查看: 2826|回复: 0
LPS53 Emerson Network Power 12V5A 内置电源板 工业电源板
发表于 2017-9-14 17:47 | 显示全部楼层 |阅读模式
EMERSON NETWORK POWER - LPS53
Electrical SpecificationsSafetyInputInput ra-nge: 90 - 264 VAC (wide range) 127-300 VdcFrequency: 47-440 HzInrush current: < 60 A peak @ 230 VAC, cold start @ 25°CInput power: < 74 WattsEfficiency: 80% - 85% typical at full loadEMI/RFI: FCC Class B conducted; CISPR 22 Class B conducted; EN55022 Class Bconducted, VDE0878PT3 Class B conductedSafety ground leakagecurrent:275uA @ 50/60 Hz; 264 VAC inputOutputMaximum power: 60W for convection (LPS52, 55 W)Adjustment range: ±20% minimumHold-up time: 10/20 ms 115/230 VAC input lineOverload protection: Short circuit protection on all outputs. Case overload protected @110-160% of normal ratingOvervoltage protection: 30-50% above nominal outputRemote sense: Compensatesd for 0.5 V lead drop max. Will operate without remote senseconnected. Reverse connection protected.
LPS53_datasheet.pdf
463.76 KB, 下载次数: 119, 下载积分: 一乐金币 -1
GMT+8, 2026-6-16 16:51 , Processed in 0.029993 second(s), 20 queries , Gzip On.
