查看: 31895|回复: 46
【仿制】3264双色点阵 128点FFT音频频谱显示
发表于 2011-9-27 21:48 | 显示全部楼层 |阅读模式
不懂编程,只会一点汇编,纯粹仿制。
原帖:http://www.ourdev.cn/bbs/bbs_content.jsp?bbs_sn=4542340&bbs_page_no=1&search_mode=4&search_text=xiayu9213&bbs_id=9999
程序还存在一点问题:
1,无信号输入时左边红色柱状不能回到零,那怕将AD输入端P1.1接地也是一样。
2,红色柱状下降速度过快,中间有空白段,显示脱节了。
3,幅度太大,柱状容易到顶
由于不懂C语言,希望高手帮忙修改一下。
https://www.yleee.com.cn/forum.php?mod=attachment&aid=NDg4NDV8YzM2OWMwY2Z8MTc2NTYxNzE1MHwwfA%3D%3D
 楼主| 发表于 2011-9-27 21:58 | 显示全部楼层
回复 1# xiayu9213
怎样上传附件?怎么上不了呢?
发表于 2011-9-27 23:08 | 显示全部楼层
回帖时选择高级模式,附件,上传即可。
发表于 2011-9-27 23:18 | 显示全部楼层
下降过快可在下降阶段加入延时,但不要用原地打转的延时,要用计数器来做。
幅度过大可减小输入音频的幅值。
发表于 2011-9-28 00:00 | 显示全部楼层
顶下,不错,用595  138的屏试的吗
 楼主| 发表于 2011-9-28 11:51 | 显示全部楼层
#include<STC12C5A.H>
#define uchar unsigned char
#define uint unsigned int
#define  channel  0x01                          //设置AD通道为 P1.1
#define ADC_FLAG    0x10            //ADC complete flag
sbit  SDA_R_TOP=P1^2;          //上
sbit  SDA_G_TOP=P1^3;
sbit  SDA_R=P1^6;
sbit  SDA_G=P1^7;
sbit  SHCP=P1^4;        //CLK
sbit  STCP=P1^5;
//放大128倍后的sin整数表(128)
code char SIN_TAB[128] = { 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70, 75, 80, 85, 89, 94, 98, 102,
105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126, 126, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112,
108, 105, 102, 98, 94, 89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30,
-36, -42, -48, -54, -59, -65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121,
-123, -124, -125, -126, -126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102,
-98, -94, -89, -85, -80, -75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6 };
//放大128倍后的cos整数表(128)
code char COS_TAB[128] = { 127, 126, 126, 125, 124, 123, 121, 119, 117, 114, 112, 108, 105, 102, 98, 94,
89, 85, 80, 75, 70, 65, 59, 54, 48, 42, 36, 30, 24, 18, 12, 6, 0, -6, -12, -18, -24, -30, -36, -42, -48, -54, -59,
-65, -70, -75, -80, -85, -89, -94, -98, -102, -105, -108, -112, -114, -117, -119, -121, -123, -124, -125, -126, -
126, -126, -126, -126, -125, -124, -123, -121, -119, -117, -114, -112, -108, -105, -102, -98, -94, -89, -85, -80,
-75, -70, -65, -59, -54, -48, -42, -36, -30, -24, -18, -12, -6, 0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 59, 65, 70,
75, 80, 85, 89, 94, 98, 102, 105, 108, 112, 114, 117, 119, 121, 123, 124, 125, 126, 126 };
//采样存储序列表
code char LIST_TAB[128] = { 0, 64, 32, 96, 16, 80, 48, 112,
8, 72, 40, 104, 24, 88, 56, 120,
4, 68, 36, 100, 20, 84, 52, 116,
12, 76, 44, 108, 28, 92, 60, 124,
2, 66, 34, 98, 18, 82, 50, 114,
10, 74, 42, 106, 26, 90, 58, 122,
6, 70, 38, 102, 22, 86, 54, 118,
14, 78, 46, 110, 30, 94, 62, 126,
1, 65, 33, 97, 17, 81, 49, 113,
9, 73, 41, 105, 25, 89, 57, 121,
5, 69, 37, 101, 21, 85, 53, 117,
13, 77, 45, 109, 29, 93, 61, 125,
3, 67, 35, 99, 19, 83, 51, 115,
11, 75, 43, 107, 27, 91, 59, 123,
7, 71, 39, 103, 23, 87, 55, 119,
15, 79, 47, 111, 31, 95, 63, 127
uchar COUNT=0,COUNT1=0,ADC_Count=0,LINE=15,G,T;
uchar i,j,k,b,p;
int Temp_Real,Temp_Imag,temp;                // 中间临时变量
uint TEMP1;
int xdata Fft_Real[128];
int xdata Fft_Image[128];               // fft的虚部
uchar xdata LED_TAB2[64];                                //记录 漂浮物 是否需要 停顿一下
uchar xdata LED_TAB[64];                                //记录红色柱状
uchar xdata LED_TAB1[64];                                //记录 漂浮点
void Delay(uint a)
        while(a--);
void FFT()
{    //uchar X;
    for( i=1; i<=7; i++)                            /* for(1) */
        b=1;
        b <<=(i-1);                                       //碟式运算,用于计算 隔多少行计算 例如 第一极 1和2行计算,,第二级
        for( j=0; j<=b-1; j++)                              /* for (2) */
            p=1;
            p <<= (7-i);
            p = p*j;
            for( k=j; k<128; k=k+2*b)                /* for (3) 基二fft */
                Temp_Real = Fft_Real[k]; Temp_Imag = Fft_Image[k]; temp = Fft_Real[k+b];
                Fft_Real[k] = Fft_Real[k] + ((Fft_Real[k+b]*COS_TAB[p])>>7) + ((Fft_Image[k+b]*SIN_TAB[p])>>7);
                Fft_Image[k] = Fft_Image[k] - ((Fft_Real[k+b]*SIN_TAB[p])>>7) + ((Fft_Image[k+b]*COS_TAB[p])>>7);
                Fft_Real[k+b] = Temp_Real - ((Fft_Real[k+b]*COS_TAB[p])>>7) - ((Fft_Image[k+b]*SIN_TAB[p])>>7);
                Fft_Image[k+b] = Temp_Imag + ((temp*SIN_TAB[p])>>7) - ((Fft_Image[k+b]*COS_TAB[p])>>7);
                // 移位.防止溢出. 结果已经是本值的 1/64
              Fft_Real[k] >>= 1;
                Fft_Image[k] >>= 1;
               Fft_Real[k+b]  >>= 1;
                Fft_Image[k+b]  >>= 1;
//        X=((((Fft_Real[1]* Fft_Real[1]))+((Fft_Image[1]*Fft_Image[1])))>>7);
         Fft_Real[0]=Fft_Image[0]=0;                  //去掉直流分量
//         Fft_Real[63]=Fft_Image[63]=0;
        for(j=0;j<64;j++)
                TEMP1=((((Fft_Real[j]* Fft_Real[j]))+((Fft_Image[j]*Fft_Image[j])))>>1);//求功率
                if(TEMP1>1)TEMP1--;
                else TEMP1=0;
                if(TEMP1>31)TEMP1=31;
                if(TEMP1>(LED_TAB[j]))LED_TAB[j]=TEMP1;
                if(TEMP1>(LED_TAB1[j]))
                {   LED_TAB1[j]=TEMP1;
                        LED_TAB2[j]=18;                                                //提顿速度=12
void Init()
     P1ASF = 0x02;                 //0000,0010, 将 P1.1 置成模拟口
     AUXR1 &=0xFB;                 //1111,1011, 令 ADRJ=0
         EADC=1;                                           //AD中断打开
         ADC_CONTR = 0xe9;//ADC_POWER | ADC_SPEEDHH | ADC_START | channel;
                                   //1110 1001   1打开 A/D (ADC_POWER)转换电源;11速度为70周期一次;
                               //0中断标志清零;1启动adc(ADC_START);001AD通道打开(这里为P1.1);
         P2M0=1;
         P0M0=1;
     TMOD=0X12;
         TH0=0x30;      //大约20K的采样率(要完整频段需40K以上。但音频中10k以下居多,故本人选择20K采样,美观些)
         TL0=0x30;
         TH1=0xEE;
         TL1=0XC0;
         ET0=1;                                               //定时器0 打开
         TR0=0;                                                      //关闭定时器
         ET1=1;
         TR1=1;
         PT1=0;
         PT0=1;
     IPH=0x20;
         IP=PADC;                                                  //中断优先级
         EA=1;                                                        //总中断打开
void ADC_Finish() interrupt 5
{           ADC_CONTR &= !ADC_FLAG;
           Fft_Real[LIST_TAB[ADC_Count]]=(int)((ADC_RES)<<1)+(ADC_RESL>>1)-256;//-512; //按LIST_TAB表里的顺序,进行存储 采样值,,
        //  ADC_CONTR = ADC_POWER | ADC_SPEEDHH| ADC_START | channel;        // 为了采集负电压,采用 偏置采集。电压提高到1/2 vcc,,所以要减去256
          if(ADC_Count<=127)ADC_Count++;
          else {EADC=0;TR0=0;}
void LED_Display() interrupt 3                                         //中断一次 显示一行。。。
        TH1=0xF3;
         TL1=0X00;
                for        (G=0;G<64;G++)                                                  //往点阵屏填充 一行的 数据
                        if(LED_TAB[G]<=LINE+16)SDA_R_TOP=1;
                        else SDA_R_TOP=0;
                          if(LED_TAB[G]<=LINE)SDA_R=1;
                        else SDA_R=0;
                        if(LED_TAB1[G]==LINE){SDA_G_TOP=1;SDA_G=0;}
                        else if(LED_TAB1[G]==(LINE+16)){SDA_G_TOP=0;SDA_G=1;}
                        else SDA_G=SDA_G_TOP=1;
                        SHCP=1;SHCP=0;
                STCP=1;STCP=0;
                P2=15-LINE;
                if(LINE>0)LINE--;
                else LINE=15;
   if(LED_TAB[COUNT]>0)LED_TAB[COUNT]--;                   //柱状递减,
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   COUNT++;
   if(COUNT>=64)COUNT=0;
        //漂浮物递减
   if(LED_TAB2[COUNT1]==0)                                        //判断是否需要停顿
                   if(LED_TAB1[COUNT1]>LED_TAB[COUNT1])LED_TAB1[COUNT1]--;//大于柱状则递减(保持漂浮物在柱状之上)
   else LED_TAB2[COUNT1]--;
   COUNT1++;
   COUNT1++;
   COUNT1++;
   COUNT1++;
   if(COUNT1>=64)COUNT1=0;
void Ad_Control() interrupt 1                                         //控制采样率
ADC_CONTR = 0xe9;//ADC_POWER | ADC_SPEEDHH| ADC_START | channel;         //开始AD采集
//        *******************                                                           main()                                                        *********************************
void main()
        Init();
        while(1)
                ADC_Count=0;
                TR0=1;
                EADC=1;        //开启定时器中断0,,开启ADC
                while(ADC_Count<128);
                FFT();
         //FFT运算。并转换为 功率值。。。
                //        TR1=1;
 楼主| 发表于 2011-9-28 11:53 | 显示全部楼层
幅度过大可减小输入音频的幅值 ...
lihongran 发表于 2011-9-27 23:18 https://www.yleee.com.cn/images/common/back.gif
    两个定时器都用上了,一个定时采集,一个定时显示一行
 楼主| 发表于 2011-9-28 11:54 | 显示全部楼层
回复 5# a60885262
    对 是595和138的屏。
发表于 2011-9-28 15:40 | 显示全部楼层
xiayu9213 发表于 2011-9-28 11:53 https://www.yleee.com.cn/images/common/back.gif
    用软件计数器来做。
 楼主| 发表于 2011-9-28 19:24 | 显示全部楼层
还是这个效果好点。
GMT+8, 2025-12-13 17:12 , Processed in 0.040603 second(s), 32 queries , Gzip On.
