查看: 3724|回复: 0
AC-DC 转换器 GE Critical Power CLP0212FPEX5Z03A 12V16.7A 200W
发表于 2017-9-12 11:29 | 显示全部楼层 |阅读模式
Features and Benefits
  • CLP0212_New_DS_V1_39.pdf (1.58 MB, 下载次数: 102)
  • Compact size 50.8 mm x 101.6 mm x 36.1 mm (2 in x 4 in x 1.4 in)
  • Universal AC Input Range (90 - 264VAC)
  • Output voltage of 12V, 24V, 28V
  • Maximum output current of 16.7A@ 12Vout (200W), 12.5A @ 12Vout (150W), 8.3A @ 24Vout (200W), 7.1A @ 28Vout (200W)
  • Standby output of 5V  @ 0.25A (select models)
  • High efficiency with 80 PLUS** Gold Certification
  • Full load capability at 50degC and 1m/s (200LFM) airflow with derating at higher temperatures or lower airflows
  • Remote ON/OFF (select models)
  • Output overcurrent protection (non-latching)
  • Overtemperature protection
  • Output overvoltage protection
  • Up to 12ms of holdup time
  • Parallellable with current sharing (select models)
  • Active power factor corrected input
  • Conducted EMI - meets CISPR22 (EN55022) and FCC Class A/B requirements
  • Compliant to RoHS EU Directive 2002/95/EC
  • UL and cUL approved to UL/CSA60950-1, TUV (EN60950-1), CE Mark (for LVD) and CB Report available
  • ISO** 9001 and ISO 14001 certified manufacturing facilities
淘宝购买链接https://item.taobao.com/
GMT+8, 2026-6-16 16:50 , Processed in 0.037436 second(s), 21 queries , Gzip On.
