查看: 4032|回复: 0
LED调光驱动器ESS030W-0700-32输出电流700ma电压21–32V
发表于 2017-3-12 14:54 | 显示全部楼层 |阅读模式
淘宝购买链接https://item.taobao.com/item.htm?spm=2013.1.20141001.2.sQrgHN&id=539902002954&scm=1007.10115.70237.100200300000000&pvid=7381e680-a654-4507-8468-f76a24f087cf&idnum=0
ESS_series ESS030W-1100-27.pdf (489.15 KB, 下载次数: 264)
厂家资料
http://www.erppowerllc.com/en/products/constant_current_led_drivers/ess-series
LED调光驱动器,型号ESS030W-0700-32输出电流700ma电压21–32V
尺寸84 x 40 x 25.2 mm,重量110克,0-10V是调光信号,不是驱动输出。
无标签版本,但型号是正确的。
Features
  • Compatible with TRIAC (forward-phase or leading-edge) / ELV (reverse-phase or trailing-edge) and 0-10 V dimmers
  • TRIAC dimming only at 120 Vac
  • Linear 0-10V dimming transfer function: 10V=100%, 1V=10%, 0.1V=1%
  • Lifetime: 109,000 hours at 70°C case hot spot temperature (57°C ambient temperature) for ESS030W-0620-42 (26 W)
  • Protections: output open load, over-current and short-circuit (hiccup), and over-temperature with auto recovery
  • Conducted and radiated EMI: Compliant with FCC CFR Title 47 Part 15 Class B (120 Vac)/Class A (277 Vac) and EN55015 (CISPR 15) at 220/230/240 Vac
  • Complies with ENERGY STAR® luminaire specification and DLC (DesignLight Consortium®) technical requirements
  • IP64-rated case with silicone-based potting
  • 90°C maximum case hot spot temperature
  • Class 2 power supply
  • Double-insulated power supply between input and output (class II)
GMT+8, 2026-6-16 17:07 , Processed in 0.032445 second(s), 21 queries , Gzip On.
