查看: 4673|回复: 0
黄色指示灯CANAL HB SERIES 船型开关16A/250VAC T125 银合金触点
发表于 2017-8-16 16:00 | 显示全部楼层 |阅读模式
品名:HB110-C9N-BBN-CW,全新库存备件,嘉尼CANAL开关HB SERIES 船型开关跷板开关大电流16A/250银点,20A 125VAC / 16A 250VAC (UL,CUL)
淘宝购买链接https://item.taobao.com/item.htm?spm=a1z10.5-c.w4002-14755185229.62.2f669dfbhoZnUN&id=557255747055
HB SERIES
SPST, SPDT ROCKER SWITCHES UP TO 20A 125VAC, IP42 RATING, T125
classical outlook, crystal lighting, 6A "L", splash protected
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
  • 20A 125VAC / 16A 250VAC (UL,CUL)
  • 6A 125VL, 3/4HP 250VAC(UL,CUL)
  • 16(4) A 250VAC~T125 (VDE, ENEC)
  • 16A 250VAC (CQC)
  • Initial contact resistance : 20m ohm max.
  • Insulation resistance : 100M ohm min, at 500VDC
  • Dielectric strength : 1,000VAC for 1 minute
  • Electrical life : 10,000 cycles
  • Temperature range : -20 to +125 degrees in Celsius
  • Two-Color actuator available
  • Classical outlook, full or soft lighting
  • Switch for Class II appliances
  • Base : Nylon 66, UL rated 94V-2 min
  • Actuator : Nylon 66 or PC, UL rated 94V-2 min
  • Spring : Piano wire
  • Contacts : Silver alloy
  • Terminals : Silver plated copper
  • Lamp : Neon
Quoted from Wekipedia:
~Inrush current, input surge current or switch-on surge is the maximum, instantaneous input current drawn by an electrical device when first turned on. For example, incandescent light bulbs have high inrush currents until their filaments warm up and their resistance increases. Alternating current electric motors and transformers may draw several times...... ~
Choosing a switch that can have a good capacity for your device is thus very important for your device's safety. Our HB series can offer an option up to 6A'L' up to 92A inrush that can be the appropriate switch to ensure your device's life and stability.
GMT+8, 2026-6-16 16:50 , Processed in 0.033992 second(s), 21 queries , Gzip On.
