楼主: jesen_2010
请问该时序图中DC/X那里的0是什么意思?
发表于 2013-10-16 16:28 | 显示全部楼层
jesen_2010 发表于 2013-10-16 09:25
谢谢指点 p pause? 还有那个D/CX 0那里什么意思?再命令最后一位要把D/CX拉低?
The write mode of the interface means that host writes commands or data to ILI9341. The 3-lines serial data
packet contains a data/command select bit (D/CX) and a transmission byte. If the D/CX bit is “low”, the
transmission byte is interpreted as a command byte. If the D/CX bit is “high”, the transmission byte is stored as
the display data RAM (Memory write command), or command register as parameter
 楼主| 发表于 2013-10-16 16:40 | 显示全部楼层
icewind 发表于 2013-10-16 16:28
The write mode of the interface means that host writes commands or data to ILI9341. The 3-lines se ...
这段我看过了,为0则写命令,为1则写数据或命令参数,在上面那个时序中,先把DC拉低,写入读ID的命令,然后再发4个字节的00H(空操作命令),去交换4个字节的ID数据,对不嘛?
发表于 2013-10-16 17:30 | 显示全部楼层
现在关键问题是,这个屏到底用了哪几个接口
 楼主| 发表于 2013-10-16 17:34 | 显示全部楼层
CS D/CX SCL SDI SDO
 楼主| 发表于 2013-10-16 17:38 | 显示全部楼层
附上屏资料
屏规格书.0.pdf
690.19 KB, 下载次数: 416, 下载积分: 一乐金币 -1
发表于 2013-10-16 21:02 | 显示全部楼层
jesen_2010 发表于 2013-10-16 16:40
这段我看过了,为0则写命令,为1则写数据或命令参数,在上面那个时序中,先把DC拉低,写入读ID的命令,然 ...
是的
When DCX = ’1’, data is selected.
When DCX = ’0’, command is selected.
GMT+8, 2026-6-16 19:39 , Processed in 0.031663 second(s), 24 queries , Gzip On.
