版主
回帖0
积分66879
阅读权限200
注册时间2008-11-12
[jzsjiale_daogou]FSP030-RHAN2 12V2.5A 电源变压器,=https://www.yleee.com.cn/data/attachment/forum/201808/30/163804mv6ewpw84uiz62v4.jpg,=https://item.taobao.com/item.htm?spm=0.7095261.0.0.b0fe1debb2D4ae&id=576629595438,=85,=38,=#,=#,=#,=576629595438[/jzsjiale_daogou]Quick OverviewDimensions : 110 x 50 x 32mm
Application : IPC systems, Set top boxes, Modems
Watt : 30W
Specifications | Model Name | FSP030-RHAN2 | Wattage | 30W | Product Highlight | V-Output | 12V |
| O/P Current | 2.5A |
| Socket Type | C14 | Input Electrical | Input Voltage | 90 ~ 264 V |
| Input Frequency | 47 ~ 63 Hz | Output Electrical | Single Output | 12 V / 2.5 A | No load and Efficiency | No Load | < 0.1 Watts |
| Efficiency | ≧86 % |
| DOE Level | VI | Environmental Requirement | Temperature Range | Operating: 0 to + 40 ℃
Storage : -20 to + 60 ℃ |
| Altitude | 5000 M |
| MTBF | 100,000 hours at typical load at 25℃ ambient | Mechanical | Dimension | 110 x 50 x 32 mm |
| LED Indicator | No |
| On/ Off Switch | No | Protection | OVP,OCP,OTP | Safety | CE,UL/cUL,FCC,TUV/GS |
