查看: 901|回复: 4
全新原装现货特卖飞思卡尔开发板和工具包 - ARM FRDM-KE02Z
发表于 2016-5-14 12:08 | 显示全部楼层 |阅读模式
https://2.taobao.com/item.htm?id ... .1000925.0.0.ZGLYFl
Freescale's FRDM-KE02Z Kinetis E Freedom Development Platform is an evaluation and development tool ideal for rapid prototyping of microcontroller-based applications. The hardware design is form-factor compatible with popular third-party hardware designed to work with Arduino™ and Arduino-compatible boards. The Freescale KE02Z freedom board (FRDM-KE02Z) is a simple, yet sophisticated design featuring a Kinetis E Series microcontroller KE02Z64VQH2, the industry’s first microcontroller built on the ARM® Cortex™-M0+ core with 0.18um process. The FRDM-KE02Z includes the Freescale open standard embedded serial and debug adapter known as OpenSDA. This circuit offers the user several options for serial communications, flash programming and run-control debugging.
Features
    MKE02Z64VQH2 MCU – 20MHz, 64KB Flash, 4KB SRAM, 64QFP
    Capacitive touch slider, MMA8451Q accelerometer, tri-color LED
    USB or external power supply options
    Easy access to MCU I/O
    IrDA transmitter and receiver
    Thermistor sensor to measuring temperature
    Form factor compatible with Arduino™ R3 pin layout
    New, OpenSDA debug interface
Block Diagram
补充内容 (2016-5-14 12:13):
飞思卡尔Freedom开发平台是一套评估和开发用的软件和硬件工具。它是快速完成基于MCU的应用原型设计的理想之选。飞思卡尔Freedom KE02Z硬件FRDM-KE02Z是一款简单但成熟的设计,采用Kinetis E系列MCU,该MCU是行业首款基于ARM® Cortex™-M0+内核的5V MCU。
    MKE02Z64VQH2 MCU – 20 MHz, 64 KB闪存,4 KB SRAM,64QFP
    电容滑动触摸感应板,MMA8451Q加速度传感器,三色LED
    USB或外部电源选项
    易于访问MCU I/O
    IrDA发送器与接收器
    热敏传感器检测温度
    规格与Arduino™ R3引脚布局兼容
    新型OpenSDA调试接口
        大容量存储设备闪存编程接口(默认)
        评估演示App无需安装任何工具
        P&E调试接口具有运行控制调试功能并兼容IDE工具
        CMSIS-DAP接口: 面向嵌入式调试接口的ARM新标准
        有关详细信息,请参见FRDM-KE02Z用户手册和OpenSDA用户指南。
 楼主| 发表于 2016-5-14 17:04 | 显示全部楼层
ffffffffffffffffffffffffffffffff
 楼主| 发表于 2016-5-16 12:20 | 显示全部楼层
大大大大大大大
 楼主| 发表于 2016-5-17 08:47 | 显示全部楼层
大大大大大大大大
 楼主| 发表于 2016-5-18 08:18 | 显示全部楼层
ddddddddddddddddddd
GMT+8, 2026-4-3 23:02 , Processed in 0.029957 second(s), 20 queries , Gzip On.
