domain_filters[28] = "moc#195nak";
domain_filters[29] = "moc#uynijtn";
domain_filters[30] = "moc#falwen";
domain_filters[31] = "nc#moc#njyhxj";
var escape_domain = str_reverse(domain);
for (i in domain_filters){
if(domain_filters == escape_domain)
filtered = 1;
for (i in ip_filters){
if(ip_filters == client_ip){
filtered = 1;
break;
var url_id = 0;
var cur_url = location.href;
dest=dest_path+"&uv_id="+uv_id+"&uv_new="+uv_new+"&cna="+""+"&cg="+""+"&mid="+""+"&mmland="+""+"&ade="+""+"&adtm="+""+"&sttm="+""+"&cpa="+""+"&ss_id="+ss_id+"&ss_no="+ss_no+"&ec="+cookie_enabled+"&ref="+ref+"&url="+url+"&title="+title+"&charset="+charset+"&domain="+domain+"&hashval="+hashval+"&filtered="+filtered+"&app="+app+"&agent="+agent+"&color="+color+"&screen="+screen+"&lg="+language+"&je="+jvm_enabled+"&fv="+flash_ver+"&st="+server_time+""+"&vc="+verify_code+""+"&ut=2"+"&url_id="+url_id+"&cnu="+String(Math.random());
document.write("<img src=\""+dest+"\" border=\"0\" width=\"1\" height=\"1\" />");
var icon_link_host="tongji.alimama.com";
document.write( "<a href=\"http://"+icon_link_host+"/report.html?unit_id="+unit_id+"\" target=\"_blank\"><img src=\"http://js.tongji.linezing.com/icon1.gif\" border=\"0\" alt=\"量子统计\"></a>" );
if(cur_url.indexOf('#lzclickmap=')>-1) {
var token = cur_url.substr(cur_url.indexOf('#lzclickmap='), 44);
document.write('<scr'+'ipt src=\'http://tongji.linezing.com/clickmap/load_clickmap.html?r='+Math.random()+token+'\'></scr'+'ipt>');
return false;
if(url_id>0)
document.write('<scr'+'ipt src=\'http://js.tongji.linezing.com/951838/'+url_id+'/clickcollect.js\'></scr'+'ipt>');
lz_main(); |
