查看: 2820|回复: 3
[STM8/STM32] STM32 官方VCP虚拟串口,不接USB主程序不运行原因
发表于 2016-3-21 16:51 | 显示全部楼层 |阅读模式
最近使用STM32 VCP,但是不连接USB主程序不运行。查看库文件发现USB挂起时使STM32进入了睡眠状态。把挂起函数电源控制部分代码注释掉,问题解决(代码没有更深入研究,仅供参考)。
* Function Name  : Suspend
* Description    : sets suspend mode operating conditions
* Input          : None.
* Output         : None.
* Return         : USB_SUCCESS.
void Suspend(void)
    uint32_t i =0;
    uint16_t wCNTR;
    uint32_t tmpreg = 0;
  __IO uint32_t savePWR_CR=0;
    /* suspend preparation */
    /*Store CNTR value */
    wCNTR = _GetCNTR();
    /* This a sequence to apply a force RESET to handle a robustness case */
    /*Store endpoints registers status */
    for (i=0;i<8;i++) EP[i] = _GetENDPOINT(i);
    /* unmask RESET flag */
    wCNTR|=CNTR_RESETM;
    _SetCNTR(wCNTR);
    /*apply FRES */
    wCNTR|=CNTR_FRES;
    _SetCNTR(wCNTR);
    /*clear FRES*/
    wCNTR&=~CNTR_FRES;
    _SetCNTR(wCNTR);
    /*poll for RESET flag in ISTR*/
    while((_GetISTR()&ISTR_RESET) == 0);
    /* clear RESET flag in ISTR */
    _SetISTR((uint16_t)CLR_RESET);
    //restore Enpoints
    for (i=0;i<8;i++)
    _SetENDPOINT(i, EP[i]);
    // Now it is safe to enter macrocell in suspend mode
    wCNTR |= CNTR_FSUSP;
    _SetCNTR(wCNTR);
// force low-power mode in the macrocell
    wCNTR = _GetCNTR();
    wCNTR |= CNTR_LPMODE;
     _SetCNTR(wCNTR);
    //prepare entry in low power mode (STOP mode)
    // Select the regulator state in STOP mode
    savePWR_CR = PWR->CR;
    tmpreg = PWR->CR;
    // Clear PDDS and LPDS bits
    tmpreg &= ((uint32_t)0xFFFFFFFC);
    //Set LPDS bit according to PWR_Regulator value
    tmpreg |= PWR_Regulator_LowPower;
    //Store the new value
     PWR->CR = tmpreg;
    // Set SLEEPDEEP bit of Cortex System Control Register
#if defined (STM32F30X) || defined (STM32F37X)
        SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
#else
       SCB->SCR |= SCB_SCR_SLEEPDEEP;
#endif
    //enter system in STOP mode, only when wakeup flag in not set
    if((_GetISTR()&ISTR_WKUP)==0)
        __WFI();
        // Reset SLEEPDEEP bit of Cortex System Control Register
                SCB->SCR &= (uint32_t)~((uint32_t)SCB_SCR_SLEEPDEEP_Msk);
#else
                SCB->SCR &= (uint32_t)~((uint32_t)SCB_SCR_SLEEPDEEP);
#endif
    else
        // Clear Wakeup flag
        _SetISTR(CLR_WKUP);
    // clear FSUSP to abort entry in suspend mode
        wCNTR = _GetCNTR();
        wCNTR&=~CNTR_FSUSP;
        _SetCNTR(wCNTR);
        //restore sleep mode configuration
        // restore Power regulator config in sleep mode
        PWR->CR = savePWR_CR;
#else
#endif
发表于 2016-3-21 18:03 | 显示全部楼层
一看到代码  瞬间睡着了
发表于 2016-3-26 14:04 | 显示全部楼层
不知道为什么,一看到库函数,头立马晕了。
发表于 2016-5-27 22:06 | 显示全部楼层
正常,那个例程是基于中断的
GMT+8, 2026-6-23 06:26 , Processed in 0.029715 second(s), 21 queries , Gzip On.
