楼主: mdy-5153
[其他综合] 悬赏: 能提供管脚定义并驱动的, 奖励5片LCD
发表于 2012-3-17 11:58 | 显示全部楼层
我可以提供不过没带电脑回来要下周一或二。
发表于 2012-3-17 12:33 | 显示全部楼层
我有带驱动电路板的,应该是一样的屏,可惜碎了一个角,还能部分显示。晚上测试。
发表于 2012-3-17 22:23 | 显示全部楼层
5:  3V3
6:  GND
7:时钟
8:
9:数据
26:NC
27:NC
28:NC
29:NC
发表于 2012-3-17 22:27 | 显示全部楼层
5:  3V3
6:  GND
7:
8:
9:
26:NC
27:NC
28:NC
29:NC
灰太狼8888 发表于 2012-3-17 22:23 https://www.yleee.com.cn/images/common/back.gif
    根据应用板,实际只用5个脚,即下方5~9  这五个脚与右侧面1~5分别对应
发表于 2012-3-17 22:45 | 显示全部楼层
L C M 命 名 规 则
http://www.av-display.com.cn/cn/images/lcm_coding.jpg
(1)Product Category
CodeDescription
A  AV-Display standard Modules
C  AV-Display Custom-designed modules
(2)Package
CodeDescription
B  COB Type
G  COG Type
T  TAB Type
P  SMT type
F  COF Type
(3)Display Type
CodeDescription
C  Character type products
G  Graphic type products
S  Segment, Icon type products
Z  Others
(4)Display Resolution
CodeDescription
111Graphic:“ 111” refers to number of the lines in the display Character:“ 111” refers to the number of dots per line。nbsp;
(5)Display resolution
CodeDescription
222(Graphic:“222” refers to the number of dots per column Character:“222” refers to the number of the lines in the display Segment/Icon:“222”refers to the segment/icon quantity
(6)Serial Letter
CodeDescription
A~Z(1) ~ (6) same,outline dimension different, From A, B, C…X, Y, Z,AA,AB,AC…ZX,ZY,ZZ
(7)Serial Number
CodeDescription
00~99(1) ~ (7) same but has different parameters, like LCD voltage、IC、Resistor, etc。 From 00, 01, 02…99
(8)LCD Mode
CodeDescription
T  TN,Positive,Grey
N  TN,Negative
H  HTN,Positive
L  HTN, Negative
G  STN,Positive,Grey
Y  STN,Positive,Y/G
B  STN,Negative,Blue
F  FSTN,Positive
M  FSTN,Negative
D  FFSTN,Negative
(9)Polarizar type, operating temp and view angle
CodeDescription
A  Reflective,normal (0~50℃),6:00
D  Reflective,normal (0~50℃),12:00
G  Reflective,wide,6:00
J  Reflective,wide,12:00
B  Transflective,normal (0~50℃),6:00
E  Transflective,normal (0~50℃),12:00
H  Transflective,wide,6:00
K  Transflective,wide,12:00
C  Transmissive,normal (0~50℃),6:00
F  Transmissive,normal (0~50℃),12:00
I  Transmissive,wide,6:00
L  Transmissive,wide,12:00
Z  Others
(10)Backlight type
CodeDescription
N  W/O backlight
B  LED Blue
W  LED White
Y  LED Y/G
A  LED Amber
R  LED Red
O  LED Orange
G  LED Green
E  EL Blue Green
D  EL Orange / Yellow
T  EL White
C  CCFL White
S  RGB
Z  Others
[/td]
(11)Touch Panel (add-in)
CodeDescription
TPProducts with Touch Panel. If without, it is blank.
(12)Rohs compliant (add-in)
CodeDescription
RProducts with ROHS compliant, if without, it is blank.
(13)Extended number 01~99 (add-in)
CodeDescription
01~99Products with only different resistors/capacitance or jumper options or equivalent IC type, etc.
是客户定制屏
 楼主| 发表于 2012-3-17 22:57 | 显示全部楼层
谢谢, 我想知道7, 8, 9 是什么脚, 驱动这个LCD有特定的指令吗?
 楼主| 发表于 2012-3-17 23:03 | 显示全部楼层
我在AV display 的网站上也看到了以上的信息。
CBS065A00-00
B  COB Type
065  Graphic
 楼主| 发表于 2012-3-17 23:06 | 显示全部楼层
应用板上只使用了5个脚? 没使用26脚吗, 左上角的那两个脚。 能解读出驱动程序吗?
 楼主| 发表于 2012-3-17 23:50 | 显示全部楼层
其实, 知道AV Display 标准LCD的管脚和驱动, 就能知道这种定制的了。
发表于 2012-3-18 09:03 | 显示全部楼层
mdy-5153 发表于 2012-3-17 23:06 https://www.yleee.com.cn/images/common/back.gif
    又拆下来看来,只用到五个脚。
GMT+8, 2026-6-23 06:12 , Processed in 0.033244 second(s), 28 queries , Gzip On.
