楼主: xiayu9213
【仿制】3264双色点阵 128点FFT音频频谱显示
发表于 2011-11-6 22:33 | 显示全部楼层
能否共享一下哦
发表于 2011-11-10 23:09 | 显示全部楼层
柱子回落太快,
发表于 2011-11-10 23:59 | 显示全部楼层
Build target '目标 1'
assembling STARTUP.A51...
compiling ddd.c...
ddd.c(1): warning C318: can't open file 'STC12C5A.H'
DDD.C(7): error C202: 'P1': undefined identifier
DDD.C(8): error C202: 'P1': undefined identifier
DDD.C(9): error C202: 'P1': undefined identifier
DDD.C(10): error C202: 'P1': undefined identifier
DDD.C(11): error C202: 'P1': undefined identifier
DDD.C(12): error C202: 'P1': undefined identifier
DDD.C(125): error C202: 'P1ASF': undefined identifier
DDD.C(126): error C202: 'AUXR1': undefined identifier
DDD.C(128): error C202: 'EADC': undefined identifier
DDD.C(129): error C202: 'ADC_CONTR': undefined identifier
DDD.C(133): error C202: 'P1M0': undefined identifier
DDD.C(134): error C202: 'P2M0': undefined identifier
DDD.C(135): error C202: 'TMOD': undefined identifier
DDD.C(136): error C202: 'TH0': undefined identifier
DDD.C(137): error C202: 'TL0': undefined identifier
DDD.C(138): error C202: 'TH1': undefined identifier
DDD.C(139): error C202: 'TL1': undefined identifier
DDD.C(140): error C202: 'ET0': undefined identifier
DDD.C(141): error C202: 'TR0': undefined identifier
DDD.C(142): error C202: 'ET1': undefined identifier
DDD.C(143): error C202: 'TR1': undefined identifier
DDD.C(144): error C202: 'PT1': undefined identifier
DDD.C(145): error C202: 'PT0': undefined identifier
DDD.C(146): error C202: 'IPH': undefined identifier
DDD.C(147): error C202: 'IP': undefined identifier
DDD.C(148): error C202: 'EA': undefined identifier
DDD.C(153): error C202: 'ADC_CONTR': undefined identifier
DDD.C(154): error C202: 'ADC_RES': undefined identifier
DDD.C(157): error C202: 'EADC': undefined identifier
DDD.C(157): error C202: 'TR0': undefined identifier
DDD.C(162): error C202: 'TH1': undefined identifier
DDD.C(163): error C202: 'TL1': undefined identifier
DDD.C(166): error C202: 'SDA_R_TOP': undefined identifier
DDD.C(167): error C202: 'SDA_R_TOP': undefined identifier
DDD.C(168): error C202: 'SDA_R': undefined identifier
DDD.C(169): error C202: 'SDA_R': undefined identifier
DDD.C(171): error C202: 'SDA_G_TOP': undefined identifier
DDD.C(171): error C202: 'SDA_G': undefined identifier
DDD.C(172): error C202: 'SDA_G_TOP': undefined identifier
DDD.C(172): error C202: 'SDA_G': undefined identifier
DDD.C(173): error C202: 'SDA_G': undefined identifier
DDD.C(174): error C202: 'SHCP': undefined identifier
DDD.C(175): error C202: 'SHCP': undefined identifier
DDD.C(176): error C202: 'SHCP': undefined identifier
DDD.C(177): error C202: 'SDA_G_TOP': undefined identifier
DDD.C(177): error C202: 'SDA_G': undefined identifier
DDD.C(177): error C202: 'SDA_R_TOP': undefined identifier
DDD.C(177): error C202: 'SDA_R': undefined identifier
DDD.C(178): error C202: 'SHCP': undefined identifier
DDD.C(180): error C202: 'STCP': undefined identifier
DDD.C(181): error C202: 'P2': undefined identifier
DDD.C(186): error C187: not an lvalue
DDD.C(189): error C187: not an lvalue
DDD.C(203): error C187: not an lvalue
DDD.C(205): error C187: not an lvalue
DDD.C(212): error C202: 'ADC_CONTR': undefined identifier
DDD.C(224): error C202: 'TR0': undefined identifier
DDD.C(225): error C202: 'EADC': undefined identifier
目标未创建
发表于 2011-11-11 00:01 | 显示全部楼层
// FFT_Code_Tables.h
// Copyright 2003 Cygnal Integrated Products, Inc.
// AUTH: BD
// DATE: 30 JAN 03
// This header file is used to provide Sine, Bit Reversal, and Window tables
// for calculating an FFT.  The tables are stored in FLASH memory (code space).
// All of the tables are conditionally used at compile time, so only one table
// of each type is used in the software.
// Target: C8051F12x
// Tool chain: KEIL C51 6.03
#define NUM_FFT 256     // Length of FFT to process
                        // Must be 2^N, where N is an integer >= 2
#define WINDOW_TYPE 4   // WINDOW_TYPE specifies the window to use on the data
                        // The available window functions are:
                        // 0 = No Window
                        // 1 = Triangle Window
                        // 2 = Hanning Window
                        // 3 = Hamming Window
                        // 4 = Blackman Window
// SinTable[] - SIN Tables are first 1/4 of a SIN wave - used to perform
// complex math functions.  These are encoded such that a value of 1.0
// corresponds to 32768, and a value of -1.0 corresponds to -32768.
// BRTable[] - Bit Reversal tables are used to bit-reverse sort the data and
// perform other indexing functions.  The Bit Reversal tables are stored
// as 1/2 of their actual value, and the real value is computed at
// runtime.
// WindowFunc[] - Tables used to window data.  These are encoded such that
// 1.0 corresponds to 65536, and 0.0 corresponds to 0.
// SIN and BR Tables for NUM_FFT = 1024
#if (NUM_FFT == 1024)
int code SinTable[256] =
0x0000, 0x00C9, 0x0192, 0x025B, 0x0324, 0x03ED, 0x04B6, 0x057F,
0x0647, 0x0710, 0x07D9, 0x08A2, 0x096A, 0x0A33, 0x0AFB, 0x0BC3,
0x0C8B, 0x0D53, 0x0E1B, 0x0EE3, 0x0FAB, 0x1072, 0x1139, 0x1201,
0x12C8, 0x138E, 0x1455, 0x151B, 0x15E2, 0x16A8, 0x176D, 0x1833,
0x18F8, 0x19BD, 0x1A82, 0x1B47, 0x1C0B, 0x1CCF, 0x1D93, 0x1E56,
0x1F19, 0x1FDC, 0x209F, 0x2161, 0x2223, 0x22E5, 0x23A6, 0x2467,
0x2528, 0x25E8, 0x26A8, 0x2767, 0x2826, 0x28E5, 0x29A3, 0x2A61,
0x2B1F, 0x2BDC, 0x2C98, 0x2D55, 0x2E11, 0x2ECC, 0x2F87, 0x3041,
0x30FB, 0x31B5, 0x326E, 0x3326, 0x33DE, 0x3496, 0x354D, 0x3604,
0x36BA, 0x376F, 0x3824, 0x38D8, 0x398C, 0x3A40, 0x3AF2, 0x3BA5,
0x3C56, 0x3D07, 0x3DB8, 0x3E68, 0x3F17, 0x3FC5, 0x4073, 0x4121,
0x41CE, 0x427A, 0x4325, 0x43D0, 0x447A, 0x4524, 0x45CD, 0x4675,
0x471C, 0x47C3, 0x4869, 0x490F, 0x49B4, 0x4A58, 0x4AFB, 0x4B9E,
0x4C3F, 0x4CE1, 0x4D81, 0x4E21, 0x4EBF, 0x4F5E, 0x4FFB, 0x5097,
0x5133, 0x51CE, 0x5269, 0x5302, 0x539B, 0x5433, 0x54CA, 0x5560,
0x55F5, 0x568A, 0x571D, 0x57B0, 0x5842, 0x58D4, 0x5964, 0x59F3,
0x5A82, 0x5B10, 0x5B9D, 0x5C29, 0x5CB4, 0x5D3E, 0x5DC7, 0x5E50,
0x5ED7, 0x5F5E, 0x5FE3, 0x6068, 0x60EC, 0x616F, 0x61F1, 0x6271,
0x62F2, 0x6371, 0x63EF, 0x646C, 0x64E8, 0x6563, 0x65DD, 0x6657,
0x66CF, 0x6746, 0x67BD, 0x6832, 0x68A6, 0x6919, 0x698C, 0x69FD,
0x6A6D, 0x6ADC, 0x6B4A, 0x6BB8, 0x6C24, 0x6C8F, 0x6CF9, 0x6D62,
0x6DCA, 0x6E30, 0x6E96, 0x6EFB, 0x6F5F, 0x6FC1, 0x7023, 0x7083,
0x70E2, 0x7141, 0x719E, 0x71FA, 0x7255, 0x72AF, 0x7307, 0x735F,
0x73B5, 0x740B, 0x745F, 0x74B2, 0x7504, 0x7555, 0x75A5, 0x75F4,
0x7641, 0x768E, 0x76D9, 0x7723, 0x776C, 0x77B4, 0x77FA, 0x7840,
0x7884, 0x78C7, 0x7909, 0x794A, 0x798A, 0x79C8, 0x7A05, 0x7A42,
0x7A7D, 0x7AB6, 0x7AEF, 0x7B26, 0x7B5D, 0x7B92, 0x7BC5, 0x7BF8,
0x7C29, 0x7C5A, 0x7C89, 0x7CB7, 0x7CE3, 0x7D0F, 0x7D39, 0x7D62,
0x7D8A, 0x7DB0, 0x7DD6, 0x7DFA, 0x7E1D, 0x7E3F, 0x7E5F, 0x7E7F,
0x7E9D, 0x7EBA, 0x7ED5, 0x7EF0, 0x7F09, 0x7F21, 0x7F38, 0x7F4D,
0x7F62, 0x7F75, 0x7F87, 0x7F97, 0x7FA7, 0x7FB5, 0x7FC2, 0x7FCE,
0x7FD8, 0x7FE1, 0x7FE9, 0x7FF0, 0x7FF6, 0x7FFA, 0x7FFD, 0x7FFF
unsigned int code BRTable[512] =
0, 256, 128, 384, 64, 320, 192, 448,
32, 288, 160, 416, 96, 352, 224, 480,
16, 272, 144, 400, 80, 336, 208, 464,
48, 304, 176, 432, 112, 368, 240, 496,
8, 264, 136, 392, 72, 328, 200, 456,
40, 296, 168, 424, 104, 360, 232, 488,
24, 280, 152, 408, 88, 344, 216, 472,
56, 312, 184, 440, 120, 376, 248, 504,
4, 260, 132, 388, 68, 324, 196, 452,
36, 292, 164, 420, 100, 356, 228, 484,
20, 276, 148, 404, 84, 340, 212, 468,
52, 308, 180, 436, 116, 372, 244, 500,
12, 268, 140, 396, 76, 332, 204, 460,
44, 300, 172, 428, 108, 364, 236, 492,
28, 284, 156, 412, 92, 348, 220, 476,
60, 316, 188, 444, 124, 380, 252, 508,
2, 258, 130, 386, 66, 322, 194, 450,
34, 290, 162, 418, 98, 354, 226, 482,
18, 274, 146, 402, 82, 338, 210, 466,
50, 306, 178, 434, 114, 370, 242, 498,
10, 266, 138, 394, 74, 330, 202, 458,
42, 298, 170, 426, 106, 362, 234, 490,
26, 282, 154, 410, 90, 346, 218, 474,
58, 314, 186, 442, 122, 378, 250, 506,
6, 262, 134, 390, 70, 326, 198, 454,
38, 294, 166, 422, 102, 358, 230, 486,
22, 278, 150, 406, 86, 342, 214, 470,
54, 310, 182, 438, 118, 374, 246, 502,
14, 270, 142, 398, 78, 334, 206, 462,
46, 302, 174, 430, 110, 366, 238, 494,
30, 286, 158, 414, 94, 350, 222, 478,
62, 318, 190, 446, 126, 382, 254, 510,
1, 257, 129, 385, 65, 321, 193, 449,
33, 289, 161, 417, 97, 353, 225, 481,
17, 273, 145, 401, 81, 337, 209, 465,
49, 305, 177, 433, 113, 369, 241, 497,
9, 265, 137, 393, 73, 329, 201, 457,
41, 297, 169, 425, 105, 361, 233, 489,
25, 281, 153, 409, 89, 345, 217, 473,
57, 313, 185, 441, 121, 377, 249, 505,
5, 261, 133, 389, 69, 325, 197, 453,
37, 293, 165, 421, 101, 357, 229, 485,
21, 277, 149, 405, 85, 341, 213, 469,
53, 309, 181, 437, 117, 373, 245, 501,
13, 269, 141, 397, 77, 333, 205, 461,
45, 301, 173, 429, 109, 365, 237, 493,
29, 285, 157, 413, 93, 349, 221, 477,
61, 317, 189, 445, 125, 381, 253, 509,
3, 259, 131, 387, 67, 323, 195, 451,
35, 291, 163, 419, 99, 355, 227, 483,
19, 275, 147, 403, 83, 339, 211, 467,
51, 307, 179, 435, 115, 371, 243, 499,
11, 267, 139, 395, 75, 331, 203, 459,
43, 299, 171, 427, 107, 363, 235, 491,
27, 283, 155, 411, 91, 347, 219, 475,
59, 315, 187, 443, 123, 379, 251, 507,
7, 263, 135, 391, 71, 327, 199, 455,
39, 295, 167, 423, 103, 359, 231, 487,
23, 279, 151, 407, 87, 343, 215, 471,
55, 311, 183, 439, 119, 375, 247, 503,
15, 271, 143, 399, 79, 335, 207, 463,
47, 303, 175, 431, 111, 367, 239, 495,
31, 287, 159, 415, 95, 351, 223, 479,
63, 319, 191, 447, 127, 383, 255, 511
#endif
// SIN and BR Tables for NUM_FFT = 512
#if (NUM_FFT == 512)
int code SinTable[128] =
0x0000, 0x0192, 0x0324, 0x04B6, 0x0647, 0x07D9, 0x096A, 0x0AFB,
0x0C8B, 0x0E1B, 0x0FAB, 0x1139, 0x12C8, 0x1455, 0x15E2, 0x176D,
0x18F8, 0x1A82, 0x1C0B, 0x1D93, 0x1F19, 0x209F, 0x2223, 0x23A6,
0x2528, 0x26A8, 0x2826, 0x29A3, 0x2B1F, 0x2C98, 0x2E11, 0x2F87,
0x30FB, 0x326E, 0x33DE, 0x354D, 0x36BA, 0x3824, 0x398C, 0x3AF2,
0x3C56, 0x3DB8, 0x3F17, 0x4073, 0x41CE, 0x4325, 0x447A, 0x45CD,
0x471C, 0x4869, 0x49B4, 0x4AFB, 0x4C3F, 0x4D81, 0x4EBF, 0x4FFB,
0x5133, 0x5269, 0x539B, 0x54CA, 0x55F5, 0x571D, 0x5842, 0x5964,
0x5A82, 0x5B9D, 0x5CB4, 0x5DC7, 0x5ED7, 0x5FE3, 0x60EC, 0x61F1,
0x62F2, 0x63EF, 0x64E8, 0x65DD, 0x66CF, 0x67BD, 0x68A6, 0x698C,
0x6A6D, 0x6B4A, 0x6C24, 0x6CF9, 0x6DCA, 0x6E96, 0x6F5F, 0x7023,
0x70E2, 0x719E, 0x7255, 0x7307, 0x73B5, 0x745F, 0x7504, 0x75A5,
0x7641, 0x76D9, 0x776C, 0x77FA, 0x7884, 0x7909, 0x798A, 0x7A05,
0x7A7D, 0x7AEF, 0x7B5D, 0x7BC5, 0x7C29, 0x7C89, 0x7CE3, 0x7D39,
0x7D8A, 0x7DD6, 0x7E1D, 0x7E5F, 0x7E9D, 0x7ED5, 0x7F09, 0x7F38,
0x7F62, 0x7F87, 0x7FA7, 0x7FC2, 0x7FD8, 0x7FE9, 0x7FF6, 0x7FFD
unsigned char code BRTable[256] =
0, 128, 64, 192, 32, 160, 96, 224,
16, 144, 80, 208, 48, 176, 112, 240,
8, 136, 72, 200, 40, 168, 104, 232,
24, 152, 88, 216, 56, 184, 120, 248,
4, 132, 68, 196, 36, 164, 100, 228,
20, 148, 84, 212, 52, 180, 116, 244,
12, 140, 76, 204, 44, 172, 108, 236,
28, 156, 92, 220, 60, 188, 124, 252,
2, 130, 66, 194, 34, 162, 98, 226,
18, 146, 82, 210, 50, 178, 114, 242,
10, 138, 74, 202, 42, 170, 106, 234,
26, 154, 90, 218, 58, 186, 122, 250,
6, 134, 70, 198, 38, 166, 102, 230,
22, 150, 86, 214, 54, 182, 118, 246,
14, 142, 78, 206, 46, 174, 110, 238,
30, 158, 94, 222, 62, 190, 126, 254,
1, 129, 65, 193, 33, 161, 97, 225,
17, 145, 81, 209, 49, 177, 113, 241,
9, 137, 73, 201, 41, 169, 105, 233,
25, 153, 89, 217, 57, 185, 121, 249,
5, 133, 69, 197, 37, 165, 101, 229,
21, 149, 85, 213, 53, 181, 117, 245,
13, 141, 77, 205, 45, 173, 109, 237,
29, 157, 93, 221, 61, 189, 125, 253,
3, 131, 67, 195, 35, 163, 99, 227,
19, 147, 83, 211, 51, 179, 115, 243,
11, 139, 75, 203, 43, 171, 107, 235,
27, 155, 91, 219, 59, 187, 123, 251,
7, 135, 71, 199, 39, 167, 103, 231,
23, 151, 87, 215, 55, 183, 119, 247,
15, 143, 79, 207, 47, 175, 111, 239,
31, 159, 95, 223, 63, 191, 127, 255
#endif
// SIN and BR Tables for NUM_FFT = 256
#if (NUM_FFT == 256)
int code SinTable[64] =
0x0000, 0x0324, 0x0647, 0x096A, 0x0C8B, 0x0FAB, 0x12C8, 0x15E2,
0x18F8, 0x1C0B, 0x1F19, 0x2223, 0x2528, 0x2826, 0x2B1F, 0x2E11,
0x30FB, 0x33DE, 0x36BA, 0x398C, 0x3C56, 0x3F17, 0x41CE, 0x447A,
0x471C, 0x49B4, 0x4C3F, 0x4EBF, 0x5133, 0x539B, 0x55F5, 0x5842,
0x5A82, 0x5CB4, 0x5ED7, 0x60EC, 0x62F2, 0x64E8, 0x66CF, 0x68A6,
0x6A6D, 0x6C24, 0x6DCA, 0x6F5F, 0x70E2, 0x7255, 0x73B5, 0x7504,
0x7641, 0x776C, 0x7884, 0x798A, 0x7A7D, 0x7B5D, 0x7C29, 0x7CE3,
0x7D8A, 0x7E1D, 0x7E9D, 0x7F09, 0x7F62, 0x7FA7, 0x7FD8, 0x7FF6
unsigned char code BRTable[128] =
0, 64, 32, 96, 16, 80, 48, 112,
8, 72, 40, 104, 24, 88, 56, 120,
4, 68, 36, 100, 20, 84, 52, 116,
12, 76, 44, 108, 28, 92, 60, 124,
2, 66, 34, 98, 18, 82, 50, 114,
10, 74, 42, 106, 26, 90, 58, 122,
6, 70, 38, 102, 22, 86, 54, 118,
14, 78, 46, 110, 30, 94, 62, 126,
1, 65, 33, 97, 17, 81, 49, 113,
9, 73, 41, 105, 25, 89, 57, 121,
5, 69, 37, 101, 21, 85, 53, 117,
13, 77, 45, 109, 29, 93, 61, 125,
3, 67, 35, 99, 19, 83, 51, 115,
11, 75, 43, 107, 27, 91, 59, 123,
7, 71, 39, 103, 23, 87, 55, 119,
15, 79, 47, 111, 31, 95, 63, 127
#endif
// SIN and BR Tables for NUM_FFT = 128
#if (NUM_FFT == 128)
int code SinTable[32] =
0x0000, 0x0647, 0x0C8B, 0x12C8, 0x18F8, 0x1F19, 0x2528, 0x2B1F,
0x30FB, 0x36BA, 0x3C56, 0x41CE, 0x471C, 0x4C3F, 0x5133, 0x55F5,
0x5A82, 0x5ED7, 0x62F2, 0x66CF, 0x6A6D, 0x6DCA, 0x70E2, 0x73B5,
0x7641, 0x7884, 0x7A7D, 0x7C29, 0x7D8A, 0x7E9D, 0x7F62, 0x7FD8
unsigned char code BRTable[64] =
0, 32, 16, 48, 8, 40, 24, 56,
4, 36, 20, 52, 12, 44, 28, 60,
2, 34, 18, 50, 10, 42, 26, 58,
6, 38, 22, 54, 14, 46, 30, 62,
1, 33, 17, 49, 9, 41, 25, 57,
5, 37, 21, 53, 13, 45, 29, 61,
3, 35, 19, 51, 11, 43, 27, 59,
7, 39, 23, 55, 15, 47, 31, 63
#endif
// SIN and BR Tables for NUM_FFT = 64
#if (NUM_FFT == 64)
int code SinTable[16] =
0x0000, 0x0C8B, 0x18F8, 0x2528, 0x30FB, 0x3C56, 0x471C, 0x5133,
0x5A82, 0x62F2, 0x6A6D, 0x70E2, 0x7641, 0x7A7D, 0x7D8A, 0x7F62
unsigned char code BRTable[32] =
0, 16, 8, 24, 4, 20, 12, 28,
2, 18, 10, 26, 6, 22, 14, 30,
1, 17, 9, 25, 5, 21, 13, 29,
3, 19, 11, 27, 7, 23, 15, 31
#endif
// SIN and BR Tables for NUM_FFT = 32
#if (NUM_FFT == 32)
int code SinTable[8] =
0x0000, 0x18F8, 0x30FB, 0x471C, 0x5A82, 0x6A6D, 0x7641, 0x7D8A
unsigned char code BRTable[16] =
0, 8, 4, 12, 2, 10, 6, 14,
1, 9, 5, 13, 3, 11, 7, 15
#endif
// SIN and BR Tables for NUM_FFT = 16
#if (NUM_FFT == 16)
int code SinTable[4] =
0x0000, 0x30FB, 0x5A82, 0x7641
unsigned char code BRTable[8] =
0, 4, 2, 6, 1, 5, 3, 7
#endif
// SIN and BR Tables for NUM_FFT = 8
#if (NUM_FFT == 8)
int code SinTable[2] =
0x0000, 0x5A82
unsigned char code BRTable[4] =
0, 2, 1, 3
#endif
// SIN and BR Table for NUM_FFT = 4
#if (NUM_FFT == 4)
int code SinTable[1] =
0x0000
unsigned char code BRTable[2] =
0, 1
#endif
// Window Functions for NUM_FFT = 1024
#if (WINDOW_TYPE == 1)
// Triangle Window
unsigned int code WindowFunc[512] =
0x0000, 0x0080, 0x0100, 0x0180, 0x0200, 0x0280, 0x0300, 0x0380,
0x0400, 0x0480, 0x0500, 0x0580, 0x0600, 0x0680, 0x0700, 0x0780,
0x0800, 0x0880, 0x0900, 0x0980, 0x0A00, 0x0A80, 0x0B00, 0x0B80,
0x0C00, 0x0C80, 0x0D00, 0x0D80, 0x0E00, 0x0E80, 0x0F00, 0x0F80,
0x1000, 0x1080, 0x1100, 0x1180, 0x1200, 0x1280, 0x1300, 0x1380,
0x1400, 0x1480, 0x1500, 0x1580, 0x1600, 0x1680, 0x1700, 0x1780,
0x1800, 0x1880, 0x1900, 0x1980, 0x1A00, 0x1A80, 0x1B00, 0x1B80,
0x1C00, 0x1C80, 0x1D00, 0x1D80, 0x1E00, 0x1E80, 0x1F00, 0x1F80,
0x2000, 0x2080, 0x2100, 0x2180, 0x2200, 0x2280, 0x2300, 0x2380,
0x2400, 0x2480, 0x2500, 0x2580, 0x2600, 0x2680, 0x2700, 0x2780,
0x2800, 0x2880, 0x2900, 0x2980, 0x2A00, 0x2A80, 0x2B00, 0x2B80,
0x2C00, 0x2C80, 0x2D00, 0x2D80, 0x2E00, 0x2E80, 0x2F00, 0x2F80,
0x3000, 0x3080, 0x3100, 0x3180, 0x3200, 0x3280, 0x3300, 0x3380,
0x3400, 0x3480, 0x3500, 0x3580, 0x3600, 0x3680, 0x3700, 0x3780,
0x3800, 0x3880, 0x3900, 0x3980, 0x3A00, 0x3A80, 0x3B00, 0x3B80,
0x3C00, 0x3C80, 0x3D00, 0x3D80, 0x3E00, 0x3E80, 0x3F00, 0x3F80,
0x4000, 0x4080, 0x4100, 0x4180, 0x4200, 0x4280, 0x4300, 0x4380,
0x4400, 0x4480, 0x4500, 0x4580, 0x4600, 0x4680, 0x4700, 0x4780,
0x4800, 0x4880, 0x4900, 0x4980, 0x4A00, 0x4A80, 0x4B00, 0x4B80,
0x4C00, 0x4C80, 0x4D00, 0x4D80, 0x4E00, 0x4E80, 0x4F00, 0x4F80,
0x5000, 0x5080, 0x5100, 0x5180, 0x5200, 0x5280, 0x5300, 0x5380,
0x5400, 0x5480, 0x5500, 0x5580, 0x5600, 0x5680, 0x5700, 0x5780,
0x5800, 0x5880, 0x5900, 0x5980, 0x5A00, 0x5A80, 0x5B00, 0x5B80,
0x5C00, 0x5C80, 0x5D00, 0x5D80, 0x5E00, 0x5E80, 0x5F00, 0x5F80,
0x6000, 0x6080, 0x6100, 0x6180, 0x6200, 0x6280, 0x6300, 0x6380,
0x6400, 0x6480, 0x6500, 0x6580, 0x6600, 0x6680, 0x6700, 0x6780,
0x6800, 0x6880, 0x6900, 0x6980, 0x6A00, 0x6A80, 0x6B00, 0x6B80,
0x6C00, 0x6C80, 0x6D00, 0x6D80, 0x6E00, 0x6E80, 0x6F00, 0x6F80,
0x7000, 0x7080, 0x7100, 0x7180, 0x7200, 0x7280, 0x7300, 0x7380,
0x7400, 0x7480, 0x7500, 0x7580, 0x7600, 0x7680, 0x7700, 0x7780,
0x7800, 0x7880, 0x7900, 0x7980, 0x7A00, 0x7A80, 0x7B00, 0x7B80,
0x7C00, 0x7C80, 0x7D00, 0x7D80, 0x7E00, 0x7E80, 0x7F00, 0x7F80,
0x8000, 0x8080, 0x8100, 0x8180, 0x8200, 0x8280, 0x8300, 0x8380,
0x8400, 0x8480, 0x8500, 0x8580, 0x8600, 0x8680, 0x8700, 0x8780,
0x8800, 0x8880, 0x8900, 0x8980, 0x8A00, 0x8A80, 0x8B00, 0x8B80,
0x8C00, 0x8C80, 0x8D00, 0x8D80, 0x8E00, 0x8E80, 0x8F00, 0x8F80,
0x9000, 0x9080, 0x9100, 0x9180, 0x9200, 0x9280, 0x9300, 0x9380,
0x9400, 0x9480, 0x9500, 0x9580, 0x9600, 0x9680, 0x9700, 0x9780,
0x9800, 0x9880, 0x9900, 0x9980, 0x9A00, 0x9A80, 0x9B00, 0x9B80,
0x9C00, 0x9C80, 0x9D00, 0x9D80, 0x9E00, 0x9E80, 0x9F00, 0x9F80,
0xA000, 0xA080, 0xA100, 0xA180, 0xA200, 0xA280, 0xA300, 0xA380,
0xA400, 0xA480, 0xA500, 0xA580, 0xA600, 0xA680, 0xA700, 0xA780,
0xA800, 0xA880, 0xA900, 0xA980, 0xAA00, 0xAA80, 0xAB00, 0xAB80,
0xAC00, 0xAC80, 0xAD00, 0xAD80, 0xAE00, 0xAE80, 0xAF00, 0xAF80,
0xB000, 0xB080, 0xB100, 0xB180, 0xB200, 0xB280, 0xB300, 0xB380,
0xB400, 0xB480, 0xB500, 0xB580, 0xB600, 0xB680, 0xB700, 0xB780,
0xB800, 0xB880, 0xB900, 0xB980, 0xBA00, 0xBA80, 0xBB00, 0xBB80,
0xBC00, 0xBC80, 0xBD00, 0xBD80, 0xBE00, 0xBE80, 0xBF00, 0xBF80,
0xC000, 0xC080, 0xC100, 0xC180, 0xC200, 0xC280, 0xC300, 0xC380,
0xC400, 0xC480, 0xC500, 0xC580, 0xC600, 0xC680, 0xC700, 0xC780,
0xC800, 0xC880, 0xC900, 0xC980, 0xCA00, 0xCA80, 0xCB00, 0xCB80,
0xCC00, 0xCC80, 0xCD00, 0xCD80, 0xCE00, 0xCE80, 0xCF00, 0xCF80,
0xD000, 0xD080, 0xD100, 0xD180, 0xD200, 0xD280, 0xD300, 0xD380,
0xD400, 0xD480, 0xD500, 0xD580, 0xD600, 0xD680, 0xD700, 0xD780,
0xD800, 0xD880, 0xD900, 0xD980, 0xDA00, 0xDA80, 0xDB00, 0xDB80,
0xDC00, 0xDC80, 0xDD00, 0xDD80, 0xDE00, 0xDE80, 0xDF00, 0xDF80,
0xE000, 0xE080, 0xE100, 0xE180, 0xE200, 0xE280, 0xE300, 0xE380,
0xE400, 0xE480, 0xE500, 0xE580, 0xE600, 0xE680, 0xE700, 0xE780,
0xE800, 0xE880, 0xE900, 0xE980, 0xEA00, 0xEA80, 0xEB00, 0xEB80,
0xEC00, 0xEC80, 0xED00, 0xED80, 0xEE00, 0xEE80, 0xEF00, 0xEF80,
0xF000, 0xF080, 0xF100, 0xF180, 0xF200, 0xF280, 0xF300, 0xF380,
0xF400, 0xF480, 0xF500, 0xF580, 0xF600, 0xF680, 0xF700, 0xF780,
0xF800, 0xF880, 0xF900, 0xF980, 0xFA00, 0xFA80, 0xFB00, 0xFB80,
0xFC00, 0xFC80, 0xFD00, 0xFD80, 0xFE00, 0xFE80, 0xFF00, 0xFF80
#endif
#if (WINDOW_TYPE == 2)
// Hanning Window
0x0000, 0x0000, 0x0002, 0x0005, 0x0009, 0x000F, 0x0016, 0x001E,
0x0027, 0x0031, 0x003D, 0x004A, 0x0058, 0x0068, 0x0078, 0x008A,
0x009D, 0x00B2, 0x00C7, 0x00DE, 0x00F6, 0x010F, 0x012A, 0x0145,
0x0162, 0x0180, 0x01A0, 0x01C0, 0x01E2, 0x0205, 0x0229, 0x024F,
0x0275, 0x029D, 0x02C6, 0x02F0, 0x031C, 0x0348, 0x0376, 0x03A5,
0x03D6, 0x0407, 0x043A, 0x046D, 0x04A2, 0x04D9, 0x0510, 0x0549,
0x0582, 0x05BD, 0x05FA, 0x0637, 0x0675, 0x06B5, 0x06F6, 0x0738,
0x077B, 0x07BF, 0x0805, 0x084B, 0x0893, 0x08DC, 0x0926, 0x0971,
0x09BE, 0x0A0B, 0x0A5A, 0x0AAA, 0x0AFB, 0x0B4D, 0x0BA0, 0x0BF4,
0x0C4A, 0x0CA0, 0x0CF8, 0x0D50, 0x0DAA, 0x0E05, 0x0E61, 0x0EBE,
0x0F1D, 0x0F7C, 0x0FDC, 0x103E, 0x10A0, 0x1104, 0x1169, 0x11CF,
0x1235, 0x129D, 0x1306, 0x1370, 0x13DB, 0x1447, 0x14B5, 0x1523,
0x1592, 0x1602, 0x1673, 0x16E6, 0x1759, 0x17CD, 0x1842, 0x18B9,
0x1930, 0x19A8, 0x1A22, 0x1A9C, 0x1B17, 0x1B93, 0x1C10, 0x1C8E,
0x1D0D, 0x1D8E, 0x1E0E, 0x1E90, 0x1F13, 0x1F97, 0x201C, 0x20A1,
0x2128, 0x21AF, 0x2238, 0x22C1, 0x234B, 0x23D6, 0x2462, 0x24EF,
0x257D, 0x260C, 0x269B, 0x272B, 0x27BD, 0x284F, 0x28E2, 0x2975,
0x2A0A, 0x2A9F, 0x2B35, 0x2BCC, 0x2C64, 0x2CFD, 0x2D96, 0x2E31,
0x2ECC, 0x2F68, 0x3004, 0x30A1, 0x3140, 0x31DE, 0x327E, 0x331E,
0x33C0, 0x3461, 0x3504, 0x35A7, 0x364B, 0x36F0, 0x3796, 0x383C,
0x38E3, 0x398A, 0x3A32, 0x3ADB, 0x3B85, 0x3C2F, 0x3CDA, 0x3D85,
0x3E31, 0x3EDE, 0x3F8C, 0x403A, 0x40E8, 0x4197, 0x4247, 0x42F8,
0x43A9, 0x445A, 0x450D, 0x45BF, 0x4673, 0x4727, 0x47DB, 0x4890,
0x4945, 0x49FB, 0x4AB2, 0x4B69, 0x4C21, 0x4CD9, 0x4D91, 0x4E4A,
0x4F04, 0x4FBE, 0x5078, 0x5133, 0x51EE, 0x52AA, 0x5367, 0x5423,
0x54E0, 0x559E, 0x565C, 0x571A, 0x57D9, 0x5898, 0x5957, 0x5A17,
0x5AD7, 0x5B98, 0x5C59, 0x5D1A, 0x5DDC, 0x5E9E, 0x5F60, 0x6023,
0x60E6, 0x61A9, 0x626C, 0x6330, 0x63F4, 0x64B8, 0x657D, 0x6642,
0x6707, 0x67CC, 0x6892, 0x6957, 0x6A1D, 0x6AE4, 0x6BAA, 0x6C71,
0x6D37, 0x6DFE, 0x6EC6, 0x6F8D, 0x7054, 0x711C, 0x71E4, 0x72AC,
0x7374, 0x743C, 0x7504, 0x75CC, 0x7695, 0x775D, 0x7826, 0x78EF,
0x79B8, 0x7A80, 0x7B49, 0x7C12, 0x7CDB, 0x7DA4, 0x7E6D, 0x7F36,
0x7FFF, 0x80C9, 0x8192, 0x825B, 0x8324, 0x83ED, 0x84B6, 0x857F,
0x8647, 0x8710, 0x87D9, 0x88A2, 0x896A, 0x8A33, 0x8AFB, 0x8BC3,
0x8C8B, 0x8D53, 0x8E1B, 0x8EE3, 0x8FAB, 0x9072, 0x9139, 0x9201,
0x92C8, 0x938E, 0x9455, 0x951B, 0x95E2, 0x96A8, 0x976D, 0x9833,
0x98F8, 0x99BD, 0x9A82, 0x9B47, 0x9C0B, 0x9CCF, 0x9D93, 0x9E56,
0x9F19, 0x9FDC, 0xA09F, 0xA161, 0xA223, 0xA2E5, 0xA3A6, 0xA467,
0xA528, 0xA5E8, 0xA6A8, 0xA767, 0xA826, 0xA8E5, 0xA9A3, 0xAA61,
0xAB1F, 0xABDC, 0xAC98, 0xAD55, 0xAE11, 0xAECC, 0xAF87, 0xB041,
0xB0FB, 0xB1B5, 0xB26E, 0xB326, 0xB3DE, 0xB496, 0xB54D, 0xB604,
0xB6BA, 0xB76F, 0xB824, 0xB8D8, 0xB98C, 0xBA40, 0xBAF2, 0xBBA5,
0xBC56, 0xBD07, 0xBDB8, 0xBE68, 0xBF17, 0xBFC5, 0xC073, 0xC121,
0xC1CE, 0xC27A, 0xC325, 0xC3D0, 0xC47A, 0xC524, 0xC5CD, 0xC675,
0xC71C, 0xC7C3, 0xC869, 0xC90F, 0xC9B4, 0xCA58, 0xCAFB, 0xCB9E,
0xCC3F, 0xCCE1, 0xCD81, 0xCE21, 0xCEBF, 0xCF5E, 0xCFFB, 0xD097,
0xD133, 0xD1CE, 0xD269, 0xD302, 0xD39B, 0xD433, 0xD4CA, 0xD560,
0xD5F5, 0xD68A, 0xD71D, 0xD7B0, 0xD842, 0xD8D4, 0xD964, 0xD9F3,
0xDA82, 0xDB10, 0xDB9D, 0xDC29, 0xDCB4, 0xDD3E, 0xDDC7, 0xDE50,
0xDED7, 0xDF5E, 0xDFE3, 0xE068, 0xE0EC, 0xE16F, 0xE1F1, 0xE271,
0xE2F2, 0xE371, 0xE3EF, 0xE46C, 0xE4E8, 0xE563, 0xE5DD, 0xE657,
0xE6CF, 0xE746, 0xE7BD, 0xE832, 0xE8A6, 0xE919, 0xE98C, 0xE9FD,
0xEA6D, 0xEADC, 0xEB4A, 0xEBB8, 0xEC24, 0xEC8F, 0xECF9, 0xED62,
0xEDCA, 0xEE30, 0xEE96, 0xEEFB, 0xEF5F, 0xEFC1, 0xF023, 0xF083,
0xF0E2, 0xF141, 0xF19E, 0xF1FA, 0xF255, 0xF2AF, 0xF307, 0xF35F,
0xF3B5, 0xF40B, 0xF45F, 0xF4B2, 0xF504, 0xF555, 0xF5A5, 0xF5F4,
0xF641, 0xF68E, 0xF6D9, 0xF723, 0xF76C, 0xF7B4, 0xF7FA, 0xF840,
0xF884, 0xF8C7, 0xF909, 0xF94A, 0xF98A, 0xF9C8, 0xFA05, 0xFA42,
0xFA7D, 0xFAB6, 0xFAEF, 0xFB26, 0xFB5D, 0xFB92, 0xFBC5, 0xFBF8,
0xFC29, 0xFC5A, 0xFC89, 0xFCB7, 0xFCE3, 0xFD0F, 0xFD39, 0xFD62,
0xFD8A, 0xFDB0, 0xFDD6, 0xFDFA, 0xFE1D, 0xFE3F, 0xFE5F, 0xFE7F,
0xFE9D, 0xFEBA, 0xFED5, 0xFEF0, 0xFF09, 0xFF21, 0xFF38, 0xFF4D,
0xFF62, 0xFF75, 0xFF87, 0xFF97, 0xFFA7, 0xFFB5, 0xFFC2, 0xFFCE,
0xFFD8, 0xFFE1, 0xFFE9, 0xFFF0, 0xFFF6, 0xFFFA, 0xFFFD, 0xFFFF
#endif
#if (WINDOW_TYPE == 3)
// Hamming Window
0x147A, 0x147B, 0x147D, 0x147F, 0x1483, 0x1489, 0x148F, 0x1496,
0x149F, 0x14A8, 0x14B3, 0x14BF, 0x14CC, 0x14DA, 0x14EA, 0x14FA,
0x150C, 0x151E, 0x1532, 0x1547, 0x155D, 0x1574, 0x158D, 0x15A6,
0x15C1, 0x15DC, 0x15F9, 0x1617, 0x1636, 0x1656, 0x1678, 0x169A,
0x16BE, 0x16E2, 0x1708, 0x172F, 0x1757, 0x1780, 0x17AA, 0x17D5,
0x1802, 0x182F, 0x185E, 0x188E, 0x18BE, 0x18F0, 0x1923, 0x1957,
0x198C, 0x19C3, 0x19FA, 0x1A32, 0x1A6C, 0x1AA6, 0x1AE2, 0x1B1F,
0x1B5D, 0x1B9B, 0x1BDB, 0x1C1C, 0x1C5E, 0x1CA2, 0x1CE6, 0x1D2B,
0x1D71, 0x1DB8, 0x1E01, 0x1E4A, 0x1E95, 0x1EE0, 0x1F2D, 0x1F7A,
0x1FC9, 0x2018, 0x2069, 0x20BB, 0x210D, 0x2161, 0x21B6, 0x220B,
0x2262, 0x22BA, 0x2312, 0x236C, 0x23C7, 0x2422, 0x247F, 0x24DD,
0x253B, 0x259B, 0x25FC, 0x265D, 0x26C0, 0x2723, 0x2787, 0x27ED,
0x2853, 0x28BA, 0x2922, 0x298C, 0x29F6, 0x2A61, 0x2ACC, 0x2B39,
0x2BA7, 0x2C16, 0x2C85, 0x2CF6, 0x2D67, 0x2DD9, 0x2E4C, 0x2EC0,
0x2F35, 0x2FAB, 0x3022, 0x3099, 0x3112, 0x318B, 0x3205, 0x3280,
0x32FC, 0x3378, 0x33F6, 0x3474, 0x34F3, 0x3573, 0x35F4, 0x3676,
0x36F8, 0x377B, 0x37FF, 0x3884, 0x390A, 0x3990, 0x3A17, 0x3A9F,
0x3B28, 0x3BB1, 0x3C3B, 0x3CC6, 0x3D52, 0x3DDE, 0x3E6C, 0x3EFA,
0x3F88, 0x4018, 0x40A8, 0x4138, 0x41CA, 0x425C, 0x42EF, 0x4382,
0x4417, 0x44AC, 0x4541, 0x45D7, 0x466E, 0x4706, 0x479E, 0x4837,
0x48D0, 0x496B, 0x4A05, 0x4AA1, 0x4B3D, 0x4BD9, 0x4C76, 0x4D14,
0x4DB3, 0x4E51, 0x4EF1, 0x4F91, 0x5032, 0x50D3, 0x5175, 0x5217,
0x52BA, 0x535D, 0x5401, 0x54A6, 0x554B, 0x55F0, 0x5696, 0x573D,
0x57E4, 0x588B, 0x5933, 0x59DB, 0x5A84, 0x5B2E, 0x5BD7, 0x5C82,
0x5D2C, 0x5DD7, 0x5E83, 0x5F2F, 0x5FDB, 0x6088, 0x6135, 0x61E3,
0x6291, 0x633F, 0x63EE, 0x649D, 0x654D, 0x65FC, 0x66AC, 0x675D,
0x680E, 0x68BF, 0x6971, 0x6A22, 0x6AD4, 0x6B87, 0x6C3A, 0x6CED,
0x6DA0, 0x6E53, 0x6F07, 0x6FBB, 0x7070, 0x7124, 0x71D9, 0x728E,
0x7344, 0x73F9, 0x74AF, 0x7565, 0x761B, 0x76D1, 0x7788, 0x783F,
0x78F6, 0x79AD, 0x7A64, 0x7B1B, 0x7BD3, 0x7C8A, 0x7D42, 0x7DFA,
0x7EB2, 0x7F6A, 0x8022, 0x80DB, 0x8193, 0x824C, 0x8304, 0x83BD,
0x8476, 0x852E, 0x85E7, 0x86A0, 0x8759, 0x8812, 0x88CB, 0x8984,
0x8A3D, 0x8AF6, 0x8BAF, 0x8C68, 0x8D21, 0x8DDA, 0x8E93, 0x8F4B,
0x9004, 0x90BD, 0x9176, 0x922E, 0x92E7, 0x939F, 0x9457, 0x9510,
0x95C8, 0x9680, 0x9738, 0x97F0, 0x98A7, 0x995F, 0x9A16, 0x9ACD,
0x9B84, 0x9C3B, 0x9CF2, 0x9DA9, 0x9E5F, 0x9F15, 0x9FCB, 0xA081,
0xA136, 0xA1EC, 0xA2A1, 0xA355, 0xA40A, 0xA4BE, 0xA573, 0xA626,
0xA6DA, 0xA78D, 0xA840, 0xA8F3, 0xA9A5, 0xAA58, 0xAB09, 0xABBB,
0xAC6C, 0xAD1D, 0xADCD, 0xAE7E, 0xAF2D, 0xAFDD, 0xB08C, 0xB13B,
0xB1E9, 0xB297, 0xB345, 0xB3F2, 0xB49F, 0xB54B, 0xB5F7, 0xB6A2,
0xB74E, 0xB7F8, 0xB8A2, 0xB94C, 0xB9F6, 0xBA9E, 0xBB47, 0xBBEF,
0xBC96, 0xBD3D, 0xBDE4, 0xBE8A, 0xBF2F, 0xBFD4, 0xC079, 0xC11D,
0xC1C0, 0xC263, 0xC305, 0xC3A7, 0xC448, 0xC4E9, 0xC589, 0xC628,
0xC6C7, 0xC766, 0xC804, 0xC8A1, 0xC93D, 0xC9D9, 0xCA75, 0xCB0F,
0xCBA9, 0xCC43, 0xCCDC, 0xCD74, 0xCE0C, 0xCEA2, 0xCF39, 0xCFCE,
0xD063, 0xD0F7, 0xD18B, 0xD21E, 0xD2B0, 0xD342, 0xD3D2, 0xD462,
0xD4F2, 0xD580, 0xD60E, 0xD69B, 0xD728, 0xD7B4, 0xD83E, 0xD8C9,
0xD952, 0xD9DB, 0xDA63, 0xDAEA, 0xDB70, 0xDBF6, 0xDC7B, 0xDCFF,
0xDD82, 0xDE04, 0xDE86, 0xDF07, 0xDF86, 0xE006, 0xE084, 0xE101,
0xE17E, 0xE1FA, 0xE275, 0xE2EF, 0xE368, 0xE3E1, 0xE458, 0xE4CF,
0xE545, 0xE5B9, 0xE62D, 0xE6A1, 0xE713, 0xE784, 0xE7F5, 0xE864,
0xE8D3, 0xE941, 0xE9AD, 0xEA19, 0xEA84, 0xEAEE, 0xEB57, 0xEBC0,
0xEC27, 0xEC8D, 0xECF3, 0xED57, 0xEDBA, 0xEE1D, 0xEE7E, 0xEEDF,
0xEF3F, 0xEF9D, 0xEFFB, 0xF057, 0xF0B3, 0xF10E, 0xF167, 0xF1C0,
0xF218, 0xF26F, 0xF2C4, 0xF319, 0xF36D, 0xF3BF, 0xF411, 0xF462,
0xF4B1, 0xF500, 0xF54D, 0xF59A, 0xF5E5, 0xF630, 0xF679, 0xF6C1,
0xF709, 0xF74F, 0xF794, 0xF7D8, 0xF81B, 0xF85E, 0xF89E, 0xF8DE,
0xF91D, 0xF95B, 0xF998, 0xF9D3, 0xFA0E, 0xFA47, 0xFA80, 0xFAB7,
0xFAED, 0xFB23, 0xFB57, 0xFB8A, 0xFBBB, 0xFBEC, 0xFC1C, 0xFC4B,
0xFC78, 0xFCA4, 0xFCD0, 0xFCFA, 0xFD23, 0xFD4B, 0xFD72, 0xFD98,
0xFDBC, 0xFDE0, 0xFE02, 0xFE23, 0xFE44, 0xFE63, 0xFE81, 0xFE9E,
0xFEB9, 0xFED4, 0xFEED, 0xFF06, 0xFF1D, 0xFF33, 0xFF48, 0xFF5C,
0xFF6E, 0xFF80, 0xFF90, 0xFFA0, 0xFFAE, 0xFFBB, 0xFFC7, 0xFFD2,
0xFFDB, 0xFFE4, 0xFFEB, 0xFFF1, 0xFFF6, 0xFFFA, 0xFFFD, 0xFFFF
#endif
#if (WINDOW_TYPE == 4)
// Blackman Window
0x0000, 0x0000, 0x0000, 0x0001, 0x0003, 0x0005, 0x0007, 0x000A,
0x000E, 0x0012, 0x0016, 0x001A, 0x0020, 0x0025, 0x002B, 0x0032,
0x0039, 0x0040, 0x0048, 0x0050, 0x0059, 0x0062, 0x006C, 0x0076,
0x0080, 0x008B, 0x0097, 0x00A3, 0x00AF, 0x00BC, 0x00CA, 0x00D8,
0x00E6, 0x00F5, 0x0104, 0x0114, 0x0124, 0x0135, 0x0146, 0x0158,
0x016A, 0x017D, 0x0190, 0x01A4, 0x01B9, 0x01CD, 0x01E3, 0x01F9,
0x020F, 0x0226, 0x023D, 0x0255, 0x026E, 0x0287, 0x02A0, 0x02BA,
0x02D5, 0x02F0, 0x030C, 0x0328, 0x0345, 0x0362, 0x0380, 0x039F,
0x03BE, 0x03DE, 0x03FE, 0x041F, 0x0441, 0x0463, 0x0486, 0x04A9,
0x04CD, 0x04F1, 0x0516, 0x053C, 0x0563, 0x058A, 0x05B1, 0x05DA,
0x0603, 0x062C, 0x0656, 0x0681, 0x06AD, 0x06D9, 0x0706, 0x0734,
0x0762, 0x0791, 0x07C1, 0x07F1, 0x0822, 0x0854, 0x0886, 0x08B9,
0x08ED, 0x0922, 0x0957, 0x098D, 0x09C4, 0x09FC, 0x0A34, 0x0A6D,
0x0AA7, 0x0AE2, 0x0B1D, 0x0B59, 0x0B96, 0x0BD4, 0x0C12, 0x0C51,
0x0C91, 0x0CD2, 0x0D14, 0x0D56, 0x0D9A, 0x0DDE, 0x0E23, 0x0E68,
0x0EAF, 0x0EF6, 0x0F3F, 0x0F88, 0x0FD2, 0x101D, 0x1068, 0x10B5,
0x1102, 0x1150, 0x11A0, 0x11F0, 0x1240, 0x1292, 0x12E5, 0x1339,
0x138D, 0x13E2, 0x1439, 0x1490, 0x14E8, 0x1541, 0x159B, 0x15F6,
0x1652, 0x16AF, 0x170D, 0x176B, 0x17CB, 0x182B, 0x188D, 0x18EF,
0x1953, 0x19B7, 0x1A1D, 0x1A83, 0x1AEA, 0x1B53, 0x1BBC, 0x1C26,
0x1C91, 0x1CFE, 0x1D6B, 0x1DD9, 0x1E48, 0x1EB8, 0x1F2A, 0x1F9C,
0x200F, 0x2083, 0x20F8, 0x216F, 0x21E6, 0x225E, 0x22D7, 0x2352,
0x23CD, 0x2449, 0x24C7, 0x2545, 0x25C5, 0x2645, 0x26C6, 0x2749,
0x27CC, 0x2851, 0x28D7, 0x295D, 0x29E5, 0x2A6D, 0x2AF7, 0x2B82,
0x2C0E, 0x2C9A, 0x2D28, 0x2DB7, 0x2E47, 0x2ED8, 0x2F6A, 0x2FFD,
0x3091, 0x3126, 0x31BC, 0x3253, 0x32EB, 0x3384, 0x341E, 0x34B9,
0x3555, 0x35F2, 0x3691, 0x3730, 0x37D0, 0x3871, 0x3913, 0x39B7,
0x3A5B, 0x3B00, 0x3BA6, 0x3C4D, 0x3CF6, 0x3D9F, 0x3E49, 0x3EF4,
0x3FA0, 0x404D, 0x40FB, 0x41AA, 0x425A, 0x430B, 0x43BD, 0x4470,
0x4523, 0x45D8, 0x468E, 0x4744, 0x47FC, 0x48B4, 0x496D, 0x4A28,
0x4AE3, 0x4B9F, 0x4C5C, 0x4D19, 0x4DD8, 0x4E97, 0x4F58, 0x5019,
0x50DB, 0x519E, 0x5262, 0x5326, 0x53EC, 0x54B2, 0x5579, 0x5641,
0x570A, 0x57D3, 0x589D, 0x5968, 0x5A34, 0x5B01, 0x5BCE, 0x5C9C,
0x5D6B, 0x5E3A, 0x5F0B, 0x5FDB, 0x60AD, 0x617F, 0x6252, 0x6326,
0x63FA, 0x64CF, 0x65A5, 0x667B, 0x6752, 0x682A, 0x6902, 0x69DA,
0x6AB4, 0x6B8D, 0x6C68, 0x6D43, 0x6E1E, 0x6EFA, 0x6FD7, 0x70B4,
0x7192, 0x7270, 0x734E, 0x742D, 0x750D, 0x75ED, 0x76CD, 0x77AE,
0x788F, 0x7970, 0x7A52, 0x7B35, 0x7C17, 0x7CFA, 0x7DDE, 0x7EC1,
0x7FA5, 0x808A, 0x816E, 0x8253, 0x8338, 0x841E, 0x8503, 0x85E9,
0x86CF, 0x87B5, 0x889C, 0x8982, 0x8A69, 0x8B50, 0x8C37, 0x8D1E,
0x8E05, 0x8EEC, 0x8FD4, 0x90BB, 0x91A3, 0x928A, 0x9372, 0x9459,
0x9541, 0x9628, 0x9710, 0x97F7, 0x98DE, 0x99C6, 0x9AAD, 0x9B94,
0x9C7B, 0x9D61, 0x9E48, 0x9F2E, 0xA015, 0xA0FB, 0xA1E0, 0xA2C6,
0xA3AB, 0xA490, 0xA575, 0xA65A, 0xA73E, 0xA822, 0xA905, 0xA9E8,
0xAACB, 0xABAE, 0xAC90, 0xAD71, 0xAE52, 0xAF33, 0xB013, 0xB0F3,
0xB1D3, 0xB2B1, 0xB390, 0xB46D, 0xB54B, 0xB627, 0xB703, 0xB7DF,
0xB8BA, 0xB994, 0xBA6D, 0xBB46, 0xBC1E, 0xBCF6, 0xBDCD, 0xBEA3,
0xBF78, 0xC04D, 0xC121, 0xC1F4, 0xC2C6, 0xC398, 0xC468, 0xC538,
0xC607, 0xC6D5, 0xC7A2, 0xC86F, 0xC93A, 0xCA04, 0xCACE, 0xCB96,
0xCC5E, 0xCD25, 0xCDEA, 0xCEAF, 0xCF72, 0xD035, 0xD0F6, 0xD1B6,
0xD275, 0xD334, 0xD3F1, 0xD4AC, 0xD567, 0xD621, 0xD6D9, 0xD790,
0xD846, 0xD8FB, 0xD9AE, 0xDA61, 0xDB12, 0xDBC1, 0xDC70, 0xDD1D,
0xDDC9, 0xDE73, 0xDF1C, 0xDFC4, 0xE06A, 0xE10F, 0xE1B3, 0xE255,
0xE2F6, 0xE396, 0xE433, 0xE4D0, 0xE56B, 0xE605, 0xE69D, 0xE733,
0xE7C8, 0xE85C, 0xE8EE, 0xE97E, 0xEA0D, 0xEA9A, 0xEB26, 0xEBB0,
0xEC39, 0xECBF, 0xED45, 0xEDC8, 0xEE4A, 0xEECB, 0xEF49, 0xEFC6,
0xF042, 0xF0BB, 0xF133, 0xF1A9, 0xF21E, 0xF290, 0xF301, 0xF370,
0xF3DE, 0xF44A, 0xF4B3, 0xF51C, 0xF582, 0xF5E6, 0xF649, 0xF6AA,
0xF709, 0xF766, 0xF7C1, 0xF81B, 0xF873, 0xF8C8, 0xF91C, 0xF96E,
0xF9BE, 0xFA0D, 0xFA59, 0xFAA3, 0xFAEC, 0xFB33, 0xFB77, 0xFBBA,
0xFBFB, 0xFC3A, 0xFC77, 0xFCB2, 0xFCEB, 0xFD22, 0xFD57, 0xFD8A,
0xFDBB, 0xFDEA, 0xFE17, 0xFE43, 0xFE6C, 0xFE93, 0xFEB8, 0xFEDC,
0xFEFD, 0xFF1C, 0xFF39, 0xFF55, 0xFF6E, 0xFF85, 0xFF9A, 0xFFAE,
0xFFBF, 0xFFCE, 0xFFDB, 0xFFE6, 0xFFEF, 0xFFF6, 0xFFFB, 0xFFFE
#endif
#endif
// Window Functions for NUM_FFT = 512
// Triangle Window
unsigned int code WindowFunc[256] =
0x0000, 0x0100, 0x0200, 0x0300, 0x0400, 0x0500, 0x0600, 0x0700,
0x0800, 0x0900, 0x0A00, 0x0B00, 0x0C00, 0x0D00, 0x0E00, 0x0F00,
0x1000, 0x1100, 0x1200, 0x1300, 0x1400, 0x1500, 0x1600, 0x1700,
0x1800, 0x1900, 0x1A00, 0x1B00, 0x1C00, 0x1D00, 0x1E00, 0x1F00,
0x2000, 0x2100, 0x2200, 0x2300, 0x2400, 0x2500, 0x2600, 0x2700,
0x2800, 0x2900, 0x2A00, 0x2B00, 0x2C00, 0x2D00, 0x2E00, 0x2F00,
0x3000, 0x3100, 0x3200, 0x3300, 0x3400, 0x3500, 0x3600, 0x3700,
0x3800, 0x3900, 0x3A00, 0x3B00, 0x3C00, 0x3D00, 0x3E00, 0x3F00,
0x4000, 0x4100, 0x4200, 0x4300, 0x4400, 0x4500, 0x4600, 0x4700,
0x4800, 0x4900, 0x4A00, 0x4B00, 0x4C00, 0x4D00, 0x4E00, 0x4F00,
0x5000, 0x5100, 0x5200, 0x5300, 0x5400, 0x5500, 0x5600, 0x5700,
0x5800, 0x5900, 0x5A00, 0x5B00, 0x5C00, 0x5D00, 0x5E00, 0x5F00,
0x6000, 0x6100, 0x6200, 0x6300, 0x6400, 0x6500, 0x6600, 0x6700,
0x6800, 0x6900, 0x6A00, 0x6B00, 0x6C00, 0x6D00, 0x6E00, 0x6F00,
0x7000, 0x7100, 0x7200, 0x7300, 0x7400, 0x7500, 0x7600, 0x7700,
0x7800, 0x7900, 0x7A00, 0x7B00, 0x7C00, 0x7D00, 0x7E00, 0x7F00,
0x8000, 0x8100, 0x8200, 0x8300, 0x8400, 0x8500, 0x8600, 0x8700,
0x8800, 0x8900, 0x8A00, 0x8B00, 0x8C00, 0x8D00, 0x8E00, 0x8F00,
0x9000, 0x9100, 0x9200, 0x9300, 0x9400, 0x9500, 0x9600, 0x9700,
0x9800, 0x9900, 0x9A00, 0x9B00, 0x9C00, 0x9D00, 0x9E00, 0x9F00,
0xA000, 0xA100, 0xA200, 0xA300, 0xA400, 0xA500, 0xA600, 0xA700,
0xA800, 0xA900, 0xAA00, 0xAB00, 0xAC00, 0xAD00, 0xAE00, 0xAF00,
0xB000, 0xB100, 0xB200, 0xB300, 0xB400, 0xB500, 0xB600, 0xB700,
0xB800, 0xB900, 0xBA00, 0xBB00, 0xBC00, 0xBD00, 0xBE00, 0xBF00,
0xC000, 0xC100, 0xC200, 0xC300, 0xC400, 0xC500, 0xC600, 0xC700,
0xC800, 0xC900, 0xCA00, 0xCB00, 0xCC00, 0xCD00, 0xCE00, 0xCF00,
0xD000, 0xD100, 0xD200, 0xD300, 0xD400, 0xD500, 0xD600, 0xD700,
0xD800, 0xD900, 0xDA00, 0xDB00, 0xDC00, 0xDD00, 0xDE00, 0xDF00,
0xE000, 0xE100, 0xE200, 0xE300, 0xE400, 0xE500, 0xE600, 0xE700,
0xE800, 0xE900, 0xEA00, 0xEB00, 0xEC00, 0xED00, 0xEE00, 0xEF00,
0xF000, 0xF100, 0xF200, 0xF300, 0xF400, 0xF500, 0xF600, 0xF700,
0xF800, 0xF900, 0xFA00, 0xFB00, 0xFC00, 0xFD00, 0xFE00, 0xFF00
#endif
// Hanning Window
0x0000, 0x0002, 0x0009, 0x0016, 0x0027, 0x003D, 0x0058, 0x0078,
0x009D, 0x00C7, 0x00F6, 0x012A, 0x0162, 0x01A0, 0x01E2, 0x0229,
0x0275, 0x02C6, 0x031C, 0x0376, 0x03D6, 0x043A, 0x04A2, 0x0510,
0x0582, 0x05FA, 0x0675, 0x06F6, 0x077B, 0x0805, 0x0893, 0x0926,
0x09BE, 0x0A5A, 0x0AFB, 0x0BA0, 0x0C4A, 0x0CF8, 0x0DAA, 0x0E61,
0x0F1D, 0x0FDC, 0x10A0, 0x1169, 0x1235, 0x1306, 0x13DB, 0x14B5,
0x1592, 0x1673, 0x1759, 0x1842, 0x1930, 0x1A22, 0x1B17, 0x1C10,
0x1D0D, 0x1E0E, 0x1F13, 0x201C, 0x2128, 0x2238, 0x234B, 0x2462,
0x257D, 0x269B, 0x27BD, 0x28E2, 0x2A0A, 0x2B35, 0x2C64, 0x2D96,
0x2ECC, 0x3004, 0x3140, 0x327E, 0x33C0, 0x3504, 0x364B, 0x3796,
0x38E3, 0x3A32, 0x3B85, 0x3CDA, 0x3E31, 0x3F8C, 0x40E8, 0x4247,
0x43A9, 0x450D, 0x4673, 0x47DB, 0x4945, 0x4AB2, 0x4C21, 0x4D91,
0x4F04, 0x5078, 0x51EE, 0x5367, 0x54E0, 0x565C, 0x57D9, 0x5957,
0x5AD7, 0x5C59, 0x5DDC, 0x5F60, 0x60E6, 0x626C, 0x63F4, 0x657D,
0x6707, 0x6892, 0x6A1D, 0x6BAA, 0x6D37, 0x6EC6, 0x7054, 0x71E4,
0x7374, 0x7504, 0x7695, 0x7826, 0x79B8, 0x7B49, 0x7CDB, 0x7E6D,
0x7FFF, 0x8192, 0x8324, 0x84B6, 0x8647, 0x87D9, 0x896A, 0x8AFB,
0x8C8B, 0x8E1B, 0x8FAB, 0x9139, 0x92C8, 0x9455, 0x95E2, 0x976D,
0x98F8, 0x9A82, 0x9C0B, 0x9D93, 0x9F19, 0xA09F, 0xA223, 0xA3A6,
0xA528, 0xA6A8, 0xA826, 0xA9A3, 0xAB1F, 0xAC98, 0xAE11, 0xAF87,
0xB0FB, 0xB26E, 0xB3DE, 0xB54D, 0xB6BA, 0xB824, 0xB98C, 0xBAF2,
0xBC56, 0xBDB8, 0xBF17, 0xC073, 0xC1CE, 0xC325, 0xC47A, 0xC5CD,
0xC71C, 0xC869, 0xC9B4, 0xCAFB, 0xCC3F, 0xCD81, 0xCEBF, 0xCFFB,
0xD133, 0xD269, 0xD39B, 0xD4CA, 0xD5F5, 0xD71D, 0xD842, 0xD964,
0xDA82, 0xDB9D, 0xDCB4, 0xDDC7, 0xDED7, 0xDFE3, 0xE0EC, 0xE1F1,
0xE2F2, 0xE3EF, 0xE4E8, 0xE5DD, 0xE6CF, 0xE7BD, 0xE8A6, 0xE98C,
0xEA6D, 0xEB4A, 0xEC24, 0xECF9, 0xEDCA, 0xEE96, 0xEF5F, 0xF023,
0xF0E2, 0xF19E, 0xF255, 0xF307, 0xF3B5, 0xF45F, 0xF504, 0xF5A5,
0xF641, 0xF6D9, 0xF76C, 0xF7FA, 0xF884, 0xF909, 0xF98A, 0xFA05,
0xFA7D, 0xFAEF, 0xFB5D, 0xFBC5, 0xFC29, 0xFC89, 0xFCE3, 0xFD39,
0xFD8A, 0xFDD6, 0xFE1D, 0xFE5F, 0xFE9D, 0xFED5, 0xFF09, 0xFF38,
0xFF62, 0xFF87, 0xFFA7, 0xFFC2, 0xFFD8, 0xFFE9, 0xFFF6, 0xFFFD
#endif
// Hamming Window
0x147A, 0x147D, 0x1483, 0x148F, 0x149F, 0x14B3, 0x14CC, 0x14EA,
0x150C, 0x1532, 0x155D, 0x158D, 0x15C1, 0x15F9, 0x1636, 0x1678,
0x16BE, 0x1708, 0x1757, 0x17AA, 0x1802, 0x185E, 0x18BE, 0x1923,
0x198C, 0x19FA, 0x1A6C, 0x1AE2, 0x1B5D, 0x1BDB, 0x1C5E, 0x1CE6,
0x1D71, 0x1E01, 0x1E95, 0x1F2D, 0x1FC9, 0x2069, 0x210D, 0x21B6,
0x2262, 0x2312, 0x23C7, 0x247F, 0x253B, 0x25FC, 0x26C0, 0x2787,
0x2853, 0x2922, 0x29F6, 0x2ACC, 0x2BA7, 0x2C85, 0x2D67, 0x2E4C,
0x2F35, 0x3022, 0x3112, 0x3205, 0x32FC, 0x33F6, 0x34F3, 0x35F4,
0x36F8, 0x37FF, 0x390A, 0x3A17, 0x3B28, 0x3C3B, 0x3D52, 0x3E6C,
0x3F88, 0x40A8, 0x41CA, 0x42EF, 0x4417, 0x4541, 0x466E, 0x479E,
0x48D0, 0x4A05, 0x4B3D, 0x4C76, 0x4DB3, 0x4EF1, 0x5032, 0x5175,
0x52BA, 0x5401, 0x554B, 0x5696, 0x57E4, 0x5933, 0x5A84, 0x5BD7,
0x5D2C, 0x5E83, 0x5FDB, 0x6135, 0x6291, 0x63EE, 0x654D, 0x66AC,
0x680E, 0x6971, 0x6AD4, 0x6C3A, 0x6DA0, 0x6F07, 0x7070, 0x71D9,
0x7344, 0x74AF, 0x761B, 0x7788, 0x78F6, 0x7A64, 0x7BD3, 0x7D42,
0x7EB2, 0x8022, 0x8193, 0x8304, 0x8476, 0x85E7, 0x8759, 0x88CB,
0x8A3D, 0x8BAF, 0x8D21, 0x8E93, 0x9004, 0x9176, 0x92E7, 0x9457,
0x95C8, 0x9738, 0x98A7, 0x9A16, 0x9B84, 0x9CF2, 0x9E5F, 0x9FCB,
0xA136, 0xA2A1, 0xA40A, 0xA573, 0xA6DA, 0xA840, 0xA9A5, 0xAB09,
0xAC6C, 0xADCD, 0xAF2D, 0xB08C, 0xB1E9, 0xB345, 0xB49F, 0xB5F7,
0xB74E, 0xB8A2, 0xB9F6, 0xBB47, 0xBC96, 0xBDE4, 0xBF2F, 0xC079,
0xC1C0, 0xC305, 0xC448, 0xC589, 0xC6C7, 0xC804, 0xC93D, 0xCA75,
0xCBA9, 0xCCDC, 0xCE0C, 0xCF39, 0xD063, 0xD18B, 0xD2B0, 0xD3D2,
0xD4F2, 0xD60E, 0xD728, 0xD83E, 0xD952, 0xDA63, 0xDB70, 0xDC7B,
0xDD82, 0xDE86, 0xDF86, 0xE084, 0xE17E, 0xE275, 0xE368, 0xE458,
0xE545, 0xE62D, 0xE713, 0xE7F5, 0xE8D3, 0xE9AD, 0xEA84, 0xEB57,
0xEC27, 0xECF3, 0xEDBA, 0xEE7E, 0xEF3F, 0xEFFB, 0xF0B3, 0xF167,
0xF218, 0xF2C4, 0xF36D, 0xF411, 0xF4B1, 0xF54D, 0xF5E5, 0xF679,
0xF709, 0xF794, 0xF81B, 0xF89E, 0xF91D, 0xF998, 0xFA0E, 0xFA80,
0xFAED, 0xFB57, 0xFBBB, 0xFC1C, 0xFC78, 0xFCD0, 0xFD23, 0xFD72,
0xFDBC, 0xFE02, 0xFE44, 0xFE81, 0xFEB9, 0xFEED, 0xFF1D, 0xFF48,
0xFF6E, 0xFF90, 0xFFAE, 0xFFC7, 0xFFDB, 0xFFEB, 0xFFF6, 0xFFFD
#endif
// Blackman Window
0x0000, 0x0000, 0x0003, 0x0007, 0x000E, 0x0016, 0x0020, 0x002B,
0x0039, 0x0048, 0x0059, 0x006C, 0x0080, 0x0097, 0x00AF, 0x00CA,
0x00E6, 0x0104, 0x0124, 0x0146, 0x016A, 0x0190, 0x01B9, 0x01E3,
0x020F, 0x023D, 0x026E, 0x02A0, 0x02D5, 0x030C, 0x0345, 0x0380,
0x03BE, 0x03FE, 0x0441, 0x0486, 0x04CD, 0x0516, 0x0563, 0x05B1,
0x0603, 0x0656, 0x06AD, 0x0706, 0x0762, 0x07C1, 0x0822, 0x0886,
0x08ED, 0x0957, 0x09C4, 0x0A34, 0x0AA7, 0x0B1D, 0x0B96, 0x0C12,
0x0C91, 0x0D14, 0x0D9A, 0x0E23, 0x0EAF, 0x0F3F, 0x0FD2, 0x1068,
0x1102, 0x11A0, 0x1240, 0x12E5, 0x138D, 0x1439, 0x14E8, 0x159B,
0x1652, 0x170D, 0x17CB, 0x188D, 0x1953, 0x1A1D, 0x1AEA, 0x1BBC,
0x1C91, 0x1D6B, 0x1E48, 0x1F2A, 0x200F, 0x20F8, 0x21E6, 0x22D7,
0x23CD, 0x24C7, 0x25C5, 0x26C6, 0x27CC, 0x28D7, 0x29E5, 0x2AF7,
0x2C0E, 0x2D28, 0x2E47, 0x2F6A, 0x3091, 0x31BC, 0x32EB, 0x341E,
0x3555, 0x3691, 0x37D0, 0x3913, 0x3A5B, 0x3BA6, 0x3CF6, 0x3E49,
0x3FA0, 0x40FB, 0x425A, 0x43BD, 0x4523, 0x468E, 0x47FC, 0x496D,
0x4AE3, 0x4C5C, 0x4DD8, 0x4F58, 0x50DB, 0x5262, 0x53EC, 0x5579,
0x570A, 0x589D, 0x5A34, 0x5BCE, 0x5D6B, 0x5F0B, 0x60AD, 0x6252,
0x63FA, 0x65A5, 0x6752, 0x6902, 0x6AB4, 0x6C68, 0x6E1E, 0x6FD7,
0x7192, 0x734E, 0x750D, 0x76CD, 0x788F, 0x7A52, 0x7C17, 0x7DDE,
0x7FA5, 0x816E, 0x8338, 0x8503, 0x86CF, 0x889C, 0x8A69, 0x8C37,
0x8E05, 0x8FD4, 0x91A3, 0x9372, 0x9541, 0x9710, 0x98DE, 0x9AAD,
0x9C7B, 0x9E48, 0xA015, 0xA1E0, 0xA3AB, 0xA575, 0xA73E, 0xA905,
0xAACB, 0xAC90, 0xAE52, 0xB013, 0xB1D3, 0xB390, 0xB54B, 0xB703,
0xB8BA, 0xBA6D, 0xBC1E, 0xBDCD, 0xBF78, 0xC121, 0xC2C6, 0xC468,
0xC607, 0xC7A2, 0xC93A, 0xCACE, 0xCC5E, 0xCDEA, 0xCF72, 0xD0F6,
0xD275, 0xD3F1, 0xD567, 0xD6D9, 0xD846, 0xD9AE, 0xDB12, 0xDC70,
0xDDC9, 0xDF1C, 0xE06A, 0xE1B3, 0xE2F6, 0xE433, 0xE56B, 0xE69D,
0xE7C8, 0xE8EE, 0xEA0D, 0xEB26, 0xEC39, 0xED45, 0xEE4A, 0xEF49,
0xF042, 0xF133, 0xF21E, 0xF301, 0xF3DE, 0xF4B3, 0xF582, 0xF649,
0xF709, 0xF7C1, 0xF873, 0xF91C, 0xF9BE, 0xFA59, 0xFAEC, 0xFB77,
0xFBFB, 0xFC77, 0xFCEB, 0xFD57, 0xFDBB, 0xFE17, 0xFE6C, 0xFEB8,
0xFEFD, 0xFF39, 0xFF6E, 0xFF9A, 0xFFBF, 0xFFDB, 0xFFEF, 0xFFFB
#endif
#endif
// Window Functions for NUM_FFT = 256
// Triangle Window
unsigned int code WindowFunc[128] =
0x0000, 0x0200, 0x0400, 0x0600, 0x0800, 0x0A00, 0x0C00, 0x0E00,
0x1000, 0x1200, 0x1400, 0x1600, 0x1800, 0x1A00, 0x1C00, 0x1E00,
0x2000, 0x2200, 0x2400, 0x2600, 0x2800, 0x2A00, 0x2C00, 0x2E00,
0x3000, 0x3200, 0x3400, 0x3600, 0x3800, 0x3A00, 0x3C00, 0x3E00,
0x4000, 0x4200, 0x4400, 0x4600, 0x4800, 0x4A00, 0x4C00, 0x4E00,
0x5000, 0x5200, 0x5400, 0x5600, 0x5800, 0x5A00, 0x5C00, 0x5E00,
0x6000, 0x6200, 0x6400, 0x6600, 0x6800, 0x6A00, 0x6C00, 0x6E00,
0x7000, 0x7200, 0x7400, 0x7600, 0x7800, 0x7A00, 0x7C00, 0x7E00,
0x8000, 0x8200, 0x8400, 0x8600, 0x8800, 0x8A00, 0x8C00, 0x8E00,
0x9000, 0x9200, 0x9400, 0x9600, 0x9800, 0x9A00, 0x9C00, 0x9E00,
0xA000, 0xA200, 0xA400, 0xA600, 0xA800, 0xAA00, 0xAC00, 0xAE00,
0xB000, 0xB200, 0xB400, 0xB600, 0xB800, 0xBA00, 0xBC00, 0xBE00,
0xC000, 0xC200, 0xC400, 0xC600, 0xC800, 0xCA00, 0xCC00, 0xCE00,
0xD000, 0xD200, 0xD400, 0xD600, 0xD800, 0xDA00, 0xDC00, 0xDE00,
0xE000, 0xE200, 0xE400, 0xE600, 0xE800, 0xEA00, 0xEC00, 0xEE00,
0xF000, 0xF200, 0xF400, 0xF600, 0xF800, 0xFA00, 0xFC00, 0xFE00
#endif
// Hanning Window
0x0000, 0x0009, 0x0027, 0x0058, 0x009D, 0x00F6, 0x0162, 0x01E2,
0x0275, 0x031C, 0x03D6, 0x04A2, 0x0582, 0x0675, 0x077B, 0x0893,
0x09BE, 0x0AFB, 0x0C4A, 0x0DAA, 0x0F1D, 0x10A0, 0x1235, 0x13DB,
0x1592, 0x1759, 0x1930, 0x1B17, 0x1D0D, 0x1F13, 0x2128, 0x234B,
0x257D, 0x27BD, 0x2A0A, 0x2C64, 0x2ECC, 0x3140, 0x33C0, 0x364B,
0x38E3, 0x3B85, 0x3E31, 0x40E8, 0x43A9, 0x4673, 0x4945, 0x4C21,
0x4F04, 0x51EE, 0x54E0, 0x57D9, 0x5AD7, 0x5DDC, 0x60E6, 0x63F4,
0x6707, 0x6A1D, 0x6D37, 0x7054, 0x7374, 0x7695, 0x79B8, 0x7CDB,
0x7FFF, 0x8324, 0x8647, 0x896A, 0x8C8B, 0x8FAB, 0x92C8, 0x95E2,
0x98F8, 0x9C0B, 0x9F19, 0xA223, 0xA528, 0xA826, 0xAB1F, 0xAE11,
0xB0FB, 0xB3DE, 0xB6BA, 0xB98C, 0xBC56, 0xBF17, 0xC1CE, 0xC47A,
0xC71C, 0xC9B4, 0xCC3F, 0xCEBF, 0xD133, 0xD39B, 0xD5F5, 0xD842,
0xDA82, 0xDCB4, 0xDED7, 0xE0EC, 0xE2F2, 0xE4E8, 0xE6CF, 0xE8A6,
0xEA6D, 0xEC24, 0xEDCA, 0xEF5F, 0xF0E2, 0xF255, 0xF3B5, 0xF504,
0xF641, 0xF76C, 0xF884, 0xF98A, 0xFA7D, 0xFB5D, 0xFC29, 0xFCE3,
0xFD8A, 0xFE1D, 0xFE9D, 0xFF09, 0xFF62, 0xFFA7, 0xFFD8, 0xFFF6
#endif
// Hamming Window
0x147A, 0x1483, 0x149F, 0x14CC, 0x150C, 0x155D, 0x15C1, 0x1636,
0x16BE, 0x1757, 0x1802, 0x18BE, 0x198C, 0x1A6C, 0x1B5D, 0x1C5E,
0x1D71, 0x1E95, 0x1FC9, 0x210D, 0x2262, 0x23C7, 0x253B, 0x26C0,
0x2853, 0x29F6, 0x2BA7, 0x2D67, 0x2F35, 0x3112, 0x32FC, 0x34F3,
0x36F8, 0x390A, 0x3B28, 0x3D52, 0x3F88, 0x41CA, 0x4417, 0x466E,
0x48D0, 0x4B3D, 0x4DB3, 0x5032, 0x52BA, 0x554B, 0x57E4, 0x5A84,
0x5D2C, 0x5FDB, 0x6291, 0x654D, 0x680E, 0x6AD4, 0x6DA0, 0x7070,
0x7344, 0x761B, 0x78F6, 0x7BD3, 0x7EB2, 0x8193, 0x8476, 0x8759,
0x8A3D, 0x8D21, 0x9004, 0x92E7, 0x95C8, 0x98A7, 0x9B84, 0x9E5F,
0xA136, 0xA40A, 0xA6DA, 0xA9A5, 0xAC6C, 0xAF2D, 0xB1E9, 0xB49F,
0xB74E, 0xB9F6, 0xBC96, 0xBF2F, 0xC1C0, 0xC448, 0xC6C7, 0xC93D,
0xCBA9, 0xCE0C, 0xD063, 0xD2B0, 0xD4F2, 0xD728, 0xD952, 0xDB70,
0xDD82, 0xDF86, 0xE17E, 0xE368, 0xE545, 0xE713, 0xE8D3, 0xEA84,
0xEC27, 0xEDBA, 0xEF3F, 0xF0B3, 0xF218, 0xF36D, 0xF4B1, 0xF5E5,
0xF709, 0xF81B, 0xF91D, 0xFA0E, 0xFAED, 0xFBBB, 0xFC78, 0xFD23,
0xFDBC, 0xFE44, 0xFEB9, 0xFF1D, 0xFF6E, 0xFFAE, 0xFFDB, 0xFFF6
#endif
// Blackman Window
0x0000, 0x0003, 0x000E, 0x0020, 0x0039, 0x0059, 0x0080, 0x00AF,
0x00E6, 0x0124, 0x016A, 0x01B9, 0x020F, 0x026E, 0x02D5, 0x0345,
0x03BE, 0x0441, 0x04CD, 0x0563, 0x0603, 0x06AD, 0x0762, 0x0822,
0x08ED, 0x09C4, 0x0AA7, 0x0B96, 0x0C91, 0x0D9A, 0x0EAF, 0x0FD2,
0x1102, 0x1240, 0x138D, 0x14E8, 0x1652, 0x17CB, 0x1953, 0x1AEA,
0x1C91, 0x1E48, 0x200F, 0x21E6, 0x23CD, 0x25C5, 0x27CC, 0x29E5,
0x2C0E, 0x2E47, 0x3091, 0x32EB, 0x3555, 0x37D0, 0x3A5B, 0x3CF6,
0x3FA0, 0x425A, 0x4523, 0x47FC, 0x4AE3, 0x4DD8, 0x50DB, 0x53EC,
0x570A, 0x5A34, 0x5D6B, 0x60AD, 0x63FA, 0x6752, 0x6AB4, 0x6E1E,
0x7192, 0x750D, 0x788F, 0x7C17, 0x7FA5, 0x8338, 0x86CF, 0x8A69,
0x8E05, 0x91A3, 0x9541, 0x98DE, 0x9C7B, 0xA015, 0xA3AB, 0xA73E,
0xAACB, 0xAE52, 0xB1D3, 0xB54B, 0xB8BA, 0xBC1E, 0xBF78, 0xC2C6,
0xC607, 0xC93A, 0xCC5E, 0xCF72, 0xD275, 0xD567, 0xD846, 0xDB12,
0xDDC9, 0xE06A, 0xE2F6, 0xE56B, 0xE7C8, 0xEA0D, 0xEC39, 0xEE4A,
0xF042, 0xF21E, 0xF3DE, 0xF582, 0xF709, 0xF873, 0xF9BE, 0xFAEC,
0xFBFB, 0xFCEB, 0xFDBB, 0xFE6C, 0xFEFD, 0xFF6E, 0xFFBF, 0xFFEF
#endif
#endif
// Window Functions for NUM_FFT = 128
// Triangle Window
unsigned int code WindowFunc[64] =
0x0000, 0x0400, 0x0800, 0x0C00, 0x1000, 0x1400, 0x1800, 0x1C00,
0x2000, 0x2400, 0x2800, 0x2C00, 0x3000, 0x3400, 0x3800, 0x3C00,
0x4000, 0x4400, 0x4800, 0x4C00, 0x5000, 0x5400, 0x5800, 0x5C00,
0x6000, 0x6400, 0x6800, 0x6C00, 0x7000, 0x7400, 0x7800, 0x7C00,
0x8000, 0x8400, 0x8800, 0x8C00, 0x9000, 0x9400, 0x9800, 0x9C00,
0xA000, 0xA400, 0xA800, 0xAC00, 0xB000, 0xB400, 0xB800, 0xBC00,
0xC000, 0xC400, 0xC800, 0xCC00, 0xD000, 0xD400, 0xD800, 0xDC00,
0xE000, 0xE400, 0xE800, 0xEC00, 0xF000, 0xF400, 0xF800, 0xFC00
#endif
// Hanning Window
0x0000, 0x0027, 0x009D, 0x0162, 0x0275, 0x03D6, 0x0582, 0x077B,
0x09BE, 0x0C4A, 0x0F1D, 0x1235, 0x1592, 0x1930, 0x1D0D, 0x2128,
0x257D, 0x2A0A, 0x2ECC, 0x33C0, 0x38E3, 0x3E31, 0x43A9, 0x4945,
0x4F04, 0x54E0, 0x5AD7, 0x60E6, 0x6707, 0x6D37, 0x7374, 0x79B8,
0x7FFF, 0x8647, 0x8C8B, 0x92C8, 0x98F8, 0x9F19, 0xA528, 0xAB1F,
0xB0FB, 0xB6BA, 0xBC56, 0xC1CE, 0xC71C, 0xCC3F, 0xD133, 0xD5F5,
0xDA82, 0xDED7, 0xE2F2, 0xE6CF, 0xEA6D, 0xEDCA, 0xF0E2, 0xF3B5,
0xF641, 0xF884, 0xFA7D, 0xFC29, 0xFD8A, 0xFE9D, 0xFF62, 0xFFD8
#endif
// Hamming Window
0x147A, 0x149F, 0x150C, 0x15C1, 0x16BE, 0x1802, 0x198C, 0x1B5D,
0x1D71, 0x1FC9, 0x2262, 0x253B, 0x2853, 0x2BA7, 0x2F35, 0x32FC,
0x36F8, 0x3B28, 0x3F88, 0x4417, 0x48D0, 0x4DB3, 0x52BA, 0x57E4,
0x5D2C, 0x6291, 0x680E, 0x6DA0, 0x7344, 0x78F6, 0x7EB2, 0x8476,
0x8A3D, 0x9004, 0x95C8, 0x9B84, 0xA136, 0xA6DA, 0xAC6C, 0xB1E9,
0xB74E, 0xBC96, 0xC1C0, 0xC6C7, 0xCBA9, 0xD063, 0xD4F2, 0xD952,
0xDD82, 0xE17E, 0xE545, 0xE8D3, 0xEC27, 0xEF3F, 0xF218, 0xF4B1,
0xF709, 0xF91D, 0xFAED, 0xFC78, 0xFDBC, 0xFEB9, 0xFF6E, 0xFFDB
#endif
// Blackman Window
0x0000, 0x000E, 0x0039, 0x0080, 0x00E6, 0x016A, 0x020F, 0x02D5,
0x03BE, 0x04CD, 0x0603, 0x0762, 0x08ED, 0x0AA7, 0x0C91, 0x0EAF,
0x1102, 0x138D, 0x1652, 0x1953, 0x1C91, 0x200F, 0x23CD, 0x27CC,
0x2C0E, 0x3091, 0x3555, 0x3A5B, 0x3FA0, 0x4523, 0x4AE3, 0x50DB,
0x570A, 0x5D6B, 0x63FA, 0x6AB4, 0x7192, 0x788F, 0x7FA5, 0x86CF,
0x8E05, 0x9541, 0x9C7B, 0xA3AB, 0xAACB, 0xB1D3, 0xB8BA, 0xBF78,
0xC607, 0xCC5E, 0xD275, 0xD846, 0xDDC9, 0xE2F6, 0xE7C8, 0xEC39,
0xF042, 0xF3DE, 0xF709, 0xF9BE, 0xFBFB, 0xFDBB, 0xFEFD, 0xFFBF
#endif
#endif
// Window Functions for NUM_FFT = 64
#if (NUM_FFT == 64)
// Triangle Window
unsigned int code WindowFunc[32] =
0x0000, 0x0800, 0x1000, 0x1800, 0x2000, 0x2800, 0x3000, 0x3800,
0x4000, 0x4800, 0x5000, 0x5800, 0x6000, 0x6800, 0x7000, 0x7800,
0x8000, 0x8800, 0x9000, 0x9800, 0xA000, 0xA800, 0xB000, 0xB800,
0xC000, 0xC800, 0xD000, 0xD800, 0xE000, 0xE800, 0xF000, 0xF800
#endif
// Hanning Window
0x0000, 0x009D, 0x0275, 0x0582, 0x09BE, 0x0F1D, 0x1592, 0x1D0D,
0x257D, 0x2ECC, 0x38E3, 0x43A9, 0x4F04, 0x5AD7, 0x6707, 0x7374,
0x7FFF, 0x8C8B, 0x98F8, 0xA528, 0xB0FB, 0xBC56, 0xC71C, 0xD133,
0xDA82, 0xE2F2, 0xEA6D, 0xF0E2, 0xF641, 0xFA7D, 0xFD8A, 0xFF62
#endif
// Hamming Window
0x147A, 0x150C, 0x16BE, 0x198C, 0x1D71, 0x2262, 0x2853, 0x2F35,
0x36F8, 0x3F88, 0x48D0, 0x52BA, 0x5D2C, 0x680E, 0x7344, 0x7EB2,
0x8A3D, 0x95C8, 0xA136, 0xAC6C, 0xB74E, 0xC1C0, 0xCBA9, 0xD4F2,
0xDD82, 0xE545, 0xEC27, 0xF218, 0xF709, 0xFAED, 0xFDBC, 0xFF6E
#endif
// Blackman Window
0x0000, 0x0039, 0x00E6, 0x020F, 0x03BE, 0x0603, 0x08ED, 0x0C91,
0x1102, 0x1652, 0x1C91, 0x23CD, 0x2C0E, 0x3555, 0x3FA0, 0x4AE3,
0x570A, 0x63FA, 0x7192, 0x7FA5, 0x8E05, 0x9C7B, 0xAACB, 0xB8BA,
0xC607, 0xD275, 0xDDC9, 0xE7C8, 0xF042, 0xF709, 0xFBFB, 0xFEFD
#endif
#endif
// Window Functions for NUM_FFT = 32
#if (NUM_FFT == 32)
// Triangle Window
unsigned int code WindowFunc[16] =
0x0000, 0x1000, 0x2000, 0x3000, 0x4000, 0x5000, 0x6000, 0x7000,
0x8000, 0x9000, 0xA000, 0xB000, 0xC000, 0xD000, 0xE000, 0xF000
#endif
// Hanning Window
0x0000, 0x0275, 0x09BE, 0x1592, 0x257D, 0x38E3, 0x4F04, 0x6707,
0x7FFF, 0x98F8, 0xB0FB, 0xC71C, 0xDA82, 0xEA6D, 0xF641, 0xFD8A
#endif
// Hamming Window
0x147A, 0x16BE, 0x1D71, 0x2853, 0x36F8, 0x48D0, 0x5D2C, 0x7344,
0x8A3D, 0xA136, 0xB74E, 0xCBA9, 0xDD82, 0xEC27, 0xF709, 0xFDBC
#endif
// Blackman Window
0x0000, 0x00E6, 0x03BE, 0x08ED, 0x1102, 0x1C91, 0x2C0E, 0x3FA0,
0x570A, 0x7192, 0x8E05, 0xAACB, 0xC607, 0xDDC9, 0xF042, 0xFBFB
#endif
#endif
// Window Functions for NUM_FFT = 16
#if (NUM_FFT == 16)
// Triangle Window
unsigned int code WindowFunc[8] =
0x0000, 0x2000, 0x4000, 0x6000, 0x8000, 0xA000, 0xC000, 0xE000
#endif
// Hanning Window
0x0000, 0x09BE, 0x257D, 0x4F04, 0x7FFF, 0xB0FB, 0xDA82, 0xF641
#endif
// Hamming Window
0x147A, 0x1D71, 0x36F8, 0x5D2C, 0x8A3D, 0xB74E, 0xDD82, 0xF709
#endif
// Blackman Window
0x0000, 0x03BE, 0x1102, 0x2C0E, 0x570A, 0x8E05, 0xC607, 0xF042
#endif
#endif
// Window Functions for NUM_FFT = 8
#if (NUM_FFT == 8)
// Triangle Window
unsigned int code WindowFunc[4] =
0x0000, 0x4000, 0x8000, 0xC000
#endif
// Hanning Window
0x0000, 0x257D, 0x7FFF, 0xDA82
#endif
// Hamming Window
0x147A, 0x36F8, 0x8A3D, 0xDD82
#endif
// Blackman Window
0x0000, 0x1102, 0x570A, 0xC607
#endif
#endif
// Window Functions for NUM_FFT = 4
#if (NUM_FFT == 4)
// Triangle Window
unsigned int code WindowFunc[2] =
0x0000, 0x8000
#endif
// Hanning Window
0x0000, 0x7FFF
#endif
// Hamming Window
0x147A, 0x8A3D
#endif
// Blackman Window
0x0000, 0x570A
#endif
#endif
请问高手错在那了????????????????
发表于 2011-11-22 18:58 | 显示全部楼层
高手是没错的,程序就可能有错!
发表于 2011-12-15 14:32 | 显示全部楼层
请问做这个除了单片机(最小系统)、32*64点阵等还需要什么外围电路?能否分享或发份电路图给我?我的邮箱:1022280123@qq.com谢谢、、、
发表于 2012-8-5 03:07 | 显示全部楼层
我觉得模拟输入部份需要一个限幅电路, 防止电压过高损坏单片机
发表于 2012-9-11 20:05 | 显示全部楼层
效果很好哦
发表于 2012-9-25 23:08 | 显示全部楼层
烧了这个程序试了一下,和楼主的效果一样。第一列没有显示,永远只有一个绿灯亮。运行了一段时间,点阵屏很烫,不知道怎么回事啊……
 楼主| 发表于 2012-10-3 20:04 | 显示全部楼层
左边第一列是直流分量,被去掉了,不去掉会一直亮。点阵发烫是不电压高了?降低电压看看。
GMT+8, 2026-3-13 18:34 , Processed in 0.052020 second(s), 26 queries , Gzip On.
