查看: 981|回复: 4
出一批500G台式机硬盘,包无坏道,只有1个,2个的绿块,基本可以忽略,115包邮
发表于 2016-7-26 16:17 | 显示全部楼层 |阅读模式
发货时间一般2天内
都是拆机下来的,没有拆修过的,都是3.5寸的台式机盘,1T的目前有2个,都是绿盘,一个好点的170,稍有些红绿块的150。500G的有20个,都是蓝盘,另外还有些500G的绿盘和320G的蓝盘还没来得及拍照,有需要的联系我单独发图吧。
快递发申通或者顺风,视情况而定。
硬盘怕长途跋涉,祖国边疆地区暂时不发货
硬盘到手包7天,时间从快递签收时间算起,请尽量不要拖确认,反正你什么时候确认这7天都是不变的,谢谢!
每个都是单独链接,按实际拍下的发货
想看全部图的这里有打包的:http://pan.baidu.com/s/1hrXJqAw    密码:1z84
12、这个是之前剩下的,没有红绿块的,最后一块了。
https://item.taobao.com/item.htm?spm=686.1000925.0.0.yNbVRb&id=536241676849
https://img.alicdn.com/imgextra/i1/747055581/TB2YqPhtpXXXXbuXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB2ZTHstpXXXXaaXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB20Va9tpXXXXc4XpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2UpPZtpXXXXakXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i1/747055581/TB2kzvjtpXXXXaRXpXXXXXXXXXX_!!747055581.jpg
4、只有一个绿块,可以忽略了
https://item.taobao.com/item.htm?spm=686.1000925.0.0.yNbVRb&id=536242340458
https://img.alicdn.com/imgextra/i2/747055581/TB2oqvctpXXXXbZXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i3/747055581/TB2pGPttpXXXXX_XpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2DX64tpXXXXXIXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2HGDktpXXXXbiXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB2Y5_btpXXXXceXpXXXXXXXXXX_!!747055581.jpg
5、同样只有一个绿块
https://item.taobao.com/item.htm?spm=686.1000925.0.0.yNbVRb&id=536203701563
https://img.alicdn.com/imgextra/i4/747055581/TB27Ur7tpXXXXXgXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2D9PttpXXXXX3XpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i1/747055581/TB2rjH0tpXXXXXrXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i1/747055581/TB2gczPtpXXXXbBXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i1/747055581/TB2U5YztpXXXXc.XXXXXXXXXXXX_!!747055581.jpg
9、只有2个绿块,可以忽略
https://item.taobao.com/item.htm?spm=686.1000925.0.0.yNbVRb&id=536167074121
https://img.alicdn.com/imgextra/i4/747055581/TB2aKnttpXXXXX1XpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i3/747055581/TB2LkHvtpXXXXXRXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2.AHktpXXXXa9XpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB2xRbItpXXXXcjXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2fqnRtpXXXXbXXXXXXXXXXXXX_!!747055581.jpg
15、一个绿块
https://item.taobao.com/item.htm?spm=686.1000925.0.0.yNbVRb&id=536166026976
https://img.alicdn.com/imgextra/i1/747055581/TB2ftW8tpXXXXcWXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2VpvmtpXXXXa4XpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB2VxC3tpXXXXXRXFXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB28RvxtpXXXXXMXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2uyS7tpXXXXXjXFXXXXXXXXXX_!!747055581.jpg
16、一个绿块
https://item.taobao.com/item.htm?spm=686.1000925.0.0.yNbVRb&id=536094127046
https://img.alicdn.com/imgextra/i4/747055581/TB21W_atpXXXXcsXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i3/747055581/TB2tCfztpXXXXXiXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2L36FtpXXXXcIXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2l4YLtpXXXXb2XXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i1/747055581/TB2x8v1tpXXXXXWXXXXXXXXXXXX_!!747055581.jpg
17、2个绿块,忽略范围内
https://item.taobao.com/item.htm?spm=686.1000925.0.0.yNbVRb&id=536241600121
https://img.alicdn.com/imgextra/i1/747055581/TB2moT0tpXXXXX9XXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i1/747055581/TB2_KzHtpXXXXbUXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i3/747055581/TB2jFHhtpXXXXbzXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB2NsYUtpXXXXaFXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB2xkrmtpXXXXaZXpXXXXXXXXXX_!!747055581.jpg
下面三个都是只有1个绿块的
18、https://item.taobao.com/item.htm?spm=686.1000925.0.0.yNbVRb&id=536166302398
https://img.alicdn.com/imgextra/i1/747055581/TB2zgbKtpXXXXb5XXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB2iRvZtpXXXXaXXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2JAL6tpXXXXXpXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i3/747055581/TB2tcLOtpXXXXbFXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2kp2XtpXXXXctXpXXXXXXXXXX_!!747055581.jpg
19、https://item.taobao.com/item.htm?spm=686.1000925.0.0.UfEeZ0&id=536203005017
https://img.alicdn.com/imgextra/i2/747055581/TB2mUW_tpXXXXcsXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB2YzfRtpXXXXaEXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i3/747055581/TB2lWrCtpXXXXc9XXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2oR_LtpXXXXbPXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2K6CztpXXXXckXpXXXXXXXXXX_!!747055581.jpg
20、https://item.taobao.com/item.htm?spm=686.1000925.0.0.UfEeZ0&id=536165958792
https://img.alicdn.com/imgextra/i1/747055581/TB2ppzRtpXXXXaAXXXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2nES8tpXXXXc.XpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i2/747055581/TB20d_ntpXXXXaJXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i4/747055581/TB2dijstpXXXXajXpXXXXXXXXXX_!!747055581.jpg
https://img.alicdn.com/imgextra/i1/747055581/TB2pnvttpXXXXXnXpXXXXXXXXXX_!!747055581.jpg
 楼主| 发表于 2016-7-26 21:14 | 显示全部楼层
多要的朋友每多加一个减5元,其他不讲价的哦
 楼主| 发表于 2016-7-27 11:29 | 显示全部楼层
盘还有,需要的上哈
 楼主| 发表于 2016-7-27 13:54 | 显示全部楼层
没有红绿块的已出完,剩下只有1个2个绿块的抓紧,这种1个的绿块是可以忽略的,相当于没有红绿块的一样的
 楼主| 发表于 2016-7-31 21:58 | 显示全部楼层
还有最后几块,要的抓紧
GMT+8, 2026-4-4 09:54 , Processed in 0.029350 second(s), 17 queries , Gzip On.
