版主
回帖0
积分66879
阅读权限200
注册时间2008-11-12
淘宝购买链接https://item.taobao.com/item.htm ... num_id=558353454757
驱动程序
EW-7822UAC_Windows_Driver_1.0.2.9.zip
(46.81 MB, 下载次数: 232)
Product Details- Dual-Band USB Wifi Adapter to Plug into Your Samsung 960H DVR
- Allows Your DVR to Connect Wirelessly to Network
- Removes the Need for Ethernet / RJ45 Cable
- Allows More Convenient Location of DVR, Relative to Internet Router
- d Exclusively for Use with Samsung Wifi Ready DVRs
Samsung SEA-W01AC Samsung WIFI Dongle for 960H CCTV Kits A Wifi dongle for your Samsung 960H All-in-One CCTV Kit. Creates a wireless connection from your Samsung DVR to your wireless network, removing the need for an Ethernet / RJ45 cable. Box Contains 1 x Wi-Fi adapter (SEA-W01AC) 1pcs1 x Extension cable1 x Quick guide
Description
- Supports the most popular operating systems:
- Windows XP, Windows Vista, Windows 7, Window 8, Linux, MAC OS
- Supports WPS (Wi-Fi Protected Setup)
- Has hardware button for easy connection
- Main Chipset
- Realtek RTL8812AU
- Bus Type
- USB 3.0 Type A
- Data Rate
- 11a: 6/9/12/24/36/48/54Mbps 11b: 1/2/5.5/11Mbps 11g: 6/9/12/24/36/48/54Mbps 11n: (20MHz): MCS0-15, up to 144Mbps 11n (40MHz): MCS0-15, up to 300Mbps 11ac (80MHz): VHTMCS0-9, up to 867Mbps
Specifications
[td][td][td]Product Specifications | | Cable Type: | Not specified | | Connection Type: | Not specified | | Cable Length: | Not specified | | Number of Cables: | Not specified | | Frequency Band: | 2.4000-2.4835GHz (subject to local regulations) 5.150-5.825GHz (subject to local regulations | | Output Power: | 2.4GHz: 11b(11M): 16+-1.5dBm, 11g(54M): 14 +-1.5dBm 11n(20MHz, MCS7): 14+-1.5dBm, 11n(40MHz, MC37): 12+-1.5dBm 5GHz: 11a(54M): 12+-1.5dBm 11n(20MHz, MCS7): 10+-1.5dBm, 11n(40MHz, MCS7): 10+-1.5dBm 11ac(80MHz, VHTMC39): 10+-1.5dBm | | Receive Sensitivity: | 2.4GHz: 1b(11M0: -78+-2dBm, 11g(54M): -65+-2dBm 11n(20MHz, MCS7): -64+-2dBm, 11n(40MHz, MCS7): -61+-2dBm 5GHz: 11a(54M): -70+-2dBm, 11n(20MHz, MCS7): -67+-2dBm 11n (40MHz, MCS7): -64+-2dBm, 11ac (80MHx, VHTMcS9): -51+-2dBm | | Antenna: | 2 internal PIFA antennas (2T2R) | | Drivers: | Windows XP/Vista/7/8, Linux, MAC OS | | LED: | Link/Act/WPS | | Temperature: | Operating: 32-104 degrees F (0-40 degrees C), Storage: -4-140 degree F (-20-60 degree C) | | Humidity: | Operating: 0-90%, non-condensing. Storage: Max 95%, non-condensing | | Certification: | CE/FCC | Technical Support | | Phone Number: | 1-877-349-3149 | | Hours of Availability: | 9am-9pm EST, Mon-Sun | | Web Support URL: | http://www.samsungsv.com | Package Contents | | 1 Wi-Fi adapter |
