查看: 1622|回复: 2
硬货!美国凯斯特kester无铅含银3%焊锡丝
发表于 2017-3-30 20:37 | 显示全部楼层 |阅读模式
来了一批硬货!!凯斯特无铅含银焊锡丝 sn96.5 ag3.0 cu0.5 助焊剂为331型,水溶性助焊剂。
线径为0.4mm 0.25kg/个,基本都为单包装过来的。大部分都带干燥剂,个别袋子坏了,没有干燥剂,随机发了。
由于海外过来的,有轴损的,有好的。轴损的价格便宜。轴特损(壳子两头的圆壳掉了一个,极个别掉了2个)126包邮,轴一般损(圆形壳一边或者两边掉了一部分)136包邮。完好的156包邮。新疆西藏海南内蒙青海不包邮。这价格只针对论坛兄弟,限时促销。不要到涨价时候找我要哈。。价格不定时涨价了。需要的来吧!!
下面为官网过来的介绍,自己翻译吧!!
331 Flux-Cored Wire
            Kester 331 Organic Flux is a water-soluble formula for use in flux-cored solder wire. This cored solder version of the popular 2331-ZX Neutral Organic Water Soluble Liquid Flux is more effective than rosin fluxes in soldering difficult metals. The same fast action and mild properties are exhibited with 331 Organic Flux as with the liquid 2331-ZX. The flux is more heat stable than most organic fluxes, resulting in minimal smoke and odor. The residue can be completely removed with a simple heated water rinse. Deionized water is suggested to prevent introduction of chemistries from unknown water sources. 331 is classified as ORH1 per J-STD-004.                         Share
https://item.taobao.com/item.htm?spm=a230r.1.14.104.XkcART&id=547691650117&ns=1&abbucket=12#detail
 楼主| 发表于 2017-3-31 11:54 | 显示全部楼层
出货。要的来啊啊
 楼主| 发表于 2017-4-1 19:53 | 显示全部楼层
出货。要的来啊
GMT+8, 2025-10-30 23:36 , Processed in 0.031018 second(s), 20 queries , Gzip On.
