钻石会员
帖子
积分31458
阅读权限50
注册时间2008-11-16
http://item.taobao.com/item.htm?_u=6astivf094&id=36891455542
拍万能拍
1、A8的安卓开发板,串口接上有数据,可以进入命令行,接口有minipci,sata,hdmi,av,usb,网口等,使用5v电源,有测试图,串口接上
95元!(板子是接插结果,接口多)有图片跟串口数据(参数是4g rom 512m ram,cpu是tcc8801)
2、14寸的液晶屏,拆机的,有1个亮点,其它可以,1024*768的,40元一片,测试好的
3、57mm的主轴座,很重,40元,三个夹头(2个雕刻机的,一个er11夹头),三个夹头,40元!这堆打包,包快递
4、一堆外壳(电脑外壳,铝外壳,nas外壳,播放器外壳,都是外壳),一堆外壳,免费送,出打包费+邮费就行
5、atx老电源,老的品牌机的电源,1.7kg一个,共2个,只要5元一个
6、mini pci 网卡,5元
快递10元(1kg以内)
开发板串口上电数据
welcome to lk
i2c-tcc: time out!
at070tn93_panel_init : 0
telechips tcc88xx lcdc_io_init lcdc:1 clk:333000 set clk:672000
at070tn93_set_power : 1 ~
lcdc_io_init end
lcdc: panel is 800 x 480 32bpp
fb_cfg base:0x4204f5c8 xres:480 yres:272 bpp:32
tcclcd_image_ch_set lcdc:1 pLCD_ch :0x0
at070tn93_set_backlight_level : 255
Diplay initialized
platform_init()
target_init()
[NAND Physical Invalid Block Info]
CS#0: (25/1024)Blocks - (50/2048)Blocks
[NAND FTL Invalid Block Info]
[Total Physical Invalid Block Info]
(50/2048)Blocks
[Total FTL Invalid Block Info]
(25/1024)Blocks
[TNFTL MTD] [nPBpV:2048][nBBpZ:25][MTDBlockNum:256][MTDRervBlk:14]
[NAND ] [PORT CONFIG - CS[0, 1] [NAND Data Port: GPIO_B Hw4 ~ Hw11]
[NAND ] [BClk 168MHZ][1Tick 60][RE-S:0,P:5,H:2][WR-S:0,P:3,H:2][COM-S:2,P:15,H:15]
[NAND ] [NB Area:4MB][DT Area:3160MB][HD Area0:0MB][MTD Size:512MB]
[NAND ] [BadBlockNum: 0]
[NAND ] [Blk:]
-------------- [ Partition Table ] --------------
[Part 0. boot] [Start: 24] [Length: 5]
[Part 1. kpanic] [Start: 29] [Length: 3]
[Part 2. system] [Start: 32] [Length: 75]
[Part 3. splash] [Start: 107] [Length: 2]
[Part 4. cache] [Start: 109] [Length: 20]
[Part 5. userdata] [Start: 129] [Length: 144]
[Part 6. recovery] [Start: 273] [Length: 5]
[Part 7. misc] [Start: 278] [Length: 1]
[Part 8. tcc] [Start: 279] [Length: 1]
[NAND ] [Maker:0xad ][Device:0xd7][Page_size:8192]
[Spare_Size:256][Block_Size:256][MTD_Block:256][Rerv_Block:14]
[Golden Info] [Devide :0] [Bad Block: 0]
[Golden Info] [Nand Total Bad Block: 0]
[Create Bad Table[ 0] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Create Bad Table[ 1] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Create Bad Table[ 2] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Create Bad Table[ 3] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Create Bad Table[ 4] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Create Bad Table[ 5] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Create Bad Table[ 6] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Create Bad Table[ 7] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Create Bad Table[ 8] : [BadBlkNum = 0] [AccBadBlkNum = 0]
[Set BadBlk Table] [Rerv Block:14] [Bad Block:0]
flash_read_image: success (0 errors)
kernel @ 40008000 (5161888 bytes)
ramdisk @ 41000000 (719161 bytes)
Booting Linux
booting linux @ 0x40008000, ramdisk @ 0x41000000 (719161)
cmdline: console=ttyTCC,115200n8 androidboot.serialno=00000000000000001104131853030095
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 2.6.35.7-tcc (s080039@tcsz-svr) (gcc version 4.4.3 (GCC) ) #4 Fri Apr 22 17:59:41 CST 2011
[ 0.000000] CPU: ARMv7 Processor [412fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: tcc8800
[ 0.000000] Ignoring unrecognised tag 0x54434380
[ 0.000000] Memory policy: ECC disabLED, Data cache writeback
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttyTCC,115200n8 androidboot.serialno=00000000000000001104131853030095
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 512MB = 512MB total
[ 0.000000] Memory: 416936k/416936k available, 107352k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff600000 - 0xffe00000 ( 8 MB)
[ 0.000000] vmalloc : 0xe0800000 - 0xf0000000 ( 248 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0028000 ( 128 kB)
[ 0.000000] .text : 0xc0028000 - 0xc04a6000 (4600 kB)
[ 0.000000] .data : 0xc04c2000 - 0xc04f4300 ( 201 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:97
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttyTCC0] enabled
[ 0.010000] Calibrating delay loop... 799.53 BogoMIPS (lpj=3997696)
[ 0.240000] pid_max: default: 32768 minimum: 301
[ 0.240000] Mount-cache hash table entries: 512
[ 0.250000] Initializing cgroup subsys debug
[ 0.250000] Initializing cgroup subsys cpuacct
[ 0.250000] Initializing cgroup subsys freezer
[ 0.260000] CPU: Testing write buffer coherency: ok
[ 0.260000] NET: Registered protocol family 16
[ 0.270000] TCC8800 GPIO initialized
[ 0.270000] pll_0: 594000 kHz (Fixed)
[ 0.270000] pll_1: 500000 kHz (Fixed)
[ 0.280000] pll_2: 432000 kHz (Fixed)
[ 0.280000] pll_3: 672000 kHz (Fixed)
[ 0.280000] pll_4: memory clcok source
[ 0.290000] pll_5: cpu clcok source
[ 0.290000] TCC clock driver initialized
[ 0.300000] adc_init
[ 0.300000] tcc_adc_probe
[ 0.300000] attached TCC adc driver
[ 0.300000] TCC rotation driver initializing
[ 0.310000] TCC scaler driver initializing
[ 0.310000] TCC scaler1 driver initializing
[ 0.350000] bio: create slab <bio-0> at 0
[ 0.350000] ~ claa104xa01cw_init ~
[ 0.350000] ~ at070tn93_init ~
[ 0.360000] ~ tm070rdh11_init ~
[ 0.360000] SCSI subsystem initialized
[ 0.360000] usbcore: registered new interface driver usbfs
[ 0.370000] usbcore: registered new interface driver hub
[ 0.370000] usbcore: registered new device driver usb
[ 0.820000] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.820000] Bluetooth: Core ver 2.15
[ 0.820000] NET: Registered protocol family 31
[ 0.830000] Bluetooth: HCI device and connection manager initialized
[ 0.830000] Bluetooth: HCI socket layer initialized
[ 0.840000] Switching to clocksource oscr
[ 0.850000] Switched to NOHz mode on CPU #0
[ 0.850000] NET: Registered protocol family 2
[ 0.850000] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.860000] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.870000] TCP bind hash table entries: 16384 (order: 6, 327680 bytes)
[ 0.870000] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.880000] TCP reno registered
[ 0.880000] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.890000] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.900000] NET: Registered protocol family 1
[ 0.900000] Unpacking initramfs...
[ 0.960000] Freeing initrd memory: 700K
[ 0.960000] supported LCD panel type 7
[ 0.970000] at070tn93_probe : 0
[ 0.970000] tcc8800_init_mmc
[ 0.980000] ashmem: initialized
[ 0.980000] io scheduler noop registered (default)
[ 0.990000] TCC Overlay driver initializing
[ 1.000000] tccfb_init (built Apr 22 2011 10:17:34)
[ 1.000000] tcc92xx tca_fb_init (built Apr 22 2011 10:17:34)
[ 1.020000] tca_fb_init LCDC:1 end
[ 1.020000] tccfb_init
[ 1.020000] LCD panel is INNOLUX AT070TN93 800 x 480
[ 1.030000] tccfb_probe, screen_width=800, screen_height=480
[ 1.040000] map_video_memory (fbi=d9ff7a84) kenel memoy, dma:0x59000000 map_size:002ef000
[ 1.100000] [0]: tcc_setup_interrupt timed_out!!
[ 1.100000] fb0: tccfb frame buffer device
[ 1.100000] tcc_composite_init
[ 1.110000] tcc_intr: init (ver 2.0)
[ 1.110000] TCCXX JPEG Encoder driver initializing
[ 1.120000] tcc_clockctrl_init
[ 1.120000] tcc-uart.0: tcc-uart0 at MMIO 0xf0531000 (irq = 64) is a uart0
[ 1.130000] tcc-uart.1: tcc-uart1 at MMIO 0xf0531100 (irq = 65) is a uart1
[ 1.140000] loop: module loaded
[ 1.140000] pmem: 1 init
[ 1.140000] android_pmem: probe of android_pmem.0 failed with error -1
[ 1.150000] pmem_adsp: 0 init
[ 1.150000] tcc_spi: spi:0 init
[ 1.160000] tcc-spi0: init[0]
[ 1.160000] tcc_tsif: spi1 init (Apr 22 2011 10:17:33)
[ 1.170000] tcc_tsif: alloc DMA buffer @0xFF8F0000(Phy=0x59600000), size:2097152
[ 1.180000] PPP generic driver version 2.4.2
[ 1.180000] PPP Deflate Compression module registered
[ 1.180000] PPP BSD Compression module registered
[ 1.190000] PPP MPPE Compression module registered
[ 1.190000] NET: Registered protocol family 24
[ 1.200000] Initializing USB Mass Storage driver...
[ 1.200000] usbcore: registered new interface driver usb-storage
[ 1.210000] USB Mass Storage support registered.
[ 1.210000] dwc_otg: version 2.81a 04-FEB-2009 (DualRole)
[ 1.220000] Working version No 007 - 10/24/2007
[ 1.220000] Core Release: 2.81a
[ 1.230000] Setting default values for core params
[ 1.240000] Using Buffer DMA mode
[ 1.240000] Periodic Transfer Interrupt Enhancement - disabled
[ 1.240000] Multiprocessor Interrupt Enhancement - disabled
[ 1.250000] Dedicated Tx FIFOs mode
[ 1.250000] dwc_otg dwc_otg.0: DWC OTG Controller
[ 1.260000] dwc_otg dwc_otg.0: new USB bus registered, assigned bus number 1
[ 1.260000] dwc_otg dwc_otg.0: irq 48, io mem 0x00000000
[ 1.270000] hub 1-0:1.0: USB hub found
[ 1.270000] hub 1-0:1.0: 1 port detected
[ 1.280000] android init
[ 1.280000] android_probe pdata: c04cb860
[ 1.280000] android_bind
[ 1.290000] android_usb gadget: android_usb ready
[ 1.290000] f_adb init
[ 1.290000] android_register_function adb
[ 1.300000] f_mass_storage init
[ 1.300000] fsg_probe pdev: c04cbc00, pdata: c04cbe7c
[ 1.310000] android_register_function usb_mass_storage
[ 1.310000] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.320000] android_usb gadget: Number of LUNs=4
[ 1.320000] lun0: LUN: removable file: (no medium)
[ 1.330000] lun1: LUN: removable file: (no medium)
[ 1.330000] lun2: LUN: removable file: (no medium)
[ 1.340000] lun3: LUN: removable file: (no medium)
[ 1.340000] adb_bind_config
[ 1.350000] Telechips ADC Keypad Driver
[ 1.350000] Telechips ADC Touchscreen driver, (c) 2009 Telechips
[ 1.350000] tcc-ts got loaded successfully.
[ 1.360000] input: tcc-ts as /devices/platform/tcc-ts/input/input0
[ 1.370000] GPIO Matrix Keypad Driver: Start keypad matrix for tcc8801-matrix-key in polling mode
[ 1.370000] input: tcc8801-matrix-key as /devices/virtual/input/input1
[ 1.380000] TCC RTC, (c) 2010, Telechips
[ 1.380000] ddd
[ 1.390000] ddd
[ 1.390000] OLD INTCON[0x1001] iLoop [1000] RTCCON[0x3]=================================
[ 1.400000] SET INTCON[0x9003] iLoop [1000] RTCCON[0x3]=================================
[ 1.400000] tcc_rtc: alarm irq 43
[ 1.410000] using rtc device, tcc-rtc, for alarms
[ 1.410000] tcc-rtc tcc-rtc: rtc core: registered tcc-rtc as rtc0
[ 1.420000] i2c /dev entries driver
[ 1.420000] Linux video capture interface: v2.00
[ 1.430000] TCCXXX Camera driver initializing
[ 1.430000] Camera Feature is dead in bootloader! please, check!
[ 1.440000] _______cam_i2c_probe() : cam_i2c_client = 0xd9cb2800
[ 1.440000] tcc_battery_init
[ 1.450000] TCC Battery Driver Load
[ 1.460000] device-mapper: uevent: version 1.0.3
[ 1.460000] device-mapper: ioctl: 4.17.0-ioctl (2010-03-05) initialised: dm-devel@redhat.com
[ 1.470000] Bluetooth: HCI UART driver ver 2.2
[ 1.470000] Bluetooth: HCI H4 protocol initialized
[ 1.480000] Bluetooth: HCI BCSP protocol initialized
[ 1.480000] tcc-sdhc: SDHC0 init
[ 1.490000] tcc-sdhc: SDHC1 init
[ 1.490000] usbcore: registered new interface driver usbhid
[ 1.500000] usbhid: USB HID core driver
[ 1.500000] Set ID to device mode(0)
[ 1.500000] logger: created 64K log 'log_main'
[ 1.510000] logger: created 256K log 'log_events'
[ 1.510000] logger: created 64K log 'log_radio'
[ 1.520000] logger: created 64K log 'log_system'
[ 1.520000] No device for DAI IEC958
[ 1.530000] No device for DAI tcc-i2s
[ 1.530000] No device for DAI tcc-spdif
[ 1.650000] asoc: WM8731 <-> tcc-i2s mapping ok
[ 1.760000] asoc: IEC958 <-> tcc-spdif mapping ok
[ 1.760000] ALSA device list:
[ 1.760000] #0: tccx_board (WM8731)
[ 1.760000] Netfilter messages via NETLINK v0.30.
[ 1.770000] nf_conntrack version 0.5.0 (6525 buckets, 26100 max)
[ 1.780000] CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
[ 1.780000] nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
[ 1.790000] sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
[ 1.800000] ctnetlink v0.93: registering with nfnetlink.
[ 1.800000] xt_time: kernel timezone is -0000
[ 1.810000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.810000] arp_tables: (C) 2002 David S. Miller
[ 1.820000] TCP cubic registered
[ 1.820000] NET: Registered protocol family 10
[ 1.830000] lo: Disabled Privacy Extensions
[ 1.830000] Mobile IPv6
[ 1.830000] IPv6 over IPv4 tunneling driver
[ 1.840000] sit0: Disabled Privacy Extensions
[ 1.840000] ip6tnl0: Disabled Privacy Extensions
[ 1.850000] NET: Registered protocol family 17
[ 1.850000] NET: Registered protocol family 15
[ 1.850000] Bluetooth: L2CAP ver 2.14
[ 1.860000] Bluetooth: L2CAP socket layer initialized
[ 1.860000] Bluetooth: SCO (Voice Link) ver 0.6
[ 1.870000] Bluetooth: SCO socket layer initialized
[ 1.870000] Bluetooth: RFCOMM TTY layer initialized
[ 1.880000] Bluetooth: RFCOMM socket layer initialized
[ 1.880000] Bluetooth: RFCOMM ver 1.11
[ 1.890000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.890000] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.900000] lib80211: common routines for IEEE802.11 drivers
[ 1.900000] ThumbEE CPU extension supported.
[ 1.910000] TCC cpufreq driver initialized
[ 1.930000] tcc8800_init_hdmi (built Apr 22 2011 10:17:29)
[ 1.930000] HDMI Driver ver. 1.2.1 (built Apr 22 2011 10:17:31)
[ 1.940000] tcc_hdmi_power tcc88xx pwr:0 system_rev:0x620
[ 1.940000] tcc_hdmi_power tcc88xx pwr:2 system_rev:0x620
[ 1.950000] HDMI Audio Driver ver. 1.1 (built Apr 22 2011 10:17:30)
[ 1.960000] CEC Driver ver. 1.0 (built Apr 22 2011 10:17:30)
[ 1.960000] TccCECInterface_Init Start
[ 1.960000] input: telechips remote controller as /devices/virtual/input/input2
[ 1.970000] TccCECInterface_Init End
[ 1.980000] HPD Driver ver. 1.2 (built Apr 22 2011 10:17:31)
[ 1.980000] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 2
[ 1.990000] [## BT ##] init_module
[ 1.990000] read time 2011/01/27 02:30:35
[ 2.000000] tcc-rtc tcc-rtc: setting system clock to 2011-01-27 02:30:35 UTC [ 2.000000] Freeing init memory: 128K
[ 2.020000] init: /init.tcc8800.rc: 95: invalid option 'chmod'
[ 2.020000] tcc_mtd_lib: module license 'Proprietary. (C) 2010 Telechips Inc.' taints kernel.
[ 2.030000] Disabling lock debugging due to kernel taint
[ 2.040000] [MTD TCC] [PORT CONFIG - CS[0, 1] [NAND Data Port: GPIO_B Hw4 ~ Hw11] [ISR: OFF] [EIL: OFF]
[ 2.050000] [MTD TCC] DMA Alloc Addr:0x5938b000, Size:2048
[ 2.050000] [MTD TCC] [BClk 256MHZ][1Tick 40][RE-S:0,P:8,H:3][WR-S:0,P:5,H:3][COM-S:3,P:15,H:15]
[ 2.060000] [Golden Info] [Device:0] [Bad Block: 0]
[ 2.070000] [Golden Info] [Nand Total Bad Block: 0]
[ 2.070000] [MTD TCC] [PartName: boot] [StBlk : 24] [ChipNo:0]
[ 2.080000] [MTD TCC] [PartName: boot] [EndBlk: 28] [ChipNo:0]
[ 2.090000] [MTD TCC] [PartName: kpanic] [StBlk : 29] [ChipNo:0]
[ 2.090000] [MTD TCC] [PartName: kpanic] [EndBlk: 31] [ChipNo:0]
[ 2.100000] [MTD TCC] [PartName: system] [StBlk : 32] [ChipNo:0]
[ 2.100000] [MTD TCC] [PartName: system] [EndBlk: 106] [ChipNo:0]
[ 2.110000] [MTD TCC] [PartName: splash] [StBlk : 107] [ChipNo:0]
[ 2.120000] [MTD TCC] [PartName: splash] [EndBlk: 108] [ChipNo:0]
[ 2.120000] [MTD TCC] [PartName: cache] [StBlk : 109] [ChipNo:0]
[ 2.130000] [MTD TCC] [PartName: cache] [EndBlk: 128] [ChipNo:0]
[ 2.140000] [MTD TCC] [PartName: userdata] [StBlk : 129] [ChipNo:0]
[ 2.140000] [MTD TCC] [PartName: userdata] [EndBlk: 272] [ChipNo:0]
[ 2.150000] [MTD TCC] [PartName: recovery] [StBlk : 273] [ChipNo:0]
[ 2.160000] [MTD TCC] [PartName: recovery] [EndBlk: 277] [ChipNo:0]
[ 2.160000] [MTD TCC] [PartName: misc] [StBlk : 278] [ChipNo:0]
[ 2.170000] [MTD TCC] [PartName: misc] [EndBlk: 278] [ChipNo:0]
[ 2.170000] [MTD TCC] [PartName: tcc] [StBlk : 279] [ChipNo:0]
[ 2.180000] [MTD TCC] [PartName: tcc] [EndBlk: 279] [ChipNo:0]
[ 2.190000] [MTD TCC] [MTDTotalBlk: 256] [MTDRervBlk:14] [MTDStBlk: 24] [MTDEdBlk:294]
[ 2.200000] [MTD TCC] NAND device: Manufacturer ID: 0xad, Chip ID: 0xd7
[ 2.200000] [NTD BASE New]Bus Width: 8 bit, PageSize: 8192, BlockSize: 2097152
[ 2.210000] NAND device: Manufacturer ID: 0xec, Chip ID: 0xd7 (Samsung NAND 4GiB 3,3V 8-bit)
[ 2.220000] Scanning device for bad blocks
[ 2.400000] Creating 9 MTD partitions on "tcc_nand":
[ 2.410000] 0x000000000000-0x000000a00000 : "boot"
[ 2.410000] 0x000000a00000-0x000001000000 : "kpanic"
[ 2.420000] 0x000001000000-0x00000a600000 : "system"
[ 2.420000] 0x00000a600000-0x00000aa00000 : "splash"
[ 2.430000] 0x00000aa00000-0x00000d200000 : "cache"
[ 2.430000] 0x00000d200000-0x00001f200000 : "userdata"
[ 2.440000] 0x00001f200000-0x00001fc00000 : "recovery"
[ 2.450000] 0x00001fc00000-0x00001fe00000 : "misc"
[ 2.450000] 0x00001fe00000-0x000020000000 : "tcc"
[ 2.570000] yaffs: dev is 32505858 name is "mtdblock2" rw
[ 2.580000] yaffs: passed flags ""
[ 2.630000] yaffs: dev is 32505861 name is "mtdblock5" rw
[ 2.630000] yaffs: passed flags ""
[ 6.920000] yaffs: dev is 32505860 name is "mtdblock4" rw
[ 6.920000] yaffs: passed flags ""
[ 7.390000] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 7.550000]
[ 7.550000] =============================================
[ 7.560000] [NAND Physical Invalid Block Info]
[ 7.560000] =============================================
[ 7.570000] CS#0: (25/1024)Blocks - (50/2048)Blocks
[ 7.570000] =============================================
[ 7.580000] [NAND FTL Invalid Block Info]
[ 7.580000] =============================================
[ 7.590000]
[ 7.590000] CS#0: (25/1024)Blocks - (50/2048)Blocks
[ 7.600000] [Total Physical Invalid Block Info]
[ 7.600000] (50/2048)Blocks
[ 7.600000] [Total FTL Invalid Block Info]
[ 7.600000] (25/1024)Blocks
[ 7.610000] =============================================
[ 7.620000]
[ 7.620000] [TNFTL MTD] [nPBpV:2048][nBBpZ:25][MTDBlockNum:256][MTDRervBlk:14]
[ 8.310000] [NAND ] [PORT CONFIG - CS[0, 1] [NAND Data Port: GPIO_B Hw4 ~ Hw11]
[ 8.320000] [NAND ] [BClk 250MHZ][1Tick 40][RE-S:0,P:8,H:3][WR-S:0,P:4,H:3][COM-S:3,P:15,H:15]
[ 8.330000] [NAND ] [NB Area:4MB][DT Area:3160MB][HD Area0:0MB][MTD Size:512MB]
[ 8.340000] [NAND ] [BadBlockNum: 0]
[ 8.340000] [NAND ] [Blk:]
[ 9.860000] ndda: ndda1
[ 9.890000] [tcc_nand] init ndd(TCC8800, V7050)
[ 9.970000] Authentication is complete!!
[ 9.970000] ufsd: driver 8.4 (Apr 5 2011 11:56:23) LBD=ON with ioctl loaded at bf17f000
[ 9.970000] NTFS read/write support included
[ 10.060000] UMP<2>: Inserting UMP device driver. Compiled: Apr 4 2011, time: 14:27:21
[ 10.080000] UMP<2>: Using OS memory backend, allocation limit: 50331648
[ 10.090000] UMP: UMP device driver loaded
[ 10.290000] Mali<2>:
[ 10.290000] Mali<2>: Inserting Mali v7 device driver.
[ 10.290000] Mali<2>: Compiled: Apr 4 2011, time: 15:59:55.
[ 10.300000] Mali<2>: Svn revision: r2p1-05rel1
[ 10.300000] Mali<2>: MMU memory system initializing
[ 10.310000] Mali<2>: Rendercore: subsystem global mutex initialized
[ 10.310000] Mali<2>: Core: subsystem_init: Mali200
[ 10.320000] Mali<2>: Core: subsystem_init: MaliGP2
[ 10.350000] Mali<2>: MMU registered
[ 10.350000] Mali<2>: Mali OS memory allocator created with max allocation size of 0x12C00000 bytes, cpu_usage_adjust 0x00000000
[ 10.360000] Mali<1>: Mali memory allocators will be used in this order of preference (lowest numbered first) :
[ 10.370000] Mali<1>: 0: OS Memory
[ 10.380000] Mali<2>: Attach mmu: 0xd8fa0e00 to core: Mali 200 (GX525) in subsystem: Mali200
[ 10.390000] Mali<2>: Attach mmu: 0xd8fa0e00 to core: MALI GP2 in subsystem: MaliGP2
[ 10.390000] Mali: Mali device driver r2p1-05rel1 loaded
[ 10.470000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 10.520000] tcc-ehci tcc-ehci: Telechips EHCI HS
[ 10.530000] tcc-ehci tcc-ehci: new USB bus registered, assigned bus number 2
[ 10.560000] tcc-ehci tcc-ehci: irq 13, io mem 0xf0880000
[ 10.580000] tcc-ehci tcc-ehci: USB 2.0 started, EHCI 1.00
[ 10.590000] hub 2-0:1.0: USB hub found
[ 10.590000] hub 2-0:1.0: 1 port detected
[ 10.610000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 10.620000] tcc-ohci tcc-ohci.0: TCC OHCI
[ 10.620000] tcc-ohci tcc-ohci.0: new USB bus registered, assigned bus number 3
[ 10.630000] tcc-ohci tcc-ohci.0: irq 49, io mem 0xf0500000
[ 10.710000] hub 3-0:1.0: USB hub found
[ 10.720000] hub 3-0:1.0: 1 port detected
[ 10.720000] tcc-ohci tcc-ohci.1: TCC OHCI
[ 10.720000] tcc-ohci tcc-ohci.1: new USB bus registered, assigned bus number 4
[ 10.730000] tcc-ohci tcc-ohci.1: irq 13, io mem 0xf0890000
[ 10.820000] hub 4-0:1.0: USB hub found
[ 10.820000] hub 4-0:1.0: 1 port detected
[ 10.840000] enabling adb
[ 10.840000] adb_open
sh: can't access tty; job control turned off
$ [ 14.440000] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[ 14.580000] UMP<2>: New session opened
[ 14.670000] Mali<2>: MMU session begin
[ 14.670000] Mali<2>: Page directory for session 0xd8fd5a40 placed at physical address 0x57804000
[ 14.680000] Mali<2>: MMU session begin: success
[ 14.680000] Mali<2>: Core: session_begin: for Mali200
[ 14.690000] Mali<2>: Core: session_begin: for MaliGP2
[ 15.020000] UMP<2>: New session opened
[ 15.020000] Mali<2>: MMU session begin
[ 15.030000] Mali<2>: Page directory for session 0xd7977de0 placed at physical address 0x57807000
[ 15.040000] Mali<2>: MMU session begin: success
[ 15.040000] Mali<2>: Core: session_begin: for Mali200
[ 15.040000] Mali<2>: Core: session_begin: for MaliGP2
[ 18.180000] request_suspend_state: wakeup (3->0) at 18182048002 (2011-01-27 02:30:51.665137500 UTC)
[ 18.320000] kernel boot complete
[ 19.910000] UMP<2>: New session opened
[ 20.500000] UMP<2>: New session opened
[ 20.530000] Mali<2>: MMU session begin
[ 20.540000] Mali<2>: Page directory for session 0xd2c5c660 placed at physical address 0x5780C000
[ 20.550000] Mali<2>: MMU session begin: success
[ 20.550000] Mali<2>: Core: session_begin: for Mali200
[ 20.560000] Mali<2>: Core: session_begin: for MaliGP2
[ 21.510000] UMP<2>: Session closed
[ 21.510000] Mali<2>: Session ending
[ 21.520000] Mali<2>: Core: session_close: for MaliGP2
[ 21.520000] Mali<2>: Core: session_close: for Mali200
[ 21.530000] Mali<2>: MMU session end
[ 21.530000] Mali<1>: Cleanup of descriptor 1 mapping to 0xd9cdcee0 in descriptor table
[ 21.540000] Mali<1>: Cleanup of descriptor 3 mapping to 0xd9cdcc60 in descriptor table
[ 21.550000] Mali<2>: Session has ended
[ 21.960000] [0]: tcc_setup_interrupt timed_out!!
外壳
外壳
mini pci 网卡
14寸液晶
14寸液晶
安卓开发板
14寸液晶
安卓开发板数据
14寸液晶
