查看: 6274|回复: 17
用6元的这种液晶屏做的GPS测速器
发表于 2010-9-16 11:44 | 显示全部楼层 |阅读模式
因为最近重庆船帮(航模)的快艇越来越多,准备破百的船也越来越多,作为重庆船帮的一员,准备做一个测速的GPS,好对现在船只的速度做一个量化,准备用手头现成的GPS模块+AVR单片机+1602液晶 做一个小体积的测速器。
设计电路,尽量简化功能
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_399043558502f79dd5537fI7bxO2dAb5.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 01.jpg (139.84 KB)
2010-9-16 00:01
先用CNC雕刻机 做电路板~
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_4b3ce2d53410792c37b1Tzy3ybybF7Tt.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 02.jpg (104.53 KB)
2010-9-16 00:01
开工前照片
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_68b0fe2dee3cd6dd091f82ld99idxx8t.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 03.jpg (83.15 KB)
2010-9-16 00:01
基本完工,其中开始还不能正常工作,怀疑程序或者液晶问题,结果发现是单片机是坏的。。。。郁闷,换了后测试正常。上面助焊剂没有洗掉,看起来脏脏的。
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_cef12457e2119bf1d4427uomFMLcUj6p.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 04.jpg (50.08 KB)
2010-9-16 00:01
更换单片机正常,以泄心头之恨
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_fe4a2f14c41ad0956976B2pKZbQgg1OQ.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 05.jpg (36.88 KB)
2010-9-16 00:01
每次重新上电发现搜星要很久,基本上要十几分钟,结果是GPS板载小锂电用完了(买的拆机GPS模块,估计放得久了),找了一块主板电池CR2032,焊接好装上去,这下可以用N久了。。。
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_99375daf34bf86fe9e37DM6gg6Ex66ie.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 06.jpg (71.91 KB)
2010-9-16 00:01
连接一览,暂时用的外接天线放在窗台边调试
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_2a674edc5b7edf2c06ddHNY1LPlq5H5P.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 07.jpg (83.84 KB)
2010-9-16 00:01
定位信息,暂时测试一下。。。
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_d597ba97a76f17c2abfc686h3X73ehI3.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 08.jpg (68.97 KB)
2010-9-16 00:01
  今天把程序的数据提取部分、单位转换部分(节转换成千米/小时)、最大速度处理、按键判断部分完善
这是开机画面
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_631bee8893c0a245149eZ0BbyNrgI04M.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 09.jpg (92.36 KB)
2010-9-16 00:01
搜星画面,如果途中信号丢失也会自动转到这里,继续搜星
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_725a59efea32c08e48177lFbU18Nn44B.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 10.jpg (88.03 KB)
2010-9-16 00:01
搜星完毕,可以进行测试,显示数值即为速度最大值
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_c3696e346db6b26c4730XIp212VXI2Z3.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 11.jpg (92.46 KB)
2010-9-16 00:01
接下来准备外壳中。
外壳去买了三个,各种大小,这种最合适80x60x30,好不容易把2片锂电池、主控板、两个开关、GPS模块、液晶屏幕、充电口,连接线若干塞进这个壳子里面,正在充电中。。。外壳丑了点。。。。
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_696e0178093425edbe62SHo3JHzQ7CDH.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 12.jpg (59.32 KB)
2010-9-16 00:01
都是自己用笔写的
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_8ad13a4ff1935f63394bt67QtmXu0u0E.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 13.jpg (59.29 KB)
2010-9-16 00:01
可以用内置天线,也可以外接天线
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_c3c4d1f73a2a0eed31fd31VVJz3IhD96.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 14.jpg (46.9 KB)
2010-9-16 00:01
2S的航模标准充电口
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_176148e2ebb2b5af7717kx7j6xKpklSI.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 15.jpg (54.85 KB)
2010-9-16 00:01
全重131g
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_00fe6353cb3a17a3ed640NaW8ihN4WY4.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 16.jpg (45.61 KB)
2010-9-16 00:01
大小参照,没办法,我已经尽力了,在手头这些东东的情况下,没有额外花钱,就是花3元钱买了一个这个壳子。
http://bbs.5imx.com/bbs/images/GreenPark/attachimg.gif http://bbs.5imx.com/bbs/attachments/day_100916/20100916_3dfece78182ad6cb82f9eBpfsxXCSxCa.jpg http://bbs.5imx.com/bbs/images/attachicons/image.gif 17.jpg (79.68 KB)
2010-9-16 00:01
明天上班的时候拿到公交车上测试~~~~
主程序源代码晚上会发上来
基本测试数据:
电源供电:2S 手机锂电芯  7805降压  单片机、液晶屏幕 5V  gps 3.3v
总电流消耗:50ma(背光关闭)  70ma(背光开启)
GPS备份电池电流消耗:14 uA
 楼主| 发表于 2010-9-16 11:44 | 显示全部楼层
大家能不能看到图?我没传到这个服务器上
评分
参与人数 1一乐金币 +10 收起 理由
无锡风 + 10 创意
查看全部评分
发表于 2010-9-16 12:00 | 显示全部楼层
大家能不能看到图?我没传到这个服务器上
cqmiao 发表于 2010-9-16 11:44 https://www.yleee.com.cn/images/common/back.gif
可以看到。
发表于 2010-9-16 12:17 | 显示全部楼层
最好还是传上,因为有时候会不允许外链导致看不到
发表于 2010-9-16 19:05 | 显示全部楼层
人才~~~~
发表于 2010-9-16 19:10 | 显示全部楼层
麻烦楼主把图全部传上来吧,有价值的资料多一个地方保存多一分保险。此帖有加精潜力。
发表于 2010-9-16 19:22 | 显示全部楼层
发表于 2010-9-16 19:42 | 显示全部楼层
LZ开源的电源我现在还在使用中。希望这次的我也能仿制成功!顺便说下对GPS模块的选择要求吧!
发表于 2010-9-16 20:30 | 显示全部楼层
是个好东西,装在车上应该不错
发表于 2010-9-17 10:53 | 显示全部楼层
把你的船也亮一亮吧, 这是我最关心的.
GMT+8, 2025-11-24 05:55 , Processed in 0.039650 second(s), 31 queries , Gzip On.
