楼主: 农村人
超级实验室的爆炸
发表于 2011-5-19 20:40 | 显示全部楼层
在家丽炼钢???
发表于 2011-5-19 21:05 | 显示全部楼层
感觉有点恐怖呀!
发表于 2011-5-19 22:21 | 显示全部楼层
LZ小心你的相机CCD啊 快门很慢啊。
 楼主| 发表于 2011-5-19 22:48 | 显示全部楼层
//          WINSTAR Display Co.,Ltd
//    LCM              :WF57F 8 BIT (80-Series)
//    Contraller: SSD1963
//    Author     :Brian lin 2009/04/08
//    history     :
//   parameter  define
#include        <reg52.h>
#include        <stdio.h>          // define I/O functions
#include        <INTRINS.H>        // KEIL FUNCTION
#define        Data_BUS         P1
sbit           IC_A0            =P3^0;    // Data/command select L:Command,H:Data
sbit           IC_WR            =P3^7;           // L: Write, H: Read
sbit           IC_RD            =P3^4;          // Data Enable H-->L
sbit           IC_CS            =P3^1;    // L: Chip select
sbit               IC_UD                =P3^5;//=P3^6;          // L: UP to Down , H: Down to UP
sbit               IC_LR                =P3^2;          // L: Left to Right , H: Right to Left
sbit           IC_RST           =P3^6;//=P3^5;    // L: RESET
sbit                  STP                =P2^0;    // for winstar test board
sbit                  S_S             =P2^1;    // for winstar test board
void STP_SC(void)
unsigned char x,y,z;
z=P2;
P2=z|| 0x03;
  if(S_S == 1)
       do{
           for(x=0;x<255;x++)
               for(y=0;y<255;y++)
                 P2=z|| 0x03;
          }while(STP == 0);
void Write_Command(unsigned char command)
IC_RD = 1;
IC_A0 = 0;
IC_WR = 0;
IC_CS = 0;
Data_BUS = command;
IC_CS = 1;
IC_WR = 1;
void Write_Data(unsigned char data1)
IC_RD = 1;
IC_A0 = 1;
IC_WR = 0;
IC_CS = 0;
Data_BUS = data1;
IC_CS = 1;
IC_WR = 1;
void Command_Write(unsigned char command,unsigned char data1)
Write_Command(command);
Write_Data(data1);
void SendData(unsigned long color)
Write_Data((color)>>16);  // color is red
Write_Data((color)>>8);          // color is green
Write_Data(color);                  // color is blue
// initial
void Initial_SSD1963 (void)
IC_RST = 0;
_nop_();
_nop_();
_nop_();
IC_RST = 1;
_nop_();
_nop_();
_nop_();
Write_Command(0x01);     //Software Reset
Command_Write(0xe0,0x01);    //START PLL
Command_Write(0xe0,0x03);    //LOCK PLL
Write_Command(0xb0);                //SET LCD MODE  SET TFT 18Bits MODE
Write_Data(0x0c);                        //SET TFT MODE & hsync+Vsync+DEN MODE
Write_Data(0x80);                        //SET TFT MODE & hsync+Vsync+DEN MODE
Write_Data(0x01);                        //SET horizontal size=480-1 HightByte
Write_Data(0x3f);                    //SET horizontal size=480-1 LowByte
Write_Data(0x00);                        //SET vertical size=640-1 HightByte
Write_Data(0xef);                        //SET vertical size=640-1 LowByte
Write_Data(0x00);                        //SET even/odd line RGB seq.=RGB
Command_Write(0xf0,0x00);        //SET pixel data I/F format=8bit
Command_Write(0x3a,0x60);   // SET R G B format = 6 6 6
//Write_Command(0xe6);           //scan
//Write_Data(0xff);                        //
Write_Command(0xe6);                   //SET PCLK freq=4.94MHz  ; pixel clock frequency
Write_Data(0x02);
Write_Data(0xff);
Write_Data(0xff);
Write_Command(0xb4);                //SET HBP,
Write_Data(0x01);                        //SET HSYNC Tatol 440
Write_Data(0xb8);
Write_Data(0x00);                        //SET HBP 68
Write_Data(0x44);
Write_Data(0x0f);                        //SET VBP 16=15+1
Write_Data(0x00);                        //SET Hsync pulse start position
Write_Data(0x00);
Write_Data(0x00);                        //SET Hsync pulse subpixel start position
Write_Command(0xb6);                 //SET VBP,
Write_Data(0x01);                        //SET Vsync total 265=264+1
Write_Data(0x08);
Write_Data(0x00);                        //SET VBP=19
Write_Data(0x13);
Write_Data(0x07);                        //SET Vsync pulse 8=7+1
Write_Data(0x00);                        //SET Vsync pulse start position
Write_Data(0x00);
Write_Command(0x2a);                //SET column address
Write_Data(0x00);                        //SET start column address=0
Write_Data(0x00);
Write_Data(0x01);                        //SET end column address=319
Write_Data(0x3f);
Write_Command(0x2b);                //SET page address
Write_Data(0x00);                        //SET start page address=0
Write_Data(0x00);
Write_Data(0x00);                        //SET end page address=239
Write_Data(0xef);
Write_Command(0x29);                //SET display on
WindowSet(unsigned int s_x,unsigned int e_x,unsigned int s_y,unsigned int e_y)
Write_Command(0x2a);                //SET page address
Write_Data((s_x)>>8);                        //SET start page address=0
Write_Data(s_x);
Write_Data((e_x)>>8);                        //SET end page address=319
Write_Data(e_x);
Write_Command(0x2b);                //SET column address
Write_Data((s_y)>>8);                        //SET start column address=0
Write_Data(s_y);
Write_Data((e_y)>>8);                        //SET end column address=239
Write_Data(e_y);
void FULL_ON(unsigned long dat)
unsigned int x,y;
WindowSet(0x0000,0x013f,0x0000,0x00ef);
Write_Command(0x2c);
for(x=0;x<240;x++)
        for(y= 0;y<320;y++)
                SendData(dat);
FRAME()
unsigned int i,j;
for(j= 0 ;j<40;j++)
   for(i=0;i<8;i++)
    SendData(0xffffff);             //white
for(j=0;j<238;j++)
SendData(0xff0000);             //red
   for(i=0;i<159;i++)
      SendData(0x000000);             //black
SendData(0x0000ff);             //blue
for(j= 0 ;j<40;j++)
   for(i=0;i<8;i++)
void main()
IC_UD = 0;
IC_LR = 1;
Initial_SSD1963();
while(1)
                FRAME();
                STP_SC();
        FULL_ON(0xff0000);   // red
                STP_SC();
        FULL_ON(0x00ff00);   // green
                STP_SC();
        FULL_ON(0x0000ff);         // blue
                STP_SC();
        //FULL_ON(0xff00ff);
                STP_SC();
        //FULL_ON(0x00ffff);
                STP_SC();
谁来看看这是一段什么代码
发表于 2011-5-19 23:09 | 显示全部楼层
迷你等离子炮?
发表于 2011-5-19 23:40 | 显示全部楼层
这个老外应该是用B门模式拍的。
发表于 2011-5-24 10:38 | 显示全部楼层
有配音就好了
发表于 2011-5-26 21:04 | 显示全部楼层
过年了。。。。。。
   过年玩 很刺激 ~~~可控烟花~~
GMT+8, 2026-3-14 03:40 , Processed in 0.029023 second(s), 24 queries , Gzip On.
