查看: 7809|回复: 10
桌面级 水刀
发表于 2016-10-10 22:38 | 显示全部楼层 |阅读模式
Search
Main menuSkip to contentDiscoverStart a project
[/url][url=https://www.kickstarter.com/login?ref=nav]Log inSign up
登录/注册后可看大图
PLAY
[size=1.4][size=1.2][size=1.6] Bronx, NY[size=1.2] Fabrication Tools
Project We Love
Cut any material with digital precision using high pressure water. A compact waterjet for every workshop.
Share:
Tweet
Share
Embed
Pin
Post
974
[size=1.4]backers
$1,373,194
[size=1.4]pledged of $100,000 goal
31
[size=1.4]days to go
Remind me
This project will be funded on Fri, Nov 11 2016 8:57 PM AWST.
WAZER
First created  |  0 backed
wazer.com
Full bioContact
[size=1.4]Campaign [size=1.4]Updates 2
[size=1.4]Comments 106
[size=1.4]Community
About this project
The First Desktop Waterjet Cutter
[size=1.6]WAZER is the first waterjet cutter that can fit in every workshop. It cuts through any material and is compact and contained, making it, clean, safe and quiet to operate. WAZER's digital control achieves detail and accuracy impossible by hand, while freeing you up to complete other tasks.
登录/注册后可看大图
[size=1.6]Traditional waterjets cost upwards of $100,000, but with WAZER, we’re changing that, bringing this advanced technology to every workshop.
What You Can Cut
登录/注册后可看大图
What You Can Make
[size=1.6]WAZER can cut through any material, which allows you to make things with professional-grade quality.
[size=1.6]Custom Knife:
登录/注册后可看大图
Cut time: 118 min. | Abrasive used: 39 lb. Designed & finished by Mikey S.
[size=1.6] Penny Necklace:
登录/注册后可看大图
Cut time: 60 min. | Abrasive used: 20 lb. Designed & finished by Stacey L.
[size=1.6]Bakers Rack:
登录/注册后可看大图
Cut time: 95 min. | Abrasive used: 32 lb. Designed & finished by Noelle W.
[size=1.6]Belt Drive Bicycle:
登录/注册后可看大图
Cut time: 168 min. | Abrasive used: 56 lb. Designed & finished by Christian M.
[size=1.6]Glass Art:
登录/注册后可看大图
Cut time: 34 min. | Abrasive used: 11 lb. Designed & finished by David F.
What People Are Saying
[size=1.6]“Wazer is making available to everyone high-end fabrication tech that has hitherto been reserved for heavy industrial users with deep pockets.” - TechCrunch
[size=1.6]“It puts a precision-cutting technology previously only available to a few in the hands of the many.” - Digital Trends
[size=1.6]“The material options are almost limitless.” - MAKE
[size=1.6]“Now you can cut steel, stone, glass, ceramics, carbon fiber and other hard materials with something that fits on a workbench.” - Core77
登录/注册后可看大图
Why waterjet?
[size=1.6]Waterjet technology has significant advantages over conventional cutting methods:
  • Cuts any material
  • Achieves intricate detail
  • Requires no ventilation
  • Results in a smooth surface finish
  • No heat-induced material warping
登录/注册后可看大图
[size=1.6]Waterjets, however, are known for being large and expensive machines that require significant infrastructure and high maintenance. For these reasons most individual makers and small businesses don't have access to a waterjet, so we decided to make one that could be used with a limited budget and minimal space.
登录/注册后可看大图
Technology
[size=1.6]WAZER works by combining sand-like abrasive particles with a high-pressure water stream. The mixture exits the nozzle and cuts through the workpiece, removing material through a micro-erosion process. The abrasive used, referred to as "garnet", consists of rock that is ground to very small and consistent particle sizes. Garnet is a commodity, it is non-toxic and is easily disposable.
登录/注册后可看大图
How WAZER Works
[size=1.6]Hardware: WAZER has unique features that make it appropriate for a small workshop environment:
登录/注册后可看大图
[size=1.6]Watch Dan go through the process of operating WAZER step-by-step.
[size=1.6]Software: With WAZER, going from design to cutting is fast. Design your part in whichever software you’re used to, like Solidworks, Adobe Illustrator or Google SketchUp (or if you aren't familiar with any we'll suggest a basic, easy-to-learn, software for you). Load that drawing file (DXF and SVG) into WAZER software and let the easy to use software guide you through setting up your cut.
登录/注册后可看大图
OfferingWAZER comes as a desktop unit with a separated pump box, which can be placed anywhere within the vicinity of the machine. There are optional removable legs to convert WAZER into a stand-up unit.
登录/注册后可看大图
Rewards
登录/注册后可看大图
WAZER T-shirt Reward
登录/注册后可看大图
Materials and Cutting Speeds
[size=1.6]The list below shows cutting speeds for popular materials that we have actually tested on our final prototype. Email us at info@wazer.com if a material you are curious about is not included.  In order to bring you waterjet technology at this price point we had to reinvent waterjet cutting at a lower pressure. This results in slower cutting speeds compared to traditional industrial waterjets but still maintains the versatility of being able to cut anything.
登录/注册后可看大图
Abrasive Usage
[size=1.6]The materials listed above were cut with WAZER using abrasive particles (garnet) at a rate of 0.33 pounds per minute. WAZER uses garnet made specifically for waterjets that must be continually purchased in order to operate the machine. Abrasive will be available on our website, but WAZER will also work with approved third party suppliers.
Tech Specs
登录/注册后可看大图
Timeline
登录/注册后可看大图
Team
登录/注册后可看大图
[size=1.6]Work Experience: We are a team of mechanical, electrical and manufacturing engineers. Collectively we have led the designs of multiple products both at startup and large companies, with hundreds of thousands of units shipped. We have experience managing overseas manufacturers, local suppliers and in-house production. Previous experiences also include working at a local makerspace and operating an industrial waterjet at a custom fabrication shop.
登录/注册后可看大图
[size=1.6]Past Projects: The four of us met at Penn Engineering where we built custom racecars each year for the FSAE international competition. We all like to make things, whether it's a giant fan-assisted fire-pit, beer, or a trebuchet.
登录/注册后可看大图
How We Got Here
[size=1.6]WAZER began as undergraduate research, where Nisan led a team of students creating the first low-cost waterjet prototype. In early 2015, Nisan and Matt quit their jobs to continue developing the waterjet, working in the basement and testing in the backyard.
登录/注册后可看大图
[size=1.6]In January 2016 Dan and Christian came on-board, and we temporarily moved to Shenzhen, China to join Hax Accelerator, the world’s first and largest hardware accelerator.
登录/注册后可看大图
[size=1.6] We have worked tirelessly for the last 18 months developing WAZER. We have:
  • Assembled a team of engineers
  • Listened and incorporated various market needs
  • Built 5 generations of prototypes
  • Designed the final prototype with production processes in mind
  • Established relationships with key manufacturing suppliers
  • Tested the cutting performance on a wide variety of materials
登录/注册后可看大图
[size=1.6]We raised a small seed round to develop WAZER up until this point, but we need support from you, our backers, so that we can place a large enough order to produce the machines cost-effectively. In return, you will be the first to receive a desktop waterjet.
[size=1.6]More importantly, you are supporting the democratization of manufacturing, where individuals can make finished goods themselves, and you are helping turn that vision into a reality.
[size=1.6]We have created a great tool, but what really matters is what you will make with it!
登录/注册后可看大图
[size=1.6]Credits
[size=1.6]Industrial Design and Product Photography by Office for Product Design
Video by Josh Itzkowitz
Additional Photography by Jesus Salazar
Penny Necklace by Stacey Lee Webber
Custom Knife by Mikey St. Clair
Glass Bird by David Friedman
[size=1.6]Advisors
[size=1.6]Adam Libert
HAX Accelerator
Duncan Turner
Ben Joffe
Risks and challenges
[size=1.6]Mechanical
WAZER is an incredibly complex machine, combining hydraulic, pneumatic, mechanical and electrical systems. It’s a lot of components that need to work together seamlessly. That’s why we are a team of four engineers, with experience building machines and consumer products.
[size=1.6]Supply Chain
To manufacture such a complex product we inherently will have to work with many suppliers, which will be a challenge to manage and ensure that components are made properly. In order to be close to our suppliers, we have spent the last eight months in Shenzhen, China, arguably the largest manufacturing ecosystem for hardware in the world. While developing WAZER we have amassed a network of suppliers and even designed components to match the capabilities of factories we have visited in person. We will return to Shenzhen to complete the mass-manufacturable design of WAZER, select our final suppliers and oversee the initial production.
[size=1.6]Quality
Assembling each waterjet will be a challenge to ensure that everything works properly. We are committed to assembling every waterjet in our own US-based facility, so that we have full oversight of the process and can guarantee you receive a quality machine.
[size=1.6]Software
WAZER's user-centric software still needs development - currently we run WAZER using modified off-the-shelf CAM software and motion controller. Going from design drawing to CNC control is well documented, so the main challenge will be around implementing the intuitive waterjet-specific workflow that you see in our mock up. The software development will begin after Kickstarter and will run in parallel with our manufacturing efforts.
[size=1.6]Expertise
We are also going to need to grow our team, which is where a portion of the funding we raise will go towards. We’re always open to people joining our team, especially out-of-the-box thinkers with a passion for making things. Please see our website for specific openings we have available.
Learn about accountability on Kickstarter
FAQ
[size=1.4]Ask a question
Support this project
  • Make a pledge without a reward
    [size=1.6]$
  • [size=1.6]Select this reward
    Pledge $1 or moreInternational Interest
    [size=1.4]Interested in receiving WAZER in a country outside of the US or Canada?
    [size=1.4]We are working hard to figure out the best way to handle the logistics to get WAZER to you.
    [size=1.4]Pledge this amount so we can update you once we make WAZER available internationally.
    ESTIMATED DELIVERY[size=1.4]Dec 2016
    [size=1.2]337 backers
    Pledge $5 or moreSupporter
    [size=1.4]Thank you for supporting us! You'll get WAZER updates and our undying appreciation.
    ESTIMATED DELIVERY[size=1.4]Nov 2016
    [size=1.2]169 backers
    Pledge $25 or moreT-Shirt
    [size=1.4]This perk comes with our gratitude and a WAZER t-shirt. A soft and stylish cotton T. It's the perfect shirt to wear to the movies or while in the workshop.
    SHIPS TO[size=1.4]Only United States
    [size=1.2]125 backers
  • [size=1.6]Reward no longer available
    Pledge $3,599 or moreEarly Bird WAZER
    [size=1.4]40% OFF $5,999 MSRP (save $2,400).
    Comes with waterjet and pump.
    [size=1.4]Optional Stand: ADD $250 to pledge total.
    [size=1.4]Ships to US and Canada only.
    ESTIMATED DELIVERY[size=1.4]Aug 2017
    SHIPS TO[size=1.4]Only certain countries
    [size=1.2]Reward no longer available[size=1.2]30 backers
    Pledge $3,999 or moreBatch 1 WAZER
    [size=1.4]33% OFF $5,999 MSRP (save $2,000).
    ESTIMATED DELIVERY[size=1.4]Sep 2017
    [size=1.2]Reward no longer available[size=1.2]119 backers
    Pledge $4,499 or moreBatch 2 WAZER
    [size=1.4]25% OFF $5,999 MSRP (save $1,500)
    ESTIMATED DELIVERY[size=1.4]Nov 2017
    [size=1.2]Limited (4 left of 150)[size=1.2]146 backers
Featured
About us
Help
Discover
Hello
KICKSTARTER
[size=1.6]© 2016
English
发表于 2016-10-11 00:09 | 显示全部楼层
发表于 2016-10-11 09:18 | 显示全部楼层
行动真够快的  昨天才在 YouTu Be 看了视频 今天就在论坛见到了
发表于 2016-10-11 10:48 | 显示全部楼层
前段时间看到过这个众筹,好贵哦
发表于 2016-10-11 12:14 | 显示全部楼层
也在订阅的Make:Taiwan上看到了
 楼主| 发表于 2016-10-11 20:10 | 显示全部楼层
那什么 我也是 但是推送的人是 IEEE
发表于 2016-10-11 20:28 | 显示全部楼层
众大神搞一个diy套件啊
发表于 2016-10-12 14:36 | 显示全部楼层
这水得加多大的压力才能切金属啊,当然那个粉末硬度应当也很大
发表于 2016-10-12 21:01 | 显示全部楼层
玩不起太高级了。
发表于 2016-10-13 13:45 | 显示全部楼层
来一台啊~~~
GMT+8, 2026-3-13 14:40 , Processed in 0.042247 second(s), 31 queries , Gzip On.
