查看: 1279|回复: 0
德赛西威全新4S拆机 车载CD机 可插卡 AUX输入 28元包邮
发表于 2015-12-19 21:35 | 显示全部楼层 |阅读模式
淘宝地址: https://item.taobao.com/item.htm?spm=686.1000925.0.0.byBz3N&id=525401394815
此机器 德赛西威的  大众全新拆车机,一共3600台,全部大众车买车赠送导航的
车有一个保护作用,一小时会关下机,到时候在开一下就OK了
https://img.alicdn.com/imgextra/i1/174959201/TB2iF0UiFXXXXajXpXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i1/174959201/TB2YD0OiFXXXXaZXpXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i3/174959201/TB2Q6VDiFXXXXcHXpXXXXXXXXXX_!!174959201.jpg
背面,面板右侧凸出来的一竖块,是SD卡插槽
https://img.alicdn.com/imgextra/i2/174959201/TB27mueiFXXXXabXXXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i2/174959201/TB2Mq4TiFXXXXaBXpXXXXXXXXXX_!!174959201.jpg
拉倒窗台看下细节:
https://img.alicdn.com/imgextra/i4/174959201/TB2geSbiFXXXXaAXXXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i1/174959201/TB20H4NiFXXXXa9XpXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i4/174959201/TB2M4p_iFXXXXbkXXXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i2/174959201/TB2EFpHiFXXXXbLXpXXXXXXXXXX_!!174959201.jpg
从蜂窝孔可以看到内部散热片,是带鳍片的,不像其他车机的铝板:
https://img.alicdn.com/imgextra/i2/174959201/TB28sBMiFXXXXbHXpXXXXXXXXXX_!!174959201.jpg
机器全部使用内六角螺丝,手头没有对应螺丝刀,暂时没有拆机:
https://img.alicdn.com/imgextra/i2/174959201/TB2tbFOiFXXXXa3XpXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i2/174959201/TB2t0BTiFXXXXanXpXXXXXXXXXX_!!174959201.jpg
接口细节:
https://img.alicdn.com/imgextra/i2/174959201/TB2axR1iFXXXXcTXXXXXXXXXXXX_!!174959201.jpg
这是SD卡位置,位于屏幕左侧,我已经查了块卡在里面:
https://img.alicdn.com/imgextra/i3/174959201/TB2zENWiFXXXXXKXpXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i4/174959201/TB2h_OeiFXXXXX7XXXXXXXXXXXX_!!174959201.jpg
车机的外形挺有特点,单锭机身在面板的下方,CD也是从面板下方吸入。
https://img.alicdn.com/imgextra/i1/174959201/TB29_N9iFXXXXbCXXXXXXXXXXXX_!!174959201.jpg
机器安装卡槽
https://img.alicdn.com/imgextra/i2/174959201/TB2RO4UiFXXXXX7XpXXXXXXXXXX_!!174959201.jpg
机身后部固定件:
https://img.alicdn.com/imgextra/i2/174959201/TB2f.9diFXXXXahXXXXXXXXXXXX_!!174959201.jpg
机身背面的接口说明,可以看到非常简明扼要,坐上部分是四声道输出,右上两个宽些的是GND(地)和VBAT(电源正),也就是说除了喇叭线,整个车机电源部分只需要接入一正一负即可。
https://img.alicdn.com/imgextra/i2/174959201/TB2m.FOiFXXXXa.XpXXXXXXXXXX_!!174959201.jpg
尾部接口,和上面接线图对应: 喇叭输出用2.8插簧正合适,电源正负用4.7插簧正合适。
https://img.alicdn.com/imgextra/i4/174959201/TB21GediFXXXXaxXXXXXXXXXXXX_!!174959201.jpg
下面照片上几条线,左边一组是原来给丰田车机用的电源开关线,线上带一个地线插簧、一个常电插簧、受开关控制的VCC和小灯插簧。中间是两根转接线,把2.8的电源正负插簧用插片转到4.7,用在这个车机上。右边是一组电源输出夹子。
https://img.alicdn.com/imgextra/i1/174959201/TB2mbV_iFXXXXbHXXXXXXXXXXXX_!!174959201.jpg
这是接好的样子:
https://img.alicdn.com/imgextra/i4/174959201/TB2M3N2iFXXXXcPXXXXXXXXXXXX_!!174959201.jpg
上一直播放中的照片,这是播放SD卡上的MP3文件:
https://img.alicdn.com/imgextra/i3/174959201/TB2eNyjiFXXXXXqXXXXXXXXXXXX_!!174959201.jpg
播放USB上的MP3文件:
https://img.alicdn.com/imgextra/i4/174959201/TB2nJWhiFXXXXXJXXXXXXXXXXXX_!!174959201.jpg
FM收音状态:这款高尔夫7车机FM有三组存储,分别是FM1、FM2、FMAS,分别可以存储6个电台
https://img.alicdn.com/imgextra/i4/174959201/TB2wc0OiFXXXXa9XpXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i4/174959201/TB2BAV9iFXXXXbbXXXXXXXXXXXX_!!174959201.jpg
https://img.alicdn.com/imgextra/i4/174959201/TB2SQebiFXXXXajXXXXXXXXXXXX_!!174959201.jpg
在播放MP3文件过重中,可以按“INFO”键,查看MP3文件信息,包括文件名、歌曲名、专辑信息、艺术家、路径等,这是显示专辑名称:
https://img.alicdn.com/imgextra/i1/174959201/TB2jL5biFXXXXaOXXXXXXXXXXXX_!!174959201.jpg
显示艺术家,也就是演唱者:
https://img.alicdn.com/imgextra/i4/174959201/TB2.RtTiFXXXXaoXpXXXXXXXXXX_!!174959201.jpg
播放过程中,按右旋钮进入歌曲选择菜单,可以转动右旋钮进行歌曲选择,或者按面板上左箭头返回上层目录:
https://img.alicdn.com/imgextra/i1/174959201/TB2z6mgiFXXXXXJXXXXXXXXXXXX_!!174959201.jpg
FM正在搜索电台:
https://img.alicdn.com/imgextra/i1/174959201/TB2nRKXiFXXXXa5XXXXXXXXXXXX_!!174959201.jpg
FM正在预览:
https://img.alicdn.com/imgextra/i4/174959201/TB28r8LiFXXXXbEXpXXXXXXXXXX_!!174959201.jpg
按面板“MENU”键进入设置界面:
https://img.alicdn.com/imgextra/i2/174959201/TB2K4ukiFXXXXXdXXXXXXXXXXXX_!!174959201.jpg
音调里是常规调节低音、高音、左右平衡等设置:
https://img.alicdn.com/imgextra/i4/174959201/TB2sapLiFXXXXbPXpXXXXXXXXXX_!!174959201.jpg
“MENU”里“设置/SETUP”内有如下设置项:
https://img.alicdn.com/imgextra/i2/174959201/TB2Gf00iFXXXXXhXpXXXXXXXXXX_!!174959201.jpg
GMT+8, 2026-4-6 20:45 , Processed in 0.029961 second(s), 17 queries , Gzip On.
