查看: 3582|回复: 0
TDK-Lambda ALV100-24-3R8替代ELV90-24-3R8
发表于 2019-10-27 14:38 | 显示全部楼层 |阅读模式
购买链接https://www.yleee.com.cn/shop/product/tdk-lambda-alv100-24-3r8-elv90-24-3r8
资料TDK-AL100Series
SHARE
Power Supply; AC-DC; 24V; 3.8A; 90-305V In; Encapsulated; Pnl Mnt; LED Driver; AL Series
Manufacturer #: ALV100-24-3R8
Allied Stock #: 70177648
RoHS Compliant
Resources
Product Specifications
Product Attribute
Attribute Value
ConfigurationEncapsulated
Input Voltage100 VAC ; 110 VAC ; 115 VAC ; 120 VAC ; 127 VAC ; 190 VAC ; 200 VAC ; 220 VAC ; 230 VAC ; 240 VAC ; 277 VAC
Mounting TypePanel Mount
Number of Outputs1 Output
OperationSwitching
Output Current3.8 A
Output Power91.2 W
Output Voltage24 VDC
Primary TypeAC-DC
SeriesAL Series
Special FeaturesIP66
TypeLED Driver
Voltage, Input Range90-305 VAC
规格
产品属性
属性值
搜索类似
制造商:
TDK-Lambda
产品种类:
开关电源
RoHS:
详细信息
输出电压—通道1:
24 VDC
输出端数量:
1 Output
输出功率:
91.2 W
开放式框架/封闭式:
Enclosed
输入电压:
90 VAC to 305 VAC
输出电流—通道1:
3.8 A
工业:
Commercial
安装风格:
Chassis
长度:
241 mm
宽度:
43.1 mm
高度:
35 mm
系列:
AL100
商标:
TDK-Lambda
产品类型:
Switching Power Supplies
工厂包装数量:
1
子类别:
AC-DC Power Supply
零件号别名:
ALV100243R8
GMT+8, 2026-6-16 14:21 , Processed in 0.031204 second(s), 21 queries , Gzip On.
